  3. Extending range of regular nRF24L01+
28 Posts 10 Posters 29.0k Views 8 Watching
    ssrini2
    petewill:
    Do we need cat5? Will any cable do?
    Also do i need to have this antenna at both the tx and rx? Thanks for your cool video! Will try it and report my observations. We've got concrete walls in India.. I am hoping the range is still alright
    petewillP 1 Reply Last reply
    • S ssrini2
      petewill:
      petewillP
      petewillP
      petewill
      @ssrini2 I have only used cat5/cat6 cable but other wire may work. The stuff I use is solid copper (not stranded). There are many different examples out there of what can help but I have always used the method from my video. I would do some experimenting to see what works best for you. With concrete walls you may find that you want to turn on the repeating functionality on some of your MySensors devices.
        ssrini2
        It worked quite well with solid copper wire across concrete. Much appreciated. Thanks. I am now trying to see if there is a smaller length that could suffice for my experiments. Any thoughts on that? Is there a smaller wavelength wire that could suffice? Anway I will post in this forum the lengths that worked for me. Cheers!
        • S ssrini2
          petewillP
          petewillP
          petewill
          @ssrini2 There are specific lengths that will work. I used an antenna calculator to find the length I used. I can't remember where I found it but I think a quick google search should work.
            Hi guys, I tried the single wire mod but without any noticeable improvement: with a single wall in between I can't go more than 5 mt or I start getting NACK messages. I'll have to try the dipole or my radio modules are crap (as I always suspected)
            Nca78N 1 Reply Last reply
              @gohan said in Extending range of regular nRF24L01+:
              Have you first checked your power source ?
              Did you put a capacitor big enough and as close as possible to the VCC/GND pins of the radio module ?
                Yes, I'm using both adapters with voltage regulator and caps or 3v from the mega 2560 plus 100uf cap. I suspect the modules because they were very cheap. I'm waiting for the PA to arrive and meanwhile I was just trying to play around with the ones I got.
                  @gohan yes then it sounds like bad modules, that extra dollar for a lot of 10 modules often make a lot of difference in quality ;)
                    The problem is being lucky enough to get working ones. Let's see with dipole if something changes.
                    • TmasterT
                      TmasterT
                      Tmaster
                      wrote on last edited by Tmaster
                      #21
                      Tooooooo short! real range of printed antena modules are around 20 to 30m with one wall at midle.
                      You should have something doing noise,like router on same freq our other 2.4 ghz device on same frequency.
                      on my case i live ouside city so my router its the only one on 2.4ghz but never cause me problems .
                      Its really bad luck all your modules come with problems
                      some of my modules have and laptop antena instead of pcb antena,but only increase range in +/- 5m though walls
                      there's one increment that i read here from other member did on amplified version; cover the module with aluminium foil ,and leave antenna outside aluminium,i think that avoid signal propagation before antena do this job.
                      (0_1495467558388_upload-7c0bb1c4-6378-4d96-af9e-37dc56da6947
                      i'm a arduino fan .Even sometimes don't undestanding how to use it :P
                        I put them on channel 10, that should be away from wifi networks. I leave in the countryside so I don't think I have any other interference. I suspect they are just crappy modules. Hope for the shielded PA to arrive soon (of course all the interesting parts I have ordered are arriving much later than all the other junk :D )
                        • TmasterT Tmaster
                          petewillP
                          petewillP
                          petewill
                          @Tmaster said in Extending range of regular nRF24L01+:
                          This is very good advice if using the PA version. One of my PA radios was so bad it was actually took down my z-wave network network (yes, z-wave is 900MHz). After wrapping with aluminium foil (and grounding that) it works beautifully.
                            I am not using the PA version, just a common clone with trace antenna. After rating them 1 star on Amazon, the seller offered a refund in exchange for a change in review.... Sorry but I am only going to add the seller has been kind to offer a refund, but if the modules are junk I can't change my opinion :D
                            • TmasterT
                              TmasterT
                              Tmaster
                              so if you have nothing to lose ,cut the antena trace near last smd component and solder an external antena and try again. should increase signal.
                                I tried with dipole mod but didn't gain anything.
                                  #27
                                  @gohan are you aware that you need to align the antennas if you use a dipole?
                                  I am not sure how to align a pcb antenna with a dipole, but two dipoles need to be aligned so they are in parallel. Otherwise the received signal can have lower strength than when using the pcb antenna.
                                    I know but I am not going to waste more time on them
