  3. Office plant monitor
mysensorsplanthumidity
41 Posts 11 Posters 15.8k Views 10 Watching
  • Nca78N
    Stop wondering. I tried with 2477 cells and it was not much better than 2032 without capacitor ;)
    • scalzS scalz
      @Nca78 you can have brownout if the battery is near end of life and nothing has been designed to handle a bit the internal res. but with a fresh a coincell and some capa, you can do some chain tx but that's not the best for the battery life.
      The only case where i had issue with brownout at startup, plus it was a fresh coincell was with a crappy ali coincell batt!! very bad quality! now I'm using only good quality coincell like duracell, varta, maxell.. and that's day and night ;)
      @carlierd If you're interested this doc explains very well the capacitor calc etc... http://www.ti.com.cn/cn/lit/wp/swra349/swra349.pdf
      • capa ideally calculated/estimated (on mine I have 200uF, plus others for sensors, radio is 86uA etc..) and after multiple msg presentation on frsh coincell i don't fall under 2.85 (voltage starts 3.05V) because I can't recover voltage during this period.
        Hopefully a transmit is not 1sec! More something like says 30+ ms (depending if signing is needed, ack, retries.. etc). To not break capa benefits, it's better to sleep between tx during chains..to recover voltage and optimize battery life. Sleeping 200ms can be enough
      • For the capa leakage, it depends of capa. common good quality ceramic have not those leakage (few nano). Sure on this design it's not a ceramic.
      • You're right at runtime 1Mhz consumes less than 8Mhz; mA vs thousands uA. But at 1Mhz everything is slower, comms too (I mean code execution). During deep sleep, there is no difference in power consumption. Oscillator is stopped so mhz does not mean. Note: at 8Mhz you can wake in few uA, at 1Mhz it's slower of course.
      carlierdC
      carlierdC
      carlierd
      @scalz : I missed your reply ! Interesting withe paper !
        @carlierd yep, this doc inspired me too, plus coincell datasheets,. I use mega-pile for sourcing batt and they have lot of battery datasheet.
        I have also recently designed few small sensors I need to put on a panel now :)
        • moisture+temp
        • moisture+salinity/conductivity+temp
        • jkarrasJ
          jkarrasJ
          jkarras
          How did you source the probe portion of the sensor?
          • tomtasticT
            tomtasticT
            tomtastic
            Could this be used with a capacitative soil sensor to avoid corrosion of the sensor over time ?
            • tomtasticT tomtastic
              @tomtastic said in Office plant monitor:
              Yes. Do you have one in mind?
              tomtasticT 1 Reply Last reply
                tomtasticT
                tomtasticT
                tomtastic
                @NeverDie Something like https://8f26945f-a-62cb3a1a-s-sites.googlegroups.com/site/drxzcl/capsensor.brd ?
                  I don't know whether it's better or worse, but the Chirp! is a capacitive soil moisture probe that has been around for awhile and is, IIRC, atmel based. It used to sell for around $15, but I just noticed that you can buy it for less than $5 from a number of ebay sellers, such as:
                  http://www.ebay.com/itm/182446660427
                  Historically, one problem with PCB probes has been that over time water intrudes into the PCB and throws off the calibration. Not sure if there's a solution for that problem, though it seems like one should exist.
                  [Edit: I see that the original author of the Chirp does have some suggestions now regarding ways to waterproof it: https://www.tindie.com/products/miceuz/i2c-soil-moisture-sensor/ ]
                  BTW, the Chirp is open source: https://wemakethings.net/chirp/
                  There's also this, which I'm not familiar with: https://www.aliexpress.com/item/DFRobot-Capacitive-Analog-Soil-Moisture-Sensor-3-3-5-5V-Corrosion-Resistant-with-Gravity-3-Pin/32574020064.html?spm=2114.01010208.3.2.P99ddH&ws_ab_test=searchweb201556_0&aff_platform=aaf&cpt=1496178932140&sk=e2Vzr3v&aff_trace_key=17f48f5bf06b4b5daa3c5b3d8442dc7c-1496178932140-02358-e2Vzr3v
                  You might be inbterested in this thread: https://forum.mysensors.org/topic/990/soil-tensiometer-sensor-network
                    @tomtastic
                    Anyhow, the probe you referenced looks a lot like this one: http://zerocharactersleft.blogspot.com/2011/11/pcb-as-capacitive-soil-moisture-sensor.html
                    As an aside, people seem happy with the Vegetronix probe, up until its PCB suffers water intrusion. The asking price is rather high though. If I knew how to, I'd make one of those and simply waterproof it better.
