  2. Announcements
  • T TommiP
    Hi
    Is anyone else having this same problem on Rpi3?: Gateway works ok after "sudo make install" with openHAB. With "sudo ./bin/mysgw -d" I can get debug log visible and log works ok.
    But if I run "sudo systemctl enable mysgw.service" after "sudo make install", debug log start showing endlessly "mysgw: accept: Bad file descriptor". So debug log function gets destroyed and it can't be used anymore. I have made several clean installations and every time this same happens.
    Br
    Tommi
    marceloaqno
    Code Contributor
    @TommiP What I think is happening is that you are running two instances of the gateway.
    If you need to get the debug logs, first stop the mysgw service:
    sudo systemctl stop mysgw.service
    • M marceloaqno
      TommiP
      @marceloaqno
      Ok, now I understand what happened, thanks.
      • R
        R
        romeo01
        Re: 💬 Building a Raspberry Pi Gateway
        Silly questions, I'm a little bit confuse.
        I have a serial Gateway running with arduino nano + nrf24 and a raspberry pi with domoticz on board. The link between domoticz & Gateway is done via USB <=> serial port (/dev/ttyUSB0). This setup runs like a charm.
        Now, I would like to access to my Gateway via the network because I would like to use "Over The Air " functionnality with MYSController.
        Can I install MySensors Gateway on the raspberry and keep the arduino + nrf24 connected via usb ?? For the moment, I can not use GPIO port.
        If for some reason you can't use the GPIO pins of the Raspberry Pi, you could connect the radio to a arduino with the GatewaySerial sketch and feed the pi through a serial port:
        ./configure --my-gateway=serial --my-serial-port=/dev/ttyUSB0 --my-serial-baudrate=115200
        [OK] machine detected: SoC=BCM2836, Type=RPi3, CPU=armv7l.
        [OK] SPI driver detected:BCM.
        [OK] Finished.
        make
        ./bin/mysgw -d
        mysgw: Starting gateway...
        mysgw: TSF:LRT:OK
        mysgw: TSM:INIT
        mysgw: TSF:WUR:MS=0
        mysgw: !TSM:INIT:TSP FAIL
        mysgw: TSM:FAIL:CNT=1
        mysgw: TSM:FAIL:PDT
        mysgw: TSM:FAIL:RE-INIT
        mysgw: TSM:INIT
        mysgw: TSM:FAIL:CNT=2
        mysgw: TSM:FAIL:PDT
        Where is my mistake ??
        Again, Can I install MySensors Gateway on the raspberry and keep the arduino + nrf24 connected via usb or I must connected the nrf24 directly with GPIO on the Rasp ??
        Thanks in advance for your reply.
        Romeo
        gohanG 1 Reply Last reply
        • R romeo01
          [OK] Finished.
          make
          ./bin/mysgw -d
          mysgw: TSF:LRT:OK
          mysgw: TSM:INIT
          mysgw: TSF:WUR:MS=0
          mysgw: TSM:FAIL:PDT
          mysgw: TSM:INIT
          mysgw: TSM:FAIL:PDT
          Romeo
          @romeo01 I think that connecting nrf24 directly to arduino and compile mysgw as ethernet gateway is the cleanest solution (I have it as MQTT and it is working fine, but ethernet is the same). Keep in mind that you'd better use one of those adapters 5v-3.3v for nrf24 chips + capacitor because the 3v output of raspberry isn't very suited for the task.
          • R
            R
            romeo01
            Thanks gohan for fast answer.
            Arduino nano + nrf24 are already connected together. Hardware is already built.
            How access to the gatway installed on the raspberry via the network and use my arduino + nrf24 connected via usb/serial to the raspberry ??
            Sorry but I do not understand what you mean
            ...compile mysgw as ethernet gateway is the cleanest solution...
            If I configure on this way
            ./configure --my-gateway=ethernet --my-port=5003
            I could access to my Gateway via network an the Gateway will use the arduino + nrf24l via usb/serial ??
            That's why I say I'm confuse.
            --my-gateway=serial
            What is this option ? The link between gateway and nrf24 or the way to access to the Gateway ??
            • R
              R
              romeo01
              In summary,
              Is the Gateway (software) installed on the raspberry, is able to manage the nrf24 connected on arduino via USB/Serial port ??
                no, I don't think so. If you want to manage nodes over network you need to make an ethernet gateway (could be a UNO with w5100 shield, an esp8266 or mysgw compiled on raspberry)
                • R
                  R
                  romeo01
                  nrf24 connected to a arduino nano and plugged to the raspberry over the usb/serial cable is not considered as a serial device ?
                  --my-gateway=serial
                  That's exactly what I need, but how to do ??
                  Serial port /dev/ttyUSB0 is ok, because I use this with domoticz and it'running good.
                  My initial question is how to use my old gatway (arduino + nrf24) with the gateway compiled on the raspberry over the usb/serial cable ?
                    The serial gateway on the raspberry does what your nano is doing and you can't have gateways talking to each other. Maybe you could look at mycontroller and see if can manage nodes the way you want.
                    R 1 Reply Last reply
                    • dirkcD
                      dirkcD
                      dirkc
                      wrote on last edited by dirkc
                      #409
                      When talking about this Raspberry Pi Gateway, I suppose, that its just connecting the NFR24L01+ to the Raspberry Pi GPIO and run
                      ./bin/mysgw -d
                      right? On my Pi it does not work this way, maybe the NFR24L01+ is not ok. Instead I am running an external esp-wifi-gateway, but a direct gateway seems the better solution to me.
