  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 329.8k Views 52 Watching
  • dbemowskD dbemowsk
    @impertus Those errors have to do with this line:
    LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
    This is where the declaration happens. If this is commented or fails, you will get the errors you described. Do you have the correct LCD libraries installed for this?
    impertusI
    impertusI
    impertus
    wrote on last edited by m26872
    #267
    @dbemowsk i just copy/paste from the site.
    witch library should i use?
    i have added mysensors-master to IDE
    edit i could see i have out comment the line. Now i get this error
    Vanding:92: error: 'POSITIVE' was not declared in this scope
    C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void setup()':
    Vanding:116: error: no matching function for call to 'LiquidCrystal_I2C::begin(int, int)'
    C:\Users\crame\Desktop\Vanding\Vanding.ino:116:18: note: candidate is:
    In file included from C:\Users\crame\Desktop\Vanding\Vanding.ino:1:0:
    C:\Program Files (x86)\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master/LiquidCrystal_I2C.h:76:7: note: void LiquidCrystal_I2C::begin()
      void begin();
    C:\Program Files (x86)\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master/LiquidCrystal_I2C.h:76:7: note:   candidate expects 0 arguments, 2 provided
    exit status 1
    the sketch.
    // Enable debug prints
    //#define MY_NODE_ID 1  // Set this to fix your Radio ID or use Auto
    #include <TimeLib.h>
    #include <LiquidCrystal.h>
    #define NUMBER_OF_VALVES 8  // Change this to set your valve count up to 16.
    #define SKETCH_VERSION "2.0"
    #define CHILD_ID_SPRINKLER 0
    #define ACTIVE_LOW // comment out this line if your relays are active high
    #ifdef ACTIVE_LOW
    #define ALL_VALVES_OFF 0xFFFF
    #define ALL_VALVES_OFF 0U
    #ifdef DEBUG_ON
    #define SERIAL_START(x)
    typedef enum {
    SprinklerStates;
    SprinklerStates lastState;
    byte menuState = 0;
    unsigned long menuTimer;
    byte countDownTime = 10;
    int allZoneTime [NUMBER_OF_VALVES + 1];
    int valveSoloTime [NUMBER_OF_VALVES + 1];
    int valveNumber;
    int lastValve;
    unsigned long startMillis;
    const int ledPin = 5;
    const int waterButtonPin = 3;
    bool buttonPushed = false;
    bool showTime = true;
    bool clockUpdating = false;
    bool recentUpdate = true;
    const char *dayOfWeek[] = {
    String valveNickName[17] = {
    time_t lastTimeRun = 0;
    //Setup Shift Register...
    const int latchPin = 8;
    const int clockPin = 4;
    const int dataPin  = 7;
    const int outputEnablePin = 6;
    bool receivedInitialValue = false;
      pinMode(latchPin, OUTPUT);
      pinMode(clockPin, OUTPUT);
      pinMode(dataPin, OUTPUT);
      pinMode(ledPin, OUTPUT);
      pinMode(outputEnablePin, OUTPUT);
      digitalWrite (outputEnablePin, LOW);
      attachInterrupt(digitalPinToInterrupt(waterButtonPin), PushButton, RISING); //May need to change for your Arduino model
      digitalWrite (ledPin, HIGH);
      updateRelays(ALL_VALVES_OFF);
      //delay(5000);
      lcd.clear();
      lcd.backlight();
      lcd.createChar(0, clock);
      lcd.createChar(1, raindrop);
      delay(500);
      if (loadState(0) == 0xFF) // EEPROM flag
        for (int i = 0; i < 4 ; i++)
          lastTimeRun = lastTimeRun | loadState(i + 1); // assemble 4 bytes into an ussigned long epoch timestamp
      digitalWrite (ledPin, LOW);
      DEBUG_PRINTLN(F("Ready..."));
      lcd.setCursor(0, 0);
      lcd.setCursor(15, 0);
      lcd.write(byte(0));
      lcd.setCursor(0, 1);
      int clockCounter = 0;
        requestTime();
        wait(1000);
        lcd.print(".");
        clockCounter++;
        if (clockCounter > 16)
          lcd.clear();
          wait(2000);
      lcd.clear();
        lcd.print(F(" Updating  "));
        lcd.print(i);
        bool flashIcon = false;
        DEBUG_PRINT(i);
        DEBUG_PRINTLN(F(" Data..."));
        while (!receivedInitialValue)
          flashIcon = !flashIcon;
          request(i, V_VAR1);
          wait(500);
          request(i, V_VAR2);
          wait(500);
          request(i, V_VAR3);
          wait(500);
