  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 329.8k Views 52 Watching
  • P Paulb
    Hi, this is my first MySensors project having been inspired to jump in after finding @petewill great Youtube video. Thanks to @BulldogLowell for the code. After much perseverance I have everything working... kinda'.
    My last persistent issue is the system halting zone 2, ie, cycle starts and ~10 seconds in the irrigation is halted. This only happens for Zone 2 (pin 1 on the shift register). This issue only occurs when either starting Zone 2 singularly from the controller or as part of the All Zones from the controller - Zone 1 will complete, Zone 2 will start then stop after ~10 seconds. Zone 2 WILL complete fine when selected manually from the pushbutton. All Zones from the pushbutton or controller will both fail.
    I've checked and re-checked solder joints, wire connections, put the 10k external pullup resistor in and swapped out shift registers with no luck so far.
    Would appreciate any help to resolve. Thanks.
    I am using Domoticz and @Huczas modified sketch.
    Arduino Multi-Zone Sprinkler Control
    May 31, 2015
    *** Version 2.0
    * LED status indicator
    PARTS LIST:
    * Relays (8 channel)
    * NRF24L01 Radio
    * Arduino (I used a Pro Mini)
    * Capacitors (10uf and .1uf)
    * 3.3v voltage regulator
    * Resistors (270 & 10K)
    * Female Dupont Cables
    * LED
    * Push button
    * Shift Register (SN74HC595)
    * 18 gauge wire (for relay)
    INSTRUCTIONS:
      on the serial monitor.
    #include <Time.h>
    #include <LiquidCrystal.h>
    #define NUMBER_OF_VALVES 5  // Change this to set your valve count up to 16.
    #define VALVE_RESET_TIME 4500UL   // Change this (in milliseconds) for the time you need your valves to hydraulically reset and change state
    #define RADIO_ID AUTO  // Change this to fix your Radio ID or use Auto
    #define SKETCH_NAME "MySprinkler Domoticz"
    #define SKETCH_VERSION "2.0"
    #define CHILD_ID_SPRINKLER 0
    #define ACTIVE_LOW // comment out this line if your relays are active high
    #ifdef ACTIVE_LOW
    #define ALL_VALVES_OFF 0xFFFF
    #define ALL_VALVES_OFF 0U
    #ifdef DEBUG_ON
    typedef enum {
    SprinklerStates;
    SprinklerStates lastState;
    byte menuState = 0;
    unsigned long menuTimer;
    byte countDownTime = 10;
    int allZoneTime [NUMBER_OF_VALVES + 1]= {0, 1, 1, 1, 1, 1};     // Insert values in min, 0 = all zone (always 0) this is a 5 chan relay
    int valveSoloTime [NUMBER_OF_VALVES + 1]= {0, 1, 1, 1, 1, 1};   // Insert values in min, 0 = all zone (always 0) this is a 5 chan relay
    int valveNumber;
    int lastValve;
    unsigned long startMillis;
    const int ledPin = 5;
    const int waterButtonPin = 3;
    boolean buttonPushed = false;
    boolean showTime = true;
    boolean clockUpdating = false;
    boolean recentUpdate = true;
    const char *dayOfWeek[] = {
    String valveNickName[17] = {
    time_t lastTimeRun = 0;
    //Setup Shift Register...
