  3. Your workshop :)
Your workshop :)
183 Posts 36 Posters 108.4k Views 28 Watching
    Im thinking about getting this thing, do you think it may be useful ?
    dbemowskD
    dbemowskD
    @gohan That looks very much like the one that @AWI posted previously in the thread only with a nice case and a color display. The one he posted is quite a bit cheaper. I may get one myself and just 3D print a case for it. I can use your link for the 3D case design.
    http://s.click.aliexpress.com/deep_link.htm?dl_target_url=http%3A%2F%2Fwww.aliexpress.com%2Fitem%2FNew-2016-12864-LCD-Transistor-Tester-Capacitance-ESR-Meter-Diode-Triode-MOS-NPN-LCR-Mega328%2F32579390679.html&aff_short_key=e2Vzr3v
    • dbemowskD
      dbemowskD
      Just looked on ebay, and here is one a bit cheaper that comes with a basic case.
      http://www.ebay.com/itm/LCR-T4-Mega328-Transistor-Tester-Diode-Triode-Capacitance-ESR-Meter-MOS-NPN-PNP-/222247985900?var=&hash=item33bf0322ec:m:mLakYynk0RqdZT62qrYQfdw
        if you want the case it costs 10$. The one I posted it seems to have pretty much the same specs, but it can detect also IR and probably some more components. It also comes with a lithium battery instead of the classic 9V, color screen and the case looks much better :)
        J AWIA 2 Replies Last reply
          J
          J
          Jan Gatzke
          @gohan You are right. I just ordered the thing. With the case and the builtin battery it looks like a real tool. The price seems to be a promotion. Normal price is >30$.
          You shoult by the way fix the link. Makes it easier for others to order it.
          I am looking for a soldering vise. Has anyone tested this one: https://www.amazon.de/dp/B00196RV9C/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=2COJS1QZ6SUVJ&coliid=IQEGMI1GM2R46 ?
            Fixed the link; anyway it is a recurring promotion because I have seen that price for quite a while :)
            J 1 Reply Last reply
              J
              J
              Jan Gatzke
              @gohan Then you can safely lean back and wait for my review. ;)
                @Jan-Gatzke
                I have something similar on my workbench. Very useful.
                  nice wall decoration for a workshop :P :D
                    @gohan
                    I didn't select the wallpaper.... :woman: :kissing_closed_eyes:
                    • J Jan Gatzke
                      #98
                      @Jan-Gatzke I have this one:
                      0_1494092799058_upload-26847c60-5afa-46a8-85f7-ece57c9b7960
                      It's able to hold all kinds of PCB sizes and can rotate easily.
                      Tip for soldering through-hole components from the back without them falling out:
                      Place all components on the top of the PCB and put a sponge or scotch-brite on top of them. Fix to the PCB with some rubber bands and swap the PCB to solder!
                      • YveauxY Yveaux
                        J
                        J
                        Jan Gatzke
                        @Yveaux I saw that thing on Amazon. There was a review saying the brackets would melt easily when using hot air. Did you use this with hot air?
                        • J Jan Gatzke
                          @Jan-Gatzke said in Your workshop :):
                          When you clamp a PCB in it only the edges are held by the plastic brackets.
                          Unless you are blowing directly on the edge of the PCB where it is held I can imagine this could be a problem, but then, why don't you shift or rotate the PCB to get away from the brackets?
                          Yes
                            AWIA
                            AWIA
                            AWI
                            @gohan Be aware that there are quite a few different versions around. The one I posted has a rotary encoder to select and operate the pwm and frequency functions. The perspex casing fits well with the rest of the nerdy testboxes I own (dummy load, power supply, a few function generators, frequencycounter ) All a lot of functionality for very little..
                              Aren't these devices basically Arduinos? It's written on the title atmega328. If so if we could get our hands on the code, we could make our own 😀
                              AWIA 1 Reply Last reply
                              • core_cC
                                core_cC
                                core_c
                                Nice to see in what environment others spend their time.
                                There are a lot of electronic hobbyists out there! They have more (and more) stuff than coders.
                                I hope that bjornhallberg has a nice desk by now.. :stuck_out_tongue_winking_eye:
                                • J
                                  J
                                  Jan Gatzke
                                  I noticed the many of you have an oscilloscope on their desk. What exactly do you use these for? There seems to be nothing under 200$ and I wonder if it is worth it.
                                    There is also a cheap portable one under 100$, but it all depends how far you want to push yourself into electronics.
                                    • J Jan Gatzke
                                      AWIA
                                      AWIA
                                      AWI
                                      wrote on last edited by AWI
                                      #106
                                      @Jan-Gatzke For MySensor I use it mostly for measuring response times and get a general idea of what is happening timewise. Especially if you have multiple event happening at the same time. Also for getting a grip on low power
                                      0_1494178043023_upload-98a17471-1641-4d3d-82af-3dda4bd4b185
                                      it gives a lot of information which would be very hard to measure with any other instrument. (for my other hobby, analog audio design, I couldn't live without it. ;-))
                                      A few considerations:
                                      1. It can be rather complicated using a scope in first instance. (a steep learning curve)
                                      2. Unless you are just curious and want to educate yourself I would strongly disencourage buying a cheap instrument. Better to study a few manuals of serious > €300 instruments, save a little and buy the thing you need (or can't resist). 10 years ago you had to put down > €1000 for something reasonable.
                                      • AWIA AWI
                                        J
                                        J
                                        Jan Gatzke
                                        @AWI Troubleshooting power probolems with the nrf24 is a good example, thx. I think at the beginning it is more a nice to have than a must have. I am always curios for such things. Still I don't want to buy trash. I will read a bit and watch ebay for good offers. Thx for your explanation.
                                          #108
                                          As i'm actually tidying up thing, i can show some pics where i spend some tinkering time.
                                          I'm planning to renovate it, because i'm also missing place for my 3d printer and some others stuff.
                                          There is a lathe and a drill but it's for quick hurry work, there is another room for more dirty mechanical stuff.. but i can't show you, it's dirty :)
                                          My favorite tools :
                                          • my super mini TS100 solder iron. But if you ask me, for tiny SMD like DFN for instance, i prefer my Weller Magnastat with a 0.2mm tip. The tip is thinner even if i've bought the thinnest tip for the TS100.
                                          • hacked Rigol Ds1054Z. Really worth the price!
                                          • hacked T962 reflow oven. Very cool too (better for leaded solder though)
                                          • smd books
                                          • my magnifier of course!
                                          for the rest, there are also great tools like power supply, a spectrum analyzer, generators..
                                          My 1st 3d printer, i like it, works very well. I'm planning to build a new, bigger and enclosed one.
                                          Talking about soldering vise, i have this old tool i don't use it often, but when i need it, i'm happy to have it.
                                          I'm pretty sure this is not hard to reproduce with some T-Slots and so on ;)
                                          When you have a 3d printer, this thingiverse design can be helpful, for debugging stuff, or can be used for soldering but with care else plastic would melt.
                                          http://www.thingiverse.com/thing:801279
                                          dbemowskD sundberg84S 2 Replies Last reply
