  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 257.0k Views 53 Watching
  • alexsh1A alexsh1
    @meddie said in 💬 Sensebender Gateway:
    Ok i just connected the W5100 and NRF24 Module and uploaded the GatewayW5100 Sketch and when the upload is done after reset i dont get any output on serial monitor.
    The orange, green and red led are lighting.
    When i upload the SensebenderGatewaySerial then i get output on serial monitor. It think the problem must be the w5100. But what going wrong?
    @meddie Did you figure out what the problem is? I have exactly the same issue
    tbowmoT
    tbowmoT
    tbowmo
    @alexsh1
    Have you tried to enable the debug output in the GatewayW5100 example? I think it is disabled by default, due to the limited memory on the small atmega 328p
    alexsh1A 1 Reply Last reply
    • tbowmoT tbowmo
      @alexsh1
      alexsh1A
      alexsh1A
      alexsh1
      @tbowmo
      Yes, I did
      • alexsh1A
        alexsh1A
        alexsh1
        #225
        I am running Arduino IDE 1.8.1 on Windows 10
        Arduino AVR 1.6.18
        Arduino SAMD 1.6.12
        MySensors SAMD 1.0.5
        EDIT: I have tried to upload the default sketch on macbook with Arduino IDE 1.6.2
        It is still the same - no debug info in the terminal
        • alexsh1A
          alexsh1A
          alexsh1
          #226
          OK, I did manage to get debug working partially.
          The gateway reads messages, but does not work as the gateway
          0;255;3;0;9;MCO:BGN:STP
          0;255;3;0;9;TSF:MSG:READ,10-10-0,s=1,c=1,t=17,pt=5,l=4,sg=0:348
          0;255;3;0;9;TSF:MSG:READ,26-10-0,s=3,c=1,t=24,pt=5,l=4,sg=0:51219479
          0;255;3;0;9;TSF:MSG:READ,10-10-0,s=1,c=1,t=24,pt=5,l=4,sg=0:51219482
          0;255;3;0;9;TSF:MSG:READ,11-11-0,s=2,c=1,t=37,pt=7,l=5,sg=0:1717.62
          0;255;3;0;9;TSF:MSG:READ,11-11-0,s=0,c=1,t=37,pt=7,l=5,sg=0:5338.44
          0;255;3;0;9;TSF:MSG:READ,11-11-0,s=3,c=1,t=37,pt=7,l=5,sg=0:10.75
          0;255;3;0;9;TSF:MSG:READ,11-11-0,s=3,c=1,t=37,pt=7,l=5,sg=0:10.76
          0;255;3;0;9;TSF:MSG:READ,11-11-0,s=4,c=1,t=37,pt=4,l=4,sg=0:880
          0;255;3;0;9;TSF:MSG:READ,6-6-0,s=2,c=1,t=1,pt=7,l=5,sg=0:64.8
          0;255;3;0;9;TSF:MSG:READ,6-6-0,s=0,c=1,t=4,pt=7,l=5,sg=0:1015
          I never had a message:
          Gateway startup complete.
          EDIT: Self-test with SensebenderSerial sketch gives me this:
          Sensebender GateWay test routine
          Mysensors core version : 2.1.1
          GateWay sketch version : 0.2
          - > SHA204 Failed to wakeup SHA204
          - > SD CARD SD CARD did not initialize!
           -> EEPROM PASSED
          -> analog : 38 Failed
          tbowmoT 1 Reply Last reply
          • alexsh1A alexsh1
             -> EEPROM PASSED
            tbowmoT
            tbowmoT
            tbowmo
            @alexsh1
            Could you check the soldering of the samd?
            SD card fails, if you haven't inserted a card, when running the self test.
            • tbowmoT tbowmo
              @alexsh1
              alexsh1A
              alexsh1A
              alexsh1
              #228
              @tbowmo
              I do not have the SD card so that's fine
              The samd looks fine - no bridges etc
              I can try to re-solder it with a hot fan
              Do you think samd may be at fault even though the serial GW is working?
              Unfortunately, I do not have another Ethernet w5100 to try it. Probably have to order a new one
              • tbowmoT
                tbowmoT
                tbowmo
                @alexsh1
                I know that @Anticimex had problems with one of the pre-production samples that we got from China, with various problems, that was solved with "reflowing" the samd with a hot air gun.. So it was just a thought, that it could be a bad solder joint..
                The W5100 is using it's own dedicated SPI port, so even though that the radio works, doesn't mean that there couldn't be any solder problems around the samd pins for W5100.
                We have 3 different SPI ports in use on the gateway, one for the MysX connector, one for radio / sdcard, and one for W5100..
                • tbowmoT tbowmo
                  @alexsh1
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @tbowmo I do not have the oven to reflow the whole board, but can mount / unmount or re-work certain components 0805 or 0603. Below this it is a pain in the a***
                  Another observation - The GW behaves like this with or without W5100 mounted.