    const int latchPin = 8;
    const int clockPin = 4;
    const int dataPin  = 7;
    //extra for 1k resistor
    //const int outputEnablePin = 6;
    //end extra 1k
    LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
      SERIAL_START(115200);
      pinMode(latchPin, OUTPUT);
      pinMode(clockPin, OUTPUT);
      pinMode(dataPin, OUTPUT);
      pinMode(ledPin, OUTPUT);
      //internal pullup use next line
      //pinMode(waterButtonPin, INPUT_PULLUP);
      //external pullup use next line
      pinMode(waterButtonPin, INPUT);
      attachInterrupt(1, PushButton, RISING); //May need to change for your Arduino model
      digitalWrite (ledPin, HIGH);
      updateRelays(ALL_VALVES_OFF);
      //pinMode(outputEnablePin, OUTPUT);
      //digitalWrite (outputEnablePin, LOW);
      //end extra 1k
      //delay(5000);
      //delay(5000);
      lcd.clear();
      lcd.backlight();
      lcd.createChar(0, clock);
      lcd.createChar(1, raindrop);
      delay(500);
      if (gw.loadState(0) == 0xFF); // EEPROM flag
        for (int i = 0; i < 4 ; i++)
          lastTimeRun = lastTimeRun | gw.loadState(i + 1); // assemble 4 bytes into an ussigned long epoch timestamp
      gw.begin(getVariables, RADIO_ID, false); // Change 'false' to 'true' to create a Radio repeating node
        gw.present(i, S_LIGHT);
      digitalWrite (ledPin, LOW);
      DEBUG_PRINTLN(F("Ready..."));
      lcd.setCursor(0, 0);
      lcd.setCursor(15, 0);
      lcd.write(byte(0));
      lcd.setCursor(0, 1);
      int clockCounter = 0;
        gw.requestTime(receiveTime);
        delay(1000);
        lcd.print(".");
        clockCounter++;
        if (clockCounter > 16)
          lcd.clear();
          delay(2000);
      lcd.clear();
        lcd.print(F(" Updating  "));
        lcd.print(i);
        boolean flashIcon = false;
        DEBUG_PRINT(i);
        DEBUG_PRINTLN(F(" Data..."));
        while (gw.process() == false)
          flashIcon = !flashIcon;
          gw.request(i, V_VAR1);
          delay(100);
          gw.request(i, V_VAR2);
          delay(100);
          gw.request(i, V_VAR3);
          delay(100);
      lcd.clear();
      updateClock();
      updateDisplay();
      //goGetValveTimes();
      if (buttonPushed)
        menuTimer = millis();
          state = ZONE_SELECT_MENU;
          menuState = 0;
          menuState++;
            menuState = 0;
        slowToggleLED ();
        if (state != lastState)
            delay(50);
            gw.send(msg1valve.setSensor(i).set(false), false);
          lcd.clear();
          lcd.setCursor(0,0);
          lcd.setCursor(0,1);
          delay(2000);
          lastValve = -1;
        if (lastValve != valveNumber)
              gw.send(msg1valve.setSensor(i).set(true), false);
        lastValve = valveNumber;
        fastToggleLed();
          valveNumber = 1;
          startMillis = millis();
          valveNumber++;
            state = CYCLE_COMPLETE;
            lastValve = -1;
            lastTimeRun = now();
            DEBUG_PRINT(F("State = "));
            DEBUG_PRINTLN(state);
        fastToggleLed();
          DEBUG_PRINT(F("Zone: "));
          DEBUG_PRINTLN(valveNumber);
          fastToggleLed();
      else if (state = ZONE_SELECT_MENU)
        displayMenu();
      lastState = state;
    void displayMenu(void)
      static int lastSecond;
        lcd.clear();
        lcd.print(F("Starting"));
        lcd.print(F("."));
        Serial.print(".");
      lastSecond = thisSecond;
        if (menuState == 0)
          valveNumber = 1;
          state = RUN_ALL_ZONES;
          valveNumber = menuState;
          state = RUN_SINGLE_ZONE;
      lastMenuState = menuState;
    void updateRelays(int value)
      digitalWrite(latchPin, LOW);
      digitalWrite(latchPin, HIGH);
        buttonPushed = true;
    void fastToggleLed()
        fastLedTimer = millis ();
    void slowToggleLED ()
        slowLedTimer = millis ();
      boolean zoneTimeUpdate = false;
      if (message.isAck())
        if (message.sensor == i)
          if (message.type == V_LIGHT)
            if (switchState == 0)
              if (i == 0)
                valveNumber = 1;
                valveNumber = i;
