  3. NodeManager
  4. NodeManager: plugin for a rapid development of battery-powered sensors
223 Posts 23 Posters 125.6k Views 26 Watching
  • BeniKB BeniK
    @user2684 You were right! Definately a memory problem. Disabled the non-needed modules and everything is working as it should!
    REG I=1 P=3 P=6 T=0
    REG I=2 P=4 P=6 T=0
    REG I=3 P=4 P=7 T=1
    NodeManager v1.4
    INT1 M=255
    INT2 M=255
    RADIO OK
    PRES I=200, T=23
    PRES I=201, T=30
    BATT V=3.44 P=100
    SEND D=0 I=201 C=0 T=38 S= I=0 F=3.44
    PRES I=1 T=6
    PRES I=2 T=6
    PRES I=3 T=7
    READY
    MY I=199 M=1
    DS18B20 I=1 T=44.19
    SEND D=0 I=1 C=0 T=0 S= N=0 F=44.19
    DHT I=2 T=24.40
    SEND D=0 I=2 C=0 T=0 S= N=0 F=24.40
    DHT I=3 H=35.50
    SEND D=0 I=3 C=0 T=1 S= N=0 F=35.50
    SLEEP 60s
    Many many many THANKS for the help!
    U
    U
    user2684
    @BeniK said in NodeManager: plugin for a rapid development of battery-powered sensors:
    Great! I feel like there are a lot of optimizations that can be done to prevent this and other weird behaviors (tracked already with https://github.com/mysensors/NodeManager/issues/28).
    I'd need a real programmer's review sooner or later because I'm sure the way I am e.g. comparing and manipulating strings are far from being efficient...
    • BeniKB BeniK
      @user2684 By the way I am alsy trying to implement the forecasting algorithm for BME280 sensor (from here) into the BME280 section of NodeManager.cpp and Nodemanager.h but until now no joy. Maybe I am trying to do something complicated for me as a beginner into this, but I always like to learn by trial and error. Any advice you could give me to be able to implement the forecasting algorithm?
      U
      U
      user2684
      Great idea! I wonder if the issue you are facing is due to different libraries being used (I'm using Adafruit's library, not the one from MySensors examples folder, not sure if they are different). I'll give it a try as well (https://github.com/mysensors/NodeManager/issues/56), but please let me know if you'll find the way to have it working and I'll make it part of the main code base.
      • U user2684
        @mar.conte your configuration looks correct, SENSOR_MOTION is what you want to use indeed. However, the logs are saying NodeManager is presenting the sensor as S_TEMP so the issue is on NodeManager's side also because looks like SensorThermistor has been instantiated but if I look at the code, there is no way this should happen.I'll try to setup something similar to see if I can reproduce the behavior. Very stupid question: are you sure you have uploaded successfully that sketch and it is not an old one? I really cannot explain it otherwise at a first look...
        mar.conteM
        mar.conteM
        mar.conte
        @user2684
        all ok now is s_motion but is ever tripped high!!!why?
        M.C.
        U 1 Reply Last reply
        • mar.conteM mar.conte
          @user2684
          U
          U
          user2684
          @mar.conte said in NodeManager: plugin for a rapid development of battery-powered sensors:
          Default behavior is triggering on RISING but this can be changed with setMode() and setInitial(). Also ensure you are using pin 3 on a pro mini to have a valid interrupt. What is the behavior you are experiencing?
          mar.conteM 2 Replies Last reply
          • U user2684
            mar.conteM
            mar.conteM
            mar.conte
            @user2684
            for istance Sensorswitch what is code?
            M.C.
            • U user2684
              mar.conteM
              mar.conteM
              mar.conte
              @user2684
              it's ok this code?