                      @tomtastic
                      tomtasticT
                      tomtasticT
                      tomtastic
                      @NeverDie The person behind 'Chirp' actually left a comment in your last link (zerocharactersleft). He posts an interesting link back to his own studies too : https://wemakethings.net/2012/09/26/capacitance_measurement/
                        #22
                        Thanks for the link.
                        For the best results, running the square wave at 80Mhz or faster seems to be important. That's what vegetronix does. Now, the good news is that the clock on an ESP8266 can supply that frequency.. However, all this analog circuitry is beyond my purview, so I inevitably hit a wall with that. Is that something you (or someone reading this) knows how to do? For instance, I don't know whether the chirp guy's circuit that you linked to works as-is at 80Mhz, or whether it requires modification. If the latter, that's where I get stuck not knowing what to do.
                          #23
                          @tomtastic
                          It turns out that the circuit the Chirp guy described in the link that you provided is, in fact, what is built into Chirp: https://wemakethings.net/2013/06/07/chirp-plant-watering-alarm/
                          None of his calculations make reference to frequency, so maybe (?) you could hook up the circuit to 80Mhz and it would "just work." I suppose the switching speed of those transistors might be a factor. I have no insight into that, but it would probably be easy for someone to test. IIRC, the higher frequency makes a capacitive soil moisture sensor much less influenced by soil characteristics other than moisture, so it's really necessary to have that in order to make a good probe.
                          [Edit: What you don't want is a soil moisture probe that requires frequent manual re-calibration. Ordinary conductive probes all have that as an inherent problem. Hence the hunt for a worthwhile capacitive soil moisture sensor.] ]
                            Completely unrelated, but I just noticed this:
                            https://www.aliexpress.com/item/SHT10-SHT11-SHT15-waterproof-sensor-case-temperature-and-humidity-protective-cover-soil-sensor-cover-40mm-15mm/32575966509.html?spm=2114.8153822.cb0001.16.lITM8E&scm=1007.13409.76764.0&pvid=0acc75b7-138d-456f-a5bf-5147c2ea763f&tpp=1
                            So with that, you could just use a regular humidity sensor inside it to judge soil moisture. Pretty cool, yes? Not sure how big it is, but maybe you could even fit your entire sensor node inside it.
                            Nca78N 1 Reply Last reply
                              @NeverDie said in Office plant monitor:
                              One of the local shops I buy electronic parts from has those. Unfortunately it's too small to house an entire sensor.
                                This thread also has a lot of good background information and links about capacitive soil moisture sensors: https://lowpowerlab.com/forum/general-topics/using-capsense-to-measure-soil-moisture/
                                  #27
                                  It might be that one could more or less whack an 80Mhz frequency oscillation chip into the Chirp circuit: https://www.digikey.com/product-detail/en/linear-technology/LTC6905CS5-80-TRMPBF/LTC6905CS5-80-TRMPBFCT-ND/810907
                                    #28
                                    i agree with @NeverDie ;)
                                    It's better to use high freq for a reliable soil moisture, regarding soils, calibration etc. and some studies argues even more than 200Mhz. but with 80-100 it's nice.
                                    I have one design at this freq, non corrosive design, and not same as chirp though, but can't really help you (mine is not open yet, and busy on others projects).
                                    Regarding the chirp design, I think it may need an opamp for better results regarding the 1M resistor etc, and some more tuning if going high freq.
                                      simbic
                                      Trying to get this working but getting alot of errors. New to this so bear with me.
