  3. Combining relay and temperature sketch
76 Posts 9 Posters 24.1k Views 12 Watching
  • Tim76T Tim76
    @gohan no I didn't...
      for (int i=17; i<numSensors && i<MAX_ATTACHED_DS18B20; i++) {
         present(i, S_TEMP);
        pinMode(pin, OUTPUT);
    Tim76T
    Tim76T
    Tim76
    @gohan seems like it's early for both of us.....;-)
      you only have present(i, S_TEMP) but you also need to add present(sensor, S_BINARY) in the relay section otherwise you will not present any relay at all.
      Tim76T 2 Replies Last reply
        Tim76T
        Tim76T
        Tim76
        @gohan 😳😳😳 seems like it's only early for one of us...... I,ll change it later today.....
          Tim76T
          Tim76T
          Tim76
          @gohan so I fixed that....... and now I get this in Domoticz....
          0 Unknown! #1. V_TEMP (20.7) true 2017-05-10 11:44:39
          1 S_LIGHT/S_BINARY #1. V_TEMP (20.7) true 2017-05-10 11:44:43
          2 S_LIGHT/S_BINARY #1. V_TEMP (20.9) true 2017-05-10 11:44:04
          3 S_LIGHT/S_BINARY true 2017-05-10 11:34:13
          4 S_LIGHT/S_BINARY true 2017-05-10 11:34:14
          5 S_LIGHT/S_BINARY true 2017-05-10 11:34:15
          6 S_LIGHT/S_BINARY true 2017-05-10 11:34:15
          7 S_LIGHT/S_BINARY true 2017-05-10 11:34:16
          8 S_LIGHT/S_BINARY true 2017-05-10 11:34:17
          9 S_LIGHT/S_BINARY true 2017-05-10 11:34:17
          10 S_LIGHT/S_BINARY true 2017-05-10 11:34:18
          11 S_LIGHT/S_BINARY true 2017-05-10 11:34:18
          12 S_LIGHT/S_BINARY true 2017-05-10 11:34:19
          13 S_LIGHT/S_BINARY true 2017-05-10 11:34:19
          14 S_LIGHT/S_BINARY true 2017-05-10 11:34:20
          15 S_LIGHT/S_BINARY true 2017-05-10 11:34:20
          16 S_LIGHT/S_BINARY true 2017-05-10 11:34:21
          17 S_TEMP true 2017-05-10 11:34:12
          18 S_TEMP true 2017-05-10 11:34:12
          255 S_ARDUINO_NODE 2.1.1 false 2017-05-10 11:34:12
          so it seems I do get temp Id's from 17 to 32, but the values stay in 0,1,2 where the relays 1 and 2 don't work.....
            wrote on last edited by gohan
            #31
            There must be a bug in the relay section, I can't check it today, I'm out all day.
            Try to add some debug serial print to see what values are being exchanged
            Tim76T 1 Reply Last reply
              Tim76T
              Tim76T
              Tim76
              @gohan output of the serial port
              3 MCO:BGN:BFR
              144 TSM:INIT
              145 TSF:WUR:MS=0
              153 TSM:INIT:TSP OK
              154 TSM:INIT:STATID=51
              157 TSF:SID:OK,ID=51
              158 TSM:FPAR
              195 TSF:MSG:SEND,51-51-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              986 TSF:MSG:READ,0-0-51,s=255,c=3,t=8,pt=1,l=1,sg=0:0
              990 TSF:MSG:FPAR OK,ID=0,D=1
              2202 TSM:FPAR:OK
              2203 TSM:ID
              2204 TSM:ID:OK
              2206 TSM:UPL
              2211 TSF:MSG:SEND,51-51-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
              2232 TSF:MSG:READ,0-0-51,s=255,c=3,t=25,pt=1,l=1,sg=0:1
              2237 TSF:MSG:PONG RECV,HP=1
              2240 TSM:UPL:OK
              2241 TSM:READY:ID=51,PAR=0,DIS=1
              2246 TSF:MSG:SEND,51-51-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
              2284 TSF:MSG:READ,0-0-51,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              2291 TSF:MSG:SEND,51-51-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
              2301 TSF:MSG:SEND,51-51-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
              4329 TSF:MSG:SEND,51-51-0-0,s=255,c=3,t=11,pt=0,l=25,sg=0,ft=0,st=OK:Greenhouse main controlle
              4340 TSF:MSG:SEND,51-51-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
              4350 TSF:MSG:SEND,51-51-0-0,s=17,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
              4359 TSF:MSG:SEND,51-51-0-0,s=18,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
              4369 TSF:MSG:SEND,51-51-0-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
              4376 TSF:MSG:SEND,51-51-0-0,s=2,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
              4384 TSF:MSG:SEND,51-51-0-0,s=3,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
              4397 TSF:MSG:SEND,51-51-0-0,s=4,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
              4407 TSF:MSG:SEND,51-51-0-0,s=5,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