      lcd.clear();
        present(i, S_LIGHT);
      updateClock();
      updateDisplay();
      goGetValveTimes();
      if (buttonPushed)
        menuTimer = millis();
          state = ZONE_SELECT_MENU;
          menuState = 0;
          menuState++;
            menuState = 0;
        slowToggleLED ();
        if (state != lastState)
            wait(50);
            send(msg1valve.setSensor(i).set(false), false);
          lcd.clear();
          lcd.setCursor(0,0);
          lcd.setCursor(0,1);
          wait(2000);
          lastValve = -1;
        if (lastValve != valveNumber)
              send(msg1valve.setSensor(i).set(true), false);
        lastValve = valveNumber;
        fastToggleLed();
          valveNumber = 1;
          startMillis = millis();
          valveNumber++;
            state = CYCLE_COMPLETE;
            lastValve = -1;
            lastTimeRun = now();
            DEBUG_PRINT(F("State = "));
            DEBUG_PRINTLN(state);
        fastToggleLed();
          DEBUG_PRINT(F("Zone: "));
          DEBUG_PRINTLN(valveNumber);
          fastToggleLed();
        displayMenu();
      lastState = state;
    void displayMenu(void)
      static int lastSecond;
        lcd.clear();
        lcd.print(F("Starting"));
        lcd.print(F("."));
        Serial.print(".");
      lastSecond = thisSecond;
        if (menuState == 0)
          valveNumber = 1;
          state = RUN_ALL_ZONES;
          valveNumber = menuState;
          state = RUN_SINGLE_ZONE;
      lastMenuState = menuState;
    void updateRelays(int value)
      digitalWrite(latchPin, LOW);
      digitalWrite(latchPin, HIGH);
        buttonPushed = true;
    void fastToggleLed()
        fastLedTimer = millis ();
    void slowToggleLED ()
        slowLedTimer = millis ();
      bool zoneTimeUpdate = false;
      if (message.isAck())
        if (message.sensor == i)
          if (message.type == V_LIGHT)
            if (switchState == 0)
              if (i == 0)
                valveNumber = 1;
                valveNumber = i;
                DEBUG_PRINTLN(i);
            DEBUG_PRINT(i);
            DEBUG_PRINT(F(" = "));
            DEBUG_PRINTLN(variable1);
              allZoneTime[i] = variable1;
              zoneTimeUpdate = true;
            receivedInitialValue = true;
            DEBUG_PRINT(i);
            DEBUG_PRINTLN(variable2);
              valveSoloTime[i] = variable2;
            if (newMessage.length() == 0)
              DEBUG_PRINTLN(i);
            if (newMessage.length() > 16)
              newMessage.substring(0, 16);
            valveNickName[i] = "";
            DEBUG_PRINT(F("Recieved new name for zone "));
            DEBUG_PRINT(i);
            DEBUG_PRINT(F(" and it is now called: "));
      if (zoneTimeUpdate)
          if (i != 0)
            DEBUG_PRINT(F("Zone "));
            DEBUG_PRINT(i);
            DEBUG_PRINTLN(allZoneTime[i]);
        recentUpdate = false;
    void updateDisplay()
      static bool displayToggle = false;
        switch (state) {
          case STAND_BY_ALL_OFF:
            fastClear();
            if (displayToggle)
              if (clockUpdating)
                lcd.write(byte(0));
              lcd.print(hourFormat12());
              lcd.print(minute());
              lcd.print(month());
              lcd.print(day());
              lcd.print(F("/"));
              lcd.print(year() % 100);
              if (clockUpdating)
                lcd.write(byte(0));
              lcd.setCursor(11, 1);
              lcd.print(day(lastTimeRun));
          case RUN_SINGLE_ZONE:
            fastClear();
            if (displayToggle)
              lcd.print(F(" Zone:"));
              lcd.print(valveNumber);
              lcd.print(F(" Active"));
                lcd.print("min");
                lcd.print("sec  ");
          case RUN_ALL_ZONES:
            fastClear();
            if (displayToggle)
              lcd.print(F(" Active "));
              lcd.print("min");
              lcd.print("sec  ");
          case CYCLE_COMPLETE:
            if (displayToggle)
              int totalTimeRan = 0;
              lcd.print(totalTimeRan);
              lcd.print(" Minutes   ");
          default:
            // what of ZONE_SELECT_MENU?
