  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 329.8k Views 52 Watching
  • Andrej_ABA Andrej_AB
    @petewill Hi, All my other nodes have successfully paired with Vera, but irrigation controller node can't pair with Vera, I have started inclusion mode on Vera, one minute passed 0 devices found.
    Please see attached picture.
    petewillP
    petewillP
    petewill
    @Andrej_AB It looks like it's communicating ok because it's getting the time. Have you ever had a mysenors node #5 in your Vera previously and deleted it? Could it be that the Vera thinks it's already there? What happens if you clear your eeprom on your irrigation controller then manually assign a different ID and then try to pair it again?
    Andrej_ABA 1 Reply Last reply
    • petewillP petewill
      Andrej_ABA
      Andrej_ABA
      Andrej_AB
      Also thinking about it, eprom was cleaned and manually assigned new ID but still can't pair with Vera.
      Today I tried upload sketch from My sensors library 1.5.4 and node was successfully paired with Vera, then tried again last sketch and again can't pair.
      petewillP 1 Reply Last reply
        petewillP
        petewillP
        petewill
        @Andrej_AB Can you post the full log from your sensor? The device is never getting presented in what you've posted so far. I don't have enough time to dig in to the code to know if this will help but can you try moving
            present(i, S_LIGHT);
        so it's above
        I still haven't updated my irrigation controller to 2.0 yet so I haven't tested any of the code.
          so it's above
          Andrej_ABA
          Andrej_ABA
          Andrej_AB
          @petewill Finally managed to pair node with Vera controller, many thanks to @petewill for assistance with this issue.
          #define NUMBER_OF_VALVES 6  // Change this to set your valve count up to 16.
          #define RADIO_ID 7  // Set this to fix your Radio ID or use Auto```
          • impertusI
            impertusI
            impertus
            wrote on last edited by m26872
            #264
            hey @petewill
            finally i am done making the controller. but when i want to upload the code i get the error..
            C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void setup()':
            Vanding:112: error: 'lcd' was not declared in this scope
            C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void loop()':
            Vanding:255: error: 'lcd' was not declared in this scope
                   lcd.clear();
            C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void displayMenu()':
            Vanding:388: error: 'lcd' was not declared in this scope
                 lcd.clear();
            Vanding:399: error: 'lcd' was not declared in this scope
                 lcd.print(F("."));
            C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void updateDisplay()':
            Vanding:589: error: 'lcd' was not declared in this scope
                     lcd.setCursor(0, 0);
            C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void fastClear()':
            Vanding:750: error: 'lcd' was not declared in this scope
            C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void updateClock()':
            Vanding:762: error: 'lcd' was not declared in this scope
                 lcd.setCursor(15, 0);
            C:\Users\crame\Desktop\Vanding\Vanding.ino: In function 'void goGetValveTimes()':
            Vanding:791: error: 'lcd' was not declared in this scope
            exit status 1
            do you have some help 4 me??
            dbemowskD 2 Replies Last reply
            • impertusI impertus
              hey @petewill
                     lcd.clear();
                   lcd.clear();
                   lcd.print(F("."));
              exit status 1
              dbemowskD
              dbemowskD
              @impertus Can you post your entire sketch?
                hey @petewill
                       lcd.clear();
                     lcd.clear();
                     lcd.print(F("."));
                exit status 1
                dbemowskD
                dbemowskD
                @impertus Those errors have to do with this line:
                LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
                This is where the declaration happens. If this is commented or fails, you will get the errors you described. Do you have the correct LCD libraries installed for this?
                impertusI 1 Reply Last reply
                • dbemowskD dbemowsk
                  impertusI
                  impertusI
                  impertus
                  #267
                  @dbemowsk i just copy/paste from the site.
                  witch library should i use?
                  i have added mysensors-master to IDE
                  edit i could see i have out comment the line. Now i get this error
                  Vanding:92: error: 'POSITIVE' was not declared in this scope
                  Vanding:116: error: no matching function for call to 'LiquidCrystal_I2C::begin(int, int)'
                  C:\Users\crame\Desktop\Vanding\Vanding.ino:116:18: note: candidate is:
                  In file included from C:\Users\crame\Desktop\Vanding\Vanding.ino:1:0:
                  C:\Program Files (x86)\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master/LiquidCrystal_I2C.h:76:7: note: void LiquidCrystal_I2C::begin()
                    void begin();
                  C:\Program Files (x86)\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master/LiquidCrystal_I2C.h:76:7: note:   candidate expects 0 arguments, 2 provided
                  exit status 1
                  the sketch.
