  3. PIR am312
PIR am312
96 Posts 13 Posters 76.1k Views 10 Watching
    Me too. Based on AWI's report above, I just went ahead and ordered them.
    @NeverDie said in PIR am312:
    I received mine yesterday: so, 16 days from order until receipt from banggood.
      #34
      @AWI Thank you for your photo. Without it, I'm not sure how I would have deduced the correct pinout.
      So far I've only powered it up--and with merely a DMM attached to the output pin--but as a quick test it seems to work.
      Nca78N 1 Reply Last reply
        There are some tiny '+' and '-' signs on the breakout board near the pins but they are barely visible.
        • Nca78N Nca78
          #36
          @Nca78 said in PIR am312:
          On mine I don't see any pinout markings at all.
          I used a uCurrent Gold to measure the current, and and at 3.3v my measurements came out at 13.1ua in standby mode and 14.3ua at "motion detected" mode. I haven't tested it for false positives yet (it may take a while to gather the data on that), but so far I'm impressed. Nice find!
            #37
            So, I made a little test jig to try it out. It seems to have roughly 4 detection "zones" with fairly wide gaps between them where it's more or less blind. Also, if I walk straight at it from the front, it doesn't detect me until I'm about 3 feet away. So, although I'm no expert, I'd say the detection coverage is kinda spotty. Maybe the small domed plastic optics are sub-optimal? Has anyone tried alternatives?
            Just thinking out loud, but maybe you can use two and by skewing their alignment try to make it so that the gaps in one are mostly covered by the detection zones of the other, and visa versa?
            Not sure how to make the best use of this yet, but I do like the very low power consumption. I think there's a pony in there somewhere, and we just need to find it.
            Anyone have ideas?
              Did that resonate with anyone? Has anyone else observed "the problem" I described? If not, maybe I set it up wrong.
              • Nca78N
                I have experienced similar behavior yes, didn't have time to check enough but from some directions it gave me the impression not to detect anything.
                It seemed better with lens from a SR501. I'm waiting for the PCB with am612 to be able to test with a properly aligned SR501 lens.
                • Nca78N Nca78
                  @Nca78
                  Thanks! I just now took the lens cover off an SR501 and very crudely attached it to the Banggood sensor (after first removing its cap). It seems to be an improvement. So, I expect doing a proper job of it will yield an even greater improvement.
                  Fortunately, it looks as though there's a good variety of PIR lenses on Aliexpress for cheap.
                    the fun will be to make them fit on the sensor :)
                      #42
                      @gohan said in PIR am312:
                      I was thinking hot glue and a cardboard backing for prototyping, but maybe a backing which actually reflects IR (like a metal foil?) would help keep the IR bouncing around inside it more and be a good thing. Really not sure.
                      On the other hand, maybe there's a better lens which can snap onto the existing body. That would be better, at least from a hassle standpoint.
                        maybe make a mock pcb board of a SR501 with a hole in the middle so you can attach the lens on the board and stick the am312 in the center hole
                          Or, as a POC, just drill a hole in the middle of an SR501 board, since the lens already snaps smartly to that board.
                          Does PCB need a special kind of drill bit, like for glass or something?
                            I didn't want to sacrifice a working sensor :D
                            PCB is quite fragile, so any sharp bits should be fine, just don't push too much.
                              #46
                              So I guess this may mean we won't be using the bangood sensors after all. Instead we'll be buying chips and mounting them to custom PCB's, like NCA78 is doing. That is, unless there's a better lens cap that just naturally fits the body of the banggood sensor.
                              Which means I should order some of those PIR sensor IC's soon, given the long shipping lead times.
                                It depends on how you want to use them. Maybe for some people are fine while for others they need a longer range. It is all part of the DIY "fun" :D
                                  #48
                                  For a preliminary POC, I made a lens holder with cardboard and hot glue:
                                  and drilled a 15/32" hole in the middle for the PIR element, which I shoved in the back:
                                  Obviously it's still crude, but it's better than my first attempt. It also performs better. It still has spotty coverage, but not as bad as before. Obviously a more properly installed and aligned lens should perform better still.
                                  Anyhow, that's as far as I'm going to take it for now. I look forward to hearing what others might come up with, as well as their impressions about the coverage.
                                    maybe removing the smaller lens could improve the sensor?
                                      #50
                                      I did. What you see is just the holder that the regular lens snaps onto.
                                      • wallyllamaW
                                        wallyllamaW
                                        wallyllama
                                        Here is my version of a holder. It is for the bigger PIR. But it holds a dhtXX, ds18b20, and a light sensor as well.
                                          #52
                                          Nice!
                                          On my holder, the sensor depth is presumably wrong from a focusing point of view--at least if the SR501 is a proper guide for how it should be done. The sensor should really be deeper into the cavity. I suppose that alone might make a meaningful improvement. Alas, I think that may call for mounting the sensor element onto a PCB, so that it sits flush on top.