        lastUpdateTime = millis();
      lastDisplayState = state;
      int lastSecond = second();
      int lastMinute = minute();
      int lastHour = hour();
      setTime(newTime);
        DEBUG_PRINT(hourFormat12());
        DEBUG_PRINT(minute());
        DEBUG_PRINT(month());
        DEBUG_PRINT(F("/"));
        DEBUG_PRINT(day());
        DEBUG_PRINTLN(year());
        showTime = false;
    void fastClear()
    void updateClock()
        lcd.write(byte(0));
        clockUpdating = true;
        requestTime();
        lastVeraGetTime = millis();
      if (loadState(0) != 0xFF)
        saveState(0, 0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
      for (int i = 1; i < 5; i++)
        saveState(5 - i, byte(theDate >> 8 * (i - 1))); // store epoch datestamp in 4 bytes of EEPROM starting in location one
    void goGetValveTimes()
      static byte valveIndex = 1;
      if (millis() - valveUpdateTime >= 300000UL / NUMBER_OF_VALVES)// update each valve once every 5 mins (distributes the traffic)
        DEBUG_PRINTLN(F("Calling for Valve Data..."));
        lcd.write(byte(1)); //lcd.write(1);
        request(valveIndex, V_VAR1);
        request(valveIndex, V_VAR2);
        request(valveIndex, V_VAR3);
        valveUpdateTime = millis();
        valveIndex++;
        if (valveIndex > NUMBER_OF_VALVES + 1)
          valveIndex = 1;
    • TON RIJNAARDT
      TON RIJNAARDT
      TON RIJNAARD
      Can some one help me with a working sketch for Domoticz.
      I have it a little working, only Domoticz give not the childs.
      I get from the gate way the time and then is searching for the name from the zone.
      If some one can give me a working sketch than i can see what is wrong.
      Thanks in advance Ton
      • TON RIJNAARDT
        TON RIJNAARDT
        TON RIJNAARD
        • impertusI
          impertusI
          impertus
          • GimlurG
            GimlurG
            Gimlur
            wrote on last edited by Gimlur
            #271
            first off all : thank you for your job.
            I'm trying to make this sketch, but i have some problems.
            Around the line 619 with V_VAR3
            In the sensor console i have this
            0 MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.1.0
            3 TSM:INIT
            4 TSF:WUR:MS=0
            11 TSM:INIT:TSP OK
            13 TSF:SID:OK,ID=1
            15 TSM:FPAR
            51 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            144 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
            149 TSF:MSG:FPAR OK,ID=0,D=1
            2058 TSM:FPAR:OK
            2059 TSM:ID
            2060 TSM:ID:OK
            2062 TSM:UPL
            2065 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
            2072 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
            2077 TSF:MSG:PONG RECV,HP=1
            2080 TSM:UPL:OK
            2081 TSM:READY:ID=1,PAR=0,DIS=1
            2086 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
            2096 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
            2103 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=18,pt=0,l=5,sg=0,ft=0,st=OK:2.1.0
            2111 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
            2129 TSF:MSG:READ,0-0-1,s=255,c=3,t=6,pt=0,l=1,sg=0:M
            2137 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=11,sg=0,ft=0,st=OK:MySprinkler
            2146 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:2.0
            2154 TSF:MSG:SEND,1-1-0-0,s=0,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
            2161 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
            2168 TSF:MSG:SEND,1-1-0-0,s=2,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
            2177 TSF:MSG:SEND,1-1-0-0,s=3,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
            2184 TSF:MSG:SEND,1-1-0-0,s=4,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
            2190 MCO:REG:REQ
            2193 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
            2199 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
            2204 MCO:PIM:NODE REG=1
            2207 MCO:BGN:STP
            Initialisation...
            Mise des Vannes sur Off...
            Ready...
            2864 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
            2882 TSF:MSG:READ,0-0-1,s=255,c=3,t=1,pt=0,l=10,sg=0:1484768469
            Horloge mise à jour....
            Sensor's time currently set to: 07:41pm
            18/1/2017
            Mercredi
            Calling for Valve 0 Data...
