716 Posts 111 Posters 703.2k Views 93 Watching
  • ileneken3I
    ileneken3I
    ileneken3
    @sundberg84
    OK, looks like I had multiple problems.
    I somehow missed the instructions about "don't solder both", and was also slightly confused about the directions because I am using a battery (LIPO), but following the "5V regulated" instructions. When the instructions mention battery, it always mean a 3.3V battery. I had the BAT jumpered, and then I tried with and without the REG jumpered.
    At the same time, I believe I damaged the MCP1700 regulator - I will have to take it off and test it.
    So in the interest of getting this resolved quickly, I started all over again with a new board, new regulator, and jumping only REG. It worked! Here is the picture:
    You can see that the radio will get 3.3V, and the rest of the board will get 4+ volts. (The TP4056 will cut it off as it goes down to around 3V).
    So I will continue the build, and if everything goes according to spec, the radio, arduino, and sensors should all be OK. (Assuming the sensor can handle 4+ volts).
    As far as the capacitors, it looks like the spec says 1uF on input and output. So I will put those where there are labels for .1 and 10uF. For the radio, I am well aware of its capacitor needs (learning the hard way). At this point, I always put the 4.7uF cap directly on the radio.
    If everything goes well, I would recommend putting some sort of reference to LIPO batteries in the instructions. I couldn't be the only one who wants to do this.
    Great support from everyone!
      I am also looking at using lipo batteries, but I've been told they have a tendency to self discharge over time, so normal AA batteries or cr123 provide longer battery life of course if the node is not power hungry
      S 1 Reply Last reply
        Samuel235
        @gohan - I can't and wont throw figures around here concerning how much they discharge per day, but they do indeed self-discharge and in my opinion wouldn't be suitable for a sleeping node.
        MySensors 2.1.1
        ileneken3I 1 Reply Last reply
        • S Samuel235
          ileneken3I
          ileneken3I
          ileneken3
          @Samuel235
          The key question here (at least for this forum subject), is "should you a LIPO with a Easy/Newbie PCB board"? My answer is "in some cases". For sure, the gold standard of sleeping nodes is 2 AA batteries that last over a year. It's best both in terms of price and longevity. But there are scenarios for using LIPO's:
          • The AA batteries are too big. LIPO's come in all sizes, and the one from my old cell phone was nice and compact for a particular enclosure I wanted to use.
          • You have LIPO's lying around (like from an old laptop) and you just want to use them.
          • The sensors you are using are "power hungry" and you just can't find a way around it (and you can't plug it into the wall). Using a LIPO will avoid having to throw away a lot of AA's.
          As far as discharge rate, from what I read it's not too bad (just not as good as AA's). With sensors that are not power hungry, and with the right voltage regulator (like a MCP1700), I am anticipating it lasting for months. At that point, it's not that big of a deal to recharge with that frequency.
          For use with power hungry sensors (which may mean using just 2 ma), I am hoping for weeks.
          I will continue with the experiment unless someone says I am way off in my estimations.
          • J
            J
            jens persson
            As requested a few images of the version 9 board, mounted for battery with some extra pin sockets while experimenting.
            With radio and processor
            Without radio and arduino
            • J jens persson
              sundberg84S
              sundberg84S
              @jens-persson - Tnx, but hmmm.. I cant see them. Just a stop sign. Maybe my web-browser?
              gohanG 1 Reply Last reply
              • sundberg84S sundberg84
                @sundberg84 same here
                • J
                  J
                  jens persson
                  Thought the settings on the album should apply to the images also.
                  Here is a link to the album: https://goo.gl/photos/bX9HZSXdbMCvuyAv9
                  Does it work?
                  sundberg84S maghacM 2 Replies Last reply
                  • J jens persson
                    Does it work?
                    sundberg84S
                    sundberg84S
                    @jens-persson - It does! Nice images! Well done :+1:
                    I like you have added headers so you can add and remove quickly,.
                      is it me or that pro mini looks a little different than what I usually see?
                      dbemowskD 1 Reply Last reply
                        dbemowskD
                        dbemowskD
                        @gohan It's not just you. I had some 5v pro minis that were from china that looked different than the standard ones. The outer pin config was the same, but the guts of the board weere a bit different. A4 and A5 were towards the back of the board.
                        • J
                          J
                          jens persson
                          These were bought here: https://www.aliexpress.com/item/10pcs-pro-mini-atmega168-Pro-Mini-168-Mini-ATMEGA168-3-3V-8MHz-for-Arduino/32413050538.html
                          • J jens persson
                            @jens-persson they are atmega 168, that's why 😀
                            • maghacM
                              maghacM
                              maghac
                              Any comments on delivery times from itead, pcbway or seeed? Which one is fastest/easiest to deal with (I'm located in Sweden)?
                              • maghacM maghac
                                sundberg84S
                                sundberg84S
                                @maghac - tried itead and pcbway and they use same shipping so shipping times has been pretty much the same.
                                I have some old revisions I can sell you cheap in Sweden if you need fast delivery. Rev 6 and 7 I think.
                                maghacM 1 Reply Last reply
                                  maghacM
                                  maghacM
                                  maghac
                                  @sundberg84 Would be great, I'll send you a PM!
                                  • J
                                    J
                                    johmei
                                    Got a couple of 5V DC running as "test boards". Very convenient and quick to get started. A+
                                    Will have a few battery nodes running soon as the step ups come in.
                                    • J johmei
                                      sundberg84S
                                      sundberg84S
                                      @johmei - thank you for your feedback! :)
                                      • maghacM
                                        maghacM
                                        maghac
                                        Agree, very easy to start using. Upgraded one of my old "cable spaghetti" temperature sensor nodes to this board, looks much neater now, and actually fits a lot better in the box too.
                                        I soldered the arduino and the radio directly on the board, but then I realized that maybe it would be better to use female headers so I can replace them if I wanted. How are people generally using the boards?
                                        • maghacM maghac
                                          sundberg84S
                                          sundberg84S
                                          @maghac - I do both and it depends on cases and where i put it.
                                          Sometimes there just isnt enough room for headers but I try to make it as modular as possible... most important is the radio for me so I can easy swap and test if something goes wrong.
                                          I have a couple of test nodes (running time sketch for example) which is ONLY modular where I try out my hardware before soldering them as well.