                  Seems like an SPI problem to me. How can I wire W5100 to MYSX please and what shall I can in the sketch please? Thank for your help - very much appreciate it
                  AnticimexA 1 Reply Last reply
                  • alexsh1A alexsh1
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @alexsh1 The ATSHA is not connected to the SPI and is totally unrelated, so I am also inclined to suspect that perhaps one side of the SAMD is not entirely in contact with the pads. I had to hot-airgun mine to get USB working well but it was an early prototype like @tbowmo said.
                    • alexsh1A
                      alexsh1A
                      alexsh1
                      @tbowmo OK, I manage to find the answer here -
                      MYSX
                      D11 - MOSI
                      D12 - MISO
                      D13 - SCK
                      D14 -CS
                      #define MY_SOFTSPI
                      #define MY_SOFT_SPI_SCK_PIN 13
                      #define MY_SOFT_SPI_MISO_PIN 12
                      #define MY_SOFT_SPI_MOSI_PIN 11
                      MY_RF24_CS_PIN 14
                      RF24_CE_PIN ???
                      Am I correct?
                      • alexsh1A
                        alexsh1A
                        alexsh1
                        My current config for nrf24l01+ and w5100 is as follows:
                        #define MY_GATEWAY_W5100
                        #define MY_SOFTSPI
                        #define MY_RF24_CE_PIN 5
                        #define MY_RF24_CS_PIN 6
                        Why CE / CS pins are 5 and 6?
                        Should that be 27 and 3?
                        • alexsh1A
                          alexsh1A
                          alexsh1
                          #234
                          @tbowmo I have just re-worked SAMD and all the connectors (nrf24l01+ and NET_SPI), but still have the same issue sadly.
                          EDIT: If I change to rfm69, the same behavior is observed. It seems that Net_SPI is just not working.
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            #235
                            @alexsh1
                            Configuration of the pins are handled by the hardware configuration file, https://github.com/mysensors/ArduinoHwSAMD/blob/master/variants/mysensors_gw/variant.h#L227
                            If you look in the gatewayW5100 sketch, the settings for CE / CS pins are enclosed in ifdefs, so they are only used if they are not defined previously.
                            If you want to connect the W5100 to the mysx connector, you can change line 174 in the hardware definition file, use SPI2 instead of SPI1 for SPI_ETH
                            It could also be a defective W5100 shield? Can you verify that it works on other hardware?
                            • tbowmoT tbowmo
                              @alexsh1
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @tbowmo Swapping SPIs did not resolve the problem. I am now getting another W5100 to test further.
                              • alexsh1A
                                alexsh1A
                                alexsh1
                                Unfortunately, a new W5100 shield did not work - it seems like a production issue with this sensebender gatewsay as the SPI2 did not work either with W5100.
                                Will get a new one ordered.
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  Is it possible for you to check the spi wires with a scope? Just to make sure if mosi/miso/ce/Ss lines are toggling as expected?
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    #239
                                    Another thing, are you using static ip? If yes, can you ping it? If no, does your DHCP server hand out an ip address?
                                    Have you tried the basic ethernet examples for the W5100?
                                    • tbowmoT tbowmo
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      @tbowmo I am using the static IP and I can ping it, but the "Gateway Ready" message never comes up. Also I can only see the neg24l01+ log (incoming messages only)
                                      • alexsh1A alexsh1
                                        tbowmoT
                                        tbowmoT
                                        tbowmo
                                        @alexsh1
                                        If you can ping it, then the W5100 is configured. Something else is wrong..
                                        One thing that comes to mind, if you compile it as an ethernet GW, then it does not wait for serial console to be active, before initializing the radio. If you compile it as serial GW, then it waits with initialization, until serial is active.
                                        This means that you probably is missing the GW ready message on the serial port, as it is "sent" before you have an active serial connection.
                                        Look in MyHwSamd.cpp in the HwInit routine, remove the #ifdef around the while() loop, and try again.
                                        • tbowmoT tbowmo
                                          @alexsh1
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          #242
                                          @tbowmo Well, if I try the MEGA 2560 with W5100, I get the following:
                                          0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGAS-,VER=2.1.1
                                          0;255;3;0;9;TSM:INIT
                                          0;255;3;0;9;TSF:WUR:MS=0
                                          0;255;3;0;9;TSM:INIT:TSP OK
                                          0;255;3;0;9;TSM:INIT:GW MODE
                                          IP: 10.1.1.120
                                          I never get this message with Sensebender GW. I only get
                                          0;255;3;0;9;TSF:MSG:READ,11-11-0,s=2,c=1,t=37,pt=7,l=5,sg=0:2019.12
                                          0;255;3;0;9;TSF:MSG:READ,11-11-0,s=0,c=1,t=37,pt=7,l=5,sg=0:6275.51
                                          0;255;3;0;9;TSF:MSG:READ,11-11-0,s=3,c=1,t=37,pt=7,l=5,sg=0:18.77
                                          or similar messages from nodes.
