  3. Adafruit Feather M0 RFM69HCW with MySensors?
featheradafruitrfm69hcwatsamd21g18samd
17 Posts 7 Posters 10.1k Views 6 Watching
  • S
    Sweeman
    I am fairly new to all that stuff and hope that you might help me out a bit.
    I have seen the Feather getting mentioned a couple of times but so far only lafleur's post about 8 or 32bit MCUs suggested that he successfully use one of these. (https://forum.mysensors.org/topic/6718/8bit-or-32bit-processors)
    I am using the Feather M0 @433MHz RFM69 (https://www.adafruit.com/product/3177)
    Arduino IDE 1.8.2 (portable)
    MySensors 2.1.1
    DallasTemperature 3.7.7
    OneWire 2.3.3
    I want to build a sensor-node with one wire sensors, which sends back temperature and battery level to a RaspberryPi.
    As far as I can tell the Feather is not explicitly supported by the MySensors-library. When I try to compile it returns:
    In file included from C:\Users\LaborK06\Documents\Arduino\libraries\MySensors/core/MyHwSAMD.cpp:20:0,
                     from C:\Users\LaborK06\Documents\Arduino\libraries\MySensors/MySensors.h:67,
                     from F:\arduino-1.8.2-windows\Sketches\M0_Adafruit_RFM69_v01\M0_Adafruit_RFM69_v01.ino:37:
    C:\Users\LaborK06\Documents\Arduino\libraries\MySensors/core/MyHwSAMD.cpp: In function 'void hwInit()':
    C:\Users\LaborK06\Documents\Arduino\libraries\MySensors/core/MyHwSAMD.h:55:25: error: 'SerialUSB' was not declared in this scope
     #define MY_SERIALDEVICE SerialUSB
    C:\Users\LaborK06\Documents\Arduino\libraries\MySensors/core/MyHwSAMD.cpp:104:2: note: in expansion of macro 'MY_SERIALDEVICE'
      MY_SERIALDEVICE.begin(MY_BAUD_RATE);
    exit status 1
    Fehler beim Kompilieren für das Board Adafruit Feather M0.
    I saw that lafleur already contributed to the MyHwSAMD.h but even though I do have these changes in my file it does not work.
    With the Sensebender board selected it compiles (without the battery measurement) and I can even upload it, but I'd like to use the battery reading from A7, which does not work with Sensebender ("is not defined in this scope" error), I think because of the fact that sensebender only has two analog pins.
    Surely I am missing something fundamental. I hope you guys can help me.
    This is the code I am working with. Essentially the example for dallas temperature sensors with minor additions.
     * Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
     * http://www.mysensors.org/build/temp
    //#define MY_DEBUG
    //#define MY_RADIO_NRF24
    #define MY_RADIO_RFM69
    #include <OneWire.h>
    #define COMPARE_TEMP 0 // Send temperature only if changed? 1 = Yes 0 = No
    #define MY_RF69_SPI_CS 8
    #define MY_RF69_IRQ_PIN 7
    #define MY_RF69_IRQ_NUM 4
    #define VBATPIN A7  // select the input pin for the battery sense point
    int oldBatteryPcnt = 0;
    int batteryPcnt;
    int numSensors=0;
    bool receivedConfig = false;
    bool metric = true;
    MyMessage msg(0,V_TEMP);
    void before()
      sensors.begin();
      analogReference(INTERNAL1V1);
      #else
      //analogReference(INTERNAL);
    void presentation() {
      sendSketchInfo("Temperature Sensor", "1.1");
         present(i, S_TEMP);
      //sendSketchInfo("Battery Meter", "1.0");
      // get the battery Voltage
      // To make this easy we stuck a double-100K resistor divider on theBAT pin, and connected it to D9 (a.k.a analog #7 A7). You can read this pin's voltage, then double it, to get the battery voltage.
