  3. Combining relay and temperature sketch
76 Posts 9 Posters 24.1k Views 12 Watching
    I probably used wrong sintax
    Tim76T
    Tim76T
    Tim76
    @gohan tried this again...... same result.....
      for (int i=17; i<numSensors && i<MAX_ATTACHED_DS18B20; i++) {
         present(i, S_TEMP);
        pinMode(pin, OUTPUT);
    Tim76T 1 Reply Last reply
    • Tim76T Tim76
           present(i, S_TEMP);
      Tim76T
      Tim76T
      Tim76
      here's the complete code as she is right now...
      #define MY_RF24_CE_PIN 49
      #define MY_RF24_CS_PIN 53
      #define MY_NODE_ID 30
      #include <OneWire.h>
      int numSensors=0;
      bool receivedConfig = false;
      bool metric = true;
      MyMessage msgTemp(0,V_TEMP);
      #define RELAY_1  30  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
      #define NUMBER_OF_RELAYS 16 // Total number of attached relays
      void before()
        sensors.begin();
        sendSketchInfo("Greenhouse main controller", "1.0");
           present(i, S_TEMP);
        sleep(conversionTime);
          #if COMPARE_TEMP == 1
            send(msgTemp.setSensor(i).set(temperature,1));
        wait(3000);
        if (message.type==V_STATUS) {
          // Change relay state
          // Store state in eeprom
        @Tim76 you forgot to present the relays.... :sweat:
          Tim76T
          Tim76T
          Tim76
          @gohan no I didn't...
               present(i, S_TEMP);
          • Tim76T Tim76
                 present(i, S_TEMP);
            Tim76T
            Tim76T
            Tim76
            @gohan seems like it's early for both of us.....;-)
              you only have present(i, S_TEMP) but you also need to add present(sensor, S_BINARY) in the relay section otherwise you will not present any relay at all.
              Tim76T 2 Replies Last reply
                Tim76T
                Tim76T
                Tim76
                @gohan 😳😳😳 seems like it's only early for one of us...... I,ll change it later today.....
                  Tim76T
                  Tim76T
                  Tim76
                  @gohan so I fixed that....... and now I get this in Domoticz....
                  0 Unknown! #1. V_TEMP (20.7) true 2017-05-10 11:44:39
                  1 S_LIGHT/S_BINARY #1. V_TEMP (20.7) true 2017-05-10 11:44:43
                  2 S_LIGHT/S_BINARY #1. V_TEMP (20.9) true 2017-05-10 11:44:04
                  3 S_LIGHT/S_BINARY true 2017-05-10 11:34:13
                  4 S_LIGHT/S_BINARY true 2017-05-10 11:34:14
                  5 S_LIGHT/S_BINARY true 2017-05-10 11:34:15
                  6 S_LIGHT/S_BINARY true 2017-05-10 11:34:15
                  7 S_LIGHT/S_BINARY true 2017-05-10 11:34:16
                  8 S_LIGHT/S_BINARY true 2017-05-10 11:34:17
                  9 S_LIGHT/S_BINARY true 2017-05-10 11:34:17
                  10 S_LIGHT/S_BINARY true 2017-05-10 11:34:18
                  11 S_LIGHT/S_BINARY true 2017-05-10 11:34:18
                  12 S_LIGHT/S_BINARY true 2017-05-10 11:34:19
                  13 S_LIGHT/S_BINARY true 2017-05-10 11:34:19
                  14 S_LIGHT/S_BINARY true 2017-05-10 11:34:20
                  15 S_LIGHT/S_BINARY true 2017-05-10 11:34:20
                  16 S_LIGHT/S_BINARY true 2017-05-10 11:34:21
                  17 S_TEMP true 2017-05-10 11:34:12
                  18 S_TEMP true 2017-05-10 11:34:12
                  255 S_ARDUINO_NODE 2.1.1 false 2017-05-10 11:34:12
                  so it seems I do get temp Id's from 17 to 32, but the values stay in 0,1,2 where the relays 1 and 2 don't work.....
                    wrote on last edited by gohan
                    #31
                    There must be a bug in the relay section, I can't check it today, I'm out all day.
