  3. NodeManager
  4. NodeManager: plugin for a rapid development of battery-powered sensors
223 Posts 23 Posters 125.6k Views 26 Watching
  • U user2684
    @mar.conte said in NodeManager: plugin for a rapid development of battery-powered sensors:
    all ok now is s_motion but is ever tripped high!!!why?
    Default behavior is triggering on RISING but this can be changed with setMode() and setInitial(). Also ensure you are using pin 3 on a pro mini to have a valid interrupt. What is the behavior you are experiencing?
    mar.conteM
    mar.conteM
    mar.conte
    @user2684
    for istance Sensorswitch what is code?
    M.C.
    • U user2684
      mar.conteM
      mar.conteM
      mar.conte
      @user2684
      it's ok this code?
      NodeManager nodeManager;
      SensorSwitch swiTch(1,3);
      // before
      void before() {
        Serial.begin(MY_BAUD_RATE);
         * Register below your sensors
      swiTch.setMode(0);
      swiTch.setInitial(0);
      swiTch.setTriggerTime(4000);
        nodeManager.setSleep(SLEEP,60,MINUTES);
        nodeManager.registerSensor(SENSOR_MOTION,3);```
      M.C.
      U 1 Reply Last reply
      • mar.conteM mar.conte
        @user2684
        it's ok this code?
        // before
        void before() {
        swiTch.setMode(0);
        U
        U
        user2684
        @mar.conte sorry I'm not sure I have understood what you want to achieve. Do you have a motion sensor which is HIGH by default and when triggers goes LOW? Is this what you need?
        mar.conteM 1 Reply Last reply
        • U user2684
          mar.conteM
          mar.conteM
          mar.conte
          @user2684
          Hello, I have a simple pir hcr501 that normally does not send output to pin 3 (so low) but when there is movement becomes HIGH, then my CPU goes to sleep for 60 minutes; the hardware is well configured because this setup I used it with the official mysensors sketches for pir motion; I do not understand why the domoticz controller is always the pir HIGH and does not go into sleep the MCU, thanks
          M.C.
            @user2684
            U
            U
            user2684
            Ok, so you don't need any customization in NodeManager since this is meeting the default behavior (LOW by default and triggering on HIGH), sorry for the wrong advice. Let's have a look at the sensor's logs then to see why the node is waking up continuously.
            • U user2684
              mar.conteM
              mar.conteM
              mar.conte
              @user2684
              @gohan
              node
              40 MCO:BGN:BFR
              REG I=1 P=3 P=6 T=0
              NodeManager v1.4
              INT1 M=255
              INT2 M=255
              59 TSM:INIT
              135 TSF:WUR:MS=0
              155 TSM:INIT:TSP OK
              176 TSM:INIT:STATID=100
              202 TSF:SID:OK,ID=100
              225 TSM:FPAR
              370 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              2244 TSF:MSG:READ,0-0-100,s=255,c=3,t=8,pt=1,l=1,sg=0:0
              2301 TSF:MSG:FPAR OK,ID=0,D=1
              2447 TSM:FPAR:OK
              2463 TSM:ID
              2478 TSM:ID:OK
              2492 TSM:UPL
              2639 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
              3678 TSF:MSG:READ,0-0-100,s=255,c=3,t=25,pt=1,l=1,sg=0:1
              3737 TSF:MSG:PONG RECV,HP=1
              3768 TSM:UPL:OK
              3784 TSM:READY:ID=100,PAR=0,DIS=1
              3883 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
              4003 TSF:MSG:READ,0-0-100,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              4202 !TSF:MSG:SEND,100-100-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=NACK:2.1.1
              4415 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=NACK:0
              6733 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=2,st=NACK:NodeManagerTemplate
              6928 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=3,st=OK:1.0
              RADIO OK
              PRES I=200, T=23
              7137 !TSF:MSG:SEND,100-100-0-0,s=200,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=NACK:
              PRES I=201, T=30
              7321 TSF:MSG:SEND,100-100-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=1,st=OK:
              BATT V=3.25 P=93
              SEND D=0 I=201 C=0 T=38 S= I=0 F=3.25
              7469 !MCO:SND:NODE NOT REG
              7587 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:93
              PRES I=1 T=6
              7794 !TSF:MSG:SEND,100-100-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=NACK:
              READY
              7868 MCO:REG:REQ
              7933 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
              9019 TSF:MSG:READ,0-0-100,s=255,c=3,t=27,pt=1,l=1,sg=0:1
              9078 MCO:PIM:NODE REG=1
              9105 MCO:BGN:STP
              MY I=100 M=1
              9123 MCO:BGN:INIT OK,TSP=1
              THER I=1 V=354.00 T=40.05
               M=1
              SEND D=0 I=1 C=0 T=0 S= N=0 F=40.05
