  3. 8Bit or 32Bit processors
86 Posts 11 Posters 38.2k Views 8 Watching
    Sweeman
    Hi lafleur!
    I am glad to see that you are using the Adafruit Feather M0. Since I do have some issues with that, I would be grateful if you could have a look at my problem and help me out.
    https://forum.mysensors.org/topic/6908/adafruit-feather-m0-rfm69hcw-with-mysensors
    L 1 Reply Last reply
    • S Sweeman
      Hi lafleur!
      L
      L
      lafleur
      @Sweeman
      I'm on travel, and do not have any hardware to test with...
      some notes:
      Use generic M0 processor definition tool-->board--> Arduino zero (native USB port)
      If I remember, 2.1.1 has NOT yet implemented sleep for M0 processors
      Here is a striped down version of your code.... get it to work first sending messages to your gateway, then start adding your real code back.... This complies, but I DID NOT HAVE ANY HW to test it on...
      Make sure you check the radio pins on the feather and that they are correct.
           * Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
           * http://www.mysensors.org/build/temp
          //#define MY_RADIO_NRF24
          #define MY_RADIO_RFM69
      unsigned long SEND_FREQUENCY        = 10000;      // Minimum time between send (in milliseconds). We don't want to spam the gateway.
      unsigned long currentTime         = 0;
      unsigned long lastSendTime        = 0;
      unsigned long keepaliveTime       = 0;
          #define MY_RF69_SPI_CS 8
          #define MY_RF69_IRQ_PIN 7
          #define MY_RF69_IRQ_NUM 4
          MyMessage msg(0,V_TEMP);
          void before()
            //present(0, S_TEMP);
          currentTime = millis();
       /* ***************** Send Sensor Data ***************** */
          if (currentTime - lastSendTime >= SEND_FREQUENCY)          // Only send values at a maximum rate
            Serial.println("*** Sending Sensor Data");
           lastSendTime = currentTime;
          // lets send some data
            float temperature = 67.4;
            send(msg.setSensor(0).set(temperature,1));
          }  // end of if
      } // end of loop
      L S 2 Replies Last reply
      • Nca78N
        I see "cheap" and then 30-40$ boards as suggestions, am I missing something ? :o
          "cheap" is all related to where you live :D
          • L
            L
            lafleur
            wrote on last edited by lafleur
            The M0 chip cost less that the 8bit 328, so building your own boards, it cost less...
            Then you need to add a radio, $2 to $9. Crystal, $.50, connectors, flash, voltage regulators, leds, capacitors, resistors, pcb board.... ect, all add cost....
            But vendors building board, need to make a profit to stay alive, so you pay for their work....
            So yes, finish boards in small quantity cost $20 to $40 or so.... not a bad price for what you get.....
            • Nca78N
              I see, I didn't realize there were M0 chips so insanely cheap.
              • L
                L
                lafleur
                @Nca78
                As manufacturing of chips goes to smaller and smaller die size, chip cost go down and preformance goes up..... older processors cost more to build that newer parts!
                It all means better performance, less power and more features for less money...
                The intel 8080 when it was introduced was $360, power hungry, no ram, no storage, no I/O, needed a lot of support chips.... we have come a long way!!!!
                • L lafleur
                  @Sweeman
                  some notes:
                      void before()
                      }  // end of if
                  } // end of loop
                  L
                  L
                  lafleur
                  @lafleur
                  You should also add this to your test code to see debug messages from the MySensor stack.. Also add to gateway, so that you can see what happening on both ends....
                  /*  Enable debug prints to serial monitor on port 0 */
                  #define MY_DEBUG            // used by MySensor
                  #define MY_DEBUG_VERBOSE_RFM69
                  • L lafleur
                    @Sweeman
                    some notes:
                        void before()
                        }  // end of if
                    } // end of loop
                    Sweeman
                    @lafleur
                    Thank you very much! This is a big step in the right direction for me and I hope that I can get it to work with that :)
                    To add to this discussion:
                    These radios come already assembled. It is true that you could save some money by assembling them yourself and maybe more by ordering directly from Hong Kong (which takes anything between 4-10 weeks) and hoping that they sent you the right stuff. But if you add up the stuff that you would need and the time to solder etc. then at least I would end up spending more for a bigger and uglier radio.
