  3. Mini Weather Station
42 Posts 18 Posters 26.0k Views 17 Watching
  • bjacobseB
    bjacobseB
    bjacobse
    Think about to replace your DHT22 with a less current hungry sensor
    HTU21D cold be a good choice (But only running 3,3V)
    J 1 Reply Last reply
    • bjacobseB bjacobse
      J
      J
      jtm312
      @bjacobse Thanks, they look interesting. I will grab some and have a play.
        MikeF
        wrote on last edited by MikeF
        ... and here's mine - in white:
        (now managed to upload pics in portrait!)
        I'm using a BME280 instead of a BMP180 and DHT22.
        • F
          F
          flopp
          Really cool.
          Is it possible to get the 3D file for this?
          korttomaK J 2 Replies Last reply
          • F flopp
            Really cool.
            korttomaK
            korttomaK
            korttoma
            @flopp There is a link in the first post
            • Tomas
            F 1 Reply Last reply
            • korttomaK korttoma
              F
              F
              flopp
              Thank you, I must have missed it 🙀
              • F flopp
                Really cool.
                J
                J
                jtm312
                @flopp I have added the FreeCAD file to the Thingiverse post so that people can make any changes they want.
                http://www.thingiverse.com/thing:704715
                  MikeF
                  I've now uploaded an external view - see my earlier post.
                  • bjacobseB
                    bjacobseB
                    bjacobse
                    If you at some point redesign the nice looking weather station, I recommend:
                    1)To place the battery in the top, to avoid battery corrosion
                    2) Make a little hole in bottom for water condensation trip out hole
                    cadetC 1 Reply Last reply
                      cadetC
                      cadetC
                      cadet
                      @bjacobse
                      Hi
                      anybody compile code for this station for 2.0 Mysensors ?
                      Share the code please.
                      Pro mini used 5volt ver ?
                      I can't power 3 volt ver from 9 volt ? Correct ?
                      Thank you
                      Andrey
                        You can use any voltage as far as you use the right voltage regulator
                        • J
                          J
                          jtm312
                          The pro minis have an onboard voltage regulator (raw input). The specs say that they are good for up to 12v for either the 5v or 3.3v version. I used a 3.3v version as it made the rest of the interface easier.
                          • J jtm312
                            cadetC
                            cadetC
                            cadet
                            @jtm312
                            Just try to connect Pro Mini 3volt to 9 volt GND and RAW - voltage regulator very hot - I think 60-80 C
                            • dbemowskD
                              dbemowskD
                              I am curious what kind of battery life you are getting with the 9 volt battery? I tried a sensor with a 9 volt battery and the useful battery duration was less than ideal.
                              Nca78N J 2 Replies Last reply
                              • dbemowskD dbemowsk
                                @dbemowsk said in Mini Weather Station:
                                Typical capacity is around 550mAh for alcaline version. All extra voltage is wasted in the linear regulator so you end up with less than half the capacity of 2 AAA or about 20% of the capacity of 2 AA. Not a good choice imho, better switch to i2c sensors like si7021 or BME280 like MikeF did to have much lower power consumption and much lower voltage requirements and use 2 AAA. And the lower the voltage is, the lower the current consumption is for Arduino, radio and sensor so in the end instead of having 4 months of battery life you can get 2 or 3 years with 2 AAA.
                                • dbemowskD
                                  dbemowskD
                                  I had tried a 9 volt when I was building my temp/humidity sensor node and the battery didn't last for crap. At that time I was using a DHT22 with a 5 volt pro mini. I have since switched to an HDC1080 and a 3.3 volt pro mini with 2 AA batteries and it works GREAT. Here is the project if anyone wants to look.
                                  https://forum.mysensors.org/topic/6485/hdc1080-battery-operated-temp-humidity-sensor-with-wall-box
                                    J
                                    J
                                    jtm312
                                    @dbemowsk By cutting the LEDs off, I am getting 12 to 16 weeks.
                                    dbemowskD 1 Reply Last reply
                                    • J jtm312
                                      dbemowskD
                                      dbemowskD
                                      @jtm312 I don't recall exactly how much I was getting on mine, but I don't think it was that much. Are you using 3.3 or 5 volt pro minis?
                                        J
                                        J
                                        jtm312
                                        @dbemowsk I am using the 3.3V pro minis. It is the one pictured at the top of this thread. I started out by getting about a week. The big difference came after removing the LEDs, as they were using most of the power. Also sleeping most of the time.
                                        A good quality 9v also helped. Other humidity sensors can also cut the power drain.
                                        I have also built version using 2xAAA batteries, but I find that it doesn't take long before the voltages drops below the useful voltage for the radio and starts to cause a range problem. The next version I am planning on going back to using the onboard regulator with 4xAA batteries.
                                        • J jtm312
                                          dbemowskD
                                          dbemowskD
                                          @jtm312 I am using 2 AA's on my humidity sensor and that is working very well. The radios are rated I believe down to 1.9 volts. Using the regulator is going to give you more power drain on your batteries. When using 2 AA batteries, there is no need for the regulator at all. Many people say to disconnect it because it can still cause power drain. In my project I just didn't connect to the RAW pin, thus the regulator is not being used. So far I have not seen any issues with the regulator affecting anything.
