  3. Domoticz
  4. Domoticz - soil moisture + one relay = Lua script error (Blockly)
27 Posts 2 Posters 10.0k Views 2 Watching
  • k5austriaK
    k5austriaK
    k5austria
    Sorry !!! I have not seen your answer again !
    I tried everything but it did not work. The problem is value from soil moisture sensor . I think so !?
    If you fix the problem you have a drink from me :grinning:
    5_1493474335770_2017-04-29 15_46_39-Domoticz.png 4_1493474335769_2017-04-29 15_46_03-Domoticz.png 3_1493474335768_2017-04-29 15_44_25-Domoticz.png 2_1493474335767_2017-04-29 15_44_11-Domoticz.png 1_1493474335765_2017-04-29 15_43_47-Domoticz.png 0_1493474335763_2017-04-29 15_43_25-Domoticz.png
    • k5austriaK
      k5austriaK
      k5austria
      wrote on last edited by gohan
      #define CHILD_ID 0
      // Here we are setting up some water thresholds that we will
      // use later. Note that you will need to change these to match
      // your soil type and environment. It doesn't do much for me because I'm using domoticz
      int thresholdUp = 400;
      int thresholdDown = 075;
      MyMessage msg(CHILD_ID, V_LEVEL);
      unsigned long SLEEP_TIME = 30000;
      // We are setting up the pin A0 on the redboard to be our sensor
      // pin input:
      int sensorPin = A0;
      present(CHILD_ID, S_MOISTURE);
      int sensorValue;
      sensorValue = analogRead(sensorPin);
      //send back the values
      send(msg.set(sensorValue));
      // delay until next measurement (msec)
      sleep(SLEEP_TIME);
      • k5austriaK
        k5austriaK
        k5austria
        • k5austriaK
          k5austriaK
          k5austria
            According to this project, he is using V_HUM and S_HUM. Maybe you could give a try and also include his more advanced features
            • k5austriaK
              k5austriaK
              k5austria
                What error?
                • k5austriaK
                  k5austriaK
                  k5austria
                  • k5austriaK
                    k5austriaK
                    k5austria
                      #define CHILD_ID 0 change to CHILD_ID_MOISTURE
                      • k5austriaK
                        k5austriaK
                        k5austria
                        wrote on last edited by k5austria
                        #define CHILD_ID_MOISTURE 0
                        MyMessage msg(CHILD_ID_MOISTURE, S_HUM);
                        // pin input:
                        int sensorPin = A0;
                        present(CHILD_ID_MOISTURE, S_HUM);
                        int sensorValue;
                        sleep(SLEEP_TIME);
                        • k5austriaK
                          k5austriaK
                          k5austria
                            You always need to specify a value
                            • k5austriaK
                              k5austriaK
                              k5austria
                                5th row of your code
                                • k5austriaK
                                  k5austriaK
                                  k5austria
                                  • k5austriaK
                                    k5austriaK
                                    k5austria
                                    • k5austriaK
                                      k5austriaK
                                      k5austria
                                      • k5austriaK
                                        k5austriaK
                                        k5austria
                                        #23
                                        Sensor logs on to Gateway only with original sketch. Other sketchs can be quite normal uploaded to Arduino but remains for GW invisible.
                                          Pls post node serial output when not connecting to the gateway