                DEBUG_PRINTLN(i);
            DEBUG_PRINT(i);
            DEBUG_PRINT(F(" = "));
            DEBUG_PRINTLN(variable1);
              allZoneTime[i] = variable1;
              zoneTimeUpdate = true;
            DEBUG_PRINT(i);
            DEBUG_PRINTLN(variable2);
              valveSoloTime[i] = variable2;
            if (newMessage.length() == 0)
              DEBUG_PRINTLN(i);
            if (newMessage.length() > 16)
              newMessage.substring(0, 16);
            valveNickName[i] = "";
            DEBUG_PRINT(F("Recieved new name for zone "));
            DEBUG_PRINT(i);
            DEBUG_PRINT(F(" and it is now called: "));
      if (zoneTimeUpdate)
          if (i != 0)
            DEBUG_PRINT(F("Zone "));
            DEBUG_PRINT(i);
            DEBUG_PRINTLN(allZoneTime[i]);
        recentUpdate = false;
    void updateDisplay()
      static boolean displayToggle = false;
        switch (state) {
          case STAND_BY_ALL_OFF:
            fastClear();
            if (displayToggle)
              if (clockUpdating)
                lcd.write(byte(0));
              lcd.print(hourFormat12());
              lcd.print(minute());
              lcd.print(month());
              lcd.print(day());
              lcd.print(F("/"));
              lcd.print(year() % 100);
              if (clockUpdating)
                lcd.write(byte(0));
              lcd.setCursor(11, 1);
              lcd.print(day(lastTimeRun) < 10 ? F("0") : F("/"));
              lcd.print(day(lastTimeRun));
          case RUN_SINGLE_ZONE:
            fastClear();
            if (displayToggle)
              lcd.print(F(" Zone:"));
              lcd.print(valveNumber);
              lcd.print(F(" Active"));
                lcd.print("min");
                lcd.print("sec  ");
          case RUN_ALL_ZONES:
            fastClear();
            if (displayToggle)
              lcd.print(F(" Active "));
              lcd.print("min");
              lcd.print("sec  ");
          case CYCLE_COMPLETE:
            if (displayToggle)
              int totalTimeRan = 0;
              lcd.print(totalTimeRan);
              lcd.print(" Minutes   ");
        lastUpdateTime = millis();
      lastDisplayState = state;
      int lastSecond = second();
      int lastMinute = minute();
      int lastHour = hour();
      setTime(newTime);
        DEBUG_PRINT(hourFormat12());
        DEBUG_PRINT(minute());
        DEBUG_PRINT(month());
        DEBUG_PRINT(F("/"));
        DEBUG_PRINT(day());
        DEBUG_PRINTLN(year());
        showTime = false;
    void fastClear()
    void updateClock()
        lcd.write(byte(0));
        clockUpdating = true;
        lastVeraGetTime = millis();
      if (gw.loadState(0) != 0xFF)
        gw.saveState(0, 0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
      for (int i = 1; i < 5; i++)
        gw.saveState(5 - i, byte(theDate >> 8 * (i - 1))); // store epoch datestamp in 4 bytes of EEPROM starting in location one
    void goGetValveTimes()
      static byte valveIndex = 1;
      if (millis() - valveUpdateTime >= 300000UL / NUMBER_OF_VALVES)// update each valve once every 5 mins (distributes the traffic)
        DEBUG_PRINTLN(F("Calling for Valve Data..."));
        lcd.write(byte(1)); //lcd.write(1);
        gw.request(valveIndex, V_VAR1);
        gw.request(valveIndex, V_VAR2);
        gw.request(valveIndex, V_VAR3);
        valveUpdateTime = millis();
        valveIndex++;
        if (valveIndex > NUMBER_OF_VALVES + 1)
          valveIndex = 1;
    P
    P
    Paulb
    @Paulb After more troubleshooting I finally narrowed down the problem to an external factor. It seems the old desk lamp I was using on my workbench interfered with the radio signal. It is a fluorescent tube which I understand can be quite 'noisy'. Replicated the conditions several times, stopped using the lamp - presto! everything works as it should.
    • P
      P
      pettib
      Do anyone has a working solution to connect this project to a main valve who has to open when running the zones ?
        Do you mean that you need to open a main valve while any of the others are open and close it whenever the others are all closed?