                  // Enable debug prints
                  //#define MY_NODE_ID 1  // Set this to fix your Radio ID or use Auto
                  #include <TimeLib.h>
                  #include <LiquidCrystal.h>
                  #define NUMBER_OF_VALVES 8  // Change this to set your valve count up to 16.
                  #define SKETCH_VERSION "2.0"
                  #define CHILD_ID_SPRINKLER 0
                  #define ACTIVE_LOW // comment out this line if your relays are active high
                  #ifdef ACTIVE_LOW
                  #define ALL_VALVES_OFF 0xFFFF
                  #define ALL_VALVES_OFF 0U
                  #ifdef DEBUG_ON
                  #define SERIAL_START(x)
                  typedef enum {
                  SprinklerStates;
                  SprinklerStates lastState;
                  byte menuState = 0;
                  unsigned long menuTimer;
                  byte countDownTime = 10;
                  int allZoneTime [NUMBER_OF_VALVES + 1];
                  int valveSoloTime [NUMBER_OF_VALVES + 1];
                  int valveNumber;
                  int lastValve;
                  unsigned long startMillis;
                  const int ledPin = 5;
                  const int waterButtonPin = 3;
                  bool buttonPushed = false;
                  bool showTime = true;
                  bool clockUpdating = false;
                  bool recentUpdate = true;
                  const char *dayOfWeek[] = {
                  String valveNickName[17] = {
                  time_t lastTimeRun = 0;
                  //Setup Shift Register...
                  const int latchPin = 8;
                  const int clockPin = 4;
                  const int dataPin  = 7;
                  const int outputEnablePin = 6;
                  bool receivedInitialValue = false;
                    pinMode(latchPin, OUTPUT);
                    pinMode(clockPin, OUTPUT);
                    pinMode(dataPin, OUTPUT);
                    pinMode(ledPin, OUTPUT);
                    pinMode(outputEnablePin, OUTPUT);
                    digitalWrite (outputEnablePin, LOW);
                    attachInterrupt(digitalPinToInterrupt(waterButtonPin), PushButton, RISING); //May need to change for your Arduino model
                    digitalWrite (ledPin, HIGH);
                    updateRelays(ALL_VALVES_OFF);
                    //delay(5000);
                    lcd.clear();
                    lcd.backlight();
                    lcd.createChar(0, clock);
                    lcd.createChar(1, raindrop);
                    delay(500);
                    if (loadState(0) == 0xFF) // EEPROM flag
                      for (int i = 0; i < 4 ; i++)
                        lastTimeRun = lastTimeRun | loadState(i + 1); // assemble 4 bytes into an ussigned long epoch timestamp
                    digitalWrite (ledPin, LOW);
                    DEBUG_PRINTLN(F("Ready..."));
                    lcd.write(byte(0));
                    lcd.setCursor(0, 1);
                    int clockCounter = 0;
                      requestTime();
                      wait(1000);
                      lcd.print(".");
                      clockCounter++;
                      if (clockCounter > 16)
                        lcd.clear();
                        wait(2000);
                    lcd.clear();
                      lcd.print(F(" Updating  "));
                      lcd.print(i);
                      bool flashIcon = false;
                      DEBUG_PRINT(i);
                      DEBUG_PRINTLN(F(" Data..."));
                      while (!receivedInitialValue)
                        flashIcon = !flashIcon;
                        request(i, V_VAR1);
                        wait(500);
                        request(i, V_VAR2);
                        wait(500);
                        request(i, V_VAR3);
                        wait(500);
                    lcd.clear();
                    updateClock();
                    updateDisplay();
                    goGetValveTimes();
                    if (buttonPushed)
                      menuTimer = millis();
                        state = ZONE_SELECT_MENU;
                        menuState = 0;
                        menuState++;
                          menuState = 0;
                      slowToggleLED ();
                      if (state != lastState)
                          wait(50);
                          send(msg1valve.setSensor(i).set(false), false);
                        lcd.clear();
                        lcd.setCursor(0,0);
                        lcd.setCursor(0,1);
                        wait(2000);
                        lastValve = -1;
                      if (lastValve != valveNumber)
                            send(msg1valve.setSensor(i).set(true), false);
                      lastValve = valveNumber;
                      fastToggleLed();
                        valveNumber = 1;
