  3. Your workshop :)
Your workshop :)
183 Posts 36 Posters 108.4k Views 28 Watching
  • S Samuel235
    @dbemowsk - If you only want it to do what you need it to do then you're all good. I'm a little bit of a perfectionist and whether or not i need it to have a feature, i tend to attempt to get the printer to have that feature anyway. But at the end of the day if you're only using it for personal things and it does everything you want it to, then there is no need to change :)
    What i will say though is: I thought that i would be okay with just a RAMPS and arduino board, but i pushed the boat out and went for a DUET WIFI board, and damn these things are beautiful to use!
    dbemowskD
    dbemowskD
    @Samuel235 So do you have dual extruders?
    S 1 Reply Last reply
    • dbemowskD dbemowsk
      Samuel235
      @dbemowsk - I don't. And right now i'm not even thinking about it as i've done my far share of detailed printing and i do not wish to print anything slow and small scale that requires 0.08 mm layer heights and support everywhere. My printer has been on solid for the last 88 hours on 4 prints doing exactly that.
      I'm trying to slowly approach my maximum speed, printing comfortably at 60mm/s at the moment but would like a little more. My printer is pretty basic still, i'm still a student living at home so i'm saving money everywhere i can right not but as soon as i have no income issues, dual extruder, advanced bed probing, enclosure, quick change hotends with a tornado extruder maybe.
      MySensors 2.1.1
        Aren't these devices basically Arduinos? It's written on the title atmega328. If so if we could get our hands on the code, we could make our own 😀
        AWIA
        AWIA
        AWI
        @gohan said in Your workshop :):
        I finally found the place where the Chinese get their code and design for the "Transistortester". It comes from a german site
        0_1494697102560_upload-93c9329f-c8ba-4dd1-bf66-1757acf21a03 a very extensive project. I doubt if I will ever be able to match or even comprehend what they accomplished. :bow:
        • AWIA AWI
          @AWI great digging! :+1:
          The specs and list of functions are impressive.
          Do you think the Chinese hardware is an identical copy of this design?
          gohanG AWIA 2 Replies Last reply
          • YveauxY Yveaux
            wrote on last edited by gohan
            #131
            @Yveaux said in Your workshop :):
            Why not? Chinese are great at copying stuff :D
              Yes, and they're great in optimizing for cost; as long as any signal comes out, all components will be removed/replaced by cheaper ones...
              • YveauxY Yveaux
                AWIA
                AWIA
                AWI
                @Yveaux I soldered the thing myself so build quality is .... ;-) The board I received looks to be solid as well as the components.
                Accuracy in resistor/ capacitor meaurement is fine (~5% which is also the toleration of the components tested) Semiconductor analysis is enough for me with Fet / Junction transistors as I can determine the most important characteristics (including the pin layout!) which are within 10% of the datasheet. (pins are 100% correct :-))
                gohanG 1 Reply Last reply
                • AWIA AWI
                  @AWI did you order the parts or did you make the tester on your own with the parts you had?
                  AWIA 1 Reply Last reply
                    AWIA
                    AWIA
                    AWI
                    @gohan I used a kit. There is also a description and suggestions on improvement of the "Chinese clones" in the documentation of the project.
                    • core_cC
                      core_cC
                      core_c
                      @AWI "I soldered the thing myself so build quality is ...."
                      I guess the missing word is: "top", and the last dot is just interpunction.
                      • core_cC core_c
                        AWIA
                        AWIA
                        AWI
                        @core_c Thanks, I missed that ;-)
                          I got my 2017 transistor tester and since the cost for the pre-assembled was not far off from the kit, I did go the lazy way and I have to say the soldering quality seems OK.
                            I need little advice: is it worth buying the Ts100 soldering iron for 50€ + some accessories (holder and one extra tip, I already have a laptop power supply I can use) or go for a Hakko FX-888D for 120€ (you get holder in the price and extra tips cost significantly lower but I don't know if I ever need many different sizes)?
                            KoreshK 1 Reply Last reply
                              KoreshK
                              KoreshK
                              Koresh
                              @gohan Imho - TS100 is beautiful toy, nice gadget, but not really useful tool. TS100 iron has much less ergonomics in comparation with others soldering stations. I recommend buy it only as extra tool, not main tool ;)
                              • sundberg84S
                                sundberg84S
                                After changing my HA and network to new location I made some changes to my workshop. Still some work in progress.
                                YveauxY Nca78N 2 Replies Last reply
                                • sundberg84S sundberg84
                                  @sundberg84 said in Your workshop :):
                                  And some big spider to kill... :smirk:
                                    @sundberg84 we have the same model of soldering iron, hot air gun, and multimeter. And we might end up having a similar power supply too, as I'll build one sooner or later.
                                    But my stack of unused EasyPCBs is a bit smaller :D
                                    • YveauxY Yveaux
                                      sundberg84S
                                      sundberg84S
                                      @yveaux said in Your workshop :):
                                      That is Hugo. He has been around since I was a kid. Hard to kill since he is made of plastic but loves to scare new people.
                                      • Nca78N Nca78
                                        sundberg84S
                                        sundberg84S
                                        #145
                                        @nca78 - haha, thats nice :) I been thinking about changing my power supply though. Posting to much images isnt good for you ;) On my swedish blog I had a guy explaining about relative ground. When I probe around with my oscilloscope and power the electronics with my PSU they are not the same ground and this can apparently create some magic smoke. So far so good and I have been to lazy to learn more about the theory (Im sure there are people here with great knowledge about this) but the advice was to change my PSU to a "real" one.
                                        • N
                                          N
                                          Nina Baines
                                          So many space, I jealous :)