              NodeManager nodeManager;
              SensorSwitch swiTch(1,3);
              // before
              void before() {
                Serial.begin(MY_BAUD_RATE);
                 * Register below your sensors
              swiTch.setMode(0);
              swiTch.setInitial(0);
              swiTch.setTriggerTime(4000);
                nodeManager.setSleep(SLEEP,60,MINUTES);
                nodeManager.registerSensor(SENSOR_MOTION,3);```
              M.C.
                @user2684
                it's ok this code?
                // before
                void before() {
                swiTch.setMode(0);
                U
                U
                user2684
                @mar.conte sorry I'm not sure I have understood what you want to achieve. Do you have a motion sensor which is HIGH by default and when triggers goes LOW? Is this what you need?
                mar.conteM 1 Reply Last reply
                • U user2684
                  mar.conteM
                  mar.conteM
                  mar.conte
                  @user2684
                  Hello, I have a simple pir hcr501 that normally does not send output to pin 3 (so low) but when there is movement becomes HIGH, then my CPU goes to sleep for 60 minutes; the hardware is well configured because this setup I used it with the official mysensors sketches for pir motion; I do not understand why the domoticz controller is always the pir HIGH and does not go into sleep the MCU, thanks
                  M.C.
                    @user2684
                    U
                    U
                    user2684
                    Ok, so you don't need any customization in NodeManager since this is meeting the default behavior (LOW by default and triggering on HIGH), sorry for the wrong advice. Let's have a look at the sensor's logs then to see why the node is waking up continuously.
                    • U user2684
                      mar.conteM
                      mar.conteM
                      mar.conte
                      @user2684
                      @gohan
                      node
                      40 MCO:BGN:BFR
                      REG I=1 P=3 P=6 T=0
                      NodeManager v1.4
                      INT1 M=255
                      INT2 M=255
                      59 TSM:INIT
                      135 TSF:WUR:MS=0
                      155 TSM:INIT:TSP OK
                      176 TSM:INIT:STATID=100
                      202 TSF:SID:OK,ID=100
                      225 TSM:FPAR
                      370 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      2244 TSF:MSG:READ,0-0-100,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                      2301 TSF:MSG:FPAR OK,ID=0,D=1
                      2447 TSM:FPAR:OK
                      2463 TSM:ID
                      2478 TSM:ID:OK
                      2492 TSM:UPL
                      2639 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                      3678 TSF:MSG:READ,0-0-100,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                      3737 TSF:MSG:PONG RECV,HP=1
                      3768 TSM:UPL:OK
                      3784 TSM:READY:ID=100,PAR=0,DIS=1
                      3883 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                      4003 TSF:MSG:READ,0-0-100,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                      4202 !TSF:MSG:SEND,100-100-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=NACK:2.1.1
                      4415 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=NACK:0
                      6733 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=2,st=NACK:NodeManagerTemplate
                      6928 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=3,st=OK:1.0
                      RADIO OK
                      PRES I=200, T=23
                      7137 !TSF:MSG:SEND,100-100-0-0,s=200,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=NACK:
                      PRES I=201, T=30
                      7321 TSF:MSG:SEND,100-100-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=1,st=OK:
                      BATT V=3.25 P=93
                      SEND D=0 I=201 C=0 T=38 S= I=0 F=3.25
                      7469 !MCO:SND:NODE NOT REG
                      7587 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:93
                      PRES I=1 T=6
                      7794 !TSF:MSG:SEND,100-100-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=NACK:
                      READY
                      7868 MCO:REG:REQ
                      7933 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
                      9019 TSF:MSG:READ,0-0-100,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                      9078 MCO:PIM:NODE REG=1
                      9105 MCO:BGN:STP
                      MY I=100 M=1
                      9123 MCO:BGN:INIT OK,TSP=1
                      THER I=1 V=354.00 T=40.05
                       M=1
                      SEND D=0 I=1 C=0 T=0 S= N=0 F=40.05
                      9224 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:40.05
                      SLEEP 3600s
                      9316 MCO:SLP:MS=3600000,SMS=1,I1=255,M1=255,I2=255,M2=255
                      9527 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:287