              9224 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:40.05
              SLEEP 3600s
              9316 MCO:SLP:MS=3600000,SMS=1,I1=255,M1=255,I2=255,M2=255
              9527 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:287
              9607 TSF:MSG:READ,0-0-100,s=255,c=3,t=27,pt=1,l=1,sg=0:1
              9666 !TSF:MSG:LEN,0!=8
              10108 MCO:SLP:TPD```
              Gateway
              0;255;3;0;9;TSF:MSG:READ,100-100-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
              0;255;3;0;9;TSF:MSG:BC
              0;255;3;0;9;TSF:MSG:FPAR REQ,ID=100
              0;255;3;0;9;TSF:PNG:SEND,TO=0
              0;255;3;0;9;TSF:CKU:OK
              0;255;3;0;9;TSF:MSG:GWL OK
              0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
              0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
              0;255;3;0;9;TSF:MSG:PINGED,ID=100,HP=1
              0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
              0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
              0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.1.1
              0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/0/0/17
              0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=11,pt=0,l=19,sg=0:NodeManagerTemplate
              0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/3/0/11
              0;255;3;0;9;TSF:MSG:READ,100-100-0,s=200,c=0,t=23,pt=0,l=0,sg=0:
              0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/200/0/0/23
              0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=0,pt=1,l=1,sg=0:85
              0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/3/0/0
              0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
              0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
              0;255;3;0;9;TSF:MSG:READ,100-100-0,s=1,c=1,t=0,pt=7,l=5,sg=0:36.72
              0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/1/1/0/0
              0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=22,pt=5,l=4,sg=0:286
              0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/3/0/22
              0;255;3;0;9;Message arrived on topic: domoticz/out/MyMQTT/0/0/3/0/18
              0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/0/255/3/0/22
              M.C.
                @user2684
                @gohan
                node
                40 MCO:BGN:BFR
                REG I=1 P=3 P=6 T=0
                NodeManager v1.4
                INT1 M=255
                INT2 M=255
                59 TSM:INIT
                135 TSF:WUR:MS=0
                155 TSM:INIT:TSP OK
                225 TSM:FPAR
                2447 TSM:FPAR:OK
                2463 TSM:ID
                2478 TSM:ID:OK
                2492 TSM:UPL
                3768 TSM:UPL:OK
                RADIO OK
                PRES I=200, T=23
                PRES I=201, T=30
                BATT V=3.25 P=93
                PRES I=1 T=6
                READY
                7868 MCO:REG:REQ
                9105 MCO:BGN:STP
                MY I=100 M=1
                 M=1
                SLEEP 3600s
                Gateway
                U
                U
                user2684
                @mar.conte there is something strange with this node. First of all the node is still presenting the temperature and not the motion sensor. Then I see a lot of failures during transmit but also while receiving (!TSF:MSG:LEN,0!=8). Are you sure you don't have something like two nodes with the same id?
                • U user2684
                  mar.conteM
                  mar.conteM
                  mar.conte
                  wrote on last edited by mar.conte
                  #84
                  @user2684
                  hi, I noticed that the zero node has a child called S_Arduino_Repeater with an id equal to 255 child node, called 100 S_Arduino_Node, what do you recommend?
                  smotion now appears I had mistakenly entered analog 0 on a wire that went to +Power
                  M.C.
                    @user2684
                    U
                    U
                    user2684
                    The node 0 is the gateway which presents itself as S_ARDUINO_REPEATER, the child id 255 is the broadcast address, the node id 100 is instead you node. This is all correct (with or without NodeManager). Glad to hear the motion sensor is now showing up. Is it still trigger continuously?
                    • U user2684
                      mar.conteM
                      mar.conteM
                      mar.conte
                      @user2684
                      Yes trig again!!!
                      M.C.
                        @user2684
                        Yes trig again!!!
                        U
                        U
                        user2684
                        Yes trig again!!!
                        Ok, if triggers continuously, please share the logs of the node now that has been fixed so we can have a look.
                        • U user2684
                          Yes trig again!!!
