  2. Announcements
  3. 💬 Using Arduino
💬 Using Arduino
27 Posts 15 Posters 19.7k Views 15 Watching
    wrote on last edited by hek
    This thread contains comments for the article "Using Arduino" posted on MySensors.org.
    • dougD
      dougD
      doug
      Hi, just to let you know MySensors libraries don't seem to be found in Arduino IDE build 1.6.12
      • dougD doug
        @doug could you clarify what you mean?
        Are you unable to install the MySensors library? if so, what did you do and what message did you get?
          A Former User
          I think that Doug means that if you go to Sketch -> Include Library -> Manage Libraries... and enter MySens into the search box there is NO MySensor library to be included.
          Just found that out myself. Downloaded the 1.6.12 IDE and installed it on a "clean" mac OS X system.
          • Marc2014M
            Marc2014M
            Marc2014
            I test it now and have the same Problem. The Arduino IDE shows no MySens or MySensors Library to add. And so i can't use this. Can anybody help?
              A Former User
              As a work around I downloaded the zip file from: https://www.mysensors.org/download and added it with Sketch -> Add Library -> Add .ZIP Library. select the downloaded zip file.
              If you are done you can find the MySensors Library in the Sketch -> Add Library drop down list under Contributed Libraries.
              • tbowmoT
                tbowmoT
                tbowmo
                It seems that mysensors library is missing in arduino library manager..
                I have filed an issue with arduino on github, so hopefully we will get it solved
                • mahesh2000M
                  mahesh2000M
                  mahesh2000
                  Using Arduino IDE 1.6.2, no problem compiling MySensors/AltSoftwareSerial/Test/test.ino. Had to make two changes: add some #defines and include an extra library. I'm using a Nordic nRF24L01+ on a Chinese board. I had to add:
                  #define MY_GATEWAY_SERIAL
                  before
                  Also, had to add the AltSofwareSerial library, otherwise I received the error "AltSoftSerial.h: No such file or directory".
                  If I don't follow up with a new comment it means that this config worked. I'm on Windows 10, using a fakeduino Uno, hoping to connect to an nRF24LE1 over 250Kbps.
                  and MySensors libraries. A
                  • mahesh2000M
                    mahesh2000M
                    mahesh2000
                    couldn't get nRF24L01+ to work. Making do with two nRF24LE1s communicating with each other.
                    • mppM
                      mppM
                      mpp
                      Would be nice to have a link to the example sketches (the ones using external libraries) here: https://github.com/mysensors/MySensorsArduinoExamples
                      MyController with USB powered WeMos D1/mini ESP8266 MQTT Gateways and battery powered Arduino Pro Mini using the RFM69 radio
                      • mppM mpp
                        Thanks for the suggestion @mpp. I have added a section for the external examples.
                        • Matt BriggsM
                          Matt BriggsM
                          Matt Briggs
                          So this is going to cause an argument in the sketch?:
                          // This will be called contentiously after setup.
                          Maybe should be "continuously"
                          • N
                            N
                            Newzwaver
                            Why do i get this error? Any idea how to fix it?
                            Arduino: 1.6.5 (Windows 8.1), Board: "Arduino Uno"
                            In file included from C:\Users\Audrey\Documents\Arduino\libraries\MySensors/drivers/RF24/RF24.cpp:23:0,
                            from C:\Users\Audrey\Documents\Arduino\libraries\MySensors/MySensors.h:290,
                            from GatewayW5100.ino:116:
                            C:\Users\Audrey\Documents\Arduino\libraries\MySensors/drivers/RF24/RF24.h:37:17: fatal error: SPI.h: No such file or directory
                            compilation terminated.
                            Error compiling.
                            • N
                              N
                              Newzwaver
                              Messing around with it and got this message, still not idea how to fix it
                              Using library MySensors in folder: C:\Users\Audrey\Documents\Arduino\libraries\MySensors
                              Using library Ethernet in folder: C:\Program Files (x86)\Arduino\libraries\Ethernet
                              C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10605 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Users\Audrey\Documents\Arduino\libraries\MySensors -IC:\Program Files (x86)\Arduino\libraries\Ethernet\src C:\Users\Audrey\AppData\Local\Temp\build1062139905146989693.tmp\GatewayW5100.cpp -o C:\Users\Audrey\AppData\Local\Temp\build1062139905146989693.tmp\GatewayW5100.cpp.o
                              In file included from GatewayW5100.ino:2:0:
                              C:\Users\Audrey\Documents\Arduino\libraries\MySensors/MySensors.h:328:2: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
                              Error compiling.
                              • N Newzwaver
                                Error compiling.
                                @Newzwaver could you post the sketch?
                                • N
                                  N
                                  Newzwaver
                                  Thank you for your help, the thing is working. It has something to do with the way I have the Arduino software setup, for some reason I can't just copy a sketch and paste it in for a new sketch.
                                  • B
                                    B
                                    benji_lb
                                    The MySensors library is missing from the arduino library manager again. Should I just log a new issue and reference the previous one?
                                    • B benji_lb
                                      @benji_lb yes please do. Could you post the link to the issue here when it has been created so we can follow it?
                                      B 1 Reply Last reply
                                        B
                                        B
                                        benji_lb
                                        @mfalkvidd https://github.com/arduino/Arduino/issues/6690
                                        Done.
                                        • B benji_lb
                                          Done.
                                          B
                                          B
                                          benji_lb
                                          @benji_lb
                                          Fixed. I noticed I was running an older version of the software. Uninstalled completely and reinstalled, worked fine.
                                          Where would be the best place for an Arduino newbie to post to get some assistance? I'm looking at Gateways and i'm unsure which direction to take, and where would be best to post. Would this be OK? https://forum.mysensors.org/category/13/development