                      9607 TSF:MSG:READ,0-0-100,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                      9666 !TSF:MSG:LEN,0!=8
                      10108 MCO:SLP:TPD```
                      Gateway
                      0;255;3;0;9;TSF:MSG:READ,100-100-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                      0;255;3;0;9;TSF:MSG:BC
                      0;255;3;0;9;TSF:MSG:FPAR REQ,ID=100
                      0;255;3;0;9;TSF:PNG:SEND,TO=0
                      0;255;3;0;9;TSF:CKU:OK
                      0;255;3;0;9;TSF:MSG:GWL OK
                      0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                      0;255;3;0;9;TSF:MSG:PINGED,ID=100,HP=1
                      0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                      0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.1.1
                      0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/0/0/17
                      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=11,pt=0,l=19,sg=0:NodeManagerTemplate
                      0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/3/0/11
                      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=200,c=0,t=23,pt=0,l=0,sg=0:
                      0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/200/0/0/23
                      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=0,pt=1,l=1,sg=0:85
                      0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/3/0/0
                      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                      0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=1,c=1,t=0,pt=7,l=5,sg=0:36.72
                      0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/1/1/0/0
                      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=22,pt=5,l=4,sg=0:286
                      0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/3/0/22
                      0;255;3;0;9;Message arrived on topic: domoticz/out/MyMQTT/0/0/3/0/18
                      0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/0/255/3/0/22
                      M.C.
                        @user2684
                        @gohan
                        node
                        40 MCO:BGN:BFR
                        REG I=1 P=3 P=6 T=0
                        NodeManager v1.4
                        INT1 M=255
                        INT2 M=255
                        59 TSM:INIT
                        135 TSF:WUR:MS=0
                        155 TSM:INIT:TSP OK
                        225 TSM:FPAR
                        2447 TSM:FPAR:OK
                        2463 TSM:ID
                        2478 TSM:ID:OK
                        2492 TSM:UPL
                        3768 TSM:UPL:OK
                        RADIO OK
                        PRES I=200, T=23
                        PRES I=201, T=30
                        BATT V=3.25 P=93
                        PRES I=1 T=6
                        READY
                        7868 MCO:REG:REQ
                        9105 MCO:BGN:STP
                        MY I=100 M=1
                         M=1
                        SLEEP 3600s
                        Gateway
                        U
                        U
                        user2684
                        @mar.conte there is something strange with this node. First of all the node is still presenting the temperature and not the motion sensor. Then I see a lot of failures during transmit but also while receiving (!TSF:MSG:LEN,0!=8). Are you sure you don't have something like two nodes with the same id?
                        • U user2684
                          mar.conteM
                          mar.conteM
                          mar.conte
                          wrote on last edited by mar.conte
                          #84
                          @user2684
                          hi, I noticed that the zero node has a child called S_Arduino_Repeater with an id equal to 255 child node, called 100 S_Arduino_Node, what do you recommend?
                          smotion now appears I had mistakenly entered analog 0 on a wire that went to +Power
                          M.C.
                            @user2684
                            U
                            U
                            user2684
                            The node 0 is the gateway which presents itself as S_ARDUINO_REPEATER, the child id 255 is the broadcast address, the node id 100 is instead you node. This is all correct (with or without NodeManager). Glad to hear the motion sensor is now showing up. Is it still trigger continuously?
                            • U user2684
                              mar.conteM
                              mar.conteM
                              mar.conte
                              @user2684
                              Yes trig again!!!
                              M.C.
                                @user2684
                                Yes trig again!!!
                                U
                                U
                                user2684
                                Yes trig again!!!
                                Ok, if triggers continuously, please share the logs of the node now that has been fixed so we can have a look.
                                • U user2684
                                  Yes trig again!!!
