  2. Announcements
  • engyE engy
    @gohan I'm sorry, MQTT is not supported by OpenHab MySensors binding. Ethernet Gateway is not supported on Raspberry PI.
    marceloaqno
    Code Contributor
    wrote on last edited by marceloaqno
    #396
    @engy OpenHab2 supports mysensors serial and ethernet gateways:
    https://github.com/tobof/openhab2-addons/wiki
    Maybe the build guide may have given you that impression, but ethernet Gateway is supported on Raspberry PI:
    engyE 1 Reply Last reply
      @keldandorin just add a capacitor between vcc and gnd on the radio module as I suggested above.
      keldandorinK
      keldandorinK
      keldandorin
      @gohan Solved the problem with radio...Thx
      • M marceloaqno
        engyE
        engyE
        engy
        Thank you guys for prompt reaction. Indeed, Ethernet GW works flawlessly!
        • T
          TommiP
          Hi
          Is anyone else having this same problem on Rpi3?: Gateway works ok after "sudo make install" with openHAB. With "sudo ./bin/mysgw -d" I can get debug log visible and log works ok.
          But if I run "sudo systemctl enable mysgw.service" after "sudo make install", debug log start showing endlessly "mysgw: accept: Bad file descriptor". So debug log function gets destroyed and it can't be used anymore. I have made several clean installations and every time this same happens.
          Br
          Tommi
          • T TommiP
            Hi
            Br
            Tommi
            marceloaqno
            Code Contributor
            @TommiP What I think is happening is that you are running two instances of the gateway.
            If you need to get the debug logs, first stop the mysgw service:
            sudo systemctl stop mysgw.service
            • M marceloaqno
              TommiP
              @marceloaqno
              Ok, now I understand what happened, thanks.
              • R
                R
                romeo01
                Re: 💬 Building a Raspberry Pi Gateway
                Silly questions, I'm a little bit confuse.
                I have a serial Gateway running with arduino nano + nrf24 and a raspberry pi with domoticz on board. The link between domoticz & Gateway is done via USB <=> serial port (/dev/ttyUSB0). This setup runs like a charm.
                Now, I would like to access to my Gateway via the network because I would like to use "Over The Air " functionnality with MYSController.
                Can I install MySensors Gateway on the raspberry and keep the arduino + nrf24 connected via usb ?? For the moment, I can not use GPIO port.
                If for some reason you can't use the GPIO pins of the Raspberry Pi, you could connect the radio to a arduino with the GatewaySerial sketch and feed the pi through a serial port:
                ./configure --my-gateway=serial --my-serial-port=/dev/ttyUSB0 --my-serial-baudrate=115200
                [OK] machine detected: SoC=BCM2836, Type=RPi3, CPU=armv7l.
                [OK] SPI driver detected:BCM.
                [OK] Finished.
                make
                ./bin/mysgw -d
                mysgw: Starting gateway...
                mysgw: TSF:LRT:OK
                mysgw: TSM:INIT
                mysgw: TSF:WUR:MS=0
                mysgw: !TSM:INIT:TSP FAIL
                mysgw: TSM:FAIL:CNT=1
                mysgw: TSM:FAIL:PDT
                mysgw: TSM:FAIL:RE-INIT
                mysgw: TSM:INIT
                mysgw: TSM:FAIL:CNT=2
                mysgw: TSM:FAIL:PDT
                Where is my mistake ??
                Again, Can I install MySensors Gateway on the raspberry and keep the arduino + nrf24 connected via usb or I must connected the nrf24 directly with GPIO on the Rasp ??
                Thanks in advance for your reply.
                Romeo
                gohanG 1 Reply Last reply
                • R romeo01
                  [OK] Finished.
                  make
                  ./bin/mysgw -d
                  mysgw: TSF:LRT:OK
                  mysgw: TSM:INIT
                  mysgw: TSF:WUR:MS=0
                  mysgw: TSM:FAIL:PDT
                  mysgw: TSM:INIT
                  mysgw: TSM:FAIL:PDT
                  Romeo
                  @romeo01 I think that connecting nrf24 directly to arduino and compile mysgw as ethernet gateway is the cleanest solution (I have it as MQTT and it is working fine, but ethernet is the same). Keep in mind that you'd better use one of those adapters 5v-3.3v for nrf24 chips + capacitor because the 3v output of raspberry isn't very suited for the task.
                  • R
                    R
                    romeo01
                    Thanks gohan for fast answer.
                    Arduino nano + nrf24 are already connected together. Hardware is already built.
                    How access to the gatway installed on the raspberry via the network and use my arduino + nrf24 connected via usb/serial to the raspberry ??
                    Sorry but I do not understand what you mean
                    ...compile mysgw as ethernet gateway is the cleanest solution...
                    If I configure on this way
                    ./configure --my-gateway=ethernet --my-port=5003
                    I could access to my Gateway via network an the Gateway will use the arduino + nrf24l via usb/serial ??
                    That's why I say I'm confuse.
                    --my-gateway=serial
                    What is this option ? The link between gateway and nrf24 or the way to access to the Gateway ??
                    • R
                      R
                      romeo01
                      In summary,
                      Is the Gateway (software) installed on the raspberry, is able to manage the nrf24 connected on arduino via USB/Serial port ??
                        no, I don't think so. If you want to manage nodes over network you need to make an ethernet gateway (could be a UNO with w5100 shield, an esp8266 or mysgw compiled on raspberry)
                        • R
                          R
                          romeo01
                          nrf24 connected to a arduino nano and plugged to the raspberry over the usb/serial cable is not considered as a serial device ?
