  3. Domoticz
  4. Domoticz - soil moisture + one relay = Lua script error (Blockly)
27 Posts 2 Posters 10.0k Views 2 Watching
  • k5austriaK
    k5austriaK
    k5austria
      #define CHILD_ID_MOISTURE 0
      You always need to specify a value
      • k5austriaK
        k5austriaK
        k5austria
          5th row of your code
          • k5austriaK
            k5austriaK
            k5austria
            • k5austriaK
              k5austriaK
              k5austria
              • k5austriaK
                k5austriaK
                k5austria
                • k5austriaK
                  k5austriaK
                  k5austria
                  wrote on last edited by k5austria
                  #23
                  Sensor logs on to Gateway only with original sketch. Other sketchs can be quite normal uploaded to Arduino but remains for GW invisible.
                    Pls post node serial output when not connecting to the gateway
                    • k5austriaK
                      k5austriaK
                      k5austria
                      wrote on last edited by gohan
                      #25
                      3 TSM:INIT
                      4 TSF:WUR:MS=0
                      11 TSM:INIT:TSP OK
                      13 TSF:SID:OK,ID=2
                      14 TSM:FPAR
                      51 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      775 TSF:MSG:READ,0-0-2,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                      780 TSF:MSG:FPAR OK,ID=0,D=1
                      2058 TSM:FPAR:OK
                      2059 TSM:ID
                      2060 TSM:ID:OK
                      2062 TSM:UPL
                      2065 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                      2074 TSF:MSG:READ,0-0-2,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                      2079 TSF:MSG:PONG RECV,HP=1
                      2081 TSM:UPL:OK
                      2083 TSM:READY:ID=2,PAR=0,DIS=1
                      2087 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                      2095 TSF:MSG:READ,0-0-2,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                      2102 TSF:MSG:SEND,2-2-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
                      2110 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                      2123 TSF:MSG:READ,0-0-2,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                      2132 TSF:MSG:SEND,2-2-0-0,s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      2139 MCO:REG:REQ
                      2146 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                      2152 TSF:MSG:READ,0-0-2,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                      2157 MCO:PIM:NODE REG=1
                      2160 MCO:BGN:INIT OK,TSP=1
                      2168 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=2,l=2,sg=0,ft=0,st=OK:413
                      2174 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
                      2180 MCO:SLP:TPD
                      2182 MCO:SLP:WUP=-1
                      2189 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=2,l=2,sg=0,ft=0,st=OK:412
                      2195 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
                      2200 MCO:SLP:TPD
                      2202 MCO:SLP:WUP=-1
                      2209 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=2,l=2,sg=0,ft=0,st=OK:412
                      2214 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
                      2220 MCO:SLP:TPD
                        Check yourself in the log parser page https://www.mysensors.org/build/parser
                        Your node is connected to gateway and reporting the values (look at the 413 - 412 -412 that were sent).
                        Also please use the Code TAG when posting code or logs as it makes it more readable.
                        • k5austriaK
                          k5austriaK
                          k5austria
                          #27
                          Ok ! Sorry !
                          After several reset from raspberry is the sensor visible by Domoticz, but is not in device list.
                          1_1493548837217_2017-04-30 12_23_44-Domoticz.png 0_1493548837214_2017-04-30 12_22_50-Domoticz.png