                                  mar.conteM
                                  mar.conteM
                                  mar.conte
                                  wrote on last edited by gohan
                                  #88
                                  @user2684
                                  NODE OUTPUT
                                  40 MCO:BGN:BFR
                                  REG I=1 P=3 P=1 T=16
                                  NodeManager v1.4
                                  INT1 M=3
                                  INT2 M=255
                                  59 TSM:INIT
                                  135 TSF:WUR:MS=0
                                  153 TSM:INIT:TSP OK
                                  200 TSF:SID:OK,ID=100
                                  223 TSM:FPAR
                                  368 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  641 TSF:MSG:READ,0-0-100,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                  698 TSF:MSG:FPAR OK,ID=0,D=1
                                  2445 TSM:FPAR:OK
                                  2461 TSM:ID
                                  2476 TSM:ID:OK
                                  2490 TSM:UPL
                                  2512 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                  2633 TSF:MSG:READ,0-0-100,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                  2693 TSF:MSG:PONG RECV,HP=1
                                  2721 TSM:UPL:OK
                                  2738 TSM:READY:ID=100,PAR=0,DIS=1
                                  2785 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                  2904 TSF:MSG:READ,0-0-100,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                  3018 TSF:MSG:SEND,100-100-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
                                  3229 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=NACK:0
                                  5316 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=1,st=OK:NodeManagerTemplate
                                  5541 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=NACK:1.0
                                  RADIO OK
                                  PRES I=200, T=23
                                  5715 TSF:MSG:SEND,100-100-0-0,s=200,c=0,t=23,pt=0,l=0,sg=0,ft=1,st=OK:
                                  PRES I=201, T=30
                                  5922 !TSF:MSG:SEND,100-100-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=0,st=NACK:
                                  BATT V=3.21 P=86
                                  SEND D=0 I=201 C=0 T=38 S= I=0 F=3.21
                                  6072 !MCO:SND:NODE NOT REG
                                  6164 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=1,st=OK:86
                                  PRES I=1 T=1
                                  6371 !TSF:MSG:SEND,100-100-0-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=NACK:
                                  READY
                                  6445 MCO:REG:REQ
                                  6531 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
                                  6619 TSF:MSG:READ,0-0-100,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                  6678 MCO:PIM:NODE REG=1
                                  6705 MCO:BGN:STP
                                  MY I=100 M=1
                                  6723 MCO:BGN:INIT OK,TSP=1
                                  SWITCH I=1 P=3 V=1
                                  SEND D=0 I=1 C=0 T=16 S= N=1 F=0.00
                                  6817 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
                                  SLEEP 3600s
                                  6897 MCO:SLP:MS=3600000,SMS=1,I1=1,M1=3,I2=255,M2=255
                                  7104 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:264
                                  7684 MCO:SLP:TPD
                                  7700 MCO:SLP:WUP=1
                                  WAKE P=3, M=3
                                  AWAKE
                                  SWITCH I=1 P=3 V=1
                                  SEND D=0 I=1 C=1 T=16 S= N=1 F=0.00
                                  7786 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=1,st=OK:1
                                  SLEEP 3600s
                                  7876 MCO:SLP:MS=3600000,SMS=1,I1=1,M1=3,I2=255,M2=255
                                  8087 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:1243
                                  8667 MCO:SLP:TPD
                                  8683 MCO:SLP:WUP=1
                                  WAKE P=3, M=3
                                  AWAKE
                                  SWITCH I=1 P=3 V=1
                                  8757 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=1,st=OK:1
                                  SLEEP 3600s
                                  8859 MCO:SLP:MS=3600000,SMS=1,I1=1,M1=3,I2=255,M2=255
                                  8982 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:2226
                                  9562 MCO:SLP:TPD
                                  9578 MCO:SLP:WUP=1
                                  WAKE P=3, M=3
                                  AWAKE
                                  SWITCH I=1 P=3 V=1
                                  9621 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
                                  SLEEP 3600s
                                  9754 MCO:SLP:MS=3600000,SMS=1,I1=1,M1=3,I2=255,M2=255
                                  9961 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:3121
                                  10541 MCO:SLP:TPD
                                  Tanks
                                  M.C.