                    Try to add some debug serial print to see what values are being exchanged
                      Tim76T
                      Tim76T
                      Tim76
                      @gohan output of the serial port
                      3 MCO:BGN:BFR
                      144 TSM:INIT
                      145 TSF:WUR:MS=0
                      153 TSM:INIT:TSP OK
                      154 TSM:INIT:STATID=51
                      157 TSF:SID:OK,ID=51
                      158 TSM:FPAR
                      195 TSF:MSG:SEND,51-51-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      986 TSF:MSG:READ,0-0-51,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                      990 TSF:MSG:FPAR OK,ID=0,D=1
                      2202 TSM:FPAR:OK
                      2203 TSM:ID
                      2204 TSM:ID:OK
                      2206 TSM:UPL
                      2211 TSF:MSG:SEND,51-51-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                      2232 TSF:MSG:READ,0-0-51,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                      2237 TSF:MSG:PONG RECV,HP=1
                      2240 TSM:UPL:OK
                      2241 TSM:READY:ID=51,PAR=0,DIS=1
                      2246 TSF:MSG:SEND,51-51-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                      2284 TSF:MSG:READ,0-0-51,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                      2291 TSF:MSG:SEND,51-51-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
                      2301 TSF:MSG:SEND,51-51-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                      4329 TSF:MSG:SEND,51-51-0-0,s=255,c=3,t=11,pt=0,l=25,sg=0,ft=0,st=OK:Greenhouse main controlle
                      4340 TSF:MSG:SEND,51-51-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
                      4350 TSF:MSG:SEND,51-51-0-0,s=17,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                      4359 TSF:MSG:SEND,51-51-0-0,s=18,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                      4369 TSF:MSG:SEND,51-51-0-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                      4376 TSF:MSG:SEND,51-51-0-0,s=2,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                      4384 TSF:MSG:SEND,51-51-0-0,s=3,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                      4397 TSF:MSG:SEND,51-51-0-0,s=4,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                      4407 TSF:MSG:SEND,51-51-0-0,s=5,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                      4418 TSF:MSG:SEND,51-51-0-0,s=6,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                      4434 TSF:MSG:SEND,51-51-0-0,s=7,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                      4449 TSF:MSG:SEND,51-51-0-0,s=8,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                      4459 TSF:MSG:SEND,51-51-0-0,s=9,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                      4489 TSF:MSG:SEND,51-51-0-0,s=10,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                      4505 TSF:MSG:SEND,51-51-0-0,s=11,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                      4515 TSF:MSG:SEND,51-51-0-0,s=12,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                      4528 TSF:MSG:SEND,51-51-0-0,s=13,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                      4540 TSF:MSG:SEND,51-51-0-0,s=14,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                      4556 TSF:MSG:SEND,51-51-0-0,s=15,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                      4564 TSF:MSG:SEND,51-51-0-0,s=16,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                      4571 MCO:REG:REQ
                      4576 TSF:MSG:SEND,51-51-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                      4583 TSF:MSG:READ,0-0-51,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                      4588 MCO:PIM:NODE REG=1
                      4590 MCO:BGN:STP
                      4591 MCO:BGN:INIT OK,TSP=1
                      4596 MCO:SLP:MS=750,SMS=0,I1=255,M1=255,I2=255,M2=255
                      4601 MCO:SLP:TPD
                      4602 MCO:SLP:WUP=-1
                      4636 TSF:MSG:SEND,51-51-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:20.2
                      4690 TSF:MSG:SEND,51-51-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:20.5
                      4755 TSF:MSG:SEND,51-51-0-0,s=2,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:20.4
                      7763 MCO:SLP:MS=750,SMS=0,I1=255,M1=255,I2=255,M2=255
                      7768 MCO:SLP:TPD
                      7770 MCO:SLP:WUP=-1
                      10898 MCO:SLP:MS=750,SMS=0,I1=255,M1=255,I2=255,M2=255
                      10902 MCO:SLP:TPD
                      10904 MCO:SLP:WUP=-1
                        I'm talking about adding code to your sketch so that it prints in serial monitor the values before they are sent for presentations and you debug from those, I can't debug it for you from here 😀
                          Tim76T
                          Tim76T
                          Tim76
                          @gohan oh.... ok..... pretty new at coding, but I guess you allready figured that out.....;-)
                            No problem, it's normal, everybody started from being new at coding.
                            For debugging add only 1 or 2 temp sensors and same for relays, work it out simple and then add more
                              Tim76T
                              Tim76T
                              Tim76
                              @gohan hey Gohan,
                              I will not be able to continue to work on my code till after the weekend....😑
                                No problem, I'm here anyway 😀
                                  Tim76T
                                  Tim76T
                                  Tim76
                                  @gohan
                                  Due to work related schedule problems I won't be able to work on this code for a few weeks...... :angry:
                                  • N
                                    N
                                    Newzwaver
                                    Did you get this working and if so can you share?
                                    B 1 Reply Last reply
                                    • N Newzwaver
                                      B
                                      B
                                      bluezr1
                                      @newzwaver I'm curious aswell, been pounding my head all night trying to get a temperature and relay into one sketch.
                                      • N
                                        N
                                        Newzwaver
                                        HI
                                        I did get it to work and will post the sketch later today after work. I have it working on the ESP8266 and Arduino.
                                        • N
                                          N
                                          Newzwaver
                                          #42
                                          I figured why wait, this has the temp, hum and 2 relays working not problem. One relay controls my fan for my AV and the other controls my doorbell for my HTD Lync system.
                                           * Version 1.0: Henrik EKblad
                                           * sensor using a DHT11/DHT-22.
                                          // Enable debug prints
                                          #define MY_NODE_ID 29
                                          //#define MY_RS485
                                          #define MY_REPEATER_FEATURE
                                          #define DHT_DATA_PIN 3
                                          #define RELAY_1  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                                          #define RELAY_2  5  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                                          #define NUMBER_OF_RELAYS 2 // Total number of attached relays
                                          #define SENSOR_TEMP_OFFSET 0
                                          static const uint64_t UPDATE_INTERVAL = 60000;
                                          #define CHILD_ID_HUM 28
                                          #define CHILD_ID_TEMP 30
                                          float lastTemp;
                                          float lastHum;
                                          uint8_t nNoUpdatesTemp;
                                          uint8_t nNoUpdatesHum;
                                          bool metric = true;
                                          DHT dht;
                                          void before()
                                            sendSketchInfo("AVCABRelayTempAndHumidity", "1.1");
                                            present(CHILD_ID_HUM, S_HUM);
                                            dht.readSensor(true);
                                            if (isnan(temperature)) {
                                              lastTemp = temperature;
                                              if (!metric) {
                                              // Reset no updates counter
                                              nNoUpdatesTemp = 0;
                                              #ifdef MY_DEBUG
                                              Serial.print("T: ");
                                              nNoUpdatesTemp++;
                                            if (isnan(humidity)) {
                                              lastHum = humidity;
                                              nNoUpdatesHum = 0;
                                              #ifdef MY_DEBUG
                                              Serial.print("H: ");
                                              Serial.println(humidity);
                                              nNoUpdatesHum++;
                                            sleep(UPDATE_INTERVAL);
                                          rejoe2R 1 Reply Last reply