        P 1 Reply Last reply
          P
          P
          pettib
          @gohan exactly what I meant.
          dbemowskD 1 Reply Last reply
          • P pettib
            dbemowskD
            dbemowskD
            @pettib I started this project last summer but have not fully finished it. My setup has a pump start relay, which is essentially the same as a main valve control.
            One way to do this is to connect one more data line to a relay and in your sketch, change it so that any time a zone is triggered, turn on the main valve data line. Shouldn't be that difficult to code.
            I was originally planning to do this with hardware where I had diodes from each output of the shift register feeding to one central point which would be the main valve relay, but I had some trouble with that. Could have been that I was doing something wrong. None the less, the approach above should work without issue if programmed correctly.
              You could make a function that recursively checks if any of the valves pin is high it sets the main valve pin HIGH, if all the valve pins are LOW then it sets the main valve pin LOW
              • johnecyJ
                johnecyJ
                johnecy
                I have the irrigation controller all setup and working. I have one problem though as soon as I power it up with 5 volts for the pro mini sometimes one sometimes all the relays come on. If I am not home the water runs all day is there a programing change or a wire change I need to make to stop this. I was using the old wire diagram without the pull up on pin 13 of the 74hc I changed to the new version and added the lines off code but it still does not help.
                pndgt0P 1 Reply Last reply
                  Are you setting all pins to low during setup?
                  • dbemowskD
                    dbemowskD
                    So I had started this build going on a year ago but never finished it. That was before I found the easy newbie boards which is what I plan on using to resurrect this build. My question is, can this be built using a 3.3V pro mini, or should I be using a 5V one. I am just wondering if I need to set up my newbie board with a 3.3V regulator or not. My other question is on the resistors. I have a bunch of 1/8 watt resistors and was wondering if they would work or if I should go to 1/4 watt. I have all of the parts in my parts bin and with the newbie board it shouldn't take long to put it together, just need direction on those couple things.
                      It's hard to answer since you aren't providing many details like is it battery powered? What kind of valves are you using? What are you using those resistors for?
                        dbemowskD
                        dbemowskD
                        @gohan Sorry, I am talking about the schematic for the irrigation controller in the build section of the site. That is why I posted the question here.
                        One other thing that I just noticed, and I will post this in the easy newbie board thread also for @sundberg84, I noticed that there is a change in the pins that are broken out on the header on the left side of the board. This is the board that I am using for the build, and I was going to point out here that the schematic below shows to connect D7 and D8 to the shift register, but the REV 8 board that I am using does not break out D8. After looking at the site on the new REV 9 boards, which I have a batch of, he doesn't break out D7 or D8.. The wiring of the pins is completely different between the REV 8 and REV 9 boards. The reason I mention this is that I was going to write something up here explaining the build with a newbie board, but I think I will hold off as it might be confusing to many depending what REV of the board people have.
                        Another thing that I just notices is on the schematic. I have a copy of the schematic that I printed last year when I started this build. There has since been a change. In the old schematic that I have it shows the output enable (OE) pin of the shift register grounded, where in the one below, it showsit connected to D6 through a 1K resistor. I can understand that the change is to give arduino control to the output enable line, but because in the other schematic it didn't show D6 connected, and I didn't have D8 broken out, I used D6 in it's place. I may need to rethink some of this. In any case, I will need to make some changes to the sketch prior to uploading it.
                        0_1496074195604_upload-c4616651-6dc5-47bb-a4c6-ff77a1936257
                        • dbemowskD dbemowsk
                          dbemowskD
                          dbemowskD
                          OK, so I have this built this and have it mostly working with my Vera Plus. Below is a link to a video of a problem I am having.
                          http://www.dan.bemowski.info/videos/20170601_004213.mp4
                          So my sprinkler system has a pump start relay which gets turned on any time a valve is turned on. Because of this I made a slight hardware modification which thus required a software modification. For the hardware, I ended up using relay number 1 of my 8 channel relay board as my pump start relay control. This I have wired to pin A1. Relays 2 through 8 are connected to the shift register on Qb through Qh (outputs 2-8) skipping output 1. Because of this I had to change how the code defined which valve to start on. To do this, I changed the commented lines removing the (-1) on the bit shift. I made the assumption that in code, the relay numbers start with 0.