                          --my-gateway=serial
                          That's exactly what I need, but how to do ??
                          Serial port /dev/ttyUSB0 is ok, because I use this with domoticz and it'running good.
                          My initial question is how to use my old gatway (arduino + nrf24) with the gateway compiled on the raspberry over the usb/serial cable ?
                            The serial gateway on the raspberry does what your nano is doing and you can't have gateways talking to each other. Maybe you could look at mycontroller and see if can manage nodes the way you want.
                            R 1 Reply Last reply
                            • dirkcD
                              dirkcD
                              dirkc
                              wrote on last edited by dirkc
                              #409
                              When talking about this Raspberry Pi Gateway, I suppose, that its just connecting the NFR24L01+ to the Raspberry Pi GPIO and run
                              ./bin/mysgw -d
                              right? On my Pi it does not work this way, maybe the NFR24L01+ is not ok. Instead I am running an external esp-wifi-gateway, but a direct gateway seems the better solution to me.
                              So did I get it right, that I can use a NFR24L01+ connected to the Raspberry PI GPIO without any external gateway? If so, what are the parameters for building the mysgw daemon? I tried this one:
                              ./configure --spi-driver=SPIDEV --spi-spidev-device=/dev/spidev0.0
                              update: as in https://www.mysensors.org/view/180#wiring
                              22 – CE
                              24 – CSN/CS
                              23 – SCK
                              19 – MOSI
                              21 – MISO
                              SPI is activated:
                              $ls /dev/spidev*
                              And this is the result, when building it with the settings mentioned above. (Raspberry Pi 3, jessie 4.9.13-v7+)
                              $ sudo ./bin/mysgw -d
                              mysgw: TSM:INIT
                              mysgw: TSF:WUR:MS=0
                              mysgw: TSM:FAIL:PDT
                              mysgw: TSM:INIT
                              mysgw: TSM:FAIL:PDT
                              mysgw: TSM:INIT
                              mysgw: TSM:FAIL:CNT=3
                              mysgw: TSM:FAIL:PDT
                              mysgw: TSM:INIT
                              mysgw: TSM:FAIL:CNT=4
                              mysgw: TSM:FAIL:PDT
                              And can someone show how to bind this gateway into FHEM? As said, today I am running an esp-wifi-gateay.
                              Thanks in advance for any support...
                              Controller: Home Assistant & FHEM - Gateway: ESP8266wifi - MySensors: 2.3.2 (nRF24)
                              M gohanG 2 Replies Last reply
                                R
                                R
                                romeo01
                                @gohan
                                With the serial Gateway on the raspberry; how is connected the nfr24 ??
                                If usb/serial port is no possible, which serial port to use ?
                                  keldandorinK
                                  keldandorinK
                                  keldandorin
                                  @gohan Been trying to find my old post to tell you all how it got with my rpi and nodes that did not register. I bougt some voltage regulators LM350. used the 5v output insted of 3.3 V but still no luck to get node to register. when messauring volatage when GW send awnser it drops way below 3.3v. I think voltage output from rpi just is to bad. So I bought a nodemcu for GW instead and it works like a sharm :)
                                  • R romeo01
                                    @gohan
                                    marceloaqno
                                    Code Contributor
                                    @romeo01 You have to connect the nrf24 to the GPIO if you want to use it with the RPi, the information on the wiki was wrong, sorry about that.
                                    gohanG R 2 Replies Last reply
                                    • M marceloaqno
                                      @marceloaqno he said he can't connect nrf24 chip on the rpi, so that's why he is struggling
                                      • dirkcD dirkc
                                        ./bin/mysgw -d
                                        22 – CE
                                        24 – CSN/CS
                                        23 – SCK
                                        19 – MOSI
                                        21 – MISO
                                        SPI is activated:
                                        $ls /dev/spidev*
                                        mysgw: TSM:INIT
                                        mysgw: TSF:WUR:MS=0
                                        mysgw: TSM:FAIL:PDT
                                        mysgw: TSM:INIT
                                        mysgw: TSM:FAIL:PDT
                                        mysgw: TSM:INIT
                                        mysgw: TSM:FAIL:PDT
                                        mysgw: TSM:INIT
                                        mysgw: TSM:FAIL:PDT
                                        marceloaqno
                                        Code Contributor
                                        @dirkc Try to connect your module to the SPI0 (https://www.mysensors.org/view/180#wiring).
                                        You only need to enable the SPIDEV if you want to use the SPI1.
                                        • dirkcD dirkc
                                          ./bin/mysgw -d
                                          22 – CE
                                          24 – CSN/CS
                                          23 – SCK
                                          19 – MOSI
                                          21 – MISO
                                          SPI is activated:
                                          $ls /dev/spidev*
                                          mysgw: TSM:INIT
                                          mysgw: TSF:WUR:MS=0
                                          mysgw: TSM:FAIL:PDT
                                          mysgw: TSM:INIT
                                          mysgw: TSM:FAIL:PDT
                                          mysgw: TSM:INIT
                                          mysgw: TSM:FAIL:PDT
                                          mysgw: TSM:INIT
                                          mysgw: TSM:FAIL:PDT
                                          @dirkc I don't know where you got those pin numbers but they don't look like the ones on the guide. In addition you don't have to use spi driver. The PA version of nrf24 are quite a pain to get them working, so I suggest you first test with regular modules and then upgrade to PA