            3902 TSF:MSG:SEND,1-1-0-0,s=0,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
            3913 TSF:MSG:READ,0-0-1,s=0,c=2,t=24,pt=0,l=0,sg=0:
            Recieved variable1 valve:0 = 0
            4410 TSF:MSG:SEND,1-1-0-0,s=0,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
            4431 TSF:MSG:READ,0-0-1,s=0,c=2,t=25,pt=0,l=0,sg=0:
            Recieved variable2 valve:0 = 0
            4919 TSF:MSG:SEND,1-1-0-0,s=0,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK:
            4939 TSF:MSG:READ,0-0-1,s=0,c=2,t=26,pt=0,l=0,sg=0:
            No Name Recieved for zone 0
            5428 TSF:MSG:SEND,1-1-0-0,s=0,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK:
            5447 TSF:MSG:READ,0-0-1,s=0,c=2,t=26,pt=0,l=0,sg=0:
            In my domoticz GW i have a node MySprinkler 2.0 with 6 childs : 0 to 4 S_LIGHT/S_BINARY, 255 REPREATER
            It's seems that the communication between gateway and sensors failed with V_VAR3, V_VAR1 and V_VAR2 are ok.
            Can somebody help me, please ?
            EDIT : according to the instructions inside this skecth :
            I can't find any Variable in my domoticz Controller, only S_LIGHT childs of Sprinkler Node :
            Where is my mistake ?
            • GimlurG
              GimlurG
              Gimlur
              I reply to myself...
              Like Huczas say before, you have to modify this Sketch for Domoticz. :(
              Domoticz don't receive and manage V_VAR1, V_VAR2, V_VAR3, so you have to fixe them in code.
              But i have another question :
              is there a possibility to declare a supplementary sensor wich can manage this variables ?
              • tombstoneT
                tombstoneT
                tombstone
                Hi I looking to do My 1st MySensors Project an hoping to use this one I have a 3.2" Nextion. Will it be hard to use a nextion as a Display. Will there be help so I can get it working as I think the nextion Display will be good .... with weather updates and maybe senses to tell if the plants has to much water or no water. but thats down the trake...
                P 1 Reply Last reply
                • tombstoneT tombstone
                  P
                  P
                  Paulb
                  wrote on last edited by Paulb
                  #274
                  Hi, this is my first MySensors project having been inspired to jump in after finding @petewill great Youtube video. Thanks to @BulldogLowell for the code. After much perseverance I have everything working... kinda'.
                  My last persistent issue is the system halting zone 2, ie, cycle starts and ~10 seconds in the irrigation is halted. This only happens for Zone 2 (pin 1 on the shift register). This issue only occurs when either starting Zone 2 singularly from the controller or as part of the All Zones from the controller - Zone 1 will complete, Zone 2 will start then stop after ~10 seconds. Zone 2 WILL complete fine when selected manually from the pushbutton. All Zones from the pushbutton or controller will both fail.
                  I've checked and re-checked solder joints, wire connections, put the 10k external pullup resistor in and swapped out shift registers with no luck so far.
                  Would appreciate any help to resolve. Thanks.
                  I am using Domoticz and @Huczas modified sketch.
                  Arduino Multi-Zone Sprinkler Control
                  May 31, 2015
                  *** Version 2.0
                  * LED status indicator
                  PARTS LIST:
                  * Relays (8 channel)
                  * NRF24L01 Radio
                  * Arduino (I used a Pro Mini)
                  * Capacitors (10uf and .1uf)
                  * 3.3v voltage regulator
                  * Resistors (270 & 10K)
                  * Female Dupont Cables
                  * LED
                  * Push button
                  * Shift Register (SN74HC595)
                  * 18 gauge wire (for relay)
                  INSTRUCTIONS:
                    on the serial monitor.
                  #include <Time.h>
                  #define NUMBER_OF_VALVES 5  // Change this to set your valve count up to 16.