                          #ifdef ACTIVE_LOW
                          //#define BITSHIFT_VALVE_NUMBER ~(1U << (valveNumber-1))
                          #define BITSHIFT_VALVE_NUMBER ~(1U << (valveNumber))
                          //#define BITSHIFT_VALVE_NUMBER (1U << (valveNumber-1))
                          #define BITSHIFT_VALVE_NUMBER (1U << (valveNumber))
                          Then I needed to define the pump start relay.
                          const int pumpStart = A1;
                          and then in setup I have this:
                            pinMode(pumpStart, OUTPUT);
                            digitalWrite (pumpStart, HIGH);
                          Lastly, to operate the pump start relay whenever a zone is triggered, this is the updateRelays() function:
                            if (value == ALL_VALVES_OFF)
                              digitalWrite(pumpStart, HIGH);
                              digitalWrite(pumpStart, LOW);
                          All of this seems to work. When I trigger a zone, I see the pump start relay kick on as well as the triggered zone relay. The only problem I have is that the screen keeps cycling valve data: (1-4) on the screen, as can be seen in the video clip.
                          Here is my entire modified sketch that I have uploaded:
                          MySprinkler for MySensors
                          May 31, 2015
                          *** Version 2.0
                          PARTS LIST:
                          * NRF24L01 Radio
                          * Resistors (270, 1K & 10K)
                          * LED
                          * Push button
                          INSTRUCTIONS:
                          // Enable debug prints
                          //#define MY_NODE_ID 1  // Set this to fix your Radio ID or use Auto
                          #include <TimeLib.h>
                          #define NUMBER_OF_VALVES 4  // Change this to set your valve count up to 16.
                          #define VALVE_TIMES_RELOAD 300000UL  // Change this (in milliseconds) for how often to update all valves data from the controller (Loops at value/number valves)
                                                               // ie: 300000 for 8 valves produces requests 37.5seconds with all valves updated every 5mins
                          #define SKETCH_VERSION "2.2"
                          #ifdef ACTIVE_LOW
                          #ifdef DEBUG_ON
                          typedef enum {
                          SprinklerStates;
                          byte menuState = 0;
                          int allZoneTime [NUMBER_OF_VALVES + 1];
                          int valveSoloTime [NUMBER_OF_VALVES + 1];
                          int valveNumber;
                          int lastValve;
                          bool buttonPushed = false;
                          bool showTime = true;
                          bool clockUpdating = false;
                          bool recentUpdate = true;
                          int allVars[] = {V_VAR1, V_VAR2, V_VAR3};
                          const int latchPin = 6;
                          const int outputEnablePin = A0;
                          LiquidCrystal_I2C lcd(0x3F, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27. Mine was actually 0x3F
                          bool receivedInitialValue = false;
                          bool inSetup = true;
                            attachInterrupt(digitalPinToInterrupt(waterButtonPin), PushButton, RISING); //May need to change for your Arduino model
                            //delay(5000);
                            lcd.clear();
                            lcd.backlight();
                            delay(500);
                            if (loadState(0) == 0xFF) // EEPROM flag
                                lastTimeRun = lastTimeRun | loadState(i + 1); // assemble 4 bytes into an ussigned long epoch timestamp
                            lcd.write(byte(0));
                              requestTime();
                              wait(1000);
                              lcd.print(".");
                              clockCounter++;
                                lcd.clear();
                                wait(2000);
                            for (byte i = 1; i <= NUMBER_OF_VALVES; i++)
                              lcd.clear();
                              goGetValveTimes();
                            lcd.clear();
                            updateClock();
                            updateDisplay();
                            goGetValveTimes();
                            if (buttonPushed)
                                menuState = 0;
                                menuState++;
                                  menuState = 0;
                              slowToggleLED ();
                                  wait(50);
                                lcd.clear();
                                lcd.setCursor(0,0);
                                lcd.setCursor(0,1);
                                wait(2000);
                                lastValve = -1;
                                  wait(50);
                              fastToggleLed();
                                valveNumber = 1;
                                valveNumber++;
                                  lastValve = -1;
                                    wait(50);
                              fastToggleLed();
                                  wait(50);