      float sensorValue = analogRead(VBATPIN);
      #ifdef MY_DEBUG
      Serial.println(sensorValue);
      sensorValue *= 2; // we divided by 2, so multiply back
      sensorValue *= 3.3; // Multiply by 3.3V, our reference voltage
      sensorValue /= 1024; // convert to voltage
      #ifdef MY_DEBUG
      float batteryV  = sensorValue;
      int batteryPcnt = ((batteryV-2.7)/3.3)*100;
      Serial.print(batteryV);
      Serial.println(" V");
      Serial.print(batteryPcnt);
      Serial.println(" %");
        // Power up radio after sleep
        oldBatteryPcnt = batteryPcnt;
      sleep(SLEEP_TIME);
      // auskommentiert, da private! Stattdessen sleep(750ms)
      //int16_t conversionTime = sensors.millisToWaitForConversion(sensors.getResolution());
      //sleep(conversionTime);
      sleep(750);
        float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        #if COMPARE_TEMP == 1
        #else
          send(msg.setSensor(i).set(temperature,1));
      sleep(SLEEP_TIME);
    tbowmoT 1 Reply Last reply
    • S Sweeman
      MySensors 2.1.1
      OneWire 2.3.3
      exit status 1
      //#define MY_DEBUG
      int batteryPcnt;
      int numSensors=0;
      bool metric = true;
      void before()
        sensors.begin();
        #else
           present(i, S_TEMP);
        #ifdef MY_DEBUG
        #ifdef MY_DEBUG
        sleep(SLEEP_TIME);
        sleep(750);
          #else
        sleep(SLEEP_TIME);
      tbowmoT
      tbowmoT
      tbowmo
      @Sweeman
      You probably need to tweak the hardware definition files for the feather, in order to match the configuration that is expected by the mysensors core.
      (Or patch the core so it matches the other way around..) pin definitions on the sensebender GW is modified heavily, and does not match any of the other boards. As an example, we use 3 distinct SPI ports. One for the rfm69 / nrf24, one for w5100, and one for the MysX connector.
      I did not look that much towards the arduino zero board, for pin assignments, when I did the board layout. As I moved things around to make routing the pcba as painless as possible. That means that in some cases I am using a secondary or tertiary function of a pin, in order to get the desired hardware routed.
      Cortex M0 processors are very flexible, and the sercom units (which can be configured for SPI/I2C/Serial) can be routed to a variety of different pins, so for example MOSI on sercom0, can be on 3-4 different pins, depending on how you configure it.
      • S
        Sweeman
        wrote on last edited by Sweeman
        Thank you for the advice!
        To begin with I followed lafleurs advice from this thread: https://forum.mysensors.org/topic/6718/8bit-or-32bit-processors/4
        Unfortunately I wasn't able to establish communication by using the Zero-Board-definitions. I didn't really figure out what screwed up, since I was able to compile but it never really worked and I had no Serial-Monitor available.
        Even tweaking the hardware definiton files didn't really work out. So I had a look into the initial error again to make it work with original Adafruit-FeatherM0-definitions. And I don't know why I didn't see that earlier:
        Since SerialUSB wasn't declared I did a quick search for that error and I found this: https://forums.adafruit.com/viewtopic.php?f=22&t=88793
        Apparently they changed "SerialUSB" to only "Serial".
        I edited that in MyHwSAMD.h from
        #ifndef MY_SERIALDEVICE
        to
        and it seems to work now.
        I will have to check with a gateway tomorrow. I hope this helps anyone in the future.
        And btw. for the M0-Feather the PINs changed (I found that for the 32u4 and didn't notice the difference immediately).
        You now need to define this before including the MySensors.h
            #define MY_RF69_IRQ_PIN 3
            #define MY_RF69_IRQ_NUM 3
        Thanks for the help and setting me on the right track! I will post if it works tomorrow.
        • S
          Sweeman
          It works.
          They communicate and I am able to send data from a onewire.
          The only thing which doesn't work right now is sleep. Even though I am using MySensors 2.1.0 (lafleur mentioned that sleep does not work for M0 in 2.1.1).
          Any thoughts how to fix this? It would be annoying to change batteries all the time :)
          • tbowmoT
            tbowmoT
            tbowmo
            If I remember right, then sleep is still on the todo list for m0.. The first m0 board (Sensebender Gateway), is meant to be a gateway, and as such, does not need sleep functionality.
            • S
              Sweeman
              Hi guys,
              I do have a working node now. And I think sleep is working as well. I am using Adafruit_SleepyDog for now.
              Powerconsumption has to be tested yet. To see if the node is still active I made it flash the LED everytime it wakes up for sending data. If you leave out that part it will behave a little odd, because the LED will light up for a whole cycle and go down in the next one. But I guess that's just cosmetics.
              So far it sends battery level and the temperature from one wire sensors.
              For anybody interested I will post the code. I hope it helps someone.