                          mar.conteM
                          mar.conteM
                          mar.conte
                          wrote on last edited by gohan
                          #88
                          @user2684
                          NODE OUTPUT
                          40 MCO:BGN:BFR
                          REG I=1 P=3 P=1 T=16
                          NodeManager v1.4
                          INT1 M=3
                          INT2 M=255
                          59 TSM:INIT
                          135 TSF:WUR:MS=0
                          153 TSM:INIT:TSP OK
                          200 TSF:SID:OK,ID=100
                          223 TSM:FPAR
                          368 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          641 TSF:MSG:READ,0-0-100,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                          698 TSF:MSG:FPAR OK,ID=0,D=1
                          2445 TSM:FPAR:OK
                          2461 TSM:ID
                          2476 TSM:ID:OK
                          2490 TSM:UPL
                          2512 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                          2633 TSF:MSG:READ,0-0-100,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                          2693 TSF:MSG:PONG RECV,HP=1
                          2721 TSM:UPL:OK
                          2738 TSM:READY:ID=100,PAR=0,DIS=1
                          2785 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                          2904 TSF:MSG:READ,0-0-100,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                          3018 TSF:MSG:SEND,100-100-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
                          3229 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=NACK:0
                          5316 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=1,st=OK:NodeManagerTemplate
                          5541 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=NACK:1.0
                          RADIO OK
                          PRES I=200, T=23
                          5715 TSF:MSG:SEND,100-100-0-0,s=200,c=0,t=23,pt=0,l=0,sg=0,ft=1,st=OK:
                          PRES I=201, T=30
                          5922 !TSF:MSG:SEND,100-100-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=0,st=NACK:
                          BATT V=3.21 P=86
                          SEND D=0 I=201 C=0 T=38 S= I=0 F=3.21
                          6072 !MCO:SND:NODE NOT REG
                          6164 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=1,st=OK:86
                          PRES I=1 T=1
                          6371 !TSF:MSG:SEND,100-100-0-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=NACK:
                          READY
                          6445 MCO:REG:REQ
                          6531 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
                          6619 TSF:MSG:READ,0-0-100,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                          6678 MCO:PIM:NODE REG=1
                          6705 MCO:BGN:STP
                          MY I=100 M=1
                          6723 MCO:BGN:INIT OK,TSP=1
                          SWITCH I=1 P=3 V=1
                          SEND D=0 I=1 C=0 T=16 S= N=1 F=0.00
                          6817 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
                          SLEEP 3600s
                          6897 MCO:SLP:MS=3600000,SMS=1,I1=1,M1=3,I2=255,M2=255
                          7104 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:264
                          7684 MCO:SLP:TPD
                          7700 MCO:SLP:WUP=1
                          WAKE P=3, M=3
                          AWAKE
                          SWITCH I=1 P=3 V=1
                          SEND D=0 I=1 C=1 T=16 S= N=1 F=0.00
                          7786 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=1,st=OK:1
                          SLEEP 3600s
                          7876 MCO:SLP:MS=3600000,SMS=1,I1=1,M1=3,I2=255,M2=255
                          8087 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:1243
                          8667 MCO:SLP:TPD
                          8683 MCO:SLP:WUP=1
                          WAKE P=3, M=3
                          AWAKE
                          SWITCH I=1 P=3 V=1
                          8757 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=1,st=OK:1
                          SLEEP 3600s
                          8859 MCO:SLP:MS=3600000,SMS=1,I1=1,M1=3,I2=255,M2=255
                          8982 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:2226
                          9562 MCO:SLP:TPD
                          9578 MCO:SLP:WUP=1
                          WAKE P=3, M=3
                          AWAKE
                          SWITCH I=1 P=3 V=1
                          9621 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
                          SLEEP 3600s
                          9754 MCO:SLP:MS=3600000,SMS=1,I1=1,M1=3,I2=255,M2=255
                          9961 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:3121
                          10541 MCO:SLP:TPD
                          Tanks
                          M.C.
