  2. Announcements
  3. 2.0 Discussion: Units, sensor types and protocol
170 Posts 23 Posters 118.9k Views 7 Watching
    Yep ChildSensorType is redundant.
    If thin things like the Arduino based MQTT gateway would manage without it we could probably remove it from the normal payload.
    Request for metadata is a good idea. Would require sensor to keep this available at all time in memory or eeprom when controller requests it.
    N
    N
    ntruchsess
    As MQTT-protocoll is not stateless (it does Quality-of-service with message-storage and redelivery - though the existing gateway code doesn't support this yet) the MQTT-gateway cannot be a thin thing anyway. I wouldn't mind if it doesn't run on Uno due to memory-constraints, there's the Mega2560 or even the DUE which seems to be affordable as you only need a single gateway per install.
      First post updated.
      • tbowmoT
        tbowmoT
        tbowmo
        what about a "RS232" sensor?
        The TV in my living room has a serial port to control it (Can do everything I can with the remote) and also request status from the TV (eg. powerstate, channel being watched etc). Could be cool to include that into some kind of domotica solution
        / Thomas
          This would probably qualify for a special command-type as it's not a "normal" sensor.
          Today I've squeezed in scene controller and ir-commands among the "sensors" but they should probably also have their own commands. Thanks for the input!
          • AnticimexA
            AnticimexA
            Anticimex
            Perhaps rs232 and ir can be fused together as one type? Both are by definition serial protocols. Each with a protocol and symbol rate specific to the appliance at hand.
              I know too little about rs332 and IR to make a suitable command structure at the moment.
              • AnticimexA
                AnticimexA
                Anticimex
                Think "uart" :)
                • tbowmoT
                  tbowmoT
                  tbowmo
                  Think that, for UART it should be enough to send characters (or strings) to the sensor, and send back replies to the master (If anything comes in at the serial port)
                  I asume that if one needs to use serial to communicate with some remote device, one will setup baudrate etc. for that particular device in the arduino sketch. So no need to use initialisation commands for the serial stuff.
                  For IR it's a bit more complicated, because there is no single protocol definition like serial. for IR it could be RC5, RC6, something else, it can be different carrier frequences etc. for each brand. And it can be send to multiple devices, using the same IR "blaster"
                  / Thomas
                  AnticimexA 1 Reply Last reply
                  • tbowmoT tbowmo
                    / Thomas
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @Thomas-Bowman-Mørch well, yes. But I am more thinking a "protocol". No matter what serial interface the sensor has externally, any serial interface implement some form of protocol for managing handshaking, flow control, etc. And considering the limitation in the data packets in RF24, we cannot expect to be able to implement a "stream".
                    By having a protocol, the sensor node can ensure it collects enough data to be able to satisfy it's external device, i.e. caching data packets for making a larger continuous serial transmission. Or reading a larger continuous transmission and caching it from the device, before starting to transmitting it to the controller. If transmission starts too early, data sent from the device, could be lost (depending on HW/SW solution) as serial protocols do not have to implement flow control (and rarely does).
                    Both IR and UART share the same caveats so in that respect, I think it makes good sense to figure out a command type that can satisfy both types as the needs are similar. And then it potentially can also be applied to other serial protocols (CAN for instance).
                    • L
                      L
                      lunarok
                      Not very usefull post for you here, but I want to say I'm very pleased to see this discussion and the news I can read here or what appears in dev on the github.
                      About the presentation of sub-type accepted. After getting an almost complete controller for Jeedom, we have difficulties to "predict" things to automate and make it very simple for user to use the plugin. Like for exemple, create commands. For relays and dimmer it was easy, but after when we look for servo or some extra type it's impossible to know for now what we can create.
                      So reading, the sensor will tell it in presentation it's just perfect.
                      Same for the presentation during node of lib used, that's just better than during the sensors, make sense.
                      I read also on the protocol page, that there is a way for a node to request data from gateway/controller. Can this point be clarified, maybe it needs also the sensor/node to say what it can request ? That's also for automation of autolink. For us (Jeedom plugin) and I think for other, if we know the sensor is able to request some data, we can automaticly create the information item and the user will have only to map it to the equipment it wants to point. I don't know if this is still included/planned as I'm aware many of the "smart" part must be on the controller side, but with beautiful things like Scene Controller and LCD display, I can imagine there is a need ?
