[SOLVED] OH2 - Mosquito - Raspi Mysensors Gateway
Hello!
While i'm waiting for my hardware (ordered a couple Sensebender Micro) i tried to set up Controller and Gateway.
I followed the instructions from here here and configured with./configure --my-gateway=mqtt --my-controller-ip-address=192.168.178.160 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1But the Gateway doesn't connect to the controller:
pi@raspgateway:~/MySensors $ sudo mysgw -d mysgw: Starting gateway... mysgw: Protocol version - 2.1.1 mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.1 mysgw: TSF:LRT:OK mysgw: TSM:INIT mysgw: TSF:WUR:MS=0 mysgw: TSM:INIT:TSP OK mysgw: TSM:INIT:GW MODE mysgw: TSM:READY:ID=0,PAR=0,DIS=0 mysgw: MCO:REG:NOT NEEDED mysgw: Listening for connections on 0.0.0.0:5003 mysgw: MCO:BGN:STP mysgw: MCO:BGN:INIT OK,TSP=1 ...Then nothing more follows...
On openhabian (Raspberry) i installed the MQTT Binding (via OH2 paperUI) and Mosquitto (via openhabian config tool).
What am i missing? :/Thanks in advance!
Narf!@narf said in OH2 - Mosquito - Raspi Mysensors Gateway:
That doesn't seem to be right...
It seems it switches to listening (server) mode, while you are trying to configure an mqtt client connection. Myabe @marceloaqno has a clue? -
recompiling did the trick:
pi@raspgateway:~/MySensors $ sudo ./bin/mysgw -d mysgw: Starting gateway... mysgw: Protocol version - 2.1.1 mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.1 mysgw: TSF:LRT:OK mysgw: TSM:INIT mysgw: TSF:WUR:MS=0 mysgw: TSM:INIT:TSP OK mysgw: TSM:INIT:GW MODE mysgw: TSM:READY:ID=0,PAR=0,DIS=0 mysgw: MCO:REG:NOT NEEDED mysgw: MCO:BGN:STP mysgw: MCO:BGN:INIT OK,TSP=1 mysgw: Attempting MQTT connection... mysgw: connected to 192.168.178.160 mysgw: MQTT connected mysgw: Sending message on topic: mysensors-out/0/255/0/0/18 -
alright! today (finally!) i got my sensebender micro. they should send something right away, right?
so i plugged one in and got this on the gateway:pi@raspgateway:~/MySensors $ sudo ./bin/mysgw -d mysgw: Starting gateway... mysgw: Protocol version - 2.1.1 mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.1 mysgw: TSF:LRT:OK mysgw: TSM:INIT mysgw: TSF:WUR:MS=0 mysgw: TSM:INIT:TSP OK mysgw: TSM:INIT:GW MODE mysgw: TSM:READY:ID=0,PAR=0,DIS=0 mysgw: MCO:REG:NOT NEEDED mysgw: MCO:BGN:STP mysgw: MCO:BGN:INIT OK,TSP=1 mysgw: Attempting MQTT connection... mysgw: connected to 192.168.178.183 mysgw: MQTT connected mysgw: Sending message on topic: mysensors-out/0/255/0/0/18 mysgw: TSF:MSG:READ,255-255-255,s=255,c=7,t=255,pt=7,l=25,sg=1: 0 mysgw: !TSF:MSG:LEN,7!=32 mysgw: TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0: mysgw: Sending message on topic: mysensors-out/255/255/3/0/3 mysgw: TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0: mysgw: !TSF:MSG:LEN,0!=7 mysgw: TSF:MSG:READ,255-255-255,s=255,c=7,t=255,pt=7,l=25,sg=1: 0 mysgw: !TSF:MSG:LEN,7!=32does this mean anything? i don't get it at all...
You must add the micro to your board manager first. Instructions here:
https://github.com/mysensors/ArduinoBoardsThe Sensebender Micro sketch is available here:
https://github.com/mysensors/SensebenderMicro/tree/master/Arduino/SensebenderMicroDid you decoupling capacitor on gateway? Do you have more radios to test with in the case one is broken?
i found the board but i don't get how to load the sketch ON the board :/
first thought was to c&p the code from https://github.com/mysensors/SensebenderMicro/tree/master/Arduino/SensebenderMicrofatal error: SI7021.h: No such file or directorysecond thought was to look for an example sketch. no luck.
i have other radios. but i'd really love to upload the (right) sketch first... just... how?
@hek said in [SOLVED] OH2 - Mosquito - Raspi Mysensors Gateway:
did i what exactly?
all i can say that i wired the gateway with one of the specified NRF24L01+ Radios.
Same radio on sensebender. -
@gohan said in [SOLVED] OH2 - Mosquito - Raspi Mysensors Gateway:
you need to install library for SI7021
took libraries from here: https://github.com/mysensors/MySensorsArduinoExamples
will investigate further.i think i got the sensor up and running and it can't find a gateway?
Auto assign works if everything else is working and you have a controller that is able to assign node id.
Now it seems there is no communication with gateway: do you also have a log for the gateway? Did you put capacitors on the vcc/gnd on both gateway and node? Keep in mind that RPI is not very suited to power the nrf24 radio. -
the gateway "log" is some posts above.
pi@raspgateway:~/MySensors $ sudo ./bin/mysgw -d mysgw: Starting gateway... mysgw: Protocol version - 2.1.1 mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.1 mysgw: TSF:LRT:OK mysgw: TSM:INIT mysgw: TSF:WUR:MS=0 mysgw: TSM:INIT:TSP OK mysgw: TSM:INIT:GW MODE mysgw: TSM:READY:ID=0,PAR=0,DIS=0 mysgw: MCO:REG:NOT NEEDED mysgw: MCO:BGN:STP mysgw: MCO:BGN:INIT OK,TSP=1 mysgw: Attempting MQTT connection... mysgw: connected to 192.168.178.183 mysgw: MQTT connected mysgw: Sending message on topic: mysensors-out/0/255/0/0/18 mysgw: TSF:MSG:READ,255-255-255,s=255,c=7,t=255,pt=7,l=25,sg=1: 0 mysgw: !TSF:MSG:LEN,7!=32 mysgw: TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0: mysgw: Sending message on topic: mysensors-out/255/255/3/0/3 mysgw: TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0: mysgw: !TSF:MSG:LEN,0!=7 mysgw: TSF:MSG:READ,255-255-255,s=255,c=7,t=255,pt=7,l=25,sg=1: 0should i provide another log?
i didn't use any capacitors, neither gateway, nor node.
here isn't anything regarding capacitors.
and [here](lhttps://www.mysensors.org/build/raspberry under section "NRF24L01+ Radio" it only says "If you are using the nrf24 PA/LNA version you need to use a 5V->3.3V regulator.", but i'm using these so i thought it's ok without using regulators.
or is a regulator something different than a capacitor? -
