  3. VEML6070 and VEML6075 UV sensors
52 Posts 6 Posters 20.3k Views 5 Watching
  • alexsh1A Offline
    alexsh1A Offline
    alexsh1
    I am building a UV reporting node.
    I need to present the following:
    • μW per cm²
    • UV Index (0-11+)
    What's the best pay to present it to GW and controller (Domoticz)?
    • μW per cm² -> S_UV / V_UV
      -UV Index -> S_LIGHT_LEVEL/V_LIGHT_LEVEL???
    Alex
    • S Offline
      for the moment, if i'm not wrong, i'm using S_UV/V_UV for UV index. and temporarily S_POWER/V_WATT for uW/cm².
      Also note, depending on usecase, VEML6075 is better regarding its voltage range (i'm using both)
      alexsh1A 1 Reply Last reply
      • S scalz
        alexsh1A Offline
        alexsh1A Offline
        alexsh1
        @scalz So you are using a temp one as well for uW/cm2...
        VEML6075 is a more complex one. I think it can differentiate UV-a and UV-b or something. I ordered it a short while ago, but it would take some time before it arrives. Right now I have to think where to place it so that (1) the battery sensor is water tight if placed externally (2) direct UV exposure to the sensor (3) a transparent lid? Possible to 3d print? (4) externally or internally?
        • S Offline
          @alexsh1 for type of msg, yep..
          hehe i have some custom boards with this one :yum: I'm using it because of voltage range, one less part, and "new". UVA/UVB is a nice bonus then.
          For the enclosure, i'm still thinking the best options regarding environments i want to use them.
          If printing for outdoor, i would recommend PETG, ABS (more tricky), or better but more expensive ASA.
          • S scalz
            alexsh1A Offline
            alexsh1A Offline
            alexsh1
            @scalz The sensor has got a certain angle (55 degrees half sensitivity if I remember correctly) to provide the correct reading so the ideal place for it would be a roof? This would put an extra hurdle on enclosure design.
            I suppose it has to be outside. I can seal atmega328p with electronic leaving only the battery box and the sensor. However, as I said before designing the box is very tricky.
            • alexsh1A Offline
              alexsh1A Offline
              alexsh1
              http://www.vishay.com/docs/84310/designingveml6070.pdf
              Interesting info on the sensor
              • T Offline
                T Offline
                tbowmo
                Normal transparent glass can apparently block up to 75% of UV-B..
                So one should look into what to use as a window over the chip area..
                • T tbowmo
                  alexsh1A Offline
                  alexsh1A Offline
                  alexsh1
                  @tbowmo correct. This is why it has to be placed outside. And the sensor must be exposed as well. We need to build MySensors watertight IP67 enclosure now :-)
                  • T Offline
                    T Offline
                    tbowmo
                    @alexsh1
                    But you can not expose the sensor to rain etc. So you still need to have some cover above the chip, and this should be UV transparent..
                    • T tbowmo
                      @alexsh1
                      alexsh1A Offline
                      alexsh1A Offline
                      alexsh1
                      @tbowmo As I have just discovered there is a UV transparent plastic.
                      Maybe the enclosure can be 3D printed with such plastic?
                      There is also a UV transparent glass.
                      • alexsh1A Offline
                        alexsh1A Offline
                        alexsh1
                        The sensor has a peak
                        sensitivity at 355 nm.
                        UV Spectrum:
                        UV-a -> 315-400nm
                        UV-b -> 280-315nm
                        UV-c -> 100-280nm
                        UV-a goes through the glass and is a major one
                        UV-b account for only 3% of UV radiation
                        UV-c is absorbed by ozone layer
                        • S Offline
                          @alexsh1 so if i were you i would have bought a veml6075 when you ordered at some ic supplier! I'm joking.. or not ;)
                          • K Offline
                            K Offline
                            korttoma
                            Anyone care to share a sketch that includes the VEML6075?
