  3. Adding local sensor to NodeMCU gateway
12 Posts 5 Posters 6.8k Views 6 Watching
  • WodianW Wodian
    Is it possible to connect local sensors to the gateway itself? Because the gateway is an esp8266 I can place it anywhere I want to (if you have enough wifi signal).
    So the gateway could serve for 2 purposes instead of only a gateway.
    If its possible can someone help me to code this sensor into the gateway?
    Regards,
    Wodian
    @Wodian yes
    Just add the sensor code for your sensors to the GatewayESP example.
    You can find more information here: https://forum.mysensors.org/topic/4066/ethernet-gateway-working-as-sensor-node-it-s-possible/2
    • WodianW
      WodianW
      Wodian
      wrote on last edited by TheoL
      Have been a while and trying to add code to my gateway without succes.
      Ive been trying to add a light sensor to my gateway but it isnt recognized by Mynodes controller. In the serial monitor I cannot see anything logging about a sensor.
      This is what Ive been using so far:
       * Version 1.0 - Henrik EKblad
       * Contribution by Ivo Pullens (ESP8266 support)
       * The EthernetGateway sends data received from sensors to the WiFi link.
       * VERA CONFIGURATION:
       * LED purposes:
       * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch, only the LEDs that is defined is used.
       * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
       * nRF24L01+  ESP8266
       * VCC        VCC
       * CE         GPIO4
       * CSN/CS     GPIO15
       * SCK        GPIO14
       * MISO       GPIO12
       * MOSI       GPIO13
       * GND        GND
        * Inclusion mode button:
      #define MY_BAUD_RATE 9600
      #define MY_GATEWAY_ESP8266
      #define MY_ESP8266_SSID "*************"
      #define MY_ESP8266_PASSWORD "*******"
      // Enable UDP communication
      //#define MY_USE_UDP
      // #define MY_ESP8266_HOSTNAME "sensor-gateway"
      #define MY_IP_GATEWAY_ADDRESS 192,168,178,1
      #define MY_PORT 5003
      #define MY_CONTROLLER_IP_ADDRESS 192,168,0,25
      // Enable inclusion mode
      // #define MY_INCLUSION_BUTTON_FEATURE
      // Set blinking period
      // #define MY_DEFAULT_LED_BLINK_PERIOD 300
      // Flash leds on rx/tx/err
      #define MY_DEFAULT_ERR_LED_PIN 2  // Error led pin
      #define MY_DEFAULT_RX_LED_PIN  2  // Receive led pin
      #define MY_DEFAULT_TX_LED_PIN  2  // the PCB, on board LED
      #if defined(MY_USE_UDP)
        #include <WiFiUDP.h>
        #include <ESP8266WiFi.h>
      #define CHILD_ID_LIGHT 0
      int lastLightLevel;
      void presentation()  {
        sendSketchInfo("Light Sensor", "1.0");
        int16_t lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
        Serial.println(lightLevel);
            send(msg.set(lightLevel));
            lastLightLevel = lightLevel;
        sleep(SLEEP_TIME);
      Have been working all night to get this thing up and running.
      Any thoughts?
      TheoLT 1 Reply Last reply
      • WodianW Wodian
         * LED purposes:
         * nRF24L01+  ESP8266
         * VCC        VCC
         * CE         GPIO4
         * CSN/CS     GPIO15
         * SCK        GPIO14
         * MISO       GPIO12
         * MOSI       GPIO13
         * GND        GND
        int lastLightLevel;
          sleep(SLEEP_TIME);
        Any thoughts?
        TheoLT
        TheoLT
        TheoL
        @Wodian I've remove your SSID and password from the sketch. You probably didn't want everybody to have those.
        WodianW 1 Reply Last reply
        • TheoLT TheoL
          WodianW
          WodianW
          Wodian
          @TheoL
          Woops thanks
          • TmasterT
            TmasterT
            Tmaster
            wrote on last edited by Tmaster
            i'm having the same problem on seriagateway, even with dev. branch . my local sensor dont present on vera 3. Something it's not working as should on local gateway nodes. the not recent examples, just old examples before 2.0 released
            i'm a arduino fan .Even sometimes don't undestanding how to use it :P
            • TmasterT Tmaster
              WodianW
              WodianW
              Wodian
              @Tmaster Still havent found a solution for this. At the moment im busy with Home Assistant and using the esp8266 for mqtt communication so I dropped mysensors for now.
              • A
                antonholmstedt
                wrote on last edited by antonholmstedt
                I've been searching for a solution and found one after trial and error. I think my biggest mistake was to use the printed pin numbers instead of the gpio numbers of the nodemcu when adding my temp sensor. My code looks like this, pin 5 is D1:
                 * LED purposes:
                 * nRF24L01+  ESP8266
                 * VCC        VCC
                 * CE         GPIO4
                 * CSN/CS     GPIO15
                 * SCK        GPIO14
                 * MISO       GPIO12
                 * MOSI       GPIO13
                 * GND        GND
                #define MY_ESP8266_SSID "********"
                #define MY_ESP8266_PASSWORD "*********"
                #include <WiFiUdp.h>
                #include <OneWire.h>
                #define CHILD_ID_TEMP 1
                #define ONE_WIRE_BUS 5 // Pin where dallase sensor is connected
                int numSensors=0;
                bool receivedConfig = false;
                bool metric = true;
                MyMessage msg(CHILD_ID_TEMP,V_TEMP);
                void before()
                  sensors.begin();
                     present(i, S_TEMP);
                  sleep(conversionTime);
                    #if COMPARE_TEMP == 1
                  sleep(SLEEP_TIME);
                I know the thread was old, but I thought a solution would be worth telling :)
                Here is a sketch of the pins:
                • TmasterT
                  TmasterT
                  Tmaster
                  o vera lite the problem is : if i add a new sensor and delete it , id stays there..somewere on vera. and next time device will not be find because it is already there. i have to increase node id number on arduino sketch (i don't know if auto id works).
                  Anyone know why Vera don't really delete devices and kept te ID somewere?
                  • TmasterT Tmaster
                    @Tmaster how would Vera know the device was deleted if the ID wasn't stored?
                    TmasterT 1 Reply Last reply
                      TmasterT
                      TmasterT
                      Tmaster
                      @mfalkvidd but then if i have 200 deleted devices .it ill kept everything? how to reset that?
                      • TmasterT Tmaster
                        @Tmaster I don't know. Maybe ask Vera support?
