  3. Domoticz
  4. Domoticz - soil moisture + one relay = Lua script error (Blockly)
27 Posts 2 Posters 9.8k Views 2 Watching
  • k5austriaK Offline
    k5austriaK Offline
    k5austria
    Hi ,
    I want to link with blocky one soil moisture sensor and one Relay , but it always comes error message. I use MySensors hardware.
    Very simple but not work ?!
    https://www.domoticz.com/forum/viewtopic.php?f=62&t=17211
    My blueberries need soon the water. Please help me ! :?
    Thanks !
      Did you try to make some other rules involving either soil sensor or relay and see if error follows the soil sensor?
        k5austriaK Offline
        k5austria
        wrote on last edited by k5austria
        Hi ,
        thank you for your answer . I have tried others rules with relay and time. Everything works. Only if Moisture value is in function , come error message.
        2017-04-24 21:46:05.283 Error: EventSystem: Lua script error (Blockly), Name: soil moisture_1 => [string "result = 0; weekday = os.date('*t')['wday']; ..."]:1: attempt to index global 'utilitydevice' (a nil value)
        I have no experience with this thing i currently have no idea :disappointed:
        It would be good if works
          How do you present the soil sensor? Maybe I can try to replicate your error
            k5austriaK Offline
            k5austria
            Sorry !!! I have not seen your answer again !
            I tried everything but it did not work. The problem is value from soil moisture sensor . I think so !?
            If you fix the problem you have a drink from me :grinning:
            5_1493474335770_2017-04-29 15_46_39-Domoticz.png 4_1493474335769_2017-04-29 15_46_03-Domoticz.png 3_1493474335768_2017-04-29 15_44_25-Domoticz.png 2_1493474335767_2017-04-29 15_44_11-Domoticz.png 1_1493474335765_2017-04-29 15_43_47-Domoticz.png 0_1493474335763_2017-04-29 15_43_25-Domoticz.png
              k5austriaK Offline
              k5austria
              wrote on last edited by gohan
              #define CHILD_ID 0
              // Here we are setting up some water thresholds that we will
              // use later. Note that you will need to change these to match
              // your soil type and environment. It doesn't do much for me because I'm using domoticz
              int thresholdUp = 400;
              int thresholdDown = 075;
              MyMessage msg(CHILD_ID, V_LEVEL);
              unsigned long SLEEP_TIME = 30000;
              // We are setting up the pin A0 on the redboard to be our sensor
              // pin input:
              int sensorPin = A0;
              present(CHILD_ID, S_MOISTURE);
              int sensorValue;
              sensorValue = analogRead(sensorPin);
              //send back the values
              send(msg.set(sensorValue));
              // delay until next measurement (msec)
              sleep(SLEEP_TIME);
                k5austriaK Offline
                k5austria
                  k5austriaK Offline
                  k5austria
                    According to this project, he is using V_HUM and S_HUM. Maybe you could give a try and also include his more advanced features
                      k5austriaK Offline
                      k5austria
                        What error?
                          k5austriaK Offline
                          k5austria
                            k5austriaK Offline
                            k5austria
                              #define CHILD_ID 0 change to CHILD_ID_MOISTURE
                                k5austriaK Offline
                                k5austria
                                #define CHILD_ID_MOISTURE 0
                                MyMessage msg(CHILD_ID_MOISTURE, S_HUM);
                                // pin input:
                                int sensorPin = A0;
                                present(CHILD_ID_MOISTURE, S_HUM);
                                int sensorValue;
                                sleep(SLEEP_TIME);
                                  k5austriaK Offline
                                  k5austria
                                    You always need to specify a value
                                      k5austriaK Offline
                                      k5austria
                                        5th row of your code
                                          k5austriaK Offline
                                          k5austria