                        startMillis = millis();
                        valveNumber++;
                          state = CYCLE_COMPLETE;
                          lastValve = -1;
                          lastTimeRun = now();
                          DEBUG_PRINT(F("State = "));
                          DEBUG_PRINTLN(state);
                      fastToggleLed();
                        DEBUG_PRINT(F("Zone: "));
                        DEBUG_PRINTLN(valveNumber);
                        fastToggleLed();
                      displayMenu();
                    lastState = state;
                  void displayMenu(void)
                    static int lastSecond;
                      lcd.clear();
                      lcd.print(F("Starting"));
                      lcd.print(F("."));
                      Serial.print(".");
                    lastSecond = thisSecond;
                      if (menuState == 0)
                        valveNumber = 1;
                        state = RUN_ALL_ZONES;
                        valveNumber = menuState;
                        state = RUN_SINGLE_ZONE;
                    lastMenuState = menuState;
                  void updateRelays(int value)
                    digitalWrite(latchPin, LOW);
                    digitalWrite(latchPin, HIGH);
                      buttonPushed = true;
                  void fastToggleLed()
                      fastLedTimer = millis ();
                  void slowToggleLED ()
                      slowLedTimer = millis ();
                    bool zoneTimeUpdate = false;
                    if (message.isAck())
                      if (message.sensor == i)
                        if (message.type == V_LIGHT)
                          if (switchState == 0)
                            if (i == 0)
                              valveNumber = 1;
                              valveNumber = i;
                              DEBUG_PRINTLN(i);
                          DEBUG_PRINT(i);
                          DEBUG_PRINT(F(" = "));
                          DEBUG_PRINTLN(variable1);
                            allZoneTime[i] = variable1;
                            zoneTimeUpdate = true;
                          receivedInitialValue = true;
                          DEBUG_PRINT(i);
                          DEBUG_PRINTLN(variable2);
                            valveSoloTime[i] = variable2;
                          if (newMessage.length() == 0)
                            DEBUG_PRINTLN(i);
                          if (newMessage.length() > 16)
                            newMessage.substring(0, 16);
                          valveNickName[i] = "";
                          DEBUG_PRINT(F("Recieved new name for zone "));
                          DEBUG_PRINT(i);
                          DEBUG_PRINT(F(" and it is now called: "));
                    if (zoneTimeUpdate)
                        if (i != 0)
                          DEBUG_PRINT(F("Zone "));
                          DEBUG_PRINT(i);
                          DEBUG_PRINTLN(allZoneTime[i]);
                      recentUpdate = false;
                    static bool displayToggle = false;
                      switch (state) {
                        case STAND_BY_ALL_OFF:
                          fastClear();
                          if (displayToggle)
                            if (clockUpdating)
                              lcd.write(byte(0));
                            lcd.print(hourFormat12());
                            lcd.print(minute());
                            lcd.print(month());
                            lcd.print(day());
                            lcd.print(F("/"));
                            lcd.print(year() % 100);
                            if (clockUpdating)
                              lcd.write(byte(0));
                            lcd.setCursor(11, 1);
                            lcd.print(day(lastTimeRun));
                        case RUN_SINGLE_ZONE:
                          fastClear();
                          if (displayToggle)
                            lcd.print(F(" Zone:"));
                            lcd.print(valveNumber);
                            lcd.print(F(" Active"));
                              lcd.print("min");
                              lcd.print("sec  ");
                        case RUN_ALL_ZONES:
                          fastClear();
                          if (displayToggle)
                            lcd.print(F(" Active "));
                            lcd.print("min");
                            lcd.print("sec  ");
                        case CYCLE_COMPLETE:
                          if (displayToggle)
                            int totalTimeRan = 0;
                            lcd.print(totalTimeRan);
                            lcd.print(" Minutes   ");
                        default:
                          // what of ZONE_SELECT_MENU?