                            • Tomas
                            • K korttoma
                              alexsh1A Offline
                              alexsh1A Offline
                              alexsh1
                              @korttoma I have not received VEML6075 yet so cannot help you
                              • S Offline
                                @korttoma what do you need exactly?? I can share some example, but there is nothing fancy for veml6075. On my side i'm using this lib for the moment https://github.com/schizobovine/VEML6075 , not digged much yet but it's working with MySensors of course. You simply need the same cooking in your sketch, as usual ;)
                                • K Offline
                                  K Offline
                                  korttoma
                                  Well, I'm looking to replace my Oregon Scientific UV Sensor UVN800 (that finally stopped reporting any values) by using a VEML6075 and a Sensebender Micro.
                                  I can probably work out the code for the sketch myself but I'm not a fan of reinventing the wheel so if someone already created a sketch it would simply save me the time.
                                  I would expect the sensor to report a UV Index value between 0 and 10 like the Oregon sensor did according to this -> https://www.epa.gov/sunsafety/uv-index-scale-1
                                  The example in the Lib you mentioned @scalz seems to have the UV Index posibility
                                  • Tomas
                                  • K korttoma
                                    alexsh1A Offline
                                    alexsh1A Offline
                                    alexsh1
                                    @korttoma this thread is about VEML6075 :-)
                                    However, VEML6075 is more complex - it does report uv-a and uv-b. I do not think you'd get UVI from this sensor straight away, you'd need to do it in the sketch.
                                    I can share the sketch after I get the sensor, write a code and convert it into MySensors
                                    • S Offline
                                      @korttoma oki, i agree with you about reinventing the wheel, but for big job. I think it's always better to know how to use the lib, so that's not a waste imho ;)
                                      No time for the moment to check my bigger sketch and extract everything.
                                      But in case you would like to try your new sensor, here a quick 5-10min conversion and mix of the lib example to mysensors uv. I wouldn't release it like this, not optimized, and untested version. But it's compiling, it should work :)
                                      //#define MY_NODE_ID 10
                                      #include <VEML6075.h>
                                      VEML6075 veml6075 = VEML6075();
                                      bool sensorFound = false;
                                      #define CHILD_ID_UVI 0
                                      #define CHILD_ID_UVA 0
                                      #define CHILD_ID_UVB 0
                                      uint32_t SLEEP_TIME = 30*1000; // Sleep time between reads (in milliseconds)
                                      MyMessage uviMsg(CHILD_ID_UVI, V_UV);
                                      MyMessage uvaMsg(CHILD_ID_UVA, V_UV);
                                      MyMessage uvbMsg(CHILD_ID_UVB, V_UV);
                                          sendSketchInfo("UV Sensor", "1.3");
                                          present(CHILD_ID_UVI, S_UV);
                                          present(CHILD_ID_UVA, S_UV);
                                          present(CHILD_ID_UVB, S_UV);
                                        if (!veml6075.begin()) {
                                          Serial.println(F("VEML6075 not found!"));
                                        } else
                                          sensorFound = true;
                                        if (sensorFound) {
                                          unsigned long lastSend =0;
                                          float uvi;
                                          float uva;
                                          float uvb;
                                          static float uviOld = -1;
                                          static float uvaOld = -1;
                                          static float uvbOld = -1;
                                          // Poll sensor
                                          veml6075.poll();
                                          uva = veml6075.getUVA();
                                          Serial.print(F("UVA = "));
                                          Serial.println(uva, 2);
                                          uvb = veml6075.getUVB();
                                          Serial.print(F("UVB = "));
                                          Serial.println(uvb, 2);
                                          uvi = veml6075.getUVIndex();
                                          Serial.print(F("UV Index = "));
                                          Serial.println(uvi, 1);
                                          uint16_t devid = veml6075.getDevID();
                                          Serial.print(F("Device ID = "));
                                          Serial.println(devid, HEX);
                                          Serial.println(F("----------------"));
                                          if (uvi != uviOld) {
                                              send(uviMsg.set(uvi,2));
                                              uviOld = uvi;
                                          if (uva != uvaOld) {
                                              send(uvaMsg.set(uva,2));
                                              uvaOld = uva;
                                          if (uvb != uvbOld) {
                                              send(uvbMsg.set(uvb,2));
                                              uvbOld = uvb;
                                        sleep(SLEEP_TIME);
                                      It simply read sensor, send messages, and sleep.
