  3. Looking for tips on mounting thermal fuses.
14 Posts 8 Posters 5.9k Views 7 Watching
  • dbemowskD dbemowsk
    I just ordered 20 more for my parts bin. You can kind of see in this picture, I soldered the one in and blew it, so I just cut the leads leaving them stubbed off so I could solder the new one to those leads rather than try to remove and re-mount it to the board.
    0_1495260820556_upload-8d6324d5-a97a-4021-a42d-73c3eb23199f
    @dbemowsk Bit lame, but you could mount them in a screw terminal block.
    • mfalkviddM
      Gripping it with nose pliers between the fuse itself and where you are soldering should absorb a lot of the heat, especially id you make sure the pliers are cold when you start soldering. Nose pliers can absorb much more heat than alligator clips.
      But I like Yveaux's idea to not solder at all. How about soldering female header pins and just stick the thermal fuse in?
      dbemowskD 1 Reply Last reply
      • dpressleD
        dpressleD
        dpressle
        I just wrap it with wet toilet paper, works every time.
        dbemowskD Nca78N 2 Replies Last reply
          dbemowskD
          dbemowskD
          @mfalkvidd I am just guessing here because I have not actually tried it, but I am guessing that the holes would be too small on the female header. In order to get it to fit in the proto-board that I use, I have to drill the hole slightly larger which is why I think that, but it never hurts to try. Making the holes larger on the PCB is one of the main reasons why when these have blown on me I have cut the leads and left them in the board. I was afraid that the pads on the board would lift if I did because making the holes larger I am sure took away the thru-hole plating.
          • dpressleD dpressle
            dbemowskD
            dbemowskD
            @dpressle I was thinking more last night and thought about putting an ice cube in a bag and holding it on there while I solder it.
              @dpressle said in Looking for tips on mounting thermal fuses.:
              Haha that's a funny way to do it, but the concept is good thank you for the idea
              I didn't have problem before but as a precaution I'll use with a small sponge for soldering iron, it will hold more water, be less messy and resist to heat.
              • Nca78N Nca78
                dbemowskD
                dbemowskD
                @Nca78 said in Looking for tips on mounting thermal fuses.:
                Another good idea. Thanks.
                  Samuel235
                  Am i the only one that struggles my as off with 4 pairs of pliers on these little annoying things?
                  MySensors 2.1.1
                  • m26872M
                    m26872M
                    m26872
                    My only precaution is to raise(!) the soldering iron temperature. It allows a fast action with less propagating heat. It sounds foolish, but I actually like it and rarely fail.
                    dbemowskD S 2 Replies Last reply
                    • m26872M m26872
                      dbemowskD
                      dbemowskD
                      @m26872 I will definitely have to try this. Something I hadn't thought of, but makes sense.
                      • m26872M m26872
                        Samuel235
                        @m26872 - I do this too, hotter the iron is the better for me. Hotter and quicker wins the race.
                        MySensors 2.1.1