              4418 TSF:MSG:SEND,51-51-0-0,s=6,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
              4434 TSF:MSG:SEND,51-51-0-0,s=7,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
              4449 TSF:MSG:SEND,51-51-0-0,s=8,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
              4459 TSF:MSG:SEND,51-51-0-0,s=9,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
              4489 TSF:MSG:SEND,51-51-0-0,s=10,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
              4505 TSF:MSG:SEND,51-51-0-0,s=11,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
              4515 TSF:MSG:SEND,51-51-0-0,s=12,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
              4528 TSF:MSG:SEND,51-51-0-0,s=13,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
              4540 TSF:MSG:SEND,51-51-0-0,s=14,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
              4556 TSF:MSG:SEND,51-51-0-0,s=15,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
              4564 TSF:MSG:SEND,51-51-0-0,s=16,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
              4571 MCO:REG:REQ
              4576 TSF:MSG:SEND,51-51-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
              4583 TSF:MSG:READ,0-0-51,s=255,c=3,t=27,pt=1,l=1,sg=0:1
              4588 MCO:PIM:NODE REG=1
              4590 MCO:BGN:STP
              4591 MCO:BGN:INIT OK,TSP=1
              4596 MCO:SLP:MS=750,SMS=0,I1=255,M1=255,I2=255,M2=255
              4601 MCO:SLP:TPD
              4602 MCO:SLP:WUP=-1
              4636 TSF:MSG:SEND,51-51-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:20.2
              4690 TSF:MSG:SEND,51-51-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:20.5
              4755 TSF:MSG:SEND,51-51-0-0,s=2,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:20.4
              7763 MCO:SLP:MS=750,SMS=0,I1=255,M1=255,I2=255,M2=255
              7768 MCO:SLP:TPD
              7770 MCO:SLP:WUP=-1
              10898 MCO:SLP:MS=750,SMS=0,I1=255,M1=255,I2=255,M2=255
              10902 MCO:SLP:TPD
              10904 MCO:SLP:WUP=-1
                I'm talking about adding code to your sketch so that it prints in serial monitor the values before they are sent for presentations and you debug from those, I can't debug it for you from here 😀
                  Tim76T
                  Tim76T
                  Tim76
                  @gohan oh.... ok..... pretty new at coding, but I guess you allready figured that out.....;-)
                    No problem, it's normal, everybody started from being new at coding.
                    For debugging add only 1 or 2 temp sensors and same for relays, work it out simple and then add more
                      Tim76T
                      Tim76T
                      Tim76
                      @gohan hey Gohan,
                      I will not be able to continue to work on my code till after the weekend....😑
                        No problem, I'm here anyway 😀
                          Tim76T
                          Tim76T
                          Tim76
                          @gohan
                          Due to work related schedule problems I won't be able to work on this code for a few weeks...... :angry:
                          • N
                            N
                            Newzwaver
                            Did you get this working and if so can you share?
                            B 1 Reply Last reply
                            • N Newzwaver
                              B
                              B
                              bluezr1
                              @newzwaver I'm curious aswell, been pounding my head all night trying to get a temperature and relay into one sketch.
                              • N
                                N
                                Newzwaver
                                HI
                                I did get it to work and will post the sketch later today after work. I have it working on the ESP8266 and Arduino.
                                • N
                                  N
                                  Newzwaver
                                  #42
                                  I figured why wait, this has the temp, hum and 2 relays working not problem. One relay controls my fan for my AV and the other controls my doorbell for my HTD Lync system.
