  3. 💬 Easy/Newbie PCB (RFM69 HW/W edition) for MySensors
mysensoreasynewbiepcbmysx
106 Posts 20 Posters 56.8k Views 19 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/389/EasyNewbie-PCB-RFM69-HWW-edition-for-MySensors
      :thumbsup: Finally! :D
      • martinhjelmareM
        martinhjelmareM
        martinhjelmare
        How's the compatability 5 V arduino and RFM69 achieved? As I understand the RFM69 inputs are not 5 V tolerable.
          You need to use 3,3v mini pro, this pcb is more for battery powered nodes
          • sundberg84S
            sundberg84S
            Correct - 3.3v only - im redesigning the PCB for this.
            • martinhjelmareM
              martinhjelmareM
              martinhjelmare
              Ok, so it was just a copy-paste leftover in the feature description from the nrf version.
                sundberg84S
                sundberg84S
                @martinhjelmare - It wasnt meant to make the project visible but I did unfortunately. I will correct as soon as possible
                I dont think its going to be that newbie friendly with a level converter for 5v so Im going to propose a 3.3v Pro mini only. Then I might add a voltage regulator with 5 and 3.3v in.
                • sundberg84S
                  sundberg84S
                  Well, since I posted the thread without it was finished (not usually my way of working) I can keep you updated on the work i guess... get input on the way.
                  New schematics made... not final! Not implemented any booster yet.
                  • sundberg84S
                    sundberg84S
                    @gohan - looking better on that SMA connector...
                    Anyone knows if its possible to have a SMA and Hole for DIY antenna on the same PCB like this?
                    Edit:
                    Well, so far tonight... a couple of hours work and im happy :) some small stuff to fix before production.
                    J 1 Reply Last reply
                    • fisherF
                      fisherF
                      fisher
                      Looking forward to buy this board. Thanks for including SMA connector. Now it's complete board for me :-)
                      • sundberg84S
                        sundberg84S
                        OK - beta release.
                        I have updated the description, bom, gerber files and kicad files on openhardware.io.
                        I have placed an order for fast delivery on pcbway.com but it will take some time before my RFM69 radios reach me from china-land. So I won't be able to test it for some time.
                        IF you are curoius (and willing to debug and cut / resolder if there are errors) feel free to download the gerbers and place an order. I cant promise its 100% (or work as intended) and because of that I wont add them for sale on openhardware.io yet.
                        • sundberg84S sundberg84
                          Edit:
                          J
                          J
                          jlaraujo
                          @sundberg84 I did this in my take of a SMA with a wire Antenna option:
                          0_1494632694334_upload-ce399877-38ed-4251-924d-a293c9df13fb , you can see more details here https://www.openhardware.io/view/388/RFM69HW-Arduino-Mini-Pro-Shield.
                          Haven't tried with the wire antenna trough.
                          Domoticz, mysensors 2.3.1, RFM69 and RF24 sensors
                            Actually it seems a good solution to have the hole on the sma pad
                            • J jlaraujo
                              sundberg84S
                              sundberg84S
                              @jlaraujo , @gohan - I does look really good and effective!
                              Would be great if you could test it! At the moment I have placed my order so I cant change it for this run, but out of experience there will be other stuff I want to change.
                              Thank you for input! I greatly appreciate it!
                              • sundberg84S
                                sundberg84S
                                • sundberg84S
                                  sundberg84S
                                  So, this temporary GW is now connected to Domoticz and running at 34800 baud rate (had some problems to figure this out...) I have one (fake) node connected but still have some range issues to sort out. Most likley because of the DIY antenna...
                                  • sundberg84S
                                    sundberg84S
                                    I now have a gw and node working together on 3.3v and 433mhz (not HW version). I would say its quite safe to order the PCB if someone wants to try it out.
                                    Note to myself and others... the RFM69 is really sensitive to high power. I fried one because I tried it on a Nano which i think is using 5v on its gpio. I was just thinking... hmm 3.3v - nano got one of those!
                                    gohanG 1 Reply Last reply
                                    • sundberg84S
                                      sundberg84S
                                      And now I also have a batterynode working... Power consumtion will come later... it works atleast :)
                                      Someone that can guess what kind of power consumtion this setup would be (removing LED / regulator)?
                                        @sundberg84 said in 💬 Easy/Newbie PCB (RFM69 HW/W edition) for MySensors:
                                        It's in datasheet that it is not 5v tolerant and absolute max voltage it's like 3.6v
                                          sundberg84S
                                          sundberg84S
                                          @gohan - I was fooled by that the Nano got a 3.3v output... stupid.
