  3. Office plant monitor
mysensorsplanthumidity
41 Posts 11 Posters 15.8k Views 10 Watching
    @carlierd yep, this doc inspired me too, plus coincell datasheets,. I use mega-pile for sourcing batt and they have lot of battery datasheet.
    I have also recently designed few small sensors I need to put on a panel now :)
    • moisture+temp
    • moisture+salinity/conductivity+temp
    • jkarrasJ
      jkarrasJ
      jkarras
      How did you source the probe portion of the sensor?
      • tomtasticT
        tomtasticT
        tomtastic
        Could this be used with a capacitative soil sensor to avoid corrosion of the sensor over time ?
        • tomtasticT tomtastic
          @tomtastic said in Office plant monitor:
          Yes. Do you have one in mind?
          tomtasticT 1 Reply Last reply
            tomtasticT
            tomtasticT
            tomtastic
            @NeverDie Something like https://8f26945f-a-62cb3a1a-s-sites.googlegroups.com/site/drxzcl/capsensor.brd ?
              I don't know whether it's better or worse, but the Chirp! is a capacitive soil moisture probe that has been around for awhile and is, IIRC, atmel based. It used to sell for around $15, but I just noticed that you can buy it for less than $5 from a number of ebay sellers, such as:
              http://www.ebay.com/itm/182446660427
              Historically, one problem with PCB probes has been that over time water intrudes into the PCB and throws off the calibration. Not sure if there's a solution for that problem, though it seems like one should exist.
              [Edit: I see that the original author of the Chirp does have some suggestions now regarding ways to waterproof it: https://www.tindie.com/products/miceuz/i2c-soil-moisture-sensor/ ]
              BTW, the Chirp is open source: https://wemakethings.net/chirp/
              There's also this, which I'm not familiar with: https://www.aliexpress.com/item/DFRobot-Capacitive-Analog-Soil-Moisture-Sensor-3-3-5-5V-Corrosion-Resistant-with-Gravity-3-Pin/32574020064.html?spm=2114.01010208.3.2.P99ddH&ws_ab_test=searchweb201556_0&aff_platform=aaf&cpt=1496178932140&sk=e2Vzr3v&aff_trace_key=17f48f5bf06b4b5daa3c5b3d8442dc7c-1496178932140-02358-e2Vzr3v
              You might be inbterested in this thread: https://forum.mysensors.org/topic/990/soil-tensiometer-sensor-network
                @tomtastic
                Anyhow, the probe you referenced looks a lot like this one: http://zerocharactersleft.blogspot.com/2011/11/pcb-as-capacitive-soil-moisture-sensor.html
                As an aside, people seem happy with the Vegetronix probe, up until its PCB suffers water intrusion. The asking price is rather high though. If I knew how to, I'd make one of those and simply waterproof it better.
                  @tomtastic
                  tomtasticT
                  tomtasticT
                  tomtastic
                  @NeverDie The person behind 'Chirp' actually left a comment in your last link (zerocharactersleft). He posts an interesting link back to his own studies too : https://wemakethings.net/2012/09/26/capacitance_measurement/
                    #22
                    Thanks for the link.
                    For the best results, running the square wave at 80Mhz or faster seems to be important. That's what vegetronix does. Now, the good news is that the clock on an ESP8266 can supply that frequency.. However, all this analog circuitry is beyond my purview, so I inevitably hit a wall with that. Is that something you (or someone reading this) knows how to do? For instance, I don't know whether the chirp guy's circuit that you linked to works as-is at 80Mhz, or whether it requires modification. If the latter, that's where I get stuck not knowing what to do.
                      #23
                      @tomtastic
                      It turns out that the circuit the Chirp guy described in the link that you provided is, in fact, what is built into Chirp: https://wemakethings.net/2013/06/07/chirp-plant-watering-alarm/
                      None of his calculations make reference to frequency, so maybe (?) you could hook up the circuit to 80Mhz and it would "just work." I suppose the switching speed of those transistors might be a factor. I have no insight into that, but it would probably be easy for someone to test. IIRC, the higher frequency makes a capacitive soil moisture sensor much less influenced by soil characteristics other than moisture, so it's really necessary to have that in order to make a good probe.