                      Still a pro mini is well tested platform, performance is not an issue for a sensor node anyway
                        L
                        L
                        lafleur
                        @gohan Pro-mini, is a great part, but sometime you need a lot more! 32 bit is the future for me, less power, less cost, more resources....less hassles...
                          Agreed but at the moment you have to choose between the future that isn't sure to work or the past that has been proven reliable 😀
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @gohan
                            The only way we can get the shiny new things to be proven hardware, is to have people build stuff using it :) That way, we can have more people testing the hardware, and reporting any bugs (if there is any), and have a better chance for getting it to be the next big thing :)
                            • GertSandersG
                              GertSandersG
                              GertSanders
                              @lafleur
                              I was wondering where you can get a M0 processor for less then the price of an atmega328p ? Most SAMD21's I see are 5 times the price of an atmega328p (normal given it's much better capacities).
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                @GertSanders
                                atmega328p costs 2.07$ on mouser : http://www.mouser.dk/ProductDetail/Microchip-Technology-Atmel/ATMEGA328P-AU/
                                If you take the equivalent atsamd20E15, it cost 1.84$ http://www.mouser.dk/ProductDetail/Microchip-Technology-Atmel/ATSAMD20E15A-AU
                                (both have 32Kb flash)
                                If you beef up the atsam to the largest memory, it costs 2.36$ http://www.mouser.dk/ProductDetail/Microchip-Technology-Atmel/ATSAMD20E18A-AU
                                But then you also have 256Kb of flash and 32Kb ram available, for .29$ extra (compared to the atmega328)..
                                Of course that is not atsamd21, but for a standard node you don't need the USB capabilities of the '21, and a '20 should be enough..
                                • Nca78N
                                  wrote on last edited by Nca78
                                  On AliExpress you can find STM32 with Cortex M0 for as low as 0.4$ per unit. Not compatible with Arduino unfortunately but for that price the specs are pretty impressive...
                                  And the STM32F103C8T6 which are compatible with Arduino and soon compatible with MySensors are around 1$, similar price than AtMega328 but for Cortex M3 at 48MHz, 64KB of flash, 20KB or RAM and lots of extras.
                                  • GertSandersG
                                    GertSandersG
                                    GertSanders
                                    @tbowmo said in 8Bit or 32Bit processors:
                                    ATSAMD20E18A-AU
                                    Too bad that MOUSER still charges me 20 EUR for transport, even for something as small as a single chip. I would need to buy for more then 50 EUR before transport cost is waived. How the suppliers on Aliexpress do it, I do not know.
                                    Nca78N scalzS 2 Replies Last reply
                                    • GertSandersG GertSanders
                                      ATSAMD20E18A-AU
                                      @GertSanders said in 8Bit or 32Bit processors:
                                      They just use cheaper shipping options that are much slower. It's possible in the US too as you can order PCBs from PCBs.io for 5$ shipping included, and they are in the US.
                                        ATSAMD20E18A-AU
                                        #21
                                        @GertSanders
                                        ali, or chinese supplier, in fact are cheating a bit for getting those price.
                                        when ordering at mouser, i generally order some stock for future boards, and regarding some parts, like passives it's almost same price as ali and you're sure of the quality (and for some sensors i'm sure they're not out of specs, clones..) , with a bigger choice.
                                        but sometimes i have some missing parts too :grimacing:
                                        tme has low shipping cost, or Arrow.com is nice too as it's 20€ minimum order for getting free express shipping ;)
                                        I don't know how to get cheaper then..
                                        Nca78N sundberg84S 3 Replies Last reply
                                        • scalzS scalz
                                          @GertSanders
                                          @scalz said in 8Bit or 32Bit processors:
                                          Free shipping to Vietnam also :o
                                          Thank you @scalz I love you :D