                      I read also the OTA process will change a lot. So, is it better waiting 2.0 to include it on our side ? I mean, for the controller part, will this change a lot of things ?
                      And last point, there is actually a internal message type Reboot. This one is indicated only working for OTA bootloader. Is that true ?
                      If so, is it possible in 2.0 to include a way to request a complete presentation of an already started sensor. (that's why I ask for the Reboot message, simpler to request a reboot so the node will present itself at the same type)
                      Sometimes it's easier when migrating for exemple or reinstall, and we know the ID of sensor to ask it for presentating itself than going there to unplug it.
                      That's my thoughs after getting a little more in deep of protocol for the controler/plugin :)
                      Cédric
                      hekH T 2 Replies Last reply
                      • A
                        aliasdoc
                        Hi, I think we could integrate an uuid system in protocol, like this one https://code.google.com/p/tinkerit/wiki/TrueRandom .
                        • L lunarok
                          Cédric
                          True, reboot would send presentation again. But another option is to save the presentations in the api. Still a bit unclear which option I will choose.
                          @aliasdoc
                          What do you mean the random number should be used for?
                          • nneeooN
                            nneeooN
                            nneeoo
                            Hi. I would like my nodes measuring various values (temperature, humidity, ...) to send those values at specific times. I don't want to include the RTC on the node, so would like the node to request a sleep period from the controller. I can see there is no such possibility with the version 1.4 of the protocol. What do you think about including such thing?
                              You can use VAR1-5 for this in 1.4.
                              2.0 will have both VAR (used mostly for pushing custom data) and CONFIG (for custom node configuration).
                              nneeooN 1 Reply Last reply
                              • BulldogLowellB
                                BulldogLowellB
                                BulldogLowell
                                #129
                                Right now you can use the Time.h library and you don't need an RTC.
                                Just sync the time with MySensors call...
                                gw.requestTime(receiveTime);
                                with the function:
                                  RTC.set(controllerTime);
                                  nneeooN
                                  nneeooN
                                  nneeoo
                                  Yeah, good point. I somehow missed these general purpose variables. It might be good to add a dedicated type for it if you'll find it useful. If not I can live with the VAR for sure ;). Thanks.
                                    with the function:
                                    nneeooN
                                    nneeooN
                                    nneeoo
                                    with the function:
                                    Thanks for pointing out this library. However I don't want to track the time on the node, but would like just request the time for which the node should sleep from the controller. I think it makes more sense to have the logic in controller.
                                    • nneeooN nneeoo
                                      with the function:
                                      BulldogLowellB
                                      BulldogLowellB
                                      BulldogLowell
                                      @nneeoo
                                      Oh, you are requesting the duration of the sleep... not the moment at which you wish it to sleep.
                                      I thought you were wanting it to transmit data at certain times...
                                        @nneeoo
                                        nneeooN
                                        nneeooN
                                        nneeoo
                                        @nneeoo
                                        Well, yes. I want the node to transmit at certain time. Since the controller should know when that time is, it has to be able to calculate for how long should the node sleep, when the node asks the controller. I hope you get my point.
                                        • nneeooN nneeoo
                                          @nneeoo
                                          BulldogLowellB
                                          BulldogLowellB
                                          BulldogLowell
                                          #134
                                          @nneeoo
                                          yes, so you can use Henrik's advice and store a variable which is the time interval in seconds, minutes or even milliseconds.
                                          pass that variable into a function that uses that time as the interval to transmit your data from the sensor.
                                          something like this... pseudo code
                                          int intervalFromController; //in minutes
                                            gw.begin(getVariables, RADIO_ID, false);
                                            //your other stuff
                                            updateSensorData(intervalFromController);
                                          void getVariables(const MyMessage &message) //
                                            if (message.sensor == CHILD_ID)
                                              if (message.type == V_VAR1)
                                                // get your V_VAR1
                                          updateSensorData(int interval)
                                            static unsigned long lastTransmitTime;
                                            if (millis() - lastTransmitTime >= interval *60000UL)
                                              //collect and transmit sensor data
                                             //request sensor interval
                                            lastTransmitTime += interval * 60000UL;