                      [Edit: What you don't want is a soil moisture probe that requires frequent manual re-calibration. Ordinary conductive probes all have that as an inherent problem. Hence the hunt for a worthwhile capacitive soil moisture sensor.] ]
                        Completely unrelated, but I just noticed this:
                        https://www.aliexpress.com/item/SHT10-SHT11-SHT15-waterproof-sensor-case-temperature-and-humidity-protective-cover-soil-sensor-cover-40mm-15mm/32575966509.html?spm=2114.8153822.cb0001.16.lITM8E&scm=1007.13409.76764.0&pvid=0acc75b7-138d-456f-a5bf-5147c2ea763f&tpp=1
                        So with that, you could just use a regular humidity sensor inside it to judge soil moisture. Pretty cool, yes? Not sure how big it is, but maybe you could even fit your entire sensor node inside it.
                        Nca78N 1 Reply Last reply
                          @NeverDie said in Office plant monitor:
                          One of the local shops I buy electronic parts from has those. Unfortunately it's too small to house an entire sensor.
                            This thread also has a lot of good background information and links about capacitive soil moisture sensors: https://lowpowerlab.com/forum/general-topics/using-capsense-to-measure-soil-moisture/
                              #27
                              It might be that one could more or less whack an 80Mhz frequency oscillation chip into the Chirp circuit: https://www.digikey.com/product-detail/en/linear-technology/LTC6905CS5-80-TRMPBF/LTC6905CS5-80-TRMPBFCT-ND/810907
                                #28
                                i agree with @NeverDie ;)
                                It's better to use high freq for a reliable soil moisture, regarding soils, calibration etc. and some studies argues even more than 200Mhz. but with 80-100 it's nice.
                                I have one design at this freq, non corrosive design, and not same as chirp though, but can't really help you (mine is not open yet, and busy on others projects).
                                Regarding the chirp design, I think it may need an opamp for better results regarding the 1M resistor etc, and some more tuning if going high freq.
                                  simbic
                                  Trying to get this working but getting alot of errors. New to this so bear with me.
                                  In file included from C:\...\Arduino\libraries\Moisture_sensor\Moisture_sensor.ino:55:0:
                                  C:\...\Arduino\libraries\MySensors/MyTransportRFM69.h:31:1: error: expected class-name before '{' token
                                  C:\...\Arduino\libraries\MySensors/MyTransportRFM69.h:33:36: error: 'RFM69_FREQUENCY' was not declared in this scope
                                    MyTransportRFM69(uint8_t freqBand=RFM69_FREQUENCY, uint8_t networkId=RFM69_NETWORKID, uint8_t slaveSelectPin=RF69_SPI_CS, uint8_t interruptPin=RF69_IRQ_PIN, bool isRFM69HW=false, uint8_t interruptNum=RF69_IRQ_NUM);
                                  C:\...\Arduino\libraries\MySensors/MyTransportRFM69.h:33:71: error: 'RFM69_NETWORKID' was not declared in this scope
                                  In file included from C:\...\Arduino\libraries\Moisture_sensor\Moisture_sensor.ino:56:0:
                                  C:\...\Arduino\libraries\MySensors/MySigningAtsha204Soft.h:55:1: error: expected class-name before '{' token
                                  C:\...\Arduino\libraries\MySensors/MySigningAtsha204Soft.h:62:25: error: 'MY_RANDOMSEED_PIN' was not declared in this scope
                                     uint8_t randomseedPin=MY_RANDOMSEED_PIN);
                                  Moisture_sensor:83: error: call to 'MySigningAtsha204Soft::MySigningAtsha204Soft(bool, uint8_t)' uses the default argument for parameter 2, which is not yet defined
                                   MySigningAtsha204Soft signer;
                                  Moisture_sensor:84: error: 'MyHwATMega328' does not name a type
                                   MyHwATMega328 hw;
                                  Moisture_sensor:85: error: call to 'MyTransportRFM69::MyTransportRFM69(uint8_t, uint8_t, uint8_t, uint8_t, bool, uint8_t)' uses the default argument for parameter 1, which is not yet defined
                                   MyTransportRFM69 transport;
                                  Moisture_sensor:85: error: call to 'MyTransportRFM69::MyTransportRFM69(uint8_t, uint8_t, uint8_t, uint8_t, bool, uint8_t)' uses the default argument for parameter 2, which is not yet defined
                                  Moisture_sensor:86: error: 'MySensor' does not name a type
                                   MySensor node(transport, hw, signer);
                                  C:\...\Arduino\libraries\Moisture_sensor\Moisture_sensor.ino: In function 'void setup()':
