  3. Board and hardware failures
34 Posts 7 Posters 10.0k Views 5 Watching
  • ileneken3I
    ileneken3I
    ileneken3
    I am enclosing a picture of my attempt at a "workaround". Someone might get a good laugh out of it!
    This was a bit of a challenge to do - and it STILL doesn't work. I measure continuity with all the right pins, but I probably damaged the board. This should have been the first thing I did.
    In answer to all the questions:
    • I don't think the tracks are damaged, and there was nothing left exposed when cutting off the right side.
    • I tested the parts before soldering them on, although that doesn't mean they couldn't go bad later.
    • I will be using female headers the next couple of rounds. I just wish they weren't so big.
    • I have been watching YouTube videos about de-soldering. It will be a project for another day.
    I appreciate the help. Hopefully others have learned from my experience! I will report any other interesting findings.
    • dbemowskD
      dbemowskD
      Your pictures from your original post are a bit blurry, but pins 10 and 11 don't appear to come through to the bottom side of the board, and you solder joints don't look the best. Not sure why those pins aren't coming through the bottom side of the board, but that could be a major part of your problem. The traces that connect them to the radio are on the bottom side, so if there is not a good solder connection there, you will most likely have issues. Especially if the through hole plating is damaged in any way.
      Suggestions:
      • Use some flux and your soldering iron to clean up those solder joints. You may need to use some solder wick, or even a bare piece of copper wire with some flux on it to remove excess solder from your joints if it doesn't wick away with the tip of your iron.
      • When soldering, apply heat to both the pad and the lead coming through the hole for a second or two, then apply the solder, then remove the iron. Don't hold the iron on the pads for extended periods as you can damage the pads.
      • Use a small chisel tip rather than a conical tip. You will get better heat distribution when soldering. Hold the flat part mostly on the solder pad and touch the protruding wire when soldering.
      Here are some examples of good and bad solder joints:
      0_1495249926544_upload-cea33903-a168-4481-9820-eaab835295c6
      MAKE SURE that the tip of your soldering iron is clean too any time you are going to touch it to the board. A dirty iron tip can cause some of the issues shown above. If your tip looks anything like this, GET A NEW ONE:
      0_1495250269924_upload-cf1cb7f2-bdfd-4414-b4b9-e159546c5f87
      Here is an example of before and after wiping your tip when soldering:
      0_1495250557100_upload-b2fcd114-78bf-4717-a417-6f6dc67ad7a5
      Hope that helps.
        In the blurred picture it seems more if he trimmed the headers and also some solder in the process.
        dbemowskD 1 Reply Last reply
          dbemowskD
          dbemowskD
          @gohan said in Board and hardware failures:
          Not for 10 and 11, it looks like there are holes in the board in those two spots. The rest of them look like they are cut/trimmed.
          0_1495290184909_upload-91b19d12-79d4-48f3-b9d2-5953fda62376
          Also, look around pins 10 and 11 and a few other spots on the board. The board is really dirty like excess flux residue. That should be cleaned with alcohol.
          Nca78N 1 Reply Last reply
          • dbemowskD dbemowsk
            @dbemowsk is right here, pins 11 & 12 are not connected to the PCB.
            I've had hardare problems with PCBs only with one batch from one maker and after desoldering, if you don't severely overheat the board or apply excessive mechanical force you will not have problem, as they are all electronically tested at the end of the production process and they only send you the boards that pass the test.
            And desoldering things like pro mini or nrf24 is a real pain, most of the time you will damage them and just waste your time.
            What I do now is I unsolder the parts (mainly atmega, capacitors) on the promini using my hot air gun as it's fast and I can reuse them in SMD projects. But full ProMini and through hole NRF 24 I have given up, not worth the time wasted when you see the price on AliExpress...
            • dbemowskD
              dbemowskD
              Here are a few more things to point out:
              0_1495292197192_upload-7ef43cee-da75-41a3-af90-28562bbdbf8f
              • Nca78N Nca78
                dbemowskD
                dbemowskD
                @Nca78 Years ago I bought this desoldering iron from Radio Shack. This thing works great for thru-hole components as you can heat up the pad and lead with the tip and suck it away right away while it is hot. I have had a few troubles on some things, but overall it has worked well for me.
                0_1495292523253_upload-c347566e-310c-470b-a7a5-c5b1bd818568
                  Clever design, a little bulky for my personal taste: I'd have preferred a spring loaded mechanism
                    dbemowskD
                    dbemowskD
                    @gohan I have one at work that is a pencil type like the old plunger type solder suckers, but that one doesn't seem to work for crap. What can you expect for $8 bucks. The only reason I bought it was because I knew how well the one I had at home worked, and I thought this might do a similar job.
                    0_1495293071949_upload-55914e95-fa37-4dd3-b938-4e9d8e372863
                      I hate desoldering, that's why I try to avoid it as much as possible 😇😁
                        dbemowskD
                        dbemowskD
                        @gohan I am with you my friend, but there are times when necessity gets in the way of that.
                        • ileneken3I ileneken3
                          Hello everyone:
                          I took Gohan's advice and did the continuity tests. On two of the boards I tested, there was a lack of connectivity to pins 10 and 11. (Pins 9,13, and 12 were fine).
                          These boards were from two different batches.
                          Below is a picture of a board that was actually working for weeks. Then I get the same !TSM:INIT:TSP FAIL failures rolling out. Since this was a plant moisture sensor, I assumed it was because I got some water on it - but maybe not.