                                      In file included from C:\...\Arduino\libraries\Moisture_sensor\Moisture_sensor.ino:55:0:
                                      C:\...\Arduino\libraries\MySensors/MyTransportRFM69.h:31:1: error: expected class-name before '{' token
                                      C:\...\Arduino\libraries\MySensors/MyTransportRFM69.h:33:36: error: 'RFM69_FREQUENCY' was not declared in this scope
                                        MyTransportRFM69(uint8_t freqBand=RFM69_FREQUENCY, uint8_t networkId=RFM69_NETWORKID, uint8_t slaveSelectPin=RF69_SPI_CS, uint8_t interruptPin=RF69_IRQ_PIN, bool isRFM69HW=false, uint8_t interruptNum=RF69_IRQ_NUM);
                                      C:\...\Arduino\libraries\MySensors/MyTransportRFM69.h:33:71: error: 'RFM69_NETWORKID' was not declared in this scope
                                      In file included from C:\...\Arduino\libraries\Moisture_sensor\Moisture_sensor.ino:56:0:
                                      C:\...\Arduino\libraries\MySensors/MySigningAtsha204Soft.h:55:1: error: expected class-name before '{' token
                                      C:\...\Arduino\libraries\MySensors/MySigningAtsha204Soft.h:62:25: error: 'MY_RANDOMSEED_PIN' was not declared in this scope
                                         uint8_t randomseedPin=MY_RANDOMSEED_PIN);
                                      Moisture_sensor:83: error: call to 'MySigningAtsha204Soft::MySigningAtsha204Soft(bool, uint8_t)' uses the default argument for parameter 2, which is not yet defined
                                       MySigningAtsha204Soft signer;
                                      Moisture_sensor:84: error: 'MyHwATMega328' does not name a type
                                       MyHwATMega328 hw;
                                      Moisture_sensor:85: error: call to 'MyTransportRFM69::MyTransportRFM69(uint8_t, uint8_t, uint8_t, uint8_t, bool, uint8_t)' uses the default argument for parameter 1, which is not yet defined
                                       MyTransportRFM69 transport;
                                      Moisture_sensor:85: error: call to 'MyTransportRFM69::MyTransportRFM69(uint8_t, uint8_t, uint8_t, uint8_t, bool, uint8_t)' uses the default argument for parameter 2, which is not yet defined
                                      Moisture_sensor:86: error: 'MySensor' does not name a type
                                       MySensor node(transport, hw, signer);
                                      C:\...\Arduino\libraries\Moisture_sensor\Moisture_sensor.ino: In function 'void setup()':
                                      Moisture_sensor:112: error: 'node' was not declared in this scope
                                         node.begin();
                                      C:\...\Arduino\libraries\Moisture_sensor\Moisture_sensor.ino: In function 'void loop()':
                                      Moisture_sensor:163: error: 'node' was not declared in this scope
                                         node.send(msgMoisture.set((moistureLevel + oldMoistureLevel) / 2.0 / 10.23, 1));
                                      C:\...\Arduino\libraries\Moisture_sensor\Moisture_sensor.ino: In function 'int readMoisture()':
                                      Moisture_sensor:200: error: 'node' was not declared in this scope
                                         node.sleep(STABILIZATION_TIME);
                                      exit status 1
                                      I have looked through the code but can't seem to see what is wrong with it.
                                      Please help :)
                                      • S simbic
                                         MyHwATMega328 hw;
                                           node.begin();
                                        exit status 1
                                        Please help :)
                                        @simbic did you modify the sketch in any way? If so, could you please post it?
                                        My guess would be an incomplete #define or using incompatible versions. Which version of MySensors are you using?
                                        S 1 Reply Last reply
                                          simbic
                                          @mfalkvidd
                                          I have assembled a copy of @carlierd 's office plant monitor since it looked kinda neat.
                                          When I first tried to upload @carlierd 's Moisture_sensor.ino it complained that several libraries were missing.
                                          So I started google-fu around to find them.
                                          What was missing was:
                                          MyTransportRFM69.h
                                          MyTransport.h
                                          MySigning.h
                                          MyMessage.h
                                          aswell as drivers, that I placed in folder /utility/
                                          ATSHA204.h
                                          RFM69.h
                                          sha256.h
                                          The code is as follows. I have only pressed include mysensors' library since it complained that it was missing.
                                           * Code and idea from mfalkvidd (http://forum.mysensors.org/user/mfalkvidd).
