  3. Slim Node as a Mini 2AA Battery PIR Motion Sensor
36 Posts 12 Posters 30.7k Views 19 Watching
  • JonnyDev13J
    JonnyDev13J
    JonnyDev13
    @m26872, am I understanding correctly that you did not need to step the voltage up to 5v in order to use this PIR sensor? If that's correct, do you know if the HC-SR505 works the same way? I will probably buy some of these smaller ones, but I have HC-SR505s on hand right now and would want to try it soon.
    m26872M 1 Reply Last reply
    • JonnyDev13J JonnyDev13
      m26872M
      m26872M
      m26872
      @JonnyDev13 This IS the HC-SR505 (5V Mini PIR). With the voltage regulator and diode removed.
      Did you mean that you have the larger HC-SR501 ? In that case I don't know. I only remember that you'll need to remove the v-reg and diode in the same way to make it run on 3.3V. And I think @bjornhallberg reported successful results from longterm use of a batterypowered outdoor one.
      JonnyDev13J 1 Reply Last reply
      • m26872M m26872
        JonnyDev13J
        JonnyDev13J
        JonnyDev13
        wrote on last edited by JonnyDev13
        @m26872, yes you are correct. I have the larger ones. I must have copied and pasted the wrong part number. Thanks for the quick response. That's helpful information!
        • K
          K
          Komaandy
          Hello everybody,
          I´m struggeling with getting this sensor
          to work.
          The node registers with the GW, but doesnt submit the tripped reading.
          Not even a permanent on or something. Just nothing. So i dont know how to troubleshoot here.
          The PIR HC-SR505 is functional. I tested it with a testscript on a UNO.
          And the 2AA Slimnode is functional as well. When using the node as a binary switch it works perfectly fine,
          Just the combination 2AA Slimnode and HC-SR505 doesnt work.
          Anybody has an idea ?
          Thanks in advance Komaandy
          AWIA 1 Reply Last reply
          • K Komaandy
            Hello everybody,
            to work.
            AWIA
            AWIA
            AWI
            wrote on last edited by AWI
            #21
            @Komaandy how are you powering the circuit?
            The pir sensor is very sensitive to power fluctuations and not suited for below 3v. Also for 3v you need to "modify" the sensors power circuit. You should be able to find a lot of information when searching for the sensor.
            • K
              K
              Komaandy
              @ awi, so i desolderd and bridged the two mentioned components, and with the standard " Motion Detector " sketch it transmits tripped readings now :)
              I power the circuit via a UNO ( 3,3Volt) or via 2 AA batterys ( 3,1 Volts -> meassured via multimeter)
              but when using the given sketch in this thread only battery readings are transmitted...
              KR
              Komaandy
              • K
                K
                Komaandy
                Hello, when running the "Motion Detector sketch from the mysensors-examples" on these nodes with the 1Mhz bootloader with 2aa batteries some nodes freeze after appr. 24h .
                Some continue working, i cant find the problem.
                Does anybody have a idea what could cause those freezes ?
                Thanks in advance
                • K Komaandy
                  Thanks in advance
                  m26872M
                  m26872M
                  m26872
                  wrote on last edited by m26872
                  #24
                  @Komaandy Have you tried to add a sleep(3000); before the last sleep(...)?
                  • K
                    K
                    Komaandy
                    @m26872 Thanks for your answer and thanks for this superb node :) :)
                    No, i didnt put the additional sleep in , where should I put this ? Im a little confused...
                     * Version 1.0 - Henrik Ekblad
                    // Enable debug prints
                    // #define MY_DEBUG
                    // Initialize motion message
                        present(CHILD_ID, S_MOTION);
                        // Read digital motion value
                        bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
                        Serial.println(tripped);
                    • K Komaandy
                      // #define MY_DEBUG
                      m26872M
                      m26872M
                      m26872
                      #26
                      @Komaandy said in Slim Node as a Mini 2AA Battery PIR Motion Sensor:
                      I meant like this (look in code below), but it's just a wild guess.