                          On one of the boards, I de-soldered the radio. Then the continuity was even worse. I don't even want to show a picture of it :)
                          So - does this provide more clues? Any idea on the best way to salvage parts now? I have a feeling the pro-mini is just fine.
                          Thanks again!
                          m26872M
                          m26872M
                          m26872
                          @ileneken3 said in Board and hardware failures:
                          Since this was a plant moisture sensor, I assumed it was because I got some water on it.
                          I'll bet on (galvanic) corrosion as a root cause. Protect the pcb or use wires between pcb and sensor.
                            maybe it got watered too :D
                            ileneken3I 1 Reply Last reply
                              ileneken3I
                              ileneken3I
                              ileneken3
                              @gohan
                              OK, I started over again with the moisture sensor -taking all the advice I got.
                              • Used female headers, to allow for easily swapping hardware.
                              • No longer cutting pins on back of the board.
                              • No longer cutting right side of board off (in case damage is done).
                              • New soldering iron tip.
                              • Soldering with a magnifying glass, and being careful.
                              • Checking continuity.
                              • Checking pro-mini and radio separately.
                              • Separating the "fork" so no soil or moisture touches the PCB (avoiding corrosion).
                              I turned it all on , and got the same !TSM:INIT failures. Just when I was about to throw the board against the wall, I took a shot at shorting the REG (in addition to the BAT). Then everything worked great!
                              I guess I don't understand why that worked. I figured I'd write myself a spreadsheet, and fill in the combinations. Attached is my start.
                              Comments/Corrections?
                              0_1495593060331_newbie.pdf
                              dbemowskD sundberg84S Nca78N 3 Replies Last reply
                                @gohan
                                dbemowskD
                                dbemowskD
                                @ileneken3 First and foremostm, don't get discouraged. We are here to help. Can you show us a set of fresh pics of both sides of your board so we can see what's going on? The easy newbie board can have several configurations and depending on how you have things connected with your incoming power will determine what BAT and REG jumpers need to be in place for things to work properly.
                                  @gohan
                                  sundberg84S
                                  sundberg84S
                                  #24
                                  @ileneken3 as @dbemowsk said, there are some configurations you can use which is tested (see openhardware for details). If you have some insight and imagination thought there are probably a 100 different combination you can do... but also 100 different combination that won't work! (100 might be exaggerated but you get the picture).
                                  First rule - the board is not designed to short both bat and reg at the same time.
                                  BAT and REG as dependent on which input you use and if you use a booster/regulator or not.
                                  About your spreadsheet:
                                  1. Correct! Should work - what kind of problems did you experience?
                                  2. Correct! Should work - what kind of problems did you experience?
                                  3. Not possible. Using BAT you can not cut the PCB because the trace runs through the booster module. If you dont want to use the booster you can bypass it with a wire but its not possible using 3x5cm cut pcb.
                                  4. I dont know, I have to have a schematics because it depends in which input you use and how you put the regulator. This will feed the 3.3v pro mini with 3.7v directly and only regulate the power to the radio.
                                  You always connect your power source to VCC and never RAW - right?
                                  When you had this issue:
                                  What kind of hardware and power supply did you use? Did you use a tested radio (to exclude radio failure).
                                  Another tip is to solder the basic components first (not any sensor or accuator) and test the board with a easy sketch like timeaware sensor. If that works you can continue to include the sensor to exclude its a sensor error.
                                  The easiest way is to follow the guidelines on openhardware or ask what you want to achieve.
                                    @gohan
                                    @gohan
                                    !TSM:INIT failures.
                                    TSM INIT means radio was not initialized, in that case only 2 possibilities:
                                    • connection problem with one of the radio pins
                                    • radio doesn't get power (it seems that was the case for you)
                                    • sundberg84S sundberg84
                                      ileneken3I
                                      ileneken3I
                                      ileneken3
                                      @sundberg84
                                      "100 different combinations"
                                      Yes, I meant the spreadsheet to be a list of typical examples - not a comprehensive list. For a "newbie", having a cookbook style recipe is useful.
                                      1. Works, no problems.
                                      2. Works, no problems.
                                      3. This is a big surprise. I thought I might have been doing something wrong, but nobody caught that from the pictures I sent! For a plant monitor, where the sensor needs almost no voltage, I didn't think it made sense to use a booster. I also wanted a nice compact device to stick in the plant pot. So, given my "illegal" configuration, I suppose it's no surprise there would be some erratic behavior?
                                      4. This works great for me. The board (and most sensors) work fine in the voltage range of a LIPO - only the radio needs to be regulated down to 3.3V. The mcp1700 needs its pins crossed over to work (since the board is designed for a LE33 regulator). A correction to the BOD column would be "2.8V (default)" or "N/A".
                                      I have never used RAW.
                                      Regarding:
                                      I used 2 AA , a 3.3V pro mini with no BOD. I tested the radios, and even tried different ones. I can send a picture - but there's nothing interesting with it. So, the existing mystery is: why do I need to short both BAT and REG (which I know now is illegal)? I tried all combinations of shorting/not shorting jumpers - that is the only one that worked.
                                        ileneken3I
                                        ileneken3I
                                        ileneken3
                                        @dbemowsk
                                        Yes, I appreciate the help! I am hoping others are learning from my adventures. It wouldn't be a fun hobby without a bit of frustration here and there :)
                                        I am attaching fresh pictures. The sensor attached is a "fork" for plant moisture monitoring.
                                          You could also consider smaller pcbs available on openhardware and maybe using cr123 battery to make it smaller, since it has to go near a plant