                                    @user2684
                                    NODE OUTPUT
                                    40 MCO:BGN:BFR
                                    NodeManager v1.4
                                    INT1 M=3
                                    INT2 M=255
                                    59 TSM:INIT
                                    135 TSF:WUR:MS=0
                                    153 TSM:INIT:TSP OK
                                    223 TSM:FPAR
                                    2445 TSM:FPAR:OK
                                    2461 TSM:ID
                                    2476 TSM:ID:OK
                                    2490 TSM:UPL
                                    2721 TSM:UPL:OK
                                    RADIO OK
                                    PRES I=200, T=23
                                    PRES I=201, T=30
                                    BATT V=3.21 P=86
                                    PRES I=1 T=1
                                    READY
                                    6445 MCO:REG:REQ
                                    6705 MCO:BGN:STP
                                    MY I=100 M=1
                                    SWITCH I=1 P=3 V=1
                                    SLEEP 3600s
                                    7684 MCO:SLP:TPD
                                    7700 MCO:SLP:WUP=1
                                    WAKE P=3, M=3
                                    AWAKE
                                    SWITCH I=1 P=3 V=1
                                    SLEEP 3600s
                                    8667 MCO:SLP:TPD
                                    8683 MCO:SLP:WUP=1
                                    WAKE P=3, M=3
                                    AWAKE
                                    SWITCH I=1 P=3 V=1
                                    SLEEP 3600s
                                    9562 MCO:SLP:TPD
                                    9578 MCO:SLP:WUP=1
                                    WAKE P=3, M=3
                                    AWAKE
                                    SWITCH I=1 P=3 V=1
                                    SLEEP 3600s
                                    10541 MCO:SLP:TPD
                                    Tanks
                                    U
                                    U
                                    user2684
                                    @mar.conte ok, this looks better, the node is presenting correctly and I see the sensor triggering continuously. You still have a lot of radio failures while sending but this is another story and it is not related to the issue but keep in mind you are losing a few messages.
                                    Now, if I look at the digital read of the pin waking up the board (V=):
                                    SWITCH I=1 P=3 V=1
                                    This is HIGH so the board correctly wakes up. Since the signal apparently stays high, the board goes in and out of sleep so looks like an expected behavior. The are a couple of functions available to prevent this (setTriggerTime() and setDebounce()) but before giving direction I'd ask you to measure the voltage at pin 3 with a multimeter because it looks like the motion sensor goes HIGH and stay HIGH for a long time. If we know this timeframe, we can adjust the settings accordingly. Btw you should have the same behavior with the example sketch at https://www.mysensors.org/build/motion.
                                    • U user2684
                                      SWITCH I=1 P=3 V=1
                                      mar.conteM
                                      mar.conteM
                                      mar.conte
                                      @user2684
                                      ok, I will check first the voltage of the pir and even the power of the MCU, it seems to me that the rfm69 module does not communicate with each other (node-gateway), it seems strange because with the sketch of links that you suggested it all works well ! thanks anyway I'll do my tests and let you know soon ...
                                      M.C.
                                      • mar.conteM
                                        mar.conteM
                                        mar.conte
                                        #91
                                        I wanted to know what are the connections to monitor the batteries of my sensor, do I connect the battery V+ to the analog pin A0?
                                        M.C.
                                          U
                                          U
                                          user2684
                                          If you are connecting the arduino directly to the battery (e.g. no step-up-down), then you don't need any connection since NodeManager is able to sense and measure the input vcc (and according to my measures it is very accurate). In case instead you need to use the method here https://www.mysensors.org/build/battery, you need the following:
                                          nodeManager.setBatteryInternalVcc(false);
                                          nodeManager.setBatteryPin(A0);
                                          You can even customize the default 0.003363075 voltage per bit with setBatteryVoltsPerBit()