                      lastUpdateTime = millis();
                    lastDisplayState = state;
                    int lastSecond = second();
                    int lastMinute = minute();
                    int lastHour = hour();
                    setTime(newTime);
                      DEBUG_PRINT(hourFormat12());
                      DEBUG_PRINT(minute());
                      DEBUG_PRINT(month());
                      DEBUG_PRINT(F("/"));
                      DEBUG_PRINT(day());
                      DEBUG_PRINTLN(year());
                      showTime = false;
                  void fastClear()
                  void updateClock()
                      lcd.write(byte(0));
                      clockUpdating = true;
                      requestTime();
                      lastVeraGetTime = millis();
                    if (loadState(0) != 0xFF)
                      saveState(0, 0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
                    for (int i = 1; i < 5; i++)
                      saveState(5 - i, byte(theDate >> 8 * (i - 1))); // store epoch datestamp in 4 bytes of EEPROM starting in location one
                    static byte valveIndex = 1;
                    if (millis() - valveUpdateTime >= 300000UL / NUMBER_OF_VALVES)// update each valve once every 5 mins (distributes the traffic)
                      DEBUG_PRINTLN(F("Calling for Valve Data..."));
                      lcd.write(byte(1)); //lcd.write(1);
                      request(valveIndex, V_VAR1);
                      request(valveIndex, V_VAR2);
                      request(valveIndex, V_VAR3);
                      valveUpdateTime = millis();
                      valveIndex++;
                      if (valveIndex > NUMBER_OF_VALVES + 1)
                        valveIndex = 1;
                  • TON RIJNAARDT
                    TON RIJNAARDT
                    TON RIJNAARD
                    Can some one help me with a working sketch for Domoticz.
                    I have it a little working, only Domoticz give not the childs.
                    I get from the gate way the time and then is searching for the name from the zone.
                    If some one can give me a working sketch than i can see what is wrong.
                    Thanks in advance Ton
                    • TON RIJNAARDT
                      TON RIJNAARDT
                      TON RIJNAARD
                      • impertusI
                        impertusI
                        impertus
                        • GimlurG
                          GimlurG
                          Gimlur
                          wrote on last edited by Gimlur
                          #271
                          first off all : thank you for your job.
                          I'm trying to make this sketch, but i have some problems.
                          Around the line 619 with V_VAR3
                          In the sensor console i have this
                          0 MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.1.0
                          3 TSM:INIT
                          4 TSF:WUR:MS=0
                          11 TSM:INIT:TSP OK
                          13 TSF:SID:OK,ID=1
                          15 TSM:FPAR
                          51 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          144 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                          149 TSF:MSG:FPAR OK,ID=0,D=1
                          2058 TSM:FPAR:OK
                          2059 TSM:ID
                          2060 TSM:ID:OK
                          2062 TSM:UPL
                          2065 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                          2072 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                          2077 TSF:MSG:PONG RECV,HP=1
                          2080 TSM:UPL:OK
                          2081 TSM:READY:ID=1,PAR=0,DIS=1
                          2086 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                          2096 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                          2103 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=18,pt=0,l=5,sg=0,ft=0,st=OK:2.1.0
                          2111 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                          2129 TSF:MSG:READ,0-0-1,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                          2137 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=11,sg=0,ft=0,st=OK:MySprinkler
                          2146 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:2.0
                          2154 TSF:MSG:SEND,1-1-0-0,s=0,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                          2161 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                          2168 TSF:MSG:SEND,1-1-0-0,s=2,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                          2177 TSF:MSG:SEND,1-1-0-0,s=3,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                          2184 TSF:MSG:SEND,1-1-0-0,s=4,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                          2190 MCO:REG:REQ
                          2193 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                          2199 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                          2204 MCO:PIM:NODE REG=1
                          2207 MCO:BGN:STP
                          Initialisation...
                          Mise des Vannes sur Off...
                          Ready...
                          2864 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                          2882 TSF:MSG:READ,0-0-1,s=255,c=3,t=1,pt=0,l=10,sg=0:1484768469
                          Horloge mise à jour....
                          Sensor's time currently set to: 07:41pm
                          18/1/2017
                          Mercredi
                          Calling for Valve 0 Data...
                          3902 TSF:MSG:SEND,1-1-0-0,s=0,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                          3913 TSF:MSG:READ,0-0-1,s=0,c=2,t=24,pt=0,l=0,sg=0:
                          Recieved variable1 valve:0 = 0
                          4410 TSF:MSG:SEND,1-1-0-0,s=0,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                          4431 TSF:MSG:READ,0-0-1,s=0,c=2,t=25,pt=0,l=0,sg=0:
                          Recieved variable2 valve:0 = 0
                          4919 TSF:MSG:SEND,1-1-0-0,s=0,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK:
                          4939 TSF:MSG:READ,0-0-1,s=0,c=2,t=26,pt=0,l=0,sg=0:
                          No Name Recieved for zone 0
                          5428 TSF:MSG:SEND,1-1-0-0,s=0,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK:
                          5447 TSF:MSG:READ,0-0-1,s=0,c=2,t=26,pt=0,l=0,sg=0:
                          In my domoticz GW i have a node MySprinkler 2.0 with 6 childs : 0 to 4 S_LIGHT/S_BINARY, 255 REPREATER
                          It's seems that the communication between gateway and sensors failed with V_VAR3, V_VAR1 and V_VAR2 are ok.