                                   * Version 1.0: Henrik EKblad
                                   * sensor using a DHT11/DHT-22.
                                  // Enable debug prints
                                  #define MY_NODE_ID 29
                                  //#define MY_RS485
                                  #define MY_REPEATER_FEATURE
                                  #define DHT_DATA_PIN 3
                                  #define RELAY_1  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                                  #define RELAY_2  5  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                                  #define NUMBER_OF_RELAYS 2 // Total number of attached relays
                                  #define SENSOR_TEMP_OFFSET 0
                                  static const uint64_t UPDATE_INTERVAL = 60000;
                                  #define CHILD_ID_HUM 28
                                  #define CHILD_ID_TEMP 30
                                  float lastTemp;
                                  float lastHum;
                                  uint8_t nNoUpdatesTemp;
                                  uint8_t nNoUpdatesHum;
                                  bool metric = true;
                                  DHT dht;
                                  void before()
                                    sendSketchInfo("AVCABRelayTempAndHumidity", "1.1");
                                    present(CHILD_ID_HUM, S_HUM);
                                    dht.readSensor(true);
                                    if (isnan(temperature)) {
                                      lastTemp = temperature;
                                      if (!metric) {
                                      // Reset no updates counter
                                      nNoUpdatesTemp = 0;
                                      #ifdef MY_DEBUG
                                      Serial.print("T: ");
                                      nNoUpdatesTemp++;
                                    if (isnan(humidity)) {
                                      lastHum = humidity;
                                      nNoUpdatesHum = 0;
                                    if (message.type==V_STATUS) {
                                      // Change relay state
                                      // Store state in eeprom
                                      #ifdef MY_DEBUG
                                      Serial.print("H: ");
                                      Serial.println(humidity);
                                      nNoUpdatesHum++;
                                    sleep(UPDATE_INTERVAL);
                                  rejoe2R 1 Reply Last reply
                                  • N Newzwaver
                                    //#define MY_RS485
                                    float lastTemp;
                                    float lastHum;
                                    bool metric = true;
                                    DHT dht;
                                    void before()
                                        if (!metric) {
                                        nNoUpdatesTemp = 0;
                                        #ifdef MY_DEBUG
                                        nNoUpdatesTemp++;
                                        lastHum = humidity;
                                        nNoUpdatesHum = 0;
                                        #ifdef MY_DEBUG
                                        nNoUpdatesHum++;
                                    rejoe2R
                                    rejoe2R
                                    rejoe2
                                    @newzwaver your code is pretty hard to read due to not beeing entirely formatted as code.
                                    Nevertheless there seems not to exist any loop() section and the node is put to sleep after having received anything for a certain periode of time.
                                    This may work in most cases, but imo is not a "lucky code design".
                                    Imo better aproach:
                                    Use the https://www.arduino.cc/en/tutorial/BlinkWithoutDelay - principle. Additionally a wait() is used instead of sleep() for the time to fulfill measurements (DS18B20 in my case).
                                    If you need a working implementation of the blink-without-delay function within MySensors, see the https://www.mysensors.org/build/pulse_power example.
                                    At least three of my nodes (combining temperature and relays) work pretty well like that.
                                    • rejoe2R rejoe2
                                      Imo better aproach:
                                      B
                                      B
                                      bluezr1
                                      wrote on last edited by bluezr1
                                      #44
                                      @rejoe2 said in Combining relay and temperature sketch:
                                      Thanks Newzwaver
                                      You wouldn't happen to have a sketch with the DS18B20? I have both DHTs and DS18B20s but plan on using this to turn on and off a fan to keep my AV equipment cool. So I'm not that concerned about humidity although it wouldn't be deal breaker if it did.
                                      • B bluezr1
                                        Thanks Newzwaver
                                        rejoe2R
                                        rejoe2R
                                        rejoe2
                                        @bluezr1 Sure... But imo it is easier to stick with the given examples, they may be much easier to understand than e.g. this one:grin:
                                        sinczeS 1 Reply Last reply
                                        • rejoe2R rejoe2
                                          sinczeS
                                          sinczeS
                                          sincze
                                          MySensors Evangelist
                                          @rejoe2 NIce example thanks.
                                          rejoe2R sinczeS 2 Replies Last reply