                  #define MY_DEBUG                                  // used by MySensor (Print debug messages via serial)
                  #define MY_RADIO_RFM69                            // Select Radio-Module RFM69
                  #define MY_RFM69_FREQUENCY RF69_433MHZ            // Define our Frequency of 433 MHz
                  #define MY_IS_RFM69HW                             // Module is high power (HW/HCW)
                  //#define MY_RFM69_NETWORKID 100                  // leave out for gateway selection
                  #define MY_RF69_SPI_CS 8                          // SPI CS PIN
                  #define MY_RF69_IRQ_PIN 3                         // IRQ PIN
                  #define MY_RF69_IRQ_NUM 3                         // IRQ PIN NUM (for M0 it is the same as IRQ PIN. Will be obsolete in upcoming MySensors.h)
                  #define MY_NODE_ID 162                            // Node ID
                  #define MY_DEFAULT_TX_LED_PIN 13                  // LED Pin for "Blink while sending"
                  #define CHILD_ID_BATTERY 1                        // Battery ID (standard 1)
                  #include <SPI.h>                                  // include SPI for communication with radio
                  #include <MySensors.h>                            // include MySensors (it has to be done after the defines)
                  #include <DallasTemperature.h>                    // Lib for Dallas Temperature OneWires
                  #include <OneWire.h>                              // Lib for OneWires
                  #include <Adafruit_SleepyDog.h>
                  #define ONE_WIRE_BUS 12                           // Pin where dallase sensor is connected
                  #define MAX_ATTACHED_DS18B20 16                   // maximum number of sensors
                  int VBATPIN = A7;                                 // select the input pin for the battery sense point
                  int batteryPcnt;                                  // battery value in percent
                  int SleepCycles = 1;                              // Number of sleep cycles (each 17 seconds)
                  int n = 0;                                        // Sleepcounter
                  float lastTemperature[MAX_ATTACHED_DS18B20];      // lastTemp variabels for every possible Sensor (0 - MAX_ATTACHED_DS18B20)
                  int numSensors=0;                                 // Number of Sensors (automatically defined later)
                  bool metric = true;
                  MyMessage msg(0,V_TEMP);                          // initialize temperature message
                  MyMessage msgBatt(CHILD_ID_BATTERY,V_VOLTAGE);    // initialize battery reading
              /* ********************* Before *********************** */
                  void before()
                    sensors.begin();                                // Startup up the OneWire library
              /* ******************** Setup ************************ */
                    sensors.setWaitForConversion(false);            // requestTemperatures() will not block current thread
                    pinMode(LED_BUILTIN, OUTPUT);
              /* ********************** Presentation ********************** */
                    sendSketchInfo("Temperature Sensor", "1.1");                    // Send the sketch version information to the gateway and Controller
                    numSensors = sensors.getDeviceCount();                          // Fetch the number of attached temperature sensors
                        present(i, S_TEMP);                                         // Present all sensors to controller
                    present(CHILD_ID_BATTERY, S_MULTIMETER);                        // Present battery to controller
              /* ********************** Loop ********************** */
                  n = 0;                                                            // reset sleep count
                  if (n == 0)                                                       // Only send Data when sleep cycles completed
                    /* ***************** Get the battery Voltage ***************** */
                    // To make this easy we stuck a double-100K resistor divider on the BAT pin, and connected it to D9 (a.k.a analog #7 A7). You can read this pin's voltage, then double it, to get the battery voltage.
                    #ifdef MY_DEBUG
                    Serial.println(sensorValue);                                  // Debug msg
                    sensorValue *= 2;                                             // we divided by 2, so multiply back (because of double-100K resistor)
                    int batteryPcnt = ((batteryV-2.7)/3.3)*100;                   // for 6V batterypack (don't use 6V directly. It will fry your radio. 3.3 -5 V is OK)
                    #ifdef MY_DEBUG                                               // Battery Debug
                    send(msgBatt.set(batteryV,2));
                    /* ***************** Send Sensor Data ***************** */
                    sensors.requestTemperatures();        // Fetch temperatures from Dallas sensors
                    for (int i=0; i<numSensors && i<MAX_ATTACHED_DS18B20; i++) {        // Read temperatures and send them to controller
                      float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;     //Fetch and round temperature to one decimal (v2.1.1 "getControllerConfig" instead of "getConfig")
                      #if COMPARE_TEMP == 1        // Only send data if temperature has changed and no error
                      #else
                        if (temperature != -127.00 && temperature != 85.00) {                          // Only send Data if not -127 or 85 °C (indicates reading-error)
                           send(msg.setSensor(i).set(temperature,1));                                  // Send the new temperature
                           lastTemperature[i]=temperature;                                             // Save new temperatures for next compare
                   digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on to indicate transmission
                   delay(500);                        // wait for a 500 ms
                   digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
                  }        // end of "only send data if sleep cycles completed"-if
                /* ***************** Sleep ***************** */
                while (n <= SleepCycles)
                  Watchdog.sleep(17000);              // Deepsleep with Watchdog interrupt !!Watchdog can't handle long sleep times, hence the cycles!! (n=1 -> 17 sec * 2 = 34 sec sleep)
                  n++;
              } // end of loop
              TerrenceT NeverDieN 2 Replies Last reply
              • S Sweeman
                Hi guys,
                    bool metric = true;
                    void before()
                      #ifdef MY_DEBUG
                        #else
                    n++;
                } // end of loop
                TerrenceT
                TerrenceT
                Terrence
                @Sweeman Thank you for posting this. I will be attempting to put a mo into practice soon.