                          Can somebody help me, please ?
                          EDIT : according to the instructions inside this skecth :
                          I can't find any Variable in my domoticz Controller, only S_LIGHT childs of Sprinkler Node :
                          Where is my mistake ?
                          • GimlurG
                            GimlurG
                            Gimlur
                            I reply to myself...
                            Like Huczas say before, you have to modify this Sketch for Domoticz. :(
                            Domoticz don't receive and manage V_VAR1, V_VAR2, V_VAR3, so you have to fixe them in code.
                            But i have another question :
                            is there a possibility to declare a supplementary sensor wich can manage this variables ?
                            • tombstoneT
                              tombstoneT
                              tombstone
                              Hi I looking to do My 1st MySensors Project an hoping to use this one I have a 3.2" Nextion. Will it be hard to use a nextion as a Display. Will there be help so I can get it working as I think the nextion Display will be good .... with weather updates and maybe senses to tell if the plants has to much water or no water. but thats down the trake...
                              • tombstoneT tombstone
                                P
                                P
                                Paulb
                                wrote on last edited by Paulb
                                #274
                                Hi, this is my first MySensors project having been inspired to jump in after finding @petewill great Youtube video. Thanks to @BulldogLowell for the code. After much perseverance I have everything working... kinda'.
                                My last persistent issue is the system halting zone 2, ie, cycle starts and ~10 seconds in the irrigation is halted. This only happens for Zone 2 (pin 1 on the shift register). This issue only occurs when either starting Zone 2 singularly from the controller or as part of the All Zones from the controller - Zone 1 will complete, Zone 2 will start then stop after ~10 seconds. Zone 2 WILL complete fine when selected manually from the pushbutton. All Zones from the pushbutton or controller will both fail.
                                I've checked and re-checked solder joints, wire connections, put the 10k external pullup resistor in and swapped out shift registers with no luck so far.
                                Would appreciate any help to resolve. Thanks.
                                I am using Domoticz and @Huczas modified sketch.
                                Arduino Multi-Zone Sprinkler Control
                                May 31, 2015
                                *** Version 2.0
                                * LED status indicator
                                PARTS LIST:
                                * Relays (8 channel)
                                * NRF24L01 Radio
                                * Arduino (I used a Pro Mini)
                                * Capacitors (10uf and .1uf)
                                * 3.3v voltage regulator
                                * Resistors (270 & 10K)
                                * Female Dupont Cables
                                * LED
                                * Push button
                                * Shift Register (SN74HC595)
                                * 18 gauge wire (for relay)
                                INSTRUCTIONS:
                                  on the serial monitor.
                                #include <Time.h>
                                #define NUMBER_OF_VALVES 5  // Change this to set your valve count up to 16.