                                fastToggleLed();
                              displayMenu();
                              lastState = state;
                              lcd.clear();
                              lcd.print(F("."));
                              Serial.print(".");
                              if (menuState == 0)
                                valveNumber = 1;
                            bool zoneTimeUpdate = false;
                                    if (i == 0)
                                      valveNumber = 1;
                                      valveNumber = i;
                                      DEBUG_PRINTLN(i);
                                  DEBUG_PRINT(i);
                                  receivedInitialValue = true;
                                  DEBUG_PRINT(i);
                                    DEBUG_PRINTLN(i);
                                  DEBUG_PRINT(F("Recieved variable3 valve: "));
                                  DEBUG_PRINT(i);
                            if (zoneTimeUpdate)
                                if (i != 0)
                                  DEBUG_PRINT(i);
                                  DEBUG_PRINT(allZoneTime[i]);
                                  DEBUG_PRINT(F(" name: "));
                            static bool displayToggle = false;
                              switch (state) {
                                  fastClear();
                                  if (displayToggle)
                                    if (clockUpdating)
                                      lcd.write(byte(0));
                                    lcd.print(month());
                                    lcd.print(day());
                                    lcd.print(F("/"));
                                    if (clockUpdating)
                                      lcd.write(byte(0));
                                  fastClear();
                                  if (displayToggle)
                                      lcd.print("min");
                                      lcd.print("sec  ");
                                case RUN_ALL_ZONES:
                                  fastClear();
                                  if (displayToggle)
                                    lcd.print("min");
                                    lcd.print("sec  ");
                                  if (displayToggle)
                                default:
                                  // what of ZONE_SELECT_MENU?
                            setTime(newTime);
                              DEBUG_PRINT(day());
                              showTime = false;
                          void fastClear()
                          void updateClock()
                              lcd.write(byte(0));
                              requestTime();
                            if (loadState(0) != 0xFF)
                            if (inSetup || millis() - valveUpdateTime >= VALVE_TIMES_RELOAD / NUMBER_OF_VALVES) // update each valve once every 5 mins (distributes the traffic)
                              if (inSetup) {
                                lcd.print(valveIndex);
                              bool flashIcon = false;
                              DEBUG_PRINT(valveIndex);
                              for (int a = 0; a < (sizeof(allVars)/sizeof(int)); a++) {
                                byte timeout = 10;
                                while (!receivedInitialValue && timeout > 0)
                                  request(valveIndex, allVars[a]);
                                  wait(50);
                                  timeout--;
                              valveIndex++;
                              if (valveIndex > NUMBER_OF_VALVES)
                                valveIndex = 1;
                          As always, any help is appreciated.
                          BulldogLowellB T 2 Replies Last reply
                            #ifdef ACTIVE_LOW
                            May 31, 2015
                            *** Version 2.0
                            PARTS LIST:
                            * NRF24L01 Radio
                            * LED
                            * Push button
                            INSTRUCTIONS:
                            #ifdef ACTIVE_LOW
                            #ifdef DEBUG_ON
                            typedef enum {
                            SprinklerStates;
                            byte menuState = 0;
                            int valveNumber;
                            int lastValve;
                              //delay(5000);
                              lcd.clear();
                              lcd.backlight();
                              delay(500);
                              lcd.write(byte(0));
                                requestTime();
                                wait(1000);
                                lcd.print(".");
                                clockCounter++;
                                  lcd.clear();
                                  wait(2000);
                                lcd.clear();
                                goGetValveTimes();
                              lcd.clear();
                              updateClock();
                              updateDisplay();
                              goGetValveTimes();
                              if (buttonPushed)
                                  menuState = 0;
                                  menuState++;
                                    menuState = 0;