                                          /* Moisture sensor.        */
                                          /* Version     : 1.2.5        */
                                          /* Date        : 11/04/2016                                                           */
                                          /* Modified by : David Carlier                                                        */
                                          /*                            RST |             |  A5                                 */
                                          /*                            RX  |             |  A4                                 */
                                          /*                            TX  |   ARDUINO   |  A3                                 */
                                          /*     RFM69 (DIO0) --------- D2  |     UNO     |  A2                                 */
                                          /*                            D3  |             |  A1 --------- Moisture probe        */
                                          /*            Power --------- D4  | ATMEGA 328p |  A0 --------- Moisture probe        */
                                          /*              +3v --------- VCC |             | GND --------- GND                   */
                                          /*              GND --------- GND |  8MHz int.  | REF                                 */
                                          /*                            OSC |             | VCC --------- +3v                   */
                                          /*                            OSC |             | D13 --------- RFM69 (SCK)           */
                                          /*                            D5  |             | D12 --------- RFM69 (MISO)          */
                                          /*                            D6  |             | D11 --------- RFM69 (MOSI)          */
                                          /*                            D7  |             | D10 --------- RFM69 (NSS)           */
                                          /*              LED --------- D8  |             |  D9                                 */
                                          /* +3v = 2*AA        */
                                          #include <MyTransportRFM69.h>
                                          //Define functions
                                          #define N_ELEMENTS(array) (sizeof(array)/sizeof((array)[0]))
                                          //Constants for MySensors
                                          #define SKETCH_NAME           "Moisture Sensor"
                                          #define SKETCH_VERSION        "1.2.6"
                                          #define CHILD_ID_MOISTURE     0
                                          #define CHILD_ID_VOLTAGE      1
                                          #define LED_PIN               8
                                          #define THRESHOLD             1.1     // Only make a new reading with reverse polarity if the change is larger than 10%
                                          #define STABILIZATION_TIME    1000    // Let the sensor stabilize before reading
                                          //#define BATTERY_FULL          3143    // 2xAA usually gives 3.143V when full
                                          #define BATTERY_FULL          3100    // CR2032 usually gives 3.1V when full
                                          #define BATTERY_ZERO          2340    // 2.34V limit for 328p at 8MHz
                                          #define SLEEP_TIME            7200000 // Sleep time between reads (in milliseconds) (close to 2 hours)
                                          const int SENSOR_ANALOG_PINS[] = {A0, A1};
                                          //Variables
                                          byte direction = 0;
                                          int oldMoistureLevel = -1;
                                          //Construct MySensors library
                                          MyHwATMega328 hw;
                                          MyMessage msgMoisture(CHILD_ID_MOISTURE, V_HUM);
                                          MyMessage msgVolt(CHILD_ID_VOLTAGE, V_VOLTAGE);
                                          /* Initialization        */
                                            //Get time (for setup duration)
                                            #ifdef DEBUG
                                              unsigned long startTime = millis();
                                            //Setup LED pin
                                            pinMode(LED_PIN, OUTPUT);
                                            blinkLedFastly(3);
                                            //Set moisutre sensor pins
                                            for (int i = 0; i < N_ELEMENTS(SENSOR_ANALOG_PINS); i++)
                                              pinMode(SENSOR_ANALOG_PINS[i], OUTPUT);
                                              digitalWrite(SENSOR_ANALOG_PINS[i], LOW);
                                            //Start MySensors and send the sketch version information to the gateway
                                            node.begin();
                                            node.sendSketchInfo(SKETCH_NAME, SKETCH_VERSION);
                                            //Register all sensors
                                            node.present(CHILD_ID_MOISTURE, S_HUM);
                                            node.present(CHILD_ID_VOLTAGE, S_MULTIMETER);
                                            //Setup done !
                                            blinkLedFastly(3);
                                            //Print setup debug
                                            #ifdef DEBUG
                                              int duration = millis() - startTime;
                                              Serial.print("[Setup duration: "); Serial.print(duration, DEC); Serial.println(" ms]");
                                          /* Main loop        */
                                            //Get time (for a complete loop)
                                            #ifdef DEBUG
                                            //Get moisture level
                                            int moistureLevel = readMoisture();
                                            //Send rolling average of 2 samples to get rid of the "ripple" produced by different resistance in the internal pull-up resistors
                                            //See http://forum.mysensors.org/topic/2147/office-plant-monitoring/55 for more information
                                            //Check if it was first reading, save current value as old
                                            if (oldMoistureLevel == -1)
                                            //Verify if current measurement is not too far from the previous one
                                            if (moistureLevel > (oldMoistureLevel * THRESHOLD) || moistureLevel < (oldMoistureLevel / THRESHOLD))
                                              //The change was large, so it was probably not caused by the difference in internal pull-ups.