                                      As you can see, it's possible to get the three values from the lib.
                                      K 1 Reply Last reply
                                      • S scalz
                                          } else
                                            sensorFound = true;
                                          if (sensorFound) {
                                            float uvi;
                                            float uva;
                                            float uvb;
                                            // Poll sensor
                                            veml6075.poll();
                                                uviOld = uvi;
                                                uvaOld = uva;
                                                uvbOld = uvb;
                                          sleep(SLEEP_TIME);
                                        K Offline
                                        K Offline
                                        korttoma
                                        Thanks for the sketch @scalz , I made an attempt at it myself also. I was not avare that V_UV and S_UV could be used so I had V/S_LIGHT_LEVEL but I changed it now. Seems to compile just fine. Just need to get it tested.
                                        SensebenderMicroWithUVIndex:
                                         * Version 1.0 - Thomas Bowman Mørch
                                         * Version 1.3 - Thomas Bowman Mørch
                                         * Improved transmission logic, eliminating spurious transmissions (when temperatuere / humidity fluctuates 1 up and down between measurements)
                                         * Added OTA boot mode, need to hold A1 low while applying power. (uses slightly more power as it's waiting for bootloader messages)
                                         * Version 1.4 - Thomas Bowman Mørch
                                         * Corrected division in the code deciding whether to transmit or not, that resulted in generating an integer. Now it's generating floats as expected.
                                         * Simplified detection for OTA bootloader, now detecting if MY_OTA_FIRMWARE_FEATURE is defined. If this is defined sensebender automaticly waits 300mS after each transmission
                                         * Moved Battery status messages, so they are transmitted together with normal sensor updates (but only every 60th minute)
                                        // Define a static node address, remove if you want auto address assignment
                                        #define MY_NODE_ID 27
                                        // Enable to support OTA for this node (needs DualOptiBoot boot-loader to fully work)
                                        #include <SI7021.h>
                                        #ifndef MY_OTA_FIRMWARE_FEATURE
                                        #include "drivers/SPIFlash/SPIFlash.cpp"
                                        #include <EEPROM.h>
                                        #include <sha204_lib_return_codes.h>
                                        #include <sha204_library.h>
                                        #include <RunningAverage.h>
                                        //#include <avr/power.h>
                                        // Uncomment the line below, to transmit battery voltage as a normal sensor value
                                        //#define BATT_SENSOR    199
                                        #define RELEASE "1.4"
                                        #define AVERAGES 2
                                        // Child sensor ID's
                                        #define CHILD_ID_UVI    1
                                        #define CHILD_ID_TEMP   2
                                        #define CHILD_ID_HUM    3
                                        // How many milli seconds should we wait for OTA?
                                        #define OTA_WAIT_PERIOD 300
                                        #define FORCE_TRANSMIT_INTERVAL 30
                                        #define UVI_TRANSMIT_THRESHOLD 0.1
                                        // Pin definitions
                                        #define TEST_PIN       A0
                                        #define LED_PIN        A2
                                        #define ATSHA204_PIN   17 // A3
                                        const int sha204Pin = ATSHA204_PIN;
                                        SI7021 humiditySensor;
                                        SPIFlash flash(8, 0x1F65);
                                        // Sensor messages
                                        MyMessage msgUVI(CHILD_ID_UVI, V_UV);
                                        #ifdef BATT_SENSOR
                                        MyMessage msgBatt(BATT_SENSOR, V_VOLTAGE);
                                        // Global settings
                                        int measureCount = 0;
                                        int sendBattery = 0;
                                        boolean isMetric = true;
                                        boolean highfreq = true;
                                        boolean transmission_occured = false;
                                        float lastTemperature = -100;
                                        int lastHumidity = -100;
                                        long lastBattery = -100;
                                        int lastUVI = -100;
                                         * Setup code
                                          pinMode(LED_PIN, OUTPUT);
                                          digitalWrite(LED_PIN, LOW);
                                          //Serial.begin(115200);
                                          //Serial.print(F("Sensebender Micro FW "));
                                          //Serial.print(RELEASE);
                                          //Serial.flush();
                                          // First check if we should boot into test mode
                                          pinMode(TEST_PIN,INPUT);
                                          digitalWrite(TEST_PIN, HIGH); // Enable pullup
                                          if (!digitalRead(TEST_PIN)) testMode();
                                          // Make sure that ATSHA204 is not floating