                                #define VALVE_RESET_TIME 4500UL   // Change this (in milliseconds) for the time you need your valves to hydraulically reset and change state
                                #define RADIO_ID AUTO  // Change this to fix your Radio ID or use Auto
                                #define SKETCH_NAME "MySprinkler Domoticz"
                                #ifdef ACTIVE_LOW
                                #ifdef DEBUG_ON
                                typedef enum {
                                SprinklerStates;
                                byte menuState = 0;
                                int allZoneTime [NUMBER_OF_VALVES + 1]= {0, 1, 1, 1, 1, 1};     // Insert values in min, 0 = all zone (always 0) this is a 5 chan relay
                                int valveSoloTime [NUMBER_OF_VALVES + 1]= {0, 1, 1, 1, 1, 1};   // Insert values in min, 0 = all zone (always 0) this is a 5 chan relay
                                int valveNumber;
                                int lastValve;
                                boolean buttonPushed = false;
                                boolean showTime = true;
                                boolean clockUpdating = false;
                                boolean recentUpdate = true;
                                //extra for 1k resistor
                                //const int outputEnablePin = 6;
                                //end extra 1k
                                  SERIAL_START(115200);
                                  //internal pullup use next line
                                  //pinMode(waterButtonPin, INPUT_PULLUP);
                                  //external pullup use next line
                                  attachInterrupt(1, PushButton, RISING); //May need to change for your Arduino model
                                  //pinMode(outputEnablePin, OUTPUT);
                                  //digitalWrite (outputEnablePin, LOW);
                                  //end extra 1k
                                  //delay(5000);
                                  //delay(5000);
                                  lcd.clear();
                                  lcd.backlight();
                                  delay(500);
                                  if (gw.loadState(0) == 0xFF); // EEPROM flag
                                      lastTimeRun = lastTimeRun | gw.loadState(i + 1); // assemble 4 bytes into an ussigned long epoch timestamp
                                  gw.begin(getVariables, RADIO_ID, false); // Change 'false' to 'true' to create a Radio repeating node
                                    gw.present(i, S_LIGHT);
                                  lcd.write(byte(0));
                                    gw.requestTime(receiveTime);
                                    delay(1000);
                                    lcd.print(".");
                                    clockCounter++;
                                      lcd.clear();
                                      delay(2000);
                                  lcd.clear();
                                    lcd.print(i);
                                    boolean flashIcon = false;
                                    DEBUG_PRINT(i);
                                    while (gw.process() == false)
                                      gw.request(i, V_VAR1);
                                      delay(100);
                                      gw.request(i, V_VAR2);
                                      delay(100);
                                      gw.request(i, V_VAR3);
                                      delay(100);
                                  lcd.clear();
                                  updateClock();
                                  updateDisplay();
                                  //goGetValveTimes();
                                  if (buttonPushed)
                                      menuState = 0;
                                      menuState++;
                                        menuState = 0;
                                    slowToggleLED ();
                                        delay(50);
                                        gw.send(msg1valve.setSensor(i).set(false), false);
                                      lcd.clear();
                                      lcd.setCursor(0,0);
                                      lcd.setCursor(0,1);
                                      delay(2000);
                                      lastValve = -1;
                                          gw.send(msg1valve.setSensor(i).set(true), false);
                                    fastToggleLed();
                                      valveNumber = 1;
                                      valveNumber++;
                                        lastValve = -1;
                                    fastToggleLed();
                                      fastToggleLed();
                                  else if (state = ZONE_SELECT_MENU)
                                    displayMenu();
                                  lastState = state;
                                    lcd.clear();
                                    lcd.print(F("."));
                                    Serial.print(".");
                                    if (menuState == 0)
                                      valveNumber = 1;
                                  boolean zoneTimeUpdate = false;
                                          if (i == 0)
                                            valveNumber = 1;
                                            valveNumber = i;
                                            DEBUG_PRINTLN(i);
                                        DEBUG_PRINT(i);
                                        DEBUG_PRINT(i);
                                          DEBUG_PRINTLN(i);
                                        DEBUG_PRINT(i);
                                  if (zoneTimeUpdate)
                                      if (i != 0)
                                        DEBUG_PRINT(i);
                                  static boolean displayToggle = false;
                                    switch (state) {
                                        fastClear();
                                        if (displayToggle)
                                          if (clockUpdating)
                                            lcd.write(byte(0));
                                          lcd.print(month());
                                          lcd.print(day());
                                          lcd.print(F("/"));
                                          if (clockUpdating)
                                            lcd.write(byte(0));
                                          lcd.print(day(lastTimeRun) < 10 ? F("0") : F("/"));
                                        fastClear();
                                        if (displayToggle)
                                            lcd.print("min");
                                            lcd.print("sec  ");
                                      case RUN_ALL_ZONES:
                                        fastClear();
                                        if (displayToggle)
                                          lcd.print("min");
                                          lcd.print("sec  ");
                                        if (displayToggle)
                                  setTime(newTime);
                                    DEBUG_PRINT(day());
                                    showTime = false;
                                void fastClear()
                                void updateClock()
                                    lcd.write(byte(0));
                                  if (gw.loadState(0) != 0xFF)
                                    gw.saveState(0, 0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
                                    gw.saveState(5 - i, byte(theDate >> 8 * (i - 1))); // store epoch datestamp in 4 bytes of EEPROM starting in location one