                                              //Measure again, this time with reversed polarity.
                                            //Store current moisture level
                                            //Report data to the gateway
                                            long voltage = getVoltage();
                                            node.send(msgVolt.set(voltage / 1000.0, 2));
                                            int batteryPcnt = round((voltage - BATTERY_ZERO) * 100.0 / (BATTERY_FULL - BATTERY_ZERO));
                                            if (batteryPcnt > 100) {batteryPcnt = 100;}
                                            node.sendBatteryLevel(batteryPcnt);
                                            //Print debug
                                            #ifdef DEBUG
                                              Serial.print((moistureLevel + oldMoistureLevel) / 2.0 / 10.23);
                                              Serial.print("%");
                                              Serial.print("   ");
                                              Serial.print(voltage / 1000.0);
                                              Serial.print("v");
                                              Serial.print("   ");
                                              Serial.print(batteryPcnt);
                                              Serial.print("%");
                                              Serial.print("   ");
                                              Serial.print("["); Serial.print(duration, DEC); Serial.println(" ms]");
                                              Serial.flush();
                                            //Sleep until next measurement
                                            blinkLedFastly(1);
                                            node.sleep(SLEEP_TIME);
                                          /* Allows to get moisture.                                                            */
                                          int readMoisture()
                                            //Power on the sensor and read once to let the ADC capacitor start charging
                                            pinMode(SENSOR_ANALOG_PINS[direction], INPUT_PULLUP);
                                            analogRead(SENSOR_ANALOG_PINS[direction]);
                                            //Stabilize and read the value
                                            int moistureLevel = (1023 - analogRead(SENSOR_ANALOG_PINS[direction]));
                                            //Turn off the sensor to conserve battery and minimize corrosion
                                            //Make direction alternate between 0 and 1 to reverse polarity which reduces corrosion
                                            direction = (direction + 1) % 2;
                                            return moistureLevel;
                                          /* Allows to fastly blink the LED.                                                    */
                                          void blinkLedFastly(byte loop)
                                            byte delayOn = 150;
                                            byte delayOff = 150;
                                            for (int i = 0; i < loop; i++)
                                              blinkLed(LED_PIN, delayOn);
                                              delay(delayOff);
                                          /* Allows to blink a LED.                                                             */
                                          void blinkLed(byte pinToBlink, int delayInMs)
                                            digitalWrite(pinToBlink,HIGH);
                                            delay(delayInMs);
                                            digitalWrite(pinToBlink,LOW);
                                          /* Allows to get the real Vcc (return value in mV).                                   */
                                          /* http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/   */
                                          long getVoltage()
                                            ADMUX = (0<<REFS1) | (1<<REFS0) | (0<<ADLAR) | (1<<MUX3) | (1<<MUX2) | (1<<MUX1) | (0<<MUX0);
                                            delay(50);  // Let mux settle a little to get a more stable A/D conversion
                                            //Start a conversion
                                            ADCSRA |= _BV( ADSC );
                                            //Wait for it to complete
                                            while (bit_is_set(ADCSRA, ADSC));
                                            //Compute and return the value
                                            uint8_t low  = ADCL;                  // must read ADCL first - it then locks ADCH
                                            uint8_t high = ADCH;                  // unlocks both
                                            result = 1125300L / result;           // Calculate Vcc (in mV); 1125300 = 1.1*1023*1000
                                            return result;                        // Vcc in millivolts
                                          I have just installed Arduino IDE, and are using the latest mysensors library 2.1.1.
                                          Another thing it complains about is:
                                          Invalid library found in C:\...\Arduino\libraries\Moisture_sensor: C:\...\Arduino\libraries\Moisture_sensor```
                                          which is wierd since I have just copy+pasted it from here:
                                          https://www.openhardware.io/view/123/Office-plant-monitor
                                          aswell as built the sensor from there.
                                          If you can help, I would be very glad, as I just hoped it would be smooth sailing using mysensors. Build, upload and let it work its magic.
                                          Tack på förhand!
                                          Simon