                  #define VALVE_RESET_TIME 4500UL   // Change this (in milliseconds) for the time you need your valves to hydraulically reset and change state
                  #define RADIO_ID AUTO  // Change this to fix your Radio ID or use Auto
                  #define SKETCH_NAME "MySprinkler Domoticz"
                  #ifdef ACTIVE_LOW
                  #ifdef DEBUG_ON
                  typedef enum {
                  SprinklerStates;
                  byte menuState = 0;
                  int allZoneTime [NUMBER_OF_VALVES + 1]= {0, 1, 1, 1, 1, 1};     // Insert values in min, 0 = all zone (always 0) this is a 5 chan relay
                  int valveSoloTime [NUMBER_OF_VALVES + 1]= {0, 1, 1, 1, 1, 1};   // Insert values in min, 0 = all zone (always 0) this is a 5 chan relay
                  int valveNumber;
                  int lastValve;
                  boolean buttonPushed = false;
                  boolean showTime = true;
                  boolean clockUpdating = false;
                  boolean recentUpdate = true;
                  //extra for 1k resistor
                  //const int outputEnablePin = 6;
                  //end extra 1k
                    SERIAL_START(115200);
                    //internal pullup use next line
                    //pinMode(waterButtonPin, INPUT_PULLUP);
                    //external pullup use next line
                    attachInterrupt(1, PushButton, RISING); //May need to change for your Arduino model
                    //pinMode(outputEnablePin, OUTPUT);
                    //digitalWrite (outputEnablePin, LOW);
                    //end extra 1k
                    //delay(5000);
                    //delay(5000);
                    lcd.clear();
                    lcd.backlight();
                    delay(500);
                    if (gw.loadState(0) == 0xFF); // EEPROM flag
                        lastTimeRun = lastTimeRun | gw.loadState(i + 1); // assemble 4 bytes into an ussigned long epoch timestamp
                    gw.begin(getVariables, RADIO_ID, false); // Change 'false' to 'true' to create a Radio repeating node
                      gw.present(i, S_LIGHT);
                    lcd.write(byte(0));
                      gw.requestTime(receiveTime);
                      delay(1000);
                      lcd.print(".");
                      clockCounter++;
                        lcd.clear();
                        delay(2000);
                    lcd.clear();
                      lcd.print(i);
                      boolean flashIcon = false;
                      DEBUG_PRINT(i);
                      while (gw.process() == false)
                        gw.request(i, V_VAR1);
                        delay(100);
                        gw.request(i, V_VAR2);
                        delay(100);
                        gw.request(i, V_VAR3);
                        delay(100);
                    lcd.clear();
                    updateClock();
                    updateDisplay();
                    //goGetValveTimes();
                    if (buttonPushed)
                        menuState = 0;
                        menuState++;
                          menuState = 0;
                      slowToggleLED ();
                          delay(50);
                          gw.send(msg1valve.setSensor(i).set(false), false);
                        lcd.clear();
                        lcd.setCursor(0,0);
                        lcd.setCursor(0,1);
                        delay(2000);
                        lastValve = -1;
                            gw.send(msg1valve.setSensor(i).set(true), false);
                      fastToggleLed();
                        valveNumber = 1;
                        valveNumber++;
                          lastValve = -1;
                      fastToggleLed();
                        fastToggleLed();
                    else if (state = ZONE_SELECT_MENU)
                      displayMenu();
                    lastState = state;
                      lcd.clear();
                      lcd.print(F("."));
                      Serial.print(".");
                      if (menuState == 0)
                        valveNumber = 1;
                    boolean zoneTimeUpdate = false;
                            if (i == 0)
                              valveNumber = 1;
                              valveNumber = i;
                              DEBUG_PRINTLN(i);
                          DEBUG_PRINT(i);
                          DEBUG_PRINT(i);
                            DEBUG_PRINTLN(i);
                          DEBUG_PRINT(i);
                    if (zoneTimeUpdate)
                        if (i != 0)
                          DEBUG_PRINT(i);
                    static boolean displayToggle = false;
                      switch (state) {
                          fastClear();
                          if (displayToggle)
                            if (clockUpdating)
                              lcd.write(byte(0));
                            lcd.print(month());
                            lcd.print(day());
                            lcd.print(F("/"));
                            if (clockUpdating)
                              lcd.write(byte(0));
                            lcd.print(day(lastTimeRun) < 10 ? F("0") : F("/"));
                          fastClear();
                          if (displayToggle)
                              lcd.print("min");
                              lcd.print("sec  ");
                        case RUN_ALL_ZONES:
                          fastClear();
                          if (displayToggle)
                            lcd.print("min");
                            lcd.print("sec  ");
                          if (displayToggle)
                    setTime(newTime);
                      DEBUG_PRINT(day());
                      showTime = false;
                  void fastClear()
                  void updateClock()
                      lcd.write(byte(0));
                    if (gw.loadState(0) != 0xFF)
                      gw.saveState(0, 0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
                      gw.saveState(5 - i, byte(theDate >> 8 * (i - 1))); // store epoch datestamp in 4 bytes of EEPROM starting in location one
                      gw.request(valveIndex, V_VAR1);
                      gw.request(valveIndex, V_VAR2);
                      gw.request(valveIndex, V_VAR3);
                      valveIndex++;
                        valveIndex = 1;
                  • P Paulb
                    May 31, 2015
                    *** Version 2.0
                    PARTS LIST:
                    * NRF24L01 Radio
                    * LED
                    * Push button
                    INSTRUCTIONS:
