  3. Adding local sensor to NodeMCU gateway
12 Posts 5 Posters 6.4k Views 6 Watching
  • WodianW Offline
    WodianW Offline
    Wodian
    Is it possible to connect local sensors to the gateway itself? Because the gateway is an esp8266 I can place it anywhere I want to (if you have enough wifi signal).
    So the gateway could serve for 2 purposes instead of only a gateway.
    If its possible can someone help me to code this sensor into the gateway?
    Regards,
    Wodian
    • WodianW Wodian
      Regards,
      Wodian
      @Wodian yes
      Just add the sensor code for your sensors to the GatewayESP example.
      You can find more information here: https://forum.mysensors.org/topic/4066/ethernet-gateway-working-as-sensor-node-it-s-possible/2
      • WodianW Offline
        WodianW Offline
        Wodian
        wrote on last edited by TheoL
        Have been a while and trying to add code to my gateway without succes.
        Ive been trying to add a light sensor to my gateway but it isnt recognized by Mynodes controller. In the serial monitor I cannot see anything logging about a sensor.
        This is what Ive been using so far:
         * Version 1.0 - Henrik EKblad
         * Contribution by Ivo Pullens (ESP8266 support)
         * The EthernetGateway sends data received from sensors to the WiFi link.
         * VERA CONFIGURATION:
         * LED purposes:
         * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch, only the LEDs that is defined is used.
         * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
         * nRF24L01+  ESP8266
         * VCC        VCC
         * CE         GPIO4
         * CSN/CS     GPIO15
         * SCK        GPIO14
         * MISO       GPIO12
         * MOSI       GPIO13
         * GND        GND
          * Inclusion mode button:
        #define MY_BAUD_RATE 9600
        #define MY_GATEWAY_ESP8266
        #define MY_ESP8266_SSID "*************"
        #define MY_ESP8266_PASSWORD "*******"
        // Enable UDP communication
        //#define MY_USE_UDP
        // #define MY_ESP8266_HOSTNAME "sensor-gateway"
        #define MY_IP_GATEWAY_ADDRESS 192,168,178,1
        #define MY_PORT 5003
        #define MY_CONTROLLER_IP_ADDRESS 192,168,0,25
        // Enable inclusion mode
        // #define MY_INCLUSION_BUTTON_FEATURE
        // Set blinking period
        // #define MY_DEFAULT_LED_BLINK_PERIOD 300
        // Flash leds on rx/tx/err
        #define MY_DEFAULT_ERR_LED_PIN 2  // Error led pin
        #define MY_DEFAULT_RX_LED_PIN  2  // Receive led pin
        #define MY_DEFAULT_TX_LED_PIN  2  // the PCB, on board LED
        #if defined(MY_USE_UDP)
          #include <WiFiUDP.h>
          #include <ESP8266WiFi.h>
        #define CHILD_ID_LIGHT 0
        int lastLightLevel;
        void presentation()  {
          sendSketchInfo("Light Sensor", "1.0");
          int16_t lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
          Serial.println(lightLevel);
              send(msg.set(lightLevel));
              lastLightLevel = lightLevel;
          sleep(SLEEP_TIME);
        Have been working all night to get this thing up and running.
        Any thoughts?
        • WodianW Wodian
           * LED purposes:
           * nRF24L01+  ESP8266
           * VCC        VCC
           * CE         GPIO4
           * CSN/CS     GPIO15
           * SCK        GPIO14
           * MISO       GPIO12
           * MOSI       GPIO13
           * GND        GND
          int lastLightLevel;
            sleep(SLEEP_TIME);
          Any thoughts?
          T Offline
          T Offline
          TheoL
          @Wodian I've remove your SSID and password from the sketch. You probably didn't want everybody to have those.
          WodianW 1 Reply Last reply
          • T TheoL
            WodianW Offline
            WodianW Offline
            Wodian
            @TheoL
            Woops thanks
            • TmasterT Offline
              TmasterT Offline
              Tmaster
              wrote on last edited by Tmaster
              i'm having the same problem on seriagateway, even with dev. branch . my local sensor dont present on vera 3. Something it's not working as should on local gateway nodes. the not recent examples, just old examples before 2.0 released
              i'm a arduino fan .Even sometimes don't undestanding how to use it :P
              • TmasterT Tmaster
                WodianW Offline
                WodianW Offline
                Wodian
                @Tmaster Still havent found a solution for this. At the moment im busy with Home Assistant and using the esp8266 for mqtt communication so I dropped mysensors for now.
                • A Offline
                  A Offline
                  antonholmstedt
                  wrote on last edited by antonholmstedt
                  I've been searching for a solution and found one after trial and error. I think my biggest mistake was to use the printed pin numbers instead of the gpio numbers of the nodemcu when adding my temp sensor. My code looks like this, pin 5 is D1:
                   * LED purposes:
                   * nRF24L01+  ESP8266
                   * VCC        VCC
                   * CE         GPIO4
                   * CSN/CS     GPIO15
                   * SCK        GPIO14
                   * MISO       GPIO12
                   * MOSI       GPIO13
                   * GND        GND
                  #define MY_ESP8266_SSID "********"
                  #define MY_ESP8266_PASSWORD "*********"
                  #include <WiFiUdp.h>
                  #include <OneWire.h>
                  #define CHILD_ID_TEMP 1
                  #define ONE_WIRE_BUS 5 // Pin where dallase sensor is connected
                  int numSensors=0;
                  bool receivedConfig = false;
                  bool metric = true;
                  MyMessage msg(CHILD_ID_TEMP,V_TEMP);
                  void before()
                    sensors.begin();
                       present(i, S_TEMP);
                    sleep(conversionTime);
                      #if COMPARE_TEMP == 1
                    sleep(SLEEP_TIME);
                  I know the thread was old, but I thought a solution would be worth telling :)
                  Here is a sketch of the pins:
                  • TmasterT Offline
                    TmasterT Offline
                    Tmaster
                    o vera lite the problem is : if i add a new sensor and delete it , id stays there..somewere on vera. and next time device will not be find because it is already there. i have to increase node id number on arduino sketch (i don't know if auto id works).
                    Anyone know why Vera don't really delete devices and kept te ID somewere?
                    • TmasterT Tmaster
                      @Tmaster how would Vera know the device was deleted if the ID wasn't stored?
                      TmasterT 1 Reply Last reply
                        TmasterT Offline
                        TmasterT Offline
                        Tmaster
                        @mfalkvidd but then if i have 200 deleted devices .it ill kept everything? how to reset that?
                        • TmasterT Tmaster
                          @Tmaster I don't know. Maybe ask Vera support?
                          12.1k