                                  Moisture_sensor:112: error: 'node' was not declared in this scope
                                     node.begin();
                                  C:\...\Arduino\libraries\Moisture_sensor\Moisture_sensor.ino: In function 'void loop()':
                                  Moisture_sensor:163: error: 'node' was not declared in this scope
                                     node.send(msgMoisture.set((moistureLevel + oldMoistureLevel) / 2.0 / 10.23, 1));
                                  C:\...\Arduino\libraries\Moisture_sensor\Moisture_sensor.ino: In function 'int readMoisture()':
                                  Moisture_sensor:200: error: 'node' was not declared in this scope
                                     node.sleep(STABILIZATION_TIME);
                                  exit status 1
                                  I have looked through the code but can't seem to see what is wrong with it.
                                  Please help :)
                                  • S simbic
                                     MyHwATMega328 hw;
                                       node.begin();
                                    exit status 1
                                    Please help :)
                                    @simbic did you modify the sketch in any way? If so, could you please post it?
                                    My guess would be an incomplete #define or using incompatible versions. Which version of MySensors are you using?
                                    S 1 Reply Last reply
                                      simbic
                                      @mfalkvidd
                                      I have assembled a copy of @carlierd 's office plant monitor since it looked kinda neat.
                                      When I first tried to upload @carlierd 's Moisture_sensor.ino it complained that several libraries were missing.
                                      So I started google-fu around to find them.
                                      What was missing was:
                                      MyTransportRFM69.h
                                      MyTransport.h
                                      MySigning.h
                                      MyMessage.h
                                      aswell as drivers, that I placed in folder /utility/
                                      ATSHA204.h
                                      RFM69.h
                                      sha256.h
                                      The code is as follows. I have only pressed include mysensors' library since it complained that it was missing.
                                       * Code and idea from mfalkvidd (http://forum.mysensors.org/user/mfalkvidd).
                                      /* Moisture sensor.        */
                                      /* Version     : 1.2.5        */
                                      /* Date        : 11/04/2016                                                           */
                                      /* Modified by : David Carlier                                                        */
                                      /*                            RST |             |  A5                                 */
                                      /*                            RX  |             |  A4                                 */
                                      /*                            TX  |   ARDUINO   |  A3                                 */
                                      /*     RFM69 (DIO0) --------- D2  |     UNO     |  A2                                 */
                                      /*                            D3  |             |  A1 --------- Moisture probe        */
                                      /*            Power --------- D4  | ATMEGA 328p |  A0 --------- Moisture probe        */
                                      /*              +3v --------- VCC |             | GND --------- GND                   */
                                      /*              GND --------- GND |  8MHz int.  | REF                                 */
                                      /*                            OSC |             | VCC --------- +3v                   */
                                      /*                            OSC |             | D13 --------- RFM69 (SCK)           */
                                      /*                            D5  |             | D12 --------- RFM69 (MISO)          */
                                      /*                            D6  |             | D11 --------- RFM69 (MOSI)          */
                                      /*                            D7  |             | D10 --------- RFM69 (NSS)           */
                                      /*              LED --------- D8  |             |  D9                                 */