                                slowToggleLED ();
                                    wait(50);
                                  lcd.clear();
                                  lcd.setCursor(0,0);
                                  lcd.setCursor(0,1);
                                  wait(2000);
                                  lastValve = -1;
                                    wait(50);
                                fastToggleLed();
                                  valveNumber = 1;
                                  valveNumber++;
                                    lastValve = -1;
                                      wait(50);
                                fastToggleLed();
                                    wait(50);
                                  fastToggleLed();
                                displayMenu();
                                lastState = state;
                                lcd.clear();
                                lcd.print(F("."));
                                Serial.print(".");
                                if (menuState == 0)
                                  valveNumber = 1;
                                      if (i == 0)
                                        valveNumber = 1;
                                        valveNumber = i;
                                        DEBUG_PRINTLN(i);
                                    DEBUG_PRINT(i);
                                    DEBUG_PRINT(i);
                                      DEBUG_PRINTLN(i);
                                    DEBUG_PRINT(i);
                              if (zoneTimeUpdate)
                                  if (i != 0)
                                    DEBUG_PRINT(i);
                                switch (state) {
                                    fastClear();
                                    if (displayToggle)
                                      if (clockUpdating)
                                        lcd.write(byte(0));
                                      lcd.print(month());
                                      lcd.print(day());
                                      lcd.print(F("/"));
                                      if (clockUpdating)
                                        lcd.write(byte(0));
                                    fastClear();
                                    if (displayToggle)
                                        lcd.print("min");
                                        lcd.print("sec  ");
                                  case RUN_ALL_ZONES:
                                    fastClear();
                                    if (displayToggle)
                                      lcd.print("min");
                                      lcd.print("sec  ");
                                    if (displayToggle)
                                  default:
                              setTime(newTime);
                                DEBUG_PRINT(day());
                                showTime = false;
                            void fastClear()
                            void updateClock()
                                lcd.write(byte(0));
                                requestTime();
                                if (inSetup) {
                                  byte timeout = 10;
                                    wait(50);
                                    timeout--;
                                valveIndex++;
                                  valveIndex = 1;
                            BulldogLowellB
                            BulldogLowellB
                            BulldogLowell
                            @dbemowsk
                            what's happening in the Serial debug?
                            • dbemowskD
                              dbemowskD
                              I'll look later and report. Got company at the moment. The odd thing is that I can turn my zones on and they seem to run for the specified time just fine. It's only what I see on the display that is messed up.
                              • Black CatB
                                Black CatB
                                Black Cat
                                I've just started playing with a Z-Uno and was looking at ways to use for a project like this.
                                I'm a believer in not re-inventing the wheel and it seem that all I would need to do is to delete the radio and re-code the sketch for the extra relays ( I have already built a 4 channel relay, it's just getting over the hurdle of learning about Shift Registers).
                                Do you think this is possible or would I be better just starting from scratch?
                                • Black CatB Black Cat
                                  BulldogLowellB
                                  BulldogLowellB
                                  BulldogLowell
                                  @Black-Cat said in Irrigation Controller (up to 16 valves with Shift Registers):
                                  Z-Uno
                                  wicked cool...
                                  I'm in North America, so I have to stand by!
                                  You you should be able to easily port this for use with Z-Uno...
                                    BulldogLowellB
                                    BulldogLowellB
                                    BulldogLowell
                                    @dbemowsk
                                    yes, weird...
