  3. Your workshop :)
Your workshop :)
183 Posts 36 Posters 108.4k Views 28 Watching
  • YveauxY Yveaux
    @AWI said:
    a universal component tester 11 Euro..
    And click ;-)
    AWIA
    AWIA
    AWI
    wrote on last edited by AWI
    #83
    @Yveaux An updated version ... this one generates PWM, measure frequency and even measures DS18B20 / DHT..
    • J
      J
      Jan Gatzke
      I am especially proud of my 20 years old analog soldering station. :D
      • J Jan Gatzke
        @Jan-Gatzke said in Your workshop :):
        I have the exact same one! :+1:
        However, it's not in use anymore :flushed:
        J 1 Reply Last reply
        • YveauxY Yveaux
          J
          J
          Jan Gatzke
          @Yveaux
          I just bought a new soldering iron for it last year. Had to google for days to find spare parts. :D
          • AWIA AWI
            @AWI said in Your workshop :):
            An updated version
            Kicken!
              wrote on last edited by gohan
              #88
              Im thinking about getting this thing, do you think it may be useful ?
              dbemowskD 1 Reply Last reply
                dbemowskD
                dbemowskD
                @gohan That looks very much like the one that @AWI posted previously in the thread only with a nice case and a color display. The one he posted is quite a bit cheaper. I may get one myself and just 3D print a case for it. I can use your link for the 3D case design.
                http://s.click.aliexpress.com/deep_link.htm?dl_target_url=http%3A%2F%2Fwww.aliexpress.com%2Fitem%2FNew-2016-12864-LCD-Transistor-Tester-Capacitance-ESR-Meter-Diode-Triode-MOS-NPN-LCR-Mega328%2F32579390679.html&aff_short_key=e2Vzr3v
                • dbemowskD
                  dbemowskD
                  Just looked on ebay, and here is one a bit cheaper that comes with a basic case.
                  http://www.ebay.com/itm/LCR-T4-Mega328-Transistor-Tester-Diode-Triode-Capacitance-ESR-Meter-MOS-NPN-PNP-/222247985900?var=&hash=item33bf0322ec:m:mLakYynk0RqdZT62qrYQfdw
                    if you want the case it costs 10$. The one I posted it seems to have pretty much the same specs, but it can detect also IR and probably some more components. It also comes with a lithium battery instead of the classic 9V, color screen and the case looks much better :)
                    J AWIA 2 Replies Last reply
                      J
                      J
                      Jan Gatzke
                      @gohan You are right. I just ordered the thing. With the case and the builtin battery it looks like a real tool. The price seems to be a promotion. Normal price is >30$.
                      You shoult by the way fix the link. Makes it easier for others to order it.
                      I am looking for a soldering vise. Has anyone tested this one: https://www.amazon.de/dp/B00196RV9C/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=2COJS1QZ6SUVJ&coliid=IQEGMI1GM2R46 ?
                        Fixed the link; anyway it is a recurring promotion because I have seen that price for quite a while :)
                          J
                          J
                          Jan Gatzke
                          @gohan Then you can safely lean back and wait for my review. ;)
                            @Jan-Gatzke
                            I have something similar on my workbench. Very useful.
                              nice wall decoration for a workshop :P :D
                                @gohan
                                I didn't select the wallpaper.... :woman: :kissing_closed_eyes:
                                • J Jan Gatzke
                                  #98
                                  @Jan-Gatzke I have this one:
                                  0_1494092799058_upload-26847c60-5afa-46a8-85f7-ece57c9b7960
                                  It's able to hold all kinds of PCB sizes and can rotate easily.
                                  Tip for soldering through-hole components from the back without them falling out:
                                  Place all components on the top of the PCB and put a sponge or scotch-brite on top of them. Fix to the PCB with some rubber bands and swap the PCB to solder!
                                  • YveauxY Yveaux
                                    J
                                    J
                                    Jan Gatzke
                                    @Yveaux I saw that thing on Amazon. There was a review saying the brackets would melt easily when using hot air. Did you use this with hot air?
                                    • J Jan Gatzke
                                      When you clamp a PCB in it only the edges are held by the plastic brackets.
                                      Unless you are blowing directly on the edge of the PCB where it is held I can imagine this could be a problem, but then, why don't you shift or rotate the PCB to get away from the brackets?
                                      Yes
                                        AWIA
                                        AWIA
                                        AWI
                                        @gohan Be aware that there are quite a few different versions around. The one I posted has a rotary encoder to select and operate the pwm and frequency functions. The perspex casing fits well with the rest of the nerdy testboxes I own (dummy load, power supply, a few function generators, frequencycounter ) All a lot of functionality for very little..
                                          Aren't these devices basically Arduinos? It's written on the title atmega328. If so if we could get our hands on the code, we could make our own 😀
                                          AWIA 1 Reply Last reply