                                          pinMode(ATSHA204_PIN, INPUT);
                                          digitalWrite(ATSHA204_PIN, HIGH);
                                          digitalWrite(TEST_PIN,LOW);
                                          digitalWrite(LED_PIN, HIGH);
                                          humiditySensor.begin();
                                          veml6075.begin();
                                          //Serial.flush();
                                          //Serial.println(F(" - Online!"));
                                          isMetric = getControllerConfig().isMetric;
                                          //Serial.print(F("isMetric: ")); Serial.println(isMetric);
                                          raHum.clear();
                                          sendTempHumidityMeasurements(false);
                                          sendBattLevel(false);
                                        #ifdef MY_OTA_FIRMWARE_FEATURE
                                          //Serial.println("OTA FW update enabled");
                                        void presentation()  {
                                          sendSketchInfo("Sensebender Micro", RELEASE);
                                          present(CHILD_ID_UVI,S_UV);
                                          present(CHILD_ID_TEMP,S_TEMP);
                                          present(CHILD_ID_HUM,S_HUM);
                                        #ifdef BATT_SENSOR
                                          present(BATT_SENSOR, S_POWER);
                                         *  Main loop function
                                          measureCount ++;
                                          sendBattery ++;
                                          bool forceTransmit = false;
                                            highfreq = false;
                                          if (measureCount > FORCE_TRANSMIT_INTERVAL) { // force a transmission
                                            forceTransmit = true;
                                            measureCount = 0;
                                        /*  if (sendBattery > 60)
                                             sendBattLevel(forceTransmit); // Not needed to send battery info that often
                                             sendBattery = 0;
                                          if (transmission_occured) {
                                              wait(OTA_WAIT_PERIOD);
                                          sleep(MEASURE_INTERVAL);
                                         * Sends temperature and humidity from Si7021 sensor
                                         * Parameters
                                        void sendTempHumidityMeasurements(bool force)
                                          bool tx = force;
                                          veml6075.poll();
                                            float UVA = veml6075.getUVA();
                                            //Serial.print(F("UVA = "));
                                            //Serial.println(UVA, 2);
                                            float UVB = veml6075.getUVB();
                                            //Serial.print(F("UVB = "));
                                            //Serial.println(UVB, 2);
                                            float UVI = veml6075.getUVIndex();
                                            //Serial.print(F("UV Index = "));
                                            //Serial.println(UVI, 1);
                                          raHum.addValue(data.humidityPercent);
                                          float diffTemp = abs(lastTemperature - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths)/100.0);
                                          float diffUVI = abs(lastUVI - UVI);
                                          //Serial.print(F("TempDiff :"));Serial.println(diffTemp);
                                          //Serial.print(F("HumDiff  :"));Serial.println(diffHum);
                                          //Serial.print(F("UVIDiff  :"));Serial.println(diffUVI);
                                          if (isnan(diffHum)) tx = true;
                                          if (diffTemp > TEMP_TRANSMIT_THRESHOLD) tx = true;
                                          if (diffHum > HUMI_TRANSMIT_THRESHOLD) tx = true;
                                          if (diffUVI > UVI_TRANSMIT_THRESHOLD) tx = true;
                                          if (tx) {
                                            measureCount = 0;
                                            float temperature = (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100.0;
                                            //Serial.print("T: ");Serial.println(temperature);
                                            //Serial.print("H: ");Serial.println(humidity);
                                            send(msgTemp.set(temperature,1));
                                            send(msgHum.set(humidity));
                                            send(msgUVI.set(UVI,2));
                                            lastHumidity = humidity;
                                            lastUVI = UVI;
                                            transmission_occured = true;
                                            if (sendBattery > 60) {
                                             sendBattLevel(true); // Not needed to send battery info that often
                                             sendBattery = 0;
                                         * Parameters
                                          if (force) lastBattery = -1;
                                          long vcc = readVcc();
                                          if (vcc != lastBattery) {
                                            lastBattery = vcc;
                                        #ifdef BATT_SENSOR
                                            float send_voltage = float(vcc)/1000.0f;
                                            send(msgBatt.set(send_voltage,3));
                                            // Calculate percentage
                                            long percent = vcc / 14.0;
                                            sendBatteryLevel(percent);
                                        long readVcc() {
                                         * Verify all peripherals, and signal via the LED if any problems.