                                      #ifdef ACTIVE_LOW
                                      May 31, 2015
                                      *** Version 2.0
                                      PARTS LIST:
                                      * NRF24L01 Radio
                                      * LED
                                      * Push button
                                      INSTRUCTIONS:
                                      #ifdef ACTIVE_LOW
                                      #ifdef DEBUG_ON
                                      typedef enum {
                                      SprinklerStates;
                                      byte menuState = 0;
                                      int valveNumber;
                                      int lastValve;
                                        //delay(5000);
                                        lcd.clear();
                                        lcd.backlight();
                                        delay(500);
                                        lcd.write(byte(0));
                                          requestTime();
                                          wait(1000);
                                          lcd.print(".");
                                          clockCounter++;
                                            lcd.clear();
                                            wait(2000);
                                          lcd.clear();
                                          goGetValveTimes();
                                        lcd.clear();
                                        updateClock();
                                        updateDisplay();
                                        goGetValveTimes();
                                        if (buttonPushed)
                                            menuState = 0;
                                            menuState++;
                                              menuState = 0;
                                          slowToggleLED ();
                                              wait(50);
                                            lcd.clear();
                                            lcd.setCursor(0,0);
                                            lcd.setCursor(0,1);
                                            wait(2000);
                                            lastValve = -1;
                                              wait(50);
                                          fastToggleLed();
                                            valveNumber = 1;
                                            valveNumber++;
                                              lastValve = -1;
                                                wait(50);
                                          fastToggleLed();
                                              wait(50);
                                            fastToggleLed();
                                          displayMenu();
                                          lastState = state;
                                          lcd.clear();
                                          lcd.print(F("."));
                                          Serial.print(".");
                                          if (menuState == 0)
                                            valveNumber = 1;
                                                if (i == 0)
                                                  valveNumber = 1;
                                                  valveNumber = i;
                                                  DEBUG_PRINTLN(i);
                                              DEBUG_PRINT(i);
                                              DEBUG_PRINT(i);
                                                DEBUG_PRINTLN(i);
                                              DEBUG_PRINT(i);
                                        if (zoneTimeUpdate)
                                            if (i != 0)
                                              DEBUG_PRINT(i);
                                          switch (state) {
                                              fastClear();
                                              if (displayToggle)
                                                if (clockUpdating)
                                                  lcd.write(byte(0));
                                                lcd.print(month());
                                                lcd.print(day());
                                                lcd.print(F("/"));
                                                if (clockUpdating)
                                                  lcd.write(byte(0));
                                              fastClear();
                                              if (displayToggle)
                                                  lcd.print("min");
                                                  lcd.print("sec  ");
                                            case RUN_ALL_ZONES:
                                              fastClear();
                                              if (displayToggle)
                                                lcd.print("min");
                                                lcd.print("sec  ");
                                              if (displayToggle)
                                            default:
                                        setTime(newTime);
                                          DEBUG_PRINT(day());
                                          showTime = false;
                                      void fastClear()
                                      void updateClock()
                                          lcd.write(byte(0));
                                          requestTime();
                                          if (inSetup) {
                                            byte timeout = 10;
                                              wait(50);
                                              timeout--;
                                          valveIndex++;
                                            valveIndex = 1;
                                      Topdawg2881
                                      @dbemowsk
                                      I had this same issue. What I did to fix the issue was I commented out in the void loop the line to goGetValveTimes. I then added the timeAlarms library and set a timer to get valve times once every five minutes. The section of code looks like this. Alarm.timerRepeat (300,goGetValveTimes);
                                      I inserted that line as the last line of cade in the void setup
                                      • dbemowskD
                                        dbemowskD
                                        Okay, so I was just looking over the code. I first did a search for "Valve Data:" as that was what was showing on the screen. I found that in the goGetValveTimes() method. According to the code, that is only supposed to show if the inSetup variable evaluates to true. I then searched on that variable, and in the code just before the setup() method, I see this:
                                        But I don't see anywhere in the code where it sets that value to false. So every time the main loop() calls goGetValveTimes();, it is going to display that since inSetup never gets changed to false. At the very end of the setup routine I see this bit of code:
                                            lcd.clear();
                                            goGetValveTimes();
                                          lcd.clear();
                                        I think that it is just after that for loop, or after the lcd.clear(); that it is supposed to set inSetup to false. I have not tested this theory yet as I need to unmount my controller and open it up to push the new code to it, but I am pretty sure that this is the issue. That would explain why everything else with it appears to work normally.
                                        I double checked with the example code on the build page to see if possibly I may have deleted something when doing my edits. Looking it over, I found the same thing. If you ask me, this looks to be a bug in the code and it should be fixed and updated.
                                              lcd.clear();
                                              goGetValveTimes();
                                            lcd.clear();
                                          Topdawg2881
                                          @dbemowsk
                                          I am in front of my computer and I have my controller in front of me and hooked up. Give me a couple minutes and I will run it. See what happens.
