  2. Announcements
  3. 💬 MySensors Library - v2.x
38 Posts 15 Posters 15.5k Views 12 Watching
    Not bad, I even did an issue back then... ;)
    https://github.com/mysensors/MySensors/issues/379
    • cimba007C
      cimba007C
      cimba007
      @hek: Could you change the part with "Here is a quick summary of the config options available. NOTE: This table will be updated with more information shortly" to be collapsed at the beginning and a + to exapand? Currently this section takes a lot of space and as it is essential for beginners might frighten new users ;-)
        We talked about splitting up this page in more use-case based pages.
        • cimba007C
          cimba007C
          cimba007
          Nice to hear, keep the good work up!
          • ileneken3I
            ileneken3I
            ileneken3
            In the "Create Repeating Nodes" section, could you please change:
            #define MY_REPEATER_NODE
            to
            #define MY_REPEATER_FEATURE
            I wasted a lot of time trying to figure out why my repeater node wasn't working.
            Thanks for a great product!
            hekH 1 Reply Last reply
            • ileneken3I ileneken3
              to
              @ileneken3
              Thanks for reporting, updated.
              • mfalkviddM
                (long unrelated discussion moved to https://forum.mysensors.org/topic/5079/the-basics-of-mysensors/ )
                • R
                  R
                  Reza
                  wrote on last edited by Reza
                  what is difference between MY_PARENT_NODE_ID and MY_PARENT_NODE_IS_STATIC ?
                  when i add "MY PARENT NODE ID" to sketch of end node , so end node dont connect to controller directly ? and dont connect to other repeaters node? even when parent node is fail ?
                  edit : i test this features but dont work ! i want the my end node connect to controller with for example parent with node id 3 ! node 3 is a repeater.... but every time (with move and reset) end node choose a new parent...
                  • U
                    U
                    user2684
                    Hi, I could not find a setCommand() message Api to chose between SET or REQ, is this done on purpose? I think it may be legitimate for a node to send a REQ command instead of the default SET.
                    Looks like mSetCommand(msg, C_SET) works but I'd avoid using not standard API calls.
                    • U user2684
                      martinhjelmareM
                      martinhjelmareM
                      martinhjelmare
                      @user2684
                      void request(uint8_t childSensorId, uint8_t variableType, uint8_t destination);
                      See "Requesting data" here:
                      https://www.mysensors.org/download/sensor_api_20
                      U 1 Reply Last reply
                        @user2684
                        U
                        U
                        user2684
                        @martinhjelmare Thanks, I've completely missed it expecting it somehow in the message constructor section, my bad! Thanks again
                        • T
                          tismoj
                          Hi I just finished configuring a site map having the sample node (S_DOOR) code above as the only thing and I noticed that it only updates once (only at every restart) to the Paper UI Control, The Basic UI, and to the Classic UI, I've already inserted a prinf to check if it would print to the serial monitor, and to also see if the value is changing on every loop and it is changing.
                          But when I looked at the Karaf Console, the send() doestn't seem to be reflecting there:
                          18:25:41.084 [WARN ] [ors.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
                          18:25:41.230 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;13907396 TSF:MSG:READ,1-1-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                          18:25:41.385 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 1;255;3;0;6;0
                          18:25:41.497 [DEBUG] [ors.internal.gateway.MySensorsGateway] - I_CONFIG request received from M, answering: (is imperial?)false
                          18:25:41.636 [DEBUG] [orsAbstractConnection$MySensorsWriter] - Sending to MySensors: 1;255;3;0;6;M
                          18:25:41.812 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;13909293 !TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=NACK:M
                          18:25:41.985 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;13909301 TSF:MSG:READ,1-1-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                          18:25:42.141 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;13909309 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                          18:25:42.313 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;13909316 TSF:MSG:READ,1-1-0,s=1,c=1,t=16,pt=1,l=1,sg=0:0
                          18:25:42.480 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 1;1;1;0;16;0
                          18:25:42.597 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Node 1 found in gateway
                          18:25:42.734 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Child 1 found in node 1
                          18:25:42.846 [DEBUG] [sensors.handler.MySensorsThingHandler] - Updating channel: tripped(V_TRIPPED) value to: CLOSED
                          18:25:43.009 [DEBUG] [sensors.handler.MySensorsThingHandler] - Setting last update for node/child 1/1 to 2018-05-31T18:25:42.000+0800
                          18:25:43.034 [INFO ] [smarthome.event.ItemStateChangedEvent] - SampleDoorSensor01_LastUpdate changed from 2018-05-31T18:25:22.000+0800 to 2018-05-31T18:25:42.000+0800
                          18:25:43.320 [INFO ] [smarthome.event.ItemStateChangedEvent] - mysensors_door_9bb51413_door_1_1_lastupdate changed from 2018-05-31T18:25:22.000+0800 to 2018-05-31T18:25:42.000+0800
                          18:27:12.393 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;13999913 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                          18:27:12.518 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;13999921 TSF:MSG:BC
                          18:27:12.600 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;13999923 TSF:MSG:FPAR REQ,ID=1
                          18:27:12.745 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;13999927 TSF:PNG:SEND,TO=0
                          18:27:12.886 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;13999931 TSF:CKU:OK
                          18:27:13.029 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;13999934 TSF:MSG:GWL OK