                                        void testMode()
                                          uint8_t ret_code;
                                          byte tests = 0;
                                          digitalWrite(LED_PIN, HIGH); // Turn on LED.
                                          //Serial.println(F(" - TestMode"));
                                          //Serial.println(F("Testing peripherals!"));
                                          //Serial.flush();
                                          //Serial.print(F("-> SI7021 : "));
                                          //Serial.flush();
                                          if (humiditySensor.begin())
                                            //Serial.println(F("ok!"));
                                            tests ++;
                                            //Serial.println(F("failed!"));
                                          //Serial.flush();
                                          //Serial.print(F("-> Flash : "));
                                          //Serial.flush();
                                          if (flash.initialize())
                                            tests ++;
                                          //Serial.flush();
                                          //Serial.print(F("-> SHA204 : "));
                                          //Serial.flush();
                                          if (ret_code != SHA204_SUCCESS)
                                            //Serial.print(F("Failed to wake device. Response: ")); Serial.println(ret_code, HEX);
                                          //Serial.flush();
                                          if (ret_code == SHA204_SUCCESS)
                                            ret_code = sha204.getSerialNumber(rx_buffer);
                                              //Serial.print(F("Failed to obtain device serial number. Response: ")); Serial.println(ret_code, HEX);
                                              //Serial.print(F("Ok (serial : "));
                                              for (int i=0; i<9; i++)
                                                if (rx_buffer[i] < 0x10)
                                                  //Serial.print('0'); // Because Serial.print does not 0-pad HEX
                                                //Serial.print(rx_buffer[i], HEX);
                                              //Serial.println(")");
                                              tests ++;
                                          //Serial.flush();
                                          //Serial.println(F("Test finished"));
                                          if (tests == 3)
                                            //Serial.println(F("Selftest ok!"));
                                            while (1) // Blink OK pattern!
                                              delay(200);
                                              delay(200);
                                            //Serial.println(F("----> Selftest failed!"));
                                            while (1) // Blink FAILED pattern! Rappidly blinking..
                                        • Tomas
                                        • K korttoma
                                          #include <SI7021.h>
                                          #include <EEPROM.h>
                                          #define AVERAGES 2
                                          // Pin definitions
                                          #define TEST_PIN       A0
                                          #define LED_PIN        A2
                                          // Sensor messages
                                          #ifdef BATT_SENSOR
                                          // Global settings
                                          int lastUVI = -100;
                                           * Setup code
                                            //Serial.flush();
                                            veml6075.begin();
                                            //Serial.flush();
                                            raHum.clear();
                                          #ifdef BATT_SENSOR
                                            measureCount ++;
                                            sendBattery ++;
                                              highfreq = false;
                                              measureCount = 0;
                                               sendBattery = 0;
                                           * Parameters
                                            bool tx = force;
                                            veml6075.poll();
                                            if (tx) {
                                              measureCount = 0;
                                              lastUVI = UVI;
                                               sendBattery = 0;
                                           * Parameters
                                              lastBattery = vcc;
                                          #ifdef BATT_SENSOR
                                          long readVcc() {
                                          void testMode()
                                            uint8_t ret_code;
                                            byte tests = 0;
                                            //Serial.flush();
                                            //Serial.flush();
                                              tests ++;
                                            //Serial.flush();
                                            //Serial.flush();
                                              tests ++;
                                            //Serial.flush();
                                            //Serial.flush();
                                            //Serial.flush();
                                                tests ++;
                                            //Serial.flush();
                                            if (tests == 3)
                                                delay(200);
                                                delay(200);
                                          alexsh1A Offline
                                          alexsh1A Offline
                                          alexsh1
                                          This is the VEML6070 UV Index graph. The last day, I placed the sensor outside rather than behind my window. There is a huge difference :