                                      /* +3v = 2*AA        */
                                      #include <MyTransportRFM69.h>
                                      //Define functions
                                      #define N_ELEMENTS(array) (sizeof(array)/sizeof((array)[0]))
                                      //Constants for MySensors
                                      #define SKETCH_NAME           "Moisture Sensor"
                                      #define SKETCH_VERSION        "1.2.6"
                                      #define CHILD_ID_MOISTURE     0
                                      #define CHILD_ID_VOLTAGE      1
                                      #define LED_PIN               8
                                      #define THRESHOLD             1.1     // Only make a new reading with reverse polarity if the change is larger than 10%
                                      #define STABILIZATION_TIME    1000    // Let the sensor stabilize before reading
                                      //#define BATTERY_FULL          3143    // 2xAA usually gives 3.143V when full
                                      #define BATTERY_FULL          3100    // CR2032 usually gives 3.1V when full
                                      #define BATTERY_ZERO          2340    // 2.34V limit for 328p at 8MHz
                                      #define SLEEP_TIME            7200000 // Sleep time between reads (in milliseconds) (close to 2 hours)
                                      const int SENSOR_ANALOG_PINS[] = {A0, A1};
                                      //Variables
                                      byte direction = 0;
                                      int oldMoistureLevel = -1;
                                      //Construct MySensors library
                                      MyHwATMega328 hw;
                                      MyMessage msgMoisture(CHILD_ID_MOISTURE, V_HUM);
                                      MyMessage msgVolt(CHILD_ID_VOLTAGE, V_VOLTAGE);
                                      /* Initialization        */
                                        //Get time (for setup duration)
                                        #ifdef DEBUG
                                          unsigned long startTime = millis();
                                        //Setup LED pin
                                        pinMode(LED_PIN, OUTPUT);
                                        blinkLedFastly(3);
                                        //Set moisutre sensor pins
                                        for (int i = 0; i < N_ELEMENTS(SENSOR_ANALOG_PINS); i++)
                                          pinMode(SENSOR_ANALOG_PINS[i], OUTPUT);
                                          digitalWrite(SENSOR_ANALOG_PINS[i], LOW);
                                        //Start MySensors and send the sketch version information to the gateway
                                        node.begin();
                                        node.sendSketchInfo(SKETCH_NAME, SKETCH_VERSION);
                                        //Register all sensors
                                        node.present(CHILD_ID_MOISTURE, S_HUM);
                                        node.present(CHILD_ID_VOLTAGE, S_MULTIMETER);
                                        //Setup done !
                                        blinkLedFastly(3);
                                        //Print setup debug
                                        #ifdef DEBUG
                                          int duration = millis() - startTime;
                                          Serial.print("[Setup duration: "); Serial.print(duration, DEC); Serial.println(" ms]");
                                      /* Main loop        */
                                        //Get time (for a complete loop)
                                        #ifdef DEBUG
                                        //Get moisture level
                                        int moistureLevel = readMoisture();
                                        //Send rolling average of 2 samples to get rid of the "ripple" produced by different resistance in the internal pull-up resistors
                                        //See http://forum.mysensors.org/topic/2147/office-plant-monitoring/55 for more information
                                        //Check if it was first reading, save current value as old
                                        if (oldMoistureLevel == -1)
                                        //Verify if current measurement is not too far from the previous one
                                        if (moistureLevel > (oldMoistureLevel * THRESHOLD) || moistureLevel < (oldMoistureLevel / THRESHOLD))
                                          //The change was large, so it was probably not caused by the difference in internal pull-ups.
                                          //Measure again, this time with reversed polarity.