                      So did I get it right, that I can use a NFR24L01+ connected to the Raspberry PI GPIO without any external gateway? If so, what are the parameters for building the mysgw daemon? I tried this one:
                      ./configure --spi-driver=SPIDEV --spi-spidev-device=/dev/spidev0.0
                      update: as in https://www.mysensors.org/view/180#wiring
                      22 – CE
                      24 – CSN/CS
                      23 – SCK
                      19 – MOSI
                      21 – MISO
                      SPI is activated:
                      $ls /dev/spidev*
                      And this is the result, when building it with the settings mentioned above. (Raspberry Pi 3, jessie 4.9.13-v7+)
                      $ sudo ./bin/mysgw -d
                      mysgw: TSM:INIT
                      mysgw: TSF:WUR:MS=0
                      mysgw: TSM:FAIL:PDT
                      mysgw: TSM:INIT
                      mysgw: TSM:FAIL:PDT
                      mysgw: TSM:INIT
                      mysgw: TSM:FAIL:CNT=3
                      mysgw: TSM:FAIL:PDT
                      mysgw: TSM:INIT
                      mysgw: TSM:FAIL:CNT=4
                      mysgw: TSM:FAIL:PDT
                      And can someone show how to bind this gateway into FHEM? As said, today I am running an esp-wifi-gateay.
                      Thanks in advance for any support...
                      Controller: Home Assistant & FHEM - Gateway: ESP8266wifi - MySensors: 2.3.2 (nRF24)
                      M gohanG 2 Replies Last reply
                        R
                        R
                        romeo01
                        @gohan
                        With the serial Gateway on the raspberry; how is connected the nfr24 ??
                        If usb/serial port is no possible, which serial port to use ?
                          @keldandorin just add a capacitor between vcc and gnd on the radio module as I suggested above.
                          keldandorinK
                          keldandorinK
                          keldandorin
                          @gohan Been trying to find my old post to tell you all how it got with my rpi and nodes that did not register. I bougt some voltage regulators LM350. used the 5v output insted of 3.3 V but still no luck to get node to register. when messauring volatage when GW send awnser it drops way below 3.3v. I think voltage output from rpi just is to bad. So I bought a nodemcu for GW instead and it works like a sharm :)
                          • R romeo01
                            @gohan
                            marceloaqno
                            Code Contributor
                            @romeo01 You have to connect the nrf24 to the GPIO if you want to use it with the RPi, the information on the wiki was wrong, sorry about that.
                            gohanG R 2 Replies Last reply
                            • M marceloaqno
                              @marceloaqno he said he can't connect nrf24 chip on the rpi, so that's why he is struggling
                              • dirkcD dirkc
                                ./bin/mysgw -d
                                22 – CE
                                24 – CSN/CS
                                23 – SCK
                                19 – MOSI
                                21 – MISO
                                SPI is activated:
                                $ls /dev/spidev*
                                mysgw: TSM:INIT
                                mysgw: TSF:WUR:MS=0
                                mysgw: TSM:FAIL:PDT
                                mysgw: TSM:INIT
                                mysgw: TSM:FAIL:PDT
                                mysgw: TSM:INIT
                                mysgw: TSM:FAIL:PDT
                                mysgw: TSM:INIT
                                mysgw: TSM:FAIL:PDT
                                marceloaqno
                                Code Contributor
                                @dirkc Try to connect your module to the SPI0 (https://www.mysensors.org/view/180#wiring).
                                You only need to enable the SPIDEV if you want to use the SPI1.
                                • dirkcD dirkc
                                  ./bin/mysgw -d
                                  22 – CE
                                  24 – CSN/CS
                                  23 – SCK
                                  19 – MOSI
                                  21 – MISO
                                  SPI is activated:
                                  $ls /dev/spidev*
                                  mysgw: TSM:INIT
                                  mysgw: TSF:WUR:MS=0
                                  mysgw: TSM:FAIL:PDT
                                  mysgw: TSM:INIT
                                  mysgw: TSM:FAIL:PDT
                                  mysgw: TSM:INIT
                                  mysgw: TSM:FAIL:PDT
                                  mysgw: TSM:INIT
                                  mysgw: TSM:FAIL:PDT
                                  @dirkc I don't know where you got those pin numbers but they don't look like the ones on the guide. In addition you don't have to use spi driver. The PA version of nrf24 are quite a pain to get them working, so I suggest you first test with regular modules and then upgrade to PA
                                  • dirkcD
                                    dirkcD
                                    dirkc
                                    @gohan, @marceloaqno : sorry, I corrected the "typo", the NRF was already connected as shown in https://www.mysensors.org/view/180#wiring. I double checked that again.
                                    What is the correct setup for ./configure ?
                                    • M marceloaqno
                                      R
                                      R
                                      romeo01
                                      @marceloaqno
                                      Thanks marceloagno, the answer is clear.
                                      Keep up the great work !
                                      • dirkcD dirkc
                                        marceloaqno
                                        Code Contributor
                                        @dirkc The default settings for ./configure is to use the nrf24 module connected in the same way as shown in the guide and as an ethernet gateway.
                                        dirkcD 1 Reply Last reply
                                        • L
                                          L
                                          lshield
                                          wrote on last edited by lshield
                                          #419
                                          I'm having issues with the LED setup as shown on the page. The LEDs are just constantly on even though everything looks like it's setup just like the picture. I'm new at this so I could be doing something stupid.
