  3. Domoticz
  4. Domoticz - soil moisture + one relay = Lua script error (Blockly)
27 Posts 2 Posters 10.0k Views 2 Watching
  • k5austriaK
    k5austriaK
    k5austria
    wrote on last edited by k5austria
    #define CHILD_ID_MOISTURE 0
    // Here we are setting up some water thresholds that we will
    // use later. Note that you will need to change these to match
    // your soil type and environment. It doesn't do much for me because I'm using domoticz
    int thresholdUp = 400;
    int thresholdDown = 075;
    MyMessage msg(CHILD_ID_MOISTURE, S_HUM);
    unsigned long SLEEP_TIME = 30000;
    // We are setting up the pin A0 on the redboard to be our sensor
    // pin input:
    int sensorPin = A0;
    present(CHILD_ID_MOISTURE, S_HUM);
    int sensorValue;
    sensorValue = analogRead(sensorPin);
    //send back the values
    send(msg.set(sensorValue));
    // delay until next measurement (msec)
    sleep(SLEEP_TIME);
    • k5austriaK
      k5austriaK
      k5austria
        You always need to specify a value
        • k5austriaK
          k5austriaK
          k5austria
            5th row of your code
            • k5austriaK
              k5austriaK
              k5austria
              • k5austriaK
                k5austriaK
                k5austria
                • k5austriaK
                  k5austriaK
                  k5austria
                  • k5austriaK
                    k5austriaK
                    k5austria
                    #23
                    Sensor logs on to Gateway only with original sketch. Other sketchs can be quite normal uploaded to Arduino but remains for GW invisible.
                      Pls post node serial output when not connecting to the gateway
                      • k5austriaK
                        k5austriaK
                        k5austria
                        wrote on last edited by gohan
                        #25
                        3 TSM:INIT
                        4 TSF:WUR:MS=0
                        11 TSM:INIT:TSP OK
                        13 TSF:SID:OK,ID=2
                        14 TSM:FPAR
                        51 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        775 TSF:MSG:READ,0-0-2,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                        780 TSF:MSG:FPAR OK,ID=0,D=1
                        2058 TSM:FPAR:OK
                        2059 TSM:ID
                        2060 TSM:ID:OK
                        2062 TSM:UPL
                        2065 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                        2074 TSF:MSG:READ,0-0-2,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                        2079 TSF:MSG:PONG RECV,HP=1
                        2081 TSM:UPL:OK
                        2083 TSM:READY:ID=2,PAR=0,DIS=1
                        2087 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                        2095 TSF:MSG:READ,0-0-2,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                        2102 TSF:MSG:SEND,2-2-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
                        2110 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                        2123 TSF:MSG:READ,0-0-2,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                        2132 TSF:MSG:SEND,2-2-0-0,s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        2139 MCO:REG:REQ
                        2146 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                        2152 TSF:MSG:READ,0-0-2,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                        2157 MCO:PIM:NODE REG=1
                        2160 MCO:BGN:INIT OK,TSP=1
                        2168 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=2,l=2,sg=0,ft=0,st=OK:413
                        2174 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
                        2180 MCO:SLP:TPD
                        2182 MCO:SLP:WUP=-1
                        2189 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=2,l=2,sg=0,ft=0,st=OK:412
                        2195 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
                        2200 MCO:SLP:TPD
                        2202 MCO:SLP:WUP=-1
                        2209 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=2,l=2,sg=0,ft=0,st=OK:412
                        2214 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
                        2220 MCO:SLP:TPD
                          Check yourself in the log parser page https://www.mysensors.org/build/parser
                          Your node is connected to gateway and reporting the values (look at the 413 - 412 -412 that were sent).
                          Also please use the Code TAG when posting code or logs as it makes it more readable.
                          • k5austriaK
                            k5austriaK
                            k5austria
                            #27
                            Ok ! Sorry !
                            After several reset from raspberry is the sensor visible by Domoticz, but is not in device list.
                            1_1493548837217_2017-04-30 12_23_44-Domoticz.png 0_1493548837214_2017-04-30 12_22_50-Domoticz.png
