  3. Slim Node as a Mini 2AA Battery PIR Motion Sensor
36 Posts 12 Posters 30.7k Views 19 Watching
  • siodS
    siodS
    siod
    Hi guys,
    I am wondering, if it wouldn´t be a good idea to use the PinChangeInt Library to wake the arduino from sleep by pin change interrupts. Wouldn´t this be the most power efficient variant? Or did I understand sth. wrong with the pin change interrupts? Thanks for your help in advance!!
    still learning...
    • L
      L
      LastSamurai
      I have build a small sensor platform and I am currently running it off of a CR2032 coin cell (small and cheap). I used the same motion sensor as in this thread to build a motion detector. Everything seems to work fine until the voltage drops below ~2.8V, then it starts to trigger constantly. I guess the problem is the low voltage.
      Has anyone found a working setup with a low(er) voltage? Or successfully used a boost converter with a pir (creates false positives as well for me, although I will try that later too).
      Otherwise I would have to use 2xaa (too big) or CR123A (still kinda big and not very cheap) too ;(
      m26872M 1 Reply Last reply
      • L LastSamurai
        m26872M
        m26872M
        m26872
        @LastSamurai Since I tested it ok down to 1.6V with one AA, I have a feeling that the issue could be voltage stability rather than level. Maybe you could try two CR2032 in parallel ?
        L 1 Reply Last reply
        • m26872M m26872
          L
          L
          LastSamurai
          @m26872 Great idea, that might help. I am currently trying out another battery, and if that doesn't work I will try 2 in parallel.
          • JonnyDev13J
            JonnyDev13J
            JonnyDev13
            @m26872, am I understanding correctly that you did not need to step the voltage up to 5v in order to use this PIR sensor? If that's correct, do you know if the HC-SR505 works the same way? I will probably buy some of these smaller ones, but I have HC-SR505s on hand right now and would want to try it soon.
            • JonnyDev13J JonnyDev13
              m26872M
              m26872M
              m26872
              @JonnyDev13 This IS the HC-SR505 (5V Mini PIR). With the voltage regulator and diode removed.
              Did you mean that you have the larger HC-SR501 ? In that case I don't know. I only remember that you'll need to remove the v-reg and diode in the same way to make it run on 3.3V. And I think @bjornhallberg reported successful results from longterm use of a batterypowered outdoor one.
              JonnyDev13J 1 Reply Last reply
              • m26872M m26872
                JonnyDev13J
                JonnyDev13J
                JonnyDev13
                wrote on last edited by JonnyDev13
                @m26872, yes you are correct. I have the larger ones. I must have copied and pasted the wrong part number. Thanks for the quick response. That's helpful information!
                • K
                  K
                  Komaandy
                  Hello everybody,
                  I´m struggeling with getting this sensor
                  to work.
                  The node registers with the GW, but doesnt submit the tripped reading.
                  Not even a permanent on or something. Just nothing. So i dont know how to troubleshoot here.
                  The PIR HC-SR505 is functional. I tested it with a testscript on a UNO.
                  And the 2AA Slimnode is functional as well. When using the node as a binary switch it works perfectly fine,
                  Just the combination 2AA Slimnode and HC-SR505 doesnt work.
                  Anybody has an idea ?
                  Thanks in advance Komaandy
                  AWIA 1 Reply Last reply
                  • K Komaandy
                    Hello everybody,
                    to work.
                    AWIA
                    AWIA
                    AWI
                    wrote on last edited by AWI
                    #21
                    @Komaandy how are you powering the circuit?
                    The pir sensor is very sensitive to power fluctuations and not suited for below 3v. Also for 3v you need to "modify" the sensors power circuit. You should be able to find a lot of information when searching for the sensor.
                    • K
                      K
                      Komaandy
                      @ awi, so i desolderd and bridged the two mentioned components, and with the standard " Motion Detector " sketch it transmits tripped readings now :)
                      I power the circuit via a UNO ( 3,3Volt) or via 2 AA batterys ( 3,1 Volts -> meassured via multimeter)
                      but when using the given sketch in this thread only battery readings are transmitted...
                      KR
                      Komaandy
                      • K
                        K
                        Komaandy
                        Hello, when running the "Motion Detector sketch from the mysensors-examples" on these nodes with the 1Mhz bootloader with 2aa batteries some nodes freeze after appr. 24h .
                        Some continue working, i cant find the problem.
                        Does anybody have a idea what could cause those freezes ?
                        Thanks in advance
                        • K Komaandy
                          Thanks in advance
                          m26872M
                          m26872M
                          m26872
                          wrote on last edited by m26872
                          #24
                          @Komaandy Have you tried to add a sleep(3000); before the last sleep(...)?
                          • K
                            K
                            Komaandy
                            @m26872 Thanks for your answer and thanks for this superb node :) :)
                            No, i didnt put the additional sleep in , where should I put this ? Im a little confused...
                             * Version 1.0 - Henrik Ekblad
                            // Enable debug prints
                            // #define MY_DEBUG
                            // Initialize motion message
                                present(CHILD_ID, S_MOTION);
                                // Read digital motion value
                                bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
                                Serial.println(tripped);
                            • K Komaandy
                              // #define MY_DEBUG
                              m26872M
                              m26872M
                              m26872
                              #26
                              @Komaandy said in Slim Node as a Mini 2AA Battery PIR Motion Sensor:
                              I meant like this (look in code below), but it's just a wild guess.