                    #include <Time.h>
                    #ifdef ACTIVE_LOW
                    #ifdef DEBUG_ON
                    typedef enum {
                    SprinklerStates;
                    byte menuState = 0;
                    int valveNumber;
                    int lastValve;
                    //end extra 1k
                      //end extra 1k
                      //delay(5000);
                      //delay(5000);
                      lcd.clear();
                      lcd.backlight();
                      delay(500);
                      lcd.write(byte(0));
                        delay(1000);
                        lcd.print(".");
                        clockCounter++;
                          lcd.clear();
                          delay(2000);
                      lcd.clear();
                        lcd.print(i);
                        DEBUG_PRINT(i);
                          delay(100);
                          delay(100);
                          delay(100);
                      lcd.clear();
                      updateClock();
                      updateDisplay();
                      if (buttonPushed)
                          menuState = 0;
                          menuState++;
                            menuState = 0;
                        slowToggleLED ();
                            delay(50);
                          lcd.clear();
                          lcd.setCursor(0,0);
                          lcd.setCursor(0,1);
                          delay(2000);
                          lastValve = -1;
                        fastToggleLed();
                          valveNumber = 1;
                          valveNumber++;
                            lastValve = -1;
                        fastToggleLed();
                          fastToggleLed();
                        displayMenu();
                      lastState = state;
                        lcd.clear();
                        lcd.print(F("."));
                        Serial.print(".");
                        if (menuState == 0)
                          valveNumber = 1;
                              if (i == 0)
                                valveNumber = 1;
                                valveNumber = i;
                                DEBUG_PRINTLN(i);
                            DEBUG_PRINT(i);
                            DEBUG_PRINT(i);
                              DEBUG_PRINTLN(i);
                            DEBUG_PRINT(i);
                      if (zoneTimeUpdate)
                          if (i != 0)
                            DEBUG_PRINT(i);
                        switch (state) {
                            fastClear();
                            if (displayToggle)
                              if (clockUpdating)
                                lcd.write(byte(0));
                              lcd.print(month());
                              lcd.print(day());
                              lcd.print(F("/"));
                              if (clockUpdating)
                                lcd.write(byte(0));
                            fastClear();
                            if (displayToggle)
                                lcd.print("min");
                                lcd.print("sec  ");
                          case RUN_ALL_ZONES:
                            fastClear();
                            if (displayToggle)
                              lcd.print("min");
                              lcd.print("sec  ");
                            if (displayToggle)
                      setTime(newTime);
                        DEBUG_PRINT(day());
                        showTime = false;
                    void fastClear()
                    void updateClock()
                        lcd.write(byte(0));
                        valveIndex++;
                          valveIndex = 1;
                    P
                    P
                    Paulb
                    @Paulb After more troubleshooting I finally narrowed down the problem to an external factor. It seems the old desk lamp I was using on my workbench interfered with the radio signal. It is a fluorescent tube which I understand can be quite 'noisy'. Replicated the conditions several times, stopped using the lamp - presto! everything works as it should.
                    • P
                      P
                      pettib
                      Do anyone has a working solution to connect this project to a main valve who has to open when running the zones ?
                        Do you mean that you need to open a main valve while any of the others are open and close it whenever the others are all closed?
                          P
                          P
                          pettib
                          @gohan exactly what I meant.
                          dbemowskD 1 Reply Last reply
                          • P pettib
                            dbemowskD
                            dbemowskD
                            @pettib I started this project last summer but have not fully finished it. My setup has a pump start relay, which is essentially the same as a main valve control.
                            One way to do this is to connect one more data line to a relay and in your sketch, change it so that any time a zone is triggered, turn on the main valve data line. Shouldn't be that difficult to code.
                            I was originally planning to do this with hardware where I had diodes from each output of the shift register feeding to one central point which would be the main valve relay, but I had some trouble with that. Could have been that I was doing something wrong. None the less, the approach above should work without issue if programmed correctly.
                              You could make a function that recursively checks if any of the valves pin is high it sets the main valve pin HIGH, if all the valve pins are LOW then it sets the main valve pin LOW
                              • johnecyJ
                                johnecyJ
                                johnecy
                                I have the irrigation controller all setup and working. I have one problem though as soon as I power it up with 5 volts for the pro mini sometimes one sometimes all the relays come on. If I am not home the water runs all day is there a programing change or a wire change I need to make to stop this. I was using the old wire diagram without the pull up on pin 13 of the 74hc I changed to the new version and added the lines off code but it still does not help.
                                pndgt0P 1 Reply Last reply
                                  Are you setting all pins to low during setup?