                                        //Store current moisture level
                                        //Report data to the gateway
                                        long voltage = getVoltage();
                                        node.send(msgVolt.set(voltage / 1000.0, 2));
                                        int batteryPcnt = round((voltage - BATTERY_ZERO) * 100.0 / (BATTERY_FULL - BATTERY_ZERO));
                                        if (batteryPcnt > 100) {batteryPcnt = 100;}
                                        node.sendBatteryLevel(batteryPcnt);
                                        //Print debug
                                        #ifdef DEBUG
                                          Serial.print((moistureLevel + oldMoistureLevel) / 2.0 / 10.23);
                                          Serial.print("%");
                                          Serial.print("   ");
                                          Serial.print(voltage / 1000.0);
                                          Serial.print("v");
                                          Serial.print("   ");
                                          Serial.print(batteryPcnt);
                                          Serial.print("%");
                                          Serial.print("   ");
                                          Serial.print("["); Serial.print(duration, DEC); Serial.println(" ms]");
                                          Serial.flush();
                                        //Sleep until next measurement
                                        blinkLedFastly(1);
                                        node.sleep(SLEEP_TIME);
                                      /* Allows to get moisture.                                                            */
                                      int readMoisture()
                                        //Power on the sensor and read once to let the ADC capacitor start charging
                                        pinMode(SENSOR_ANALOG_PINS[direction], INPUT_PULLUP);
                                        analogRead(SENSOR_ANALOG_PINS[direction]);
                                        //Stabilize and read the value
                                        int moistureLevel = (1023 - analogRead(SENSOR_ANALOG_PINS[direction]));
                                        //Turn off the sensor to conserve battery and minimize corrosion
                                        //Make direction alternate between 0 and 1 to reverse polarity which reduces corrosion
                                        direction = (direction + 1) % 2;
                                        return moistureLevel;
                                      /* Allows to fastly blink the LED.                                                    */
                                      void blinkLedFastly(byte loop)
                                        byte delayOn = 150;
                                        byte delayOff = 150;
                                        for (int i = 0; i < loop; i++)
                                          blinkLed(LED_PIN, delayOn);
                                          delay(delayOff);
                                      /* Allows to blink a LED.                                                             */
                                      void blinkLed(byte pinToBlink, int delayInMs)
                                        digitalWrite(pinToBlink,HIGH);
                                        delay(delayInMs);
                                        digitalWrite(pinToBlink,LOW);
                                      /* Allows to get the real Vcc (return value in mV).                                   */
                                      /* http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/   */
                                      long getVoltage()
                                        ADMUX = (0<<REFS1) | (1<<REFS0) | (0<<ADLAR) | (1<<MUX3) | (1<<MUX2) | (1<<MUX1) | (0<<MUX0);
                                        delay(50);  // Let mux settle a little to get a more stable A/D conversion
                                        //Start a conversion
                                        ADCSRA |= _BV( ADSC );
                                        //Wait for it to complete
                                        while (bit_is_set(ADCSRA, ADSC));
                                        //Compute and return the value
                                        uint8_t low  = ADCL;                  // must read ADCL first - it then locks ADCH
                                        uint8_t high = ADCH;                  // unlocks both
                                        result = 1125300L / result;           // Calculate Vcc (in mV); 1125300 = 1.1*1023*1000
                                        return result;                        // Vcc in millivolts
                                      I have just installed Arduino IDE, and are using the latest mysensors library 2.1.1.
                                      Another thing it complains about is:
                                      Invalid library found in C:\...\Arduino\libraries\Moisture_sensor: C:\...\Arduino\libraries\Moisture_sensor```
                                      which is wierd since I have just copy+pasted it from here:
                                      https://www.openhardware.io/view/123/Office-plant-monitor
                                      aswell as built the sensor from there.
                                      If you can help, I would be very glad, as I just hoped it would be smooth sailing using mysensors. Build, upload and let it work its magic.
                                      Tack på förhand!
                                      Simon
                                      • S simbic
                                        @mfalkvidd
                                        MyTransportRFM69.h
                                        MyTransport.h
                                        MySigning.h
                                        MyMessage.h
                                        ATSHA204.h
                                        RFM69.h
                                        sha256.h
                                        /*                            RST |             |  A5                                 */
                                        /*                            RX  |             |  A4                                 */
                                        /* +3v = 2*AA        */
                                        //Define functions
                                        #define LED_PIN               8
                                        //Variables
                                        byte direction = 0;
                                        MyHwATMega328 hw;
                                          #ifdef DEBUG
                                          //Setup LED pin
                                          blinkLedFastly(3);
                                          node.begin();
                                          //Setup done !