                              // #define MY_DEBUG
                                  sleep(3000);  // Sleep 3s to make sure everything is stable before we start to sleep with interrupts.
                              • siodS
                                siodS
                                siod
                                @m26872 said in Slim Node as a Mini 2AA Battery PIR Motion Sensor:
                                Removing the 7133-regulator did not affect anything significantly due to its very low quiescent current (see datasheet, perhaps useful in some other project?)
                                ok, does that mean one does not have to remove the voltage regulator and the diode? @AWI is saying one must modify the PIR and now I am irritated...
                                still learning...
                                • K
                                  K
                                  Komaandy
                                  wrote on last edited by Komaandy
                                  #28
                                  @siod
                                  I removed both to make the smaller ( HC-SR505 ) work with ~3Volt and bridged these contacts as shown in the picture
                                  They work perfectly fine for me and are not too sensitive.
                                  Actually they dont even react on my cats, which is nice, because the "bigger" HC-SR501 always did... :)
                                  • K
                                    K
                                    Komaandy
                                    #29
                                    And with the "bigger" HC-SR501 all one need to do is obviously to connect the VCC to the pad or pin.
                                    For me at least it is working pretty fine as well. No false positives or anything else negative.
                                    Of course you have to remove the jumper first.
                                    • siodS siod
                                      m26872M
                                      m26872M
                                      m26872
                                      @siod said in Slim Node as a Mini 2AA Battery PIR Motion Sensor:
                                      That was only regarding the power consumption. I don't remember the voltage drops but I guess you'll get to it work with 2AA but for a shorter time. Why wont you remove them?
                                      • siodS
                                        siodS
                                        siod
                                        wrote on last edited by siod
                                        #31
                                        ok guys, I tried the mini PIR and the big one, on the mini PIR I removed the regulator and diode just as explained and I uploaded this sketch
                                         * EgSlimReed2
                                         * Sketch for Slim Node and HC-SR505 based motion sensor.
                                         * Inspired by:
                                         * - MySensors motion sensor example: http://www.mysensors.org/build/motion
                                         * - AWI's CR123A based Slim Node motion sensor: http://forum.mysensors.org/topic/2478/slim-cr123a-2aa-battery-node
                                         * Created by m26872
                                         * Documentation: http://forum.mysensors.org...
                                         * Version 1.0 - Test to if node can operate in some way dealing with the Pir extreme sensitivity to noise on Vcc.
                                         * Version 2.0 - First "production node". "Inactivity day counter" introduced.
                                         * This sketch will only send trips as "1" to the controller. It's up to the controller to deal with the info.
                                         * The motion node will not notify controller when resets back to low state and is ready for a new trip. In reality
                                         * this is ~10s. And EVEN IF motion is detected continuously, there will be no new trip until motion has stopped for ~10s.
                                         * The HC-SR505 is very noise sensitive and will trigger spuriously for almost any activity
                                         * on Vcc (test thoroughly). To run the HC-505 at low voltages (tested flawlessly down to 1.6V),
                                         * the 7133-reg and diode are removed (and possibly increase the sensitivity even further).
                                         * Solution is to deal with it by interrupt type, check which source, block by sleep time etc.
                                         * HC-505 output connects to MOTION_INPUT_PIN (here D3) without any supporting component. Input pull-up disabled.
                                         * Every 24 hrs without trip, increments a counter and after "BATTERY_REPORT_DAY" counts a battery report will be sent as a heartbeat signal.
                                         * Else a battery report will be sent after every "BATTERY_REPORT_BY_IRT_CYCLE" motion trips.
                                         //Sensor 21, erster PIR Sensor
                                        // Define Node ID
                                        #define MY_NODE_ID 21
                                        #define MY_PARENT_NODE_ID 0 //Repeater Node 1!
                                        //Batterysensor
                                        int oldBatteryPcnt = 0;
                                        #define CHILD_ID_BATT 7
                                        #include <Vcc.h>
                                        unsigned long SLEEP_TIME = 86400000; // Sleep time between reports (in milliseconds)
                                        //Battery
                                            //Batterysensor
                                           analogReference(INTERNAL1V1);
                                           analogReference(INTERNAL);
                                            sendSketchInfo("Motion Sensor Keller_1", "1.0");
                                            //Battery
                                            //Batterysensor
                                          // get the battery Voltage
                                           #ifdef DEBUG
                                           //float batteryV  = sensorValue * 0.003363075;
                                             wait(500);
                                             send(msgbatt.set(batteryPcnt));
                                             wait(500);
                                            // Sleep until interrupt comes in on motion sensor. Send update every 24 hours.
                                        But with any PIR I get continuos trip messages every 3 seconds. Any idea?
                                        still learning...
                                        • K
                                          K
                                          Komaandy
                                          #32
                                          I am having the exact same issues with the Mysensor2.0 version ... (!)
                                          When using Arduino IDE 1.65 and Mysensor 1.54 librarys and the sketch that is pinned in the header it works .