                • S Sweeman
                  Hi guys,
                      bool metric = true;
                      void before()
                        #ifdef MY_DEBUG
                          #else
                      n++;
                  } // end of loop
                  NeverDieN
                  NeverDieN
                  @Sweeman
                  I'm very interested to hear your power consumption measurements. I only just recently acquired an Adafruit Feather M0 RFM69HCW, and it's probably my #1 question, because if it's not good, then I'm going to shelve it until it is good. Ultra low current consumption is simpy a MUST.
                  • S
                    Sweeman
                    I think that I will have some data on that by next tuesday, since that is also my #1 requirement. I will let you know!
                    • S
                      Sweeman
                      My gear is a bit quick and dirty, because I am in a cheapo lab and would need to get a better suited resistor for my measurement to be absolutely certain. But what I get is aprox. 150mA while sending and 2mA during sleep (with 10 Ohms as measurement resistor).
                      There is some room for improvement I guess. But it is already better than the old setup.
                      I hope that helps a little and maybe you find a way to have even less power consumption.
                      I will think a little about this and decide wheather I will get some better gear for that later. :)
                      NeverDieN 1 Reply Last reply
                      • S Sweeman
                        NeverDieN
                        NeverDieN
                        @Sweeman
                        That sounds rather high. Was it the sketch above that you were running for the sleep cycle? I could try measuring with a uCurrent Gold. It's the sleep current that matters most. I'm around 1ua during sleep with an atmega328p and an RFM69.
                        S 1 Reply Last reply
                        • scalzS
                          scalzS
                          wrote on last edited by scalz
                          from datasheet, atsamd is approx 2.8uA in deepest sleep mode without rtc, 4uA with rtc 1khz. wdt should consumes some uA too. it's not comparable with 328p, it's different, not same features, still low power vs features though.
                          • NeverDieN NeverDie
                            @Sweeman
                            Sweeman
                            @NeverDie
                            Yes it was essentially the same sketch. I guess the 3.3 V regulator is consuming some power as well?
                            I would love to see it consuming even less power. But as long as it holds for about 3 months on 4500 mAh it is kind of OK for my purposes.
                            It would be great if you could measure it with your gear and maybe you have an idea how to get it even lower, since I also have to work on some peripheral stuff first. I am looking forward to hear from your tests.
                            @scalz
                            To be honest I am a little lost with all these abbreviations since I just started on working with MCUs, but I guess it is to make a point of "features need power"? But I will use these as hints as where to look for more saving potential. :)
                            Nca78N 1 Reply Last reply
                              voltage regulators do consume power and are usually bad for sleeping nodes. ;)
                              • S Sweeman
                                @NeverDie
                                @scalz
                                Nca78N
                                Nca78N
                                @Sweeman said in Adafruit Feather M0 RFM69HCW with MySensors?:
                                It's a SPX3819 and the datasheet says "Low Quiescent Current: 90μA". Out of spec for any decent battery powered sensor IMHO :P
                                • scalzS scalz
                                  NeverDieN
                                  NeverDieN
                                  @scalz said in Adafruit Feather M0 RFM69HCW with MySensors?:
                                  Thanks for posting this. I think that alone may kill it for me. For some reason I thought it was lower.
                                  • S
                                    Sweeman
                                    Hey guys aside from these power-consumption issues, I am now running the Feather as gateway and node.
                                    And I get a strange problem.
                                    The gateway is attached to a raspberry pi via usb (by-id), which runs fhem. And everything works great for about an hour to 1 1/2. Then somehow the gateway stops receiving/communicating. I already tried an active USB-Hub incase the power consumption was too high for too long. But that didn't help. I have to reset the gateway and node to make it work again.
                                    Did anybody else ever experience similar behaviour?