                      // #define MY_DEBUG
                          sleep(3000);  // Sleep 3s to make sure everything is stable before we start to sleep with interrupts.
                      • siodS
                        siodS
                        siod
                        @m26872 said in Slim Node as a Mini 2AA Battery PIR Motion Sensor:
                        Removing the 7133-regulator did not affect anything significantly due to its very low quiescent current (see datasheet, perhaps useful in some other project?)
                        ok, does that mean one does not have to remove the voltage regulator and the diode? @AWI is saying one must modify the PIR and now I am irritated...
                        still learning...
                        • K
                          K
                          Komaandy
                          wrote on last edited by Komaandy
                          #28
                          @siod
                          I removed both to make the smaller ( HC-SR505 ) work with ~3Volt and bridged these contacts as shown in the picture
                          They work perfectly fine for me and are not too sensitive.
                          Actually they dont even react on my cats, which is nice, because the "bigger" HC-SR501 always did... :)
                          • K
                            K
                            Komaandy
                            #29
                            And with the "bigger" HC-SR501 all one need to do is obviously to connect the VCC to the pad or pin.
                            For me at least it is working pretty fine as well. No false positives or anything else negative.
                            Of course you have to remove the jumper first.
                            • siodS siod
                              m26872M
                              m26872M
                              m26872
                              @siod said in Slim Node as a Mini 2AA Battery PIR Motion Sensor:
                              That was only regarding the power consumption. I don't remember the voltage drops but I guess you'll get to it work with 2AA but for a shorter time. Why wont you remove them?
                              • siodS
                                siodS
                                siod
                                wrote on last edited by siod
                                #31
                                ok guys, I tried the mini PIR and the big one, on the mini PIR I removed the regulator and diode just as explained and I uploaded this sketch
                                 * EgSlimReed2
                                 * Sketch for Slim Node and HC-SR505 based motion sensor.
                                 * Inspired by:
                                 * - MySensors motion sensor example: http://www.mysensors.org/build/motion
                                 * - AWI's CR123A based Slim Node motion sensor: http://forum.mysensors.org/topic/2478/slim-cr123a-2aa-battery-node
                                 * Created by m26872
                                 * Documentation: http://forum.mysensors.org...
                                 * Version 1.0 - Test to if node can operate in some way dealing with the Pir extreme sensitivity to noise on Vcc.
                                 * Version 2.0 - First "production node". "Inactivity day counter" introduced.
                                 * This sketch will only send trips as "1" to the controller. It's up to the controller to deal with the info.
                                 * The motion node will not notify controller when resets back to low state and is ready for a new trip. In reality
                                 * this is ~10s. And EVEN IF motion is detected continuously, there will be no new trip until motion has stopped for ~10s.
                                 * The HC-SR505 is very noise sensitive and will trigger spuriously for almost any activity
                                 * on Vcc (test thoroughly). To run the HC-505 at low voltages (tested flawlessly down to 1.6V),
                                 * the 7133-reg and diode are removed (and possibly increase the sensitivity even further).
                                 * Solution is to deal with it by interrupt type, check which source, block by sleep time etc.
                                 * HC-505 output connects to MOTION_INPUT_PIN (here D3) without any supporting component. Input pull-up disabled.
                                 * Every 24 hrs without trip, increments a counter and after "BATTERY_REPORT_DAY" counts a battery report will be sent as a heartbeat signal.
                                 * Else a battery report will be sent after every "BATTERY_REPORT_BY_IRT_CYCLE" motion trips.
                                 //Sensor 21, erster PIR Sensor
                                // Define Node ID
                                #define MY_NODE_ID 21
                                #define MY_PARENT_NODE_ID 0 //Repeater Node 1!