                                          blinkLedFastly(3);
                                          //Print setup debug
                                          #ifdef DEBUG
                                        /* Main loop        */
                                          #ifdef DEBUG
                                          //Print debug
                                          #ifdef DEBUG
                                            Serial.print("%");
                                            Serial.print("   ");
                                            Serial.print("v");
                                            Serial.print("   ");
                                            Serial.print("%");
                                            Serial.print("   ");
                                            Serial.flush();
                                          blinkLedFastly(1);
                                        int readMoisture()
                                          byte delayOn = 150;
                                            delay(delayOff);
                                          delay(delayInMs);
                                        long getVoltage()
                                        Tack på förhand!
                                        Simon
                                        @simbic that sketch is made for MySensors 1.x so it won't work with MySensors 2.x.
                                        You either need to convert it (guide: https://forum.mysensors.org/topic/4276/converting-a-sketch-from-1-5-x-to-2-0-x) or use/create one for 2.x, for example https://www.mysensors.org/build/moisture
                                        • Nca78N Nca78
                                          https://www.aliexpress.com/item/SHT10-SHT11-SHT15-waterproof-sensor-case-temperature-and-humidity-protective-cover-soil-sensor-cover-40mm-15mm/32575966509.html?spm=2114.8153822.cb0001.16.lITM8E&scm=1007.13409.76764.0&amp;pvid=0acc75b7-138d-456f-a5bf-5147c2ea763f&amp;tpp=1
                                          #33
                                          @Nca78
                                          I see now that they have expanded their selection of waterproof sensor shells:
                                          https://www.aliexpress.com/item/2pcs-Waterproof-Temperature-and-humidity-sensor-shell-SHT10-SHT21-SHT15-shT11-sht20-SHT75-sensor-protective-sleeve/32725766858.html?spm=2114.10010108.1000013.6.PVGRb3&traffic_analysisId=recommend_2088_3_81019_new2&scm=1007.13339.81019.0&pvid=b9edd7ff-9069-4c39-be95-b2d3ca8bdf17&tpp=1
                                          https://www.aliexpress.com/item/2pcs-YS1560J-Temperature-and-humidity-sensor-shell-Waterproof-temperature-sensor-protective-cover-SHT10-SHT15-SHT20/32725840346.html?spm=2114.10010108.1000013.25.PVGRb3&traffic_analysisId=recommend_2088_13_81019_new2&scm=1007.13339.81019.0&pvid=b9edd7ff-9069-4c39-be95-b2d3ca8bdf17&tpp=1
                                          https://www.aliexpress.com/item/TM16-115-temperature-and-humidity-sensor-protective-cover-waterproof-SHT10-SHT11-SHT20-SHT21-SHT15-SHT75-sensor/32578099865.html?spm=2114.10010108.1000013.10.gZI6yC&traffic_analysisId=recommend_2088_5_82199_new&scm=1007.13339.82199.0&pvid=3cc09c58-99e7-4a67-834a-3313c87ab573&tpp=1
                                          Perhaps one of those might be big enough? Or, if not, perhaps it could be joined onto a larger waterproof cavity, and just the sensor itself goes into it? Unfortunately for me, the parts appear to be metric. However, maybe a search would yield some kind of metric-to-imperial union, at which point I could then leverage cheap local parts from Home Depot or the like, to fabricate a larger cavity for the rest of a wireless mote.
                                          On the face of it, it seems plausible. It's main virtue is simplicity. Not sure what the failure modes are, or how they might be avoided if there are any. Plainly, you don't want to use components which might rust or otherwise corrode from humidity. Probably my biggest worry would be the possibility of condensate forming on the humidity sensor and skewing results until it evaporated. However, a sensor heater, such as some sensors (e.g. si7021: https://www.aliexpress.com/item/Industrial-High-Precision-Si7021-Humidity-Sensor-with-I2C-Interface-for-Arduino/32524005324.html?spm=a2g0s.13010208.99999999.350.t9NHvJ ) already have, might remedy that if it were to occur.
                                          Has anyone tried either one of the above or anything similar? For instance, perhaps wrapping a mote in Tyvek and sealing the seam with Dupont housewrap tape would work just as well.