                                    gw.request(valveIndex, V_VAR1);
                                    gw.request(valveIndex, V_VAR2);
                                    gw.request(valveIndex, V_VAR3);
                                    valveIndex++;
                                      valveIndex = 1;
                                • P Paulb
                                  May 31, 2015
                                  *** Version 2.0
                                  PARTS LIST:
                                  * NRF24L01 Radio
                                  * LED
                                  * Push button
                                  INSTRUCTIONS:
                                  #include <Time.h>
                                  #ifdef ACTIVE_LOW
                                  #ifdef DEBUG_ON
                                  typedef enum {
                                  SprinklerStates;
                                  byte menuState = 0;
                                  int valveNumber;
                                  int lastValve;
                                  //end extra 1k
                                    //end extra 1k
                                    //delay(5000);
                                    //delay(5000);
                                    lcd.clear();
                                    lcd.backlight();
                                    delay(500);
                                    lcd.write(byte(0));
                                      delay(1000);
                                      lcd.print(".");
                                      clockCounter++;
                                        lcd.clear();
                                        delay(2000);
                                    lcd.clear();
                                      lcd.print(i);
                                      DEBUG_PRINT(i);
                                        delay(100);
                                        delay(100);
                                        delay(100);
                                    lcd.clear();
                                    updateClock();
                                    updateDisplay();
                                    if (buttonPushed)
                                        menuState = 0;
                                        menuState++;
                                          menuState = 0;
                                      slowToggleLED ();
                                          delay(50);
                                        lcd.clear();
                                        lcd.setCursor(0,0);
                                        lcd.setCursor(0,1);
                                        delay(2000);
                                        lastValve = -1;
                                      fastToggleLed();
                                        valveNumber = 1;
                                        valveNumber++;
                                          lastValve = -1;
                                      fastToggleLed();
                                        fastToggleLed();
                                      displayMenu();
                                    lastState = state;
                                      lcd.clear();
                                      lcd.print(F("."));
                                      Serial.print(".");
                                      if (menuState == 0)
                                        valveNumber = 1;
                                            if (i == 0)
                                              valveNumber = 1;
                                              valveNumber = i;
                                              DEBUG_PRINTLN(i);
                                          DEBUG_PRINT(i);
                                          DEBUG_PRINT(i);
                                            DEBUG_PRINTLN(i);
                                          DEBUG_PRINT(i);
                                    if (zoneTimeUpdate)
                                        if (i != 0)
                                          DEBUG_PRINT(i);
                                      switch (state) {
                                          fastClear();
                                          if (displayToggle)
                                            if (clockUpdating)
                                              lcd.write(byte(0));
                                            lcd.print(month());
                                            lcd.print(day());
                                            lcd.print(F("/"));
                                            if (clockUpdating)
                                              lcd.write(byte(0));
                                          fastClear();
                                          if (displayToggle)
                                              lcd.print("min");
                                              lcd.print("sec  ");
                                        case RUN_ALL_ZONES:
                                          fastClear();
                                          if (displayToggle)
                                            lcd.print("min");
                                            lcd.print("sec  ");
                                          if (displayToggle)
                                    setTime(newTime);
                                      DEBUG_PRINT(day());
                                      showTime = false;
                                  void fastClear()
                                  void updateClock()
                                      lcd.write(byte(0));
                                      valveIndex++;
                                        valveIndex = 1;
                                  P
                                  P
                                  Paulb
                                  @Paulb After more troubleshooting I finally narrowed down the problem to an external factor. It seems the old desk lamp I was using on my workbench interfered with the radio signal. It is a fluorescent tube which I understand can be quite 'noisy'. Replicated the conditions several times, stopped using the lamp - presto! everything works as it should.
                                  • P
                                    P
                                    pettib
                                    Do anyone has a working solution to connect this project to a main valve who has to open when running the zones ?
                                      Do you mean that you need to open a main valve while any of the others are open and close it whenever the others are all closed?
                                        P
                                        P
                                        pettib
                                        @gohan exactly what I meant.
                                        dbemowskD 1 Reply Last reply
                                        • P pettib
                                          dbemowskD
                                          dbemowskD
                                          @pettib I started this project last summer but have not fully finished it. My setup has a pump start relay, which is essentially the same as a main valve control.
                                          One way to do this is to connect one more data line to a relay and in your sketch, change it so that any time a zone is triggered, turn on the main valve data line. Shouldn't be that difficult to code.
                                          I was originally planning to do this with hardware where I had diodes from each output of the shift register feeding to one central point which would be the main valve relay, but I had some trouble with that. Could have been that I was doing something wrong. None the less, the approach above should work without issue if programmed correctly.