                                  • dbemowskD
                                    dbemowskD
                                    So I had started this build going on a year ago but never finished it. That was before I found the easy newbie boards which is what I plan on using to resurrect this build. My question is, can this be built using a 3.3V pro mini, or should I be using a 5V one. I am just wondering if I need to set up my newbie board with a 3.3V regulator or not. My other question is on the resistors. I have a bunch of 1/8 watt resistors and was wondering if they would work or if I should go to 1/4 watt. I have all of the parts in my parts bin and with the newbie board it shouldn't take long to put it together, just need direction on those couple things.
                                      It's hard to answer since you aren't providing many details like is it battery powered? What kind of valves are you using? What are you using those resistors for?
                                        dbemowskD
                                        dbemowskD
                                        @gohan Sorry, I am talking about the schematic for the irrigation controller in the build section of the site. That is why I posted the question here.
                                        One other thing that I just noticed, and I will post this in the easy newbie board thread also for @sundberg84, I noticed that there is a change in the pins that are broken out on the header on the left side of the board. This is the board that I am using for the build, and I was going to point out here that the schematic below shows to connect D7 and D8 to the shift register, but the REV 8 board that I am using does not break out D8. After looking at the site on the new REV 9 boards, which I have a batch of, he doesn't break out D7 or D8.. The wiring of the pins is completely different between the REV 8 and REV 9 boards. The reason I mention this is that I was going to write something up here explaining the build with a newbie board, but I think I will hold off as it might be confusing to many depending what REV of the board people have.
                                        Another thing that I just notices is on the schematic. I have a copy of the schematic that I printed last year when I started this build. There has since been a change. In the old schematic that I have it shows the output enable (OE) pin of the shift register grounded, where in the one below, it showsit connected to D6 through a 1K resistor. I can understand that the change is to give arduino control to the output enable line, but because in the other schematic it didn't show D6 connected, and I didn't have D8 broken out, I used D6 in it's place. I may need to rethink some of this. In any case, I will need to make some changes to the sketch prior to uploading it.
                                        0_1496074195604_upload-c4616651-6dc5-47bb-a4c6-ff77a1936257
                                          dbemowskD
                                          dbemowskD
                                          OK, so I have this built this and have it mostly working with my Vera Plus. Below is a link to a video of a problem I am having.
                                          http://www.dan.bemowski.info/videos/20170601_004213.mp4
                                          So my sprinkler system has a pump start relay which gets turned on any time a valve is turned on. Because of this I made a slight hardware modification which thus required a software modification. For the hardware, I ended up using relay number 1 of my 8 channel relay board as my pump start relay control. This I have wired to pin A1. Relays 2 through 8 are connected to the shift register on Qb through Qh (outputs 2-8) skipping output 1. Because of this I had to change how the code defined which valve to start on. To do this, I changed the commented lines removing the (-1) on the bit shift. I made the assumption that in code, the relay numbers start with 0.
                                          #ifdef ACTIVE_LOW
                                          //#define BITSHIFT_VALVE_NUMBER ~(1U << (valveNumber-1))
                                          #define BITSHIFT_VALVE_NUMBER ~(1U << (valveNumber))
                                          //#define BITSHIFT_VALVE_NUMBER (1U << (valveNumber-1))
                                          #define BITSHIFT_VALVE_NUMBER (1U << (valveNumber))
                                          Then I needed to define the pump start relay.
                                          const int pumpStart = A1;
                                          and then in setup I have this:
                                            pinMode(pumpStart, OUTPUT);
                                            digitalWrite (pumpStart, HIGH);
                                          Lastly, to operate the pump start relay whenever a zone is triggered, this is the updateRelays() function:
                                            if (value == ALL_VALVES_OFF)
                                              digitalWrite(pumpStart, HIGH);
                                              digitalWrite(pumpStart, LOW);
                                          All of this seems to work. When I trigger a zone, I see the pump start relay kick on as well as the triggered zone relay. The only problem I have is that the screen keeps cycling valve data: (1-4) on the screen, as can be seen in the video clip.
                                          Here is my entire modified sketch that I have uploaded:
                                          MySprinkler for MySensors
                                          May 31, 2015
                                          *** Version 2.0
                                          PARTS LIST:
                                          * NRF24L01 Radio
                                          * Resistors (270, 1K & 10K)
                                          * LED
                                          * Push button
                                          INSTRUCTIONS:
                                          #define NUMBER_OF_VALVES 4  // Change this to set your valve count up to 16.