                                //Batterysensor
                                int oldBatteryPcnt = 0;
                                #define CHILD_ID_BATT 7
                                #include <Vcc.h>
                                unsigned long SLEEP_TIME = 86400000; // Sleep time between reports (in milliseconds)
                                //Battery
                                    //Batterysensor
                                   analogReference(INTERNAL1V1);
                                   analogReference(INTERNAL);
                                    sendSketchInfo("Motion Sensor Keller_1", "1.0");
                                    //Battery
                                    //Batterysensor
                                  // get the battery Voltage
                                   #ifdef DEBUG
                                   //float batteryV  = sensorValue * 0.003363075;
                                     wait(500);
                                     send(msgbatt.set(batteryPcnt));
                                     wait(500);
                                    // Sleep until interrupt comes in on motion sensor. Send update every 24 hours.
                                But with any PIR I get continuos trip messages every 3 seconds. Any idea?
                                still learning...
                                • K
                                  K
                                  Komaandy
                                  #32
                                  I am having the exact same issues with the Mysensor2.0 version ... (!)
                                  When using Arduino IDE 1.65 and Mysensor 1.54 librarys and the sketch that is pinned in the header it works .
                                  • K Komaandy
                                    m26872M
                                    m26872M
                                    m26872
                                    @Komaandy @siod
                                    Did you try version 2.2 as in https://forum.mysensors.org/topic/6511/hc-sr501-3-3v-randomly-sends-tripped-when-radio-is-on/36 ?
                                    • siodS
                                      siodS
                                      siod
                                      #34
                                      Nope, 2.2 is giving me the same fail trip messages.
                                      When using IDE 1.6.5 with 1.5.4 I don´t even get it compiled, Arduino is automatically using 2.2.0 library from 1.8.2 version which is, of course, still installed on my system and I don´t want to uninstall it...
                                      edit: Ok, the way @komaandy proposed is working, though I like the other sketch more...
                                      edit2: Well, seems like it has sth. to do with the battery sensing: when removing this part from void loop() it works as it is supposed to (see what I commented out between /* and */):
                                          //Batterysensor
                                         /*int sensorValue = analogRead(BATTERY_SENSE_PIN);
                                         #ifdef DEBUG
                                           gw.wait(500);
                                           gw.send(msgbatt.set(batteryPcnt));
                                           gw.wait(500);
                                        if (interruptReturn) {  // Woke up by rising pin
                                        gw.send(msg.set("1"));  // Just send trip (set) commands to controller. (Let controller reset and decide what to do with it.)
                                        irtCounter++;
                                        gw.sleep(3000);  // Make sure everything is stable before start to sleep with interrupts. (don't use "gw.wait()" here). Tests shows false trip ~2s after battery report otherwise.
                                        // Sleep until interrupt comes in on motion sensor or sleep time passed.
                                        interruptReturn = gw.sleep(MOTION_INPUT_PIN-2,CHANGE, ONE_DAY_SLEEP_TIME);
                                        // DEBUG_PRINT("interruptReturn: ");DEBUG_PRINTLN(interruptReturn);
                                      edit3: I obviously mixed up things, now it seems like it´s working... I will report back after some time of testing, but this should be my working code:
                                       * EgSlimReed2
                                       * Inspired by:
                                       * Created by m26872
                                      // Define Node ID
                                      #define MY_PARENT_NODE_ID 0 //Repeater Node 1=50 / Gateway=0!
                                      //Batterysensor
                                      #include <Vcc.h>
                                      //#define DEBUG
                                      #define SKETCH_NAME "Motion PIR Keller_1"
                                      #define SKETCH_VERSION "2.0"
                                      #define CHILD_ID 1
                                      #define MOTION_INPUT_PIN 3
                                      #define BATTERY_REPORT_DAY 2   // Desired heartbeat(battery report) interval when inactive.
                                      #define BATTERY_REPORT_BY_IRT_CYCLE 10  // Make a battery report after this many trips. Maximum report interval will also be equal to this number of days.
                                      #define ONE_DAY_SLEEP_TIME 86400000
                                      #define VCC_MIN 1.9
                                      #define VCC_MAX 3.3
                                      #ifdef DEBUG
                                      int dayCounter = BATTERY_REPORT_DAY;
                                      int irtCounter = 0;
                                      bool interruptReturn = false; // "false" will make the first loop disregard high output from HV-505 (from start-up) and make a battery report instead.
