  2. Announcements
  3. ๐Ÿ’ฌ Building a Raspberry Pi Gateway
    no, I don't think so. If you want to manage nodes over network you need to make an ethernet gateway (could be a UNO with w5100 shield, an esp8266 or mysgw compiled on raspberry)
    • R
      R
      romeo01
      nrf24 connected to a arduino nano and plugged to the raspberry over the usb/serial cable is not considered as a serial device ?
      What is this option ?
      --my-gateway=serial
      If for some reason you can't use the GPIO pins of the Raspberry Pi, you could connect the radio to a arduino with the GatewaySerial sketch and feed the pi through a serial port:
      That's exactly what I need, but how to do ??
      ./configure --my-gateway=serial --my-serial-port=/dev/ttyUSB0 --my-serial-baudrate=115200
      Serial port /dev/ttyUSB0 is ok, because I use this with domoticz and it'running good.
      My initial question is how to use my old gatway (arduino + nrf24) with the gateway compiled on the raspberry over the usb/serial cable ?
      I can not use GPIO port.
        The serial gateway on the raspberry does what your nano is doing and you can't have gateways talking to each other. Maybe you could look at mycontroller and see if can manage nodes the way you want.
        R 1 Reply Last reply
        • dirkcD
          dirkcD
          dirkc
          wrote on last edited by dirkc
          #409
          When talking about this Raspberry Pi Gateway, I suppose, that its just connecting the NFR24L01+ to the Raspberry Pi GPIO and run
          ./bin/mysgw -d
          right? On my Pi it does not work this way, maybe the NFR24L01+ is not ok. Instead I am running an external esp-wifi-gateway, but a direct gateway seems the better solution to me.
          So did I get it right, that I can use a NFR24L01+ connected to the Raspberry PI GPIO without any external gateway? If so, what are the parameters for building the mysgw daemon? I tried this one:
          ./configure --spi-driver=SPIDEV --spi-spidev-device=/dev/spidev0.0
          update: as in https://www.mysensors.org/view/180#wiring
          22 โ€“ CE
          24 โ€“ CSN/CS
          23 โ€“ SCK
          19 โ€“ MOSI
          21 โ€“ MISO
          SPI is activated:
          $ls /dev/spidev*
          And this is the result, when building it with the settings mentioned above. (Raspberry Pi 3, jessie 4.9.13-v7+)
          $ sudo ./bin/mysgw -d
          mysgw: Starting gateway...
          mysgw: TSM:INIT
          mysgw: TSF:WUR:MS=0
          mysgw: !TSM:INIT:TSP FAIL
          mysgw: TSM:FAIL:CNT=1
          mysgw: TSM:FAIL:PDT
          mysgw: TSM:FAIL:RE-INIT
          mysgw: TSM:INIT
          mysgw: TSM:FAIL:CNT=2
          mysgw: TSM:FAIL:PDT
          mysgw: TSM:INIT
          mysgw: TSM:FAIL:CNT=3
          mysgw: TSM:FAIL:PDT
          mysgw: TSM:INIT
          mysgw: TSM:FAIL:CNT=4
          mysgw: TSM:FAIL:PDT
          And can someone show how to bind this gateway into FHEM? As said, today I am running an esp-wifi-gateay.
          Thanks in advance for any support...
          Controller: Home Assistant & FHEM - Gateway: ESP8266wifi - MySensors: 2.3.2 (nRF24)
          M gohanG 2 Replies Last reply
            R
            R
            romeo01
            @gohan
            With the serial Gateway on the raspberry; how is connected the nfr24 ??
            If usb/serial port is no possible, which serial port to use ?
              @keldandorin just add a capacitor between vcc and gnd on the radio module as I suggested above.
              keldandorinK
              keldandorinK
              keldandorin
              @gohan Been trying to find my old post to tell you all how it got with my rpi and nodes that did not register. I bougt some voltage regulators LM350. used the 5v output insted of 3.3 V but still no luck to get node to register. when messauring volatage when GW send awnser it drops way below 3.3v. I think voltage output from rpi just is to bad. So I bought a nodemcu for GW instead and it works like a sharm :)
              • R romeo01
                @gohan
                marceloaqno
                Code Contributor
                @romeo01 You have to connect the nrf24 to the GPIO if you want to use it with the RPi, the information on the wiki was wrong, sorry about that.
                gohanG R 2 Replies Last reply
                • M marceloaqno
                  @marceloaqno he said he can't connect nrf24 chip on the rpi, so that's why he is struggling
                  • dirkcD dirkc
                    ./bin/mysgw -d
                    22 โ€“ CE
                    24 โ€“ CSN/CS
                    23 โ€“ SCK
                    19 โ€“ MOSI
                    21 โ€“ MISO
                    SPI is activated:
                    $ls /dev/spidev*
                    mysgw: TSM:INIT
                    mysgw: TSF:WUR:MS=0
                    mysgw: TSM:FAIL:PDT
                    mysgw: TSM:INIT
                    mysgw: TSM:FAIL:PDT
                    mysgw: TSM:INIT
                    mysgw: TSM:FAIL:PDT
                    mysgw: TSM:INIT
                    mysgw: TSM:FAIL:PDT
                    marceloaqno
                    Code Contributor
                    @dirkc Try to connect your module to the SPI0 (https://www.mysensors.org/view/180#wiring).
                    You only need to enable the SPIDEV if you want to use the SPI1.
                    • dirkcD dirkc
                      ./bin/mysgw -d
                      22 โ€“ CE
                      24 โ€“ CSN/CS
                      23 โ€“ SCK
                      19 โ€“ MOSI
                      21 โ€“ MISO
                      SPI is activated:
                      $ls /dev/spidev*
                      mysgw: TSM:INIT
                      mysgw: TSF:WUR:MS=0
                      mysgw: TSM:FAIL:PDT
                      mysgw: TSM:INIT
                      mysgw: TSM:FAIL:PDT
                      mysgw: TSM:INIT
                      mysgw: TSM:FAIL:PDT
                      mysgw: TSM:INIT
                      mysgw: TSM:FAIL:PDT
                      @dirkc I don't know where you got those pin numbers but they don't look like the ones on the guide. In addition you don't have to use spi driver. The PA version of nrf24 are quite a pain to get them working, so I suggest you first test with regular modules and then upgrade to PA
                      • dirkcD
                        dirkcD
                        dirkc
                        @gohan, @marceloaqno : sorry, I corrected the "typo", the NRF was already connected as shown in https://www.mysensors.org/view/180#wiring. I double checked that again.
                        What is the correct setup for ./configure ?
                        • M marceloaqno
                          R
                          R
                          romeo01
                          @marceloaqno
                          Thanks marceloagno, the answer is clear.
                          Keep up the great work !
                          • dirkcD dirkc
                            marceloaqno
                            Code Contributor
                            @dirkc The default settings for ./configure is to use the nrf24 module connected in the same way as shown in the guide and as an ethernet gateway.
                            dirkcD 1 Reply Last reply
                            • L
                              L
                              lshield
                              wrote on last edited by lshield
                              #419
                              I'm having issues with the LED setup as shown on the page. The LEDs are just constantly on even though everything looks like it's setup just like the picture. I'm new at this so I could be doing something stupid.
                              • M marceloaqno
                                dirkcD
                                dirkcD
                                dirkc
                                @marceloaqno ok, thanks, I will change the radio.
                                  marceloaqno
                                  Code Contributor
                                  Support for RFM69 was added to the development branch (finally!).
                                  jirmJ 1 Reply Last reply
                                  • M marceloaqno
                                    jirmJ
                                    jirmJ
                                    jirm
                                    @marceloaqno
                                    Iยดm really happy ear that !
                                    RFM69 is one of best RF transceivers in these days for IoT.
                                    So good news I believe for Mysensors community.
                                    You know if are any hope that RFM69 will be added too to OPI boards support mysgw development ?
                                    Congratulations for that great work !
                                    • jirmJ jirm
                                      @marceloaqno
                                      marceloaqno
                                      Code Contributor
                                      @jirm Support for RFM69 also applies to the OrangePi :wink:
                                      • M marceloaqno
                                        jirmJ
                                        jirmJ
                                        jirm
                                        wrote on last edited by jirm
                                        #424
                                        @marceloaqno
                                        Awesome !!!
                                        Thank you so much.
                                        Best regards
                                        • F
                                          F
                                          ftw64
                                          When I configure "MY_RFM69_MAX_POWER_LEVEL_DBM" in MyConfig.h, compiling fails.
                                          Perhaps you should change the code in ./drivers/RFM69/new/RFM69_new.h from:
                                          #define RFM69_MAX_POWER_LEVEL_DBM MY_RFM69_MAX_POWER_LEVEL_DBM //!< MY_RFM69_MAX_POWER_LEVEL_DBM
                                          to:
                                          #define RFM69_MAX_POWER_LEVEL_DBM ((rfm69_powerlevel_t)MY_RFM69_MAX_POWER_LEVEL_DBM) //!< MY_RFM69_MAX_POWER_LEVEL_DBM
                                          With your input, this post could be even better ๐Ÿ’—