                                          #define VALVE_TIMES_RELOAD 300000UL  // Change this (in milliseconds) for how often to update all valves data from the controller (Loops at value/number valves)
        // ie: 300000 for 8 valves produces requests 37.5seconds with all valves updated every 5mins
                                          #define SKETCH_VERSION "2.2"
                                          #ifdef ACTIVE_LOW
                                          #ifdef DEBUG_ON
                                          typedef enum {
                                          SprinklerStates;
                                          byte menuState = 0;
                                          int valveNumber;
                                          int lastValve;
                                          int allVars[] = {V_VAR1, V_VAR2, V_VAR3};
                                          const int latchPin = 6;
                                          const int outputEnablePin = A0;
                                          LiquidCrystal_I2C lcd(0x3F, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27. Mine was actually 0x3F
                                          bool inSetup = true;
                                            //delay(5000);
                                            lcd.clear();
                                            lcd.backlight();
                                            delay(500);
                                            lcd.write(byte(0));
                                              requestTime();
                                              wait(1000);
                                              lcd.print(".");
                                              clockCounter++;
                                                lcd.clear();
                                                wait(2000);
                                            for (byte i = 1; i <= NUMBER_OF_VALVES; i++)
                                              lcd.clear();
                                              goGetValveTimes();
                                            lcd.clear();
                                            updateClock();
                                            updateDisplay();
                                            goGetValveTimes();
                                            if (buttonPushed)
                                                menuState = 0;
                                                menuState++;
                                                  menuState = 0;
                                              slowToggleLED ();
                                                  wait(50);
                                                lcd.clear();
                                                lcd.setCursor(0,0);
                                                lcd.setCursor(0,1);
                                                wait(2000);
                                                lastValve = -1;
                                                  wait(50);
                                              fastToggleLed();
                                                valveNumber = 1;
                                                valveNumber++;
                                                  lastValve = -1;
                                                    wait(50);
                                              fastToggleLed();
                                                  wait(50);
                                                fastToggleLed();
                                              displayMenu();
                                              lastState = state;
                                              lcd.clear();
                                              lcd.print(F("."));
                                              Serial.print(".");
                                              if (menuState == 0)
                                                valveNumber = 1;
                                                    if (i == 0)
                                                      valveNumber = 1;
                                                      valveNumber = i;
                                                      DEBUG_PRINTLN(i);
                                                  DEBUG_PRINT(i);
                                                  DEBUG_PRINT(i);
                                                    DEBUG_PRINTLN(i);
                                                  DEBUG_PRINT(F("Recieved variable3 valve: "));
                                                  DEBUG_PRINT(i);
                                            if (zoneTimeUpdate)
                                                if (i != 0)
                                                  DEBUG_PRINT(i);
                                                  DEBUG_PRINT(allZoneTime[i]);
                                                  DEBUG_PRINT(F(" name: "));
                                              switch (state) {
                                                  fastClear();
                                                  if (displayToggle)
                                                    if (clockUpdating)
                                                      lcd.write(byte(0));
                                                    lcd.print(month());
                                                    lcd.print(day());
                                                    lcd.print(F("/"));
                                                    if (clockUpdating)
                                                      lcd.write(byte(0));
                                                  fastClear();
                                                  if (displayToggle)
                                                      lcd.print("min");
                                                      lcd.print("sec  ");
                                                case RUN_ALL_ZONES:
                                                  fastClear();
                                                  if (displayToggle)
                                                    lcd.print("min");
                                                    lcd.print("sec  ");
                                                  if (displayToggle)
                                                default:
                                            setTime(newTime);
                                              DEBUG_PRINT(day());
                                              showTime = false;
                                          void fastClear()
                                          void updateClock()
                                              lcd.write(byte(0));
                                              requestTime();
                                            if (inSetup || millis() - valveUpdateTime >= VALVE_TIMES_RELOAD / NUMBER_OF_VALVES) // update each valve once every 5 mins (distributes the traffic)
                                              if (inSetup) {
                                                lcd.print(valveIndex);
                                              DEBUG_PRINT(valveIndex);
                                              for (int a = 0; a < (sizeof(allVars)/sizeof(int)); a++) {
                                                byte timeout = 10;
                                                while (!receivedInitialValue && timeout > 0)
                                                  request(valveIndex, allVars[a]);
                                                  wait(50);
                                                  timeout--;
                                              valveIndex++;
                                              if (valveIndex > NUMBER_OF_VALVES)
                                                valveIndex = 1;
                                          As always, any help is appreciated.
                                          BulldogLowellB T 2 Replies Last reply