                            @user2684
                            NODE OUTPUT
                            40 MCO:BGN:BFR
                            NodeManager v1.4
                            INT1 M=3
                            INT2 M=255
                            59 TSM:INIT
                            135 TSF:WUR:MS=0
                            153 TSM:INIT:TSP OK
                            223 TSM:FPAR
                            2445 TSM:FPAR:OK
                            2461 TSM:ID
                            2476 TSM:ID:OK
                            2490 TSM:UPL
                            2721 TSM:UPL:OK
                            RADIO OK
                            PRES I=200, T=23
                            PRES I=201, T=30
                            BATT V=3.21 P=86
                            PRES I=1 T=1
                            READY
                            6445 MCO:REG:REQ
                            6705 MCO:BGN:STP
                            MY I=100 M=1
                            SWITCH I=1 P=3 V=1
                            SLEEP 3600s
                            7684 MCO:SLP:TPD
                            7700 MCO:SLP:WUP=1
                            WAKE P=3, M=3
                            AWAKE
                            SWITCH I=1 P=3 V=1
                            SLEEP 3600s
                            8667 MCO:SLP:TPD
                            8683 MCO:SLP:WUP=1
                            WAKE P=3, M=3
                            AWAKE
                            SWITCH I=1 P=3 V=1
                            SLEEP 3600s
                            9562 MCO:SLP:TPD
                            9578 MCO:SLP:WUP=1
                            WAKE P=3, M=3
                            AWAKE
                            SWITCH I=1 P=3 V=1
                            SLEEP 3600s
                            10541 MCO:SLP:TPD
                            Tanks
                            U
                            U
                            user2684
                            @mar.conte ok, this looks better, the node is presenting correctly and I see the sensor triggering continuously. You still have a lot of radio failures while sending but this is another story and it is not related to the issue but keep in mind you are losing a few messages.
                            Now, if I look at the digital read of the pin waking up the board (V=):
                            SWITCH I=1 P=3 V=1
                            This is HIGH so the board correctly wakes up. Since the signal apparently stays high, the board goes in and out of sleep so looks like an expected behavior. The are a couple of functions available to prevent this (setTriggerTime() and setDebounce()) but before giving direction I'd ask you to measure the voltage at pin 3 with a multimeter because it looks like the motion sensor goes HIGH and stay HIGH for a long time. If we know this timeframe, we can adjust the settings accordingly. Btw you should have the same behavior with the example sketch at https://www.mysensors.org/build/motion.
                            mar.conteM 2 Replies Last reply
                            • U user2684
                              SWITCH I=1 P=3 V=1
                              mar.conteM
                              mar.conteM
                              mar.conte
                              @user2684
                              ok, I will check first the voltage of the pir and even the power of the MCU, it seems to me that the rfm69 module does not communicate with each other (node-gateway), it seems strange because with the sketch of links that you suggested it all works well ! thanks anyway I'll do my tests and let you know soon ...
                              M.C.
                              • mar.conteM
                                mar.conteM
                                mar.conte
                                #91
                                I wanted to know what are the connections to monitor the batteries of my sensor, do I connect the battery V+ to the analog pin A0?
                                M.C.
                                  U
                                  U
                                  user2684
                                  If you are connecting the arduino directly to the battery (e.g. no step-up-down), then you don't need any connection since NodeManager is able to sense and measure the input vcc (and according to my measures it is very accurate). In case instead you need to use the method here https://www.mysensors.org/build/battery, you need the following:
                                  nodeManager.setBatteryInternalVcc(false);
                                  nodeManager.setBatteryPin(A0);
                                  You can even customize the default 0.003363075 voltage per bit with setBatteryVoltsPerBit()
                                  • U user2684
                                    mar.conteM
                                    mar.conteM
                                    mar.conte
                                    @user2684
                                    THEN MY NODE WILL BE CONNECTED TO A BATTERY 3.6 VOLT AA 2600 MAH, SO I DO NOT RIGHT CONNECTIONS? BUT I HAVE TO CHANGE OTHER PARAMETERS TO BEING 3.6?
                                    TANKS
                                    M.C.
                                      @user2684
                                      TANKS
                                      U
                                      U
                                      user2684
                                      TANKS
                                      If directly connected to the battery you don't need any other connection. To set minimum and maximum voltage to have an accurate battery percentage level calculated you need to use e.g.:
                                      nodeManager.setBatteryMin(2.7);
                                      nodeManager.setBatteryMax(3.6);
                                      So the percentage will be calculated between the two values.
                                      • U user2684
                                        TANKS
                                        mar.conteM
                                        mar.conteM
                                        mar.conte
                                        @user2684
                                        Much easy INFINITE THANKS AND CONGRATULATIONS
                                        M.C.
                                        • U user2684
                                          SWITCH I=1 P=3 V=1
                                          mar.conteM
                                          mar.conteM
                                          mar.conte
                                          #96
                                          @user2684
                                          Solved
                                          I solved it by putting settriggertime (5000) setdebounce (50); also solved the supply problems because if power is ftdi with the sensor was always high, with batteries the pir is stable and works well
                                          thanks for the support
                                          This is my reprap printed house for my project
                                          M.C.