                                      Vcc vcc;
                                      //Battery
                                            //Batterysensor
                                        DEBUG_SERIAL(9600);
                                        DEBUG_PRINTLN(("Serial started"));
                                        delay(100); // to settle power for radio
                                        gw.begin(NULL,MY_NODE_ID);
                                        pinMode(MOTION_INPUT_PIN, INPUT);
                                        digitalWrite(MOTION_INPUT_PIN, LOW);    // Disable internal pull-ups
                                        gw.present(CHILD_ID, S_MOTION);
                                        DEBUG_PRINTLN("Warming and blocking PIR trip for 20s.");
                                        gw.sleep(20000); // Wait until HC-505 warmed-up and output returned low.
                                          gw.sendSketchInfo("Motion Sensor Keller_1", "1.0");
                                          //Battery
                                          gw.present(CHILD_ID_BATT,V_VOLTAGE);
                                          //Batterysensor
                                         #ifdef DEBUG
                                           gw.wait(500);
                                           gw.wait(500);
                                          irtCounter++;
                                        if (irtCounter>=BATTERY_REPORT_BY_IRT_CYCLE) {
                                          irtCounter=0;
                                          sendBatteryReport();
                                        else { // Woke up by timer  (or it's the first run)
                                        dayCounter++;
                                        if (dayCounter >= BATTERY_REPORT_DAY) {
                                            dayCounter = 0;
                                      void sendBatteryReport() {
                                            float p = vcc.Read_Perc(VCC_MIN, VCC_MAX, true);
                                            int batteryPcnt = static_cast<int>(p);
                                      edit4: ok, with my edited code this sketch is also working fine now with IDE 1.8.2 and lib 2.2.0 beta. So now everythings works fine!
                                       * EgSlimReed2
                                       * Inspired by:
                                       * Created by m26872
                                      // Define Node ID
                                      #define MY_PARENT_NODE_ID 50 //Repeater Node 1!
                                      //Batterysensor
                                      #include <Vcc.h>
                                      #define VCC_MIN 1.9
                                      #define VCC_MAX 3.3
                                      int irtCounter = 0;
                                      Vcc vcc;
                                      //Battery
                                          //Batterysensor
                                          //Battery
                                          //Batterysensor
                                         #ifdef DEBUG
                                           wait(500);
                                           wait(500);
                                              irtCounter++;
                                          irtCounter=0;
                                        dayCounter++;
                                            dayCounter = 0;
                                      still learning...
                                      • Sven 0S
                                        Sven 0S
                                        Sven 0
                                        I know this is an old topic, but it seems tried and true, so.. How is everyone's experience with this design sofar? Has it been reliable? How far has the 24 month battery life claim held up?
                                        I've been looking for a detection node that I could use for various tasks around the house (Motion detect, reed switch detect, even a simple door bell). But with a plain arduino pro mini I keep running into abysmal battery life. However this setup seems to handle a year on some AA batteries quite easily?
                                        If I can get some confirmation on the reliability on these, I can pull the trigger on producing a handful of these slimnodes. ;)
                                        • Sven 0S Sven 0
                                          m26872M
                                          m26872M
                                          m26872
                                          @Sven-0
                                          Fun to see this old topic again. And also the coincidence, since my visits here have been rare for a long time. :disappointed:
                                          Anyway, I'm running a few slimnodes since the beginning and have both good and bad experiences. In general, the battery lifetime is your least concern. Instead I have had issues with sensors, sensitivity, switch contact corrosion, mechanical robustness, wifi interference, repaeter, gateway, controller, waf, kids, animals, etc, etc.
                                          Regarding this particular PIR slimnode it's very stable, but it is not universal for every situation due to the limited range and missing sinsitivity adjustment. E.g I can't use it too near my basement windows due to the moving cold air. And in my living room I have sun reflections to deal with.
                                          I suggest you start by building a testnode to check if it works for your conditions.:slot_machine:
                                          A recent PIR-slimnode battery life example; My hallway one died last week after 33 months and around 6000 trips/month.:muscle:
