  3. Domoticz
  4. Domoticz - soil moisture + one relay = Lua script error (Blockly)
27 Posts 2 Posters 9.9k Views 2 Watching
  • k5austriaK
    k5austriaK
    k5austria
    Hi ,
    I want to link with blocky one soil moisture sensor and one Relay , but it always comes error message. I use MySensors hardware.
    Very simple but not work ?!
    https://www.domoticz.com/forum/viewtopic.php?f=62&t=17211
    My blueberries need soon the water. Please help me ! :?
    Thanks !
      Did you try to make some other rules involving either soil sensor or relay and see if error follows the soil sensor?
      • k5austriaK
        k5austriaK
        k5austria
        wrote on last edited by k5austria
        Hi ,
        thank you for your answer . I have tried others rules with relay and time. Everything works. Only if Moisture value is in function , come error message.
        2017-04-24 21:46:05.283 Error: EventSystem: Lua script error (Blockly), Name: soil moisture_1 => [string "result = 0; weekday = os.date('*t')['wday']; ..."]:1: attempt to index global 'utilitydevice' (a nil value)
        I have no experience with this thing i currently have no idea :disappointed:
        It would be good if works
          How do you present the soil sensor? Maybe I can try to replicate your error
          • k5austriaK
            k5austriaK
            k5austria
            Sorry !!! I have not seen your answer again !
            I tried everything but it did not work. The problem is value from soil moisture sensor . I think so !?
            If you fix the problem you have a drink from me :grinning:
            5_1493474335770_2017-04-29 15_46_39-Domoticz.png 4_1493474335769_2017-04-29 15_46_03-Domoticz.png 3_1493474335768_2017-04-29 15_44_25-Domoticz.png 2_1493474335767_2017-04-29 15_44_11-Domoticz.png 1_1493474335765_2017-04-29 15_43_47-Domoticz.png 0_1493474335763_2017-04-29 15_43_25-Domoticz.png
            • k5austriaK
              k5austriaK
              k5austria
              wrote on last edited by gohan
              #define CHILD_ID 0
              // Here we are setting up some water thresholds that we will
              // use later. Note that you will need to change these to match
              // your soil type and environment. It doesn't do much for me because I'm using domoticz
              int thresholdUp = 400;
              int thresholdDown = 075;
              MyMessage msg(CHILD_ID, V_LEVEL);
              unsigned long SLEEP_TIME = 30000;
              // We are setting up the pin A0 on the redboard to be our sensor
              // pin input:
              int sensorPin = A0;
              present(CHILD_ID, S_MOISTURE);
              int sensorValue;
              sensorValue = analogRead(sensorPin);
              //send back the values
              send(msg.set(sensorValue));
              // delay until next measurement (msec)
              sleep(SLEEP_TIME);
              • k5austriaK
                k5austriaK
                k5austria
                • k5austriaK
                  k5austriaK
                  k5austria
                    According to this project, he is using V_HUM and S_HUM. Maybe you could give a try and also include his more advanced features
                    • k5austriaK
                      k5austriaK
                      k5austria
                        What error?
                        • k5austriaK
                          k5austriaK
                          k5austria
                          • k5austriaK
                            k5austriaK
                            k5austria
                              #define CHILD_ID 0 change to CHILD_ID_MOISTURE
                              • k5austriaK
                                k5austriaK
                                k5austria
                                #define CHILD_ID_MOISTURE 0
                                MyMessage msg(CHILD_ID_MOISTURE, S_HUM);
                                // pin input:
                                int sensorPin = A0;
                                present(CHILD_ID_MOISTURE, S_HUM);
                                int sensorValue;
                                sleep(SLEEP_TIME);
                                • k5austriaK
                                  k5austriaK
                                  k5austria
                                    You always need to specify a value
                                    • k5austriaK
                                      k5austriaK
                                      k5austria
                                        5th row of your code
                                        • k5austriaK
                                          k5austriaK
                                          k5austria