                          18:27:13.236 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;14000772 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                          18:27:14.417 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;14001947 TSF:MSG:READ,1-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                          18:27:14.584 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;14001954 TSF:MSG:PINGED,ID=1,HP=1
                          18:27:14.728 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;14001993 !TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
                          18:28:40.531 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;14088079 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                          18:28:40.705 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;14088085 TSF:MSG:BC
                          18:28:40.831 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;14088088 TSF:MSG:FPAR REQ,ID=1
                          18:28:40.966 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;14088092 TSF:PNG:SEND,TO=0
                          18:28:41.096 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;14088095 TSF:CKU:OK
                          18:28:41.220 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;14088098 TSF:MSG:GWL OK
                          18:28:41.489 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;14089036 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                          18:28:42.576 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;14090113 TSF:MSG:READ,1-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                          18:28:42.745 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;14090119 TSF:MSG:PINGED,ID=1,HP=1
                          18:28:42.899 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;14090159 !TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
                          18:30:08.695 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;14176243 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                          18:30:08.796 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;14176250 TSF:MSG:BC
                          18:30:08.911 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;14176253 TSF:MSG:FPAR REQ,ID=1
                          18:30:09.050 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;14176257 TSF:PNG:SEND,TO=0
                          18:30:09.183 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;14176261 TSF:CKU:OK
                          18:30:09.315 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;14176264 TSF:MSG:GWL OK
                          18:30:09.464 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;14176282 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                          18:30:10.698 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;14178277 TSF:MSG:READ,1-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                          18:30:10.865 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;14178284 TSF:MSG:PINGED,ID=1,HP=1
                          18:30:11.007 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;14178324 !TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
                          • T
                            tismoj
                            Please disregard my prev inquiry, I was able to find a solution that same day, but it required me to modify MySensors library (inside RF24_spiMultiByteTransfer function) and also exposed one of the functions in RF24.h to get it to work.
                            • A
                              APL2017
                              Please confirm that to have node configured as repeater only, it is sufficient to have the following code written:
                              • A APL2017
                                @apl2017 I don't think you need to include SPI.h
                                #define MY_REPEATER_FEATURE (and all other MySensors defines) must be placed before including MySensors.h
                                • A
                                  APL2017
                                  Thank you MFalkvidd. I was wondering why many examples in your library have SPI.h library called while have no SPI communication required, it sounds like it can be removed from them as well..
                                  Also, do I need to place CHILD MySensors defines before including MySensors.h? It is not how many examples are done, please clarify.
                                  • A APL2017
                                    Which examples are you referring to? I am not able to find any occurrences of including SPI.h in the examples:
                                    Micke @ Quasi Arduino/libraries/MySensors HEAD
                                    $ grep -ir 'SPI\.h' examples/ | wc -l
                                    The child ids are not used by the MySensors library. They are only used in the sketch, so there is no need to define them before including the library.
                                    A 1 Reply Last reply
                                      APL2017
                                      wrote on last edited by APL2017
                                      #23
                                      @mfalkvidd I am referring to the following code example on Build page of MySensors site: Distance, Door/Window/Button, GPS Sensor, IR Sender/Receiver, Parking Sensor, Servo, Temperature, UV
                                      • A APL2017
                                        Thanks for clarifying @apl2017
                                        Those examples use external libraries and are therefore placed outside the main MySensors git repo. Some of the external libraries might need SPI. I doubt most of them do though, especially button and servo.
                                        I'm not sure how to verify that in an efficient way though. We woldn't want to break the examples.
                                          APL2017
                                          @mfalkvidd One of the efficient ways to do it (if doable) is to replace site examples with links to main MySensors git repo. I noticed that some examples on site are incorporated into the pages, some are done as links already. I realize thou that examples in git repo could be different. The goal of git repo examples, as I see it, is to show technology capabilities covering majority of typical applications, while on website you may also publish some real exotic examples, such as sky stars, or whole house fan.
                                          Please don't get me wrong, I love MySensors and very pleased with technology, documentation and support. This is just in my nature to attempt to clarify and optimize whatever I can. My colleagues at work hate me for this...
