  3. VEML6070 and VEML6075 UV sensors
52 Posts 6 Posters 20.6k Views 5 Watching
  • scalzS scalz
    @alexsh1 for type of msg, yep..
    hehe i have some custom boards with this one :yum: I'm using it because of voltage range, one less part, and "new". UVA/UVB is a nice bonus then.
    For the enclosure, i'm still thinking the best options regarding environments i want to use them.
    If printing for outdoor, i would recommend PETG, ABS (more tricky), or better but more expensive ASA.
    alexsh1A
    alexsh1A
    alexsh1
    @scalz The sensor has got a certain angle (55 degrees half sensitivity if I remember correctly) to provide the correct reading so the ideal place for it would be a roof? This would put an extra hurdle on enclosure design.
    I suppose it has to be outside. I can seal atmega328p with electronic leaving only the battery box and the sensor. However, as I said before designing the box is very tricky.
    • alexsh1A
      alexsh1A
      alexsh1
      http://www.vishay.com/docs/84310/designingveml6070.pdf
      Interesting info on the sensor
      • tbowmoT
        tbowmoT
        tbowmo
        Normal transparent glass can apparently block up to 75% of UV-B..
        So one should look into what to use as a window over the chip area..
        alexsh1A 1 Reply Last reply
        • tbowmoT tbowmo
          alexsh1A
          alexsh1A
          alexsh1
          @tbowmo correct. This is why it has to be placed outside. And the sensor must be exposed as well. We need to build MySensors watertight IP67 enclosure now :-)
          • tbowmoT
            tbowmoT
            tbowmo
            @alexsh1
            But you can not expose the sensor to rain etc. So you still need to have some cover above the chip, and this should be UV transparent..
            • tbowmoT tbowmo
              @alexsh1
              alexsh1A
              alexsh1A
              alexsh1
              @tbowmo As I have just discovered there is a UV transparent plastic.
              Maybe the enclosure can be 3D printed with such plastic?
              There is also a UV transparent glass.
              • alexsh1A
                alexsh1A
                alexsh1
                The sensor has a peak
                sensitivity at 355 nm.
                UV Spectrum:
                UV-a -> 315-400nm
                UV-b -> 280-315nm
                UV-c -> 100-280nm
                UV-a goes through the glass and is a major one
                UV-b account for only 3% of UV radiation
                UV-c is absorbed by ozone layer
                  @alexsh1 so if i were you i would have bought a veml6075 when you ordered at some ic supplier! I'm joking.. or not ;)
                  • korttomaK
                    korttomaK
                    korttoma
                    Anyone care to share a sketch that includes the VEML6075?
                    • Tomas
                    • korttomaK korttoma
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @korttoma I have not received VEML6075 yet so cannot help you
                        @korttoma what do you need exactly?? I can share some example, but there is nothing fancy for veml6075. On my side i'm using this lib for the moment https://github.com/schizobovine/VEML6075 , not digged much yet but it's working with MySensors of course. You simply need the same cooking in your sketch, as usual ;)
                        • korttomaK
                          korttomaK
                          korttoma
                          Well, I'm looking to replace my Oregon Scientific UV Sensor UVN800 (that finally stopped reporting any values) by using a VEML6075 and a Sensebender Micro.
                          I can probably work out the code for the sketch myself but I'm not a fan of reinventing the wheel so if someone already created a sketch it would simply save me the time.
                          I would expect the sensor to report a UV Index value between 0 and 10 like the Oregon sensor did according to this -> https://www.epa.gov/sunsafety/uv-index-scale-1
                          The example in the Lib you mentioned @scalz seems to have the UV Index posibility
                          • Tomas
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @korttoma this thread is about VEML6075 :-)
                            However, VEML6075 is more complex - it does report uv-a and uv-b. I do not think you'd get UVI from this sensor straight away, you'd need to do it in the sketch.
                            I can share the sketch after I get the sensor, write a code and convert it into MySensors
                              @korttoma oki, i agree with you about reinventing the wheel, but for big job. I think it's always better to know how to use the lib, so that's not a waste imho ;)
                              No time for the moment to check my bigger sketch and extract everything.
                              But in case you would like to try your new sensor, here a quick 5-10min conversion and mix of the lib example to mysensors uv. I wouldn't release it like this, not optimized, and untested version. But it's compiling, it should work :)
                              //#define MY_NODE_ID 10
                              #include <VEML6075.h>
                              VEML6075 veml6075 = VEML6075();
                              bool sensorFound = false;
                              #define CHILD_ID_UVI 0
                              #define CHILD_ID_UVA 0
                              #define CHILD_ID_UVB 0
                              uint32_t SLEEP_TIME = 30*1000; // Sleep time between reads (in milliseconds)
                              MyMessage uviMsg(CHILD_ID_UVI, V_UV);
                              MyMessage uvaMsg(CHILD_ID_UVA, V_UV);
                              MyMessage uvbMsg(CHILD_ID_UVB, V_UV);
                                  sendSketchInfo("UV Sensor", "1.3");
                                  present(CHILD_ID_UVI, S_UV);
                                  present(CHILD_ID_UVA, S_UV);
                                  present(CHILD_ID_UVB, S_UV);
                                if (!veml6075.begin()) {
                                  Serial.println(F("VEML6075 not found!"));
                                } else
                                  sensorFound = true;
                                if (sensorFound) {
                                  unsigned long lastSend =0;
                                  float uvi;
                                  float uva;
                                  float uvb;
                                  static float uviOld = -1;
                                  static float uvaOld = -1;
                                  static float uvbOld = -1;
                                  // Poll sensor
                                  veml6075.poll();
                                  uva = veml6075.getUVA();
                                  Serial.print(F("UVA = "));
                                  Serial.println(uva, 2);
                                  uvb = veml6075.getUVB();
                                  Serial.print(F("UVB = "));
                                  Serial.println(uvb, 2);
                                  uvi = veml6075.getUVIndex();
                                  Serial.print(F("UV Index = "));
                                  Serial.println(uvi, 1);
                                  uint16_t devid = veml6075.getDevID();
                                  Serial.print(F("Device ID = "));
                                  Serial.println(devid, HEX);
                                  Serial.println(F("----------------"));
                                  if (uvi != uviOld) {
                                      send(uviMsg.set(uvi,2));
                                      uviOld = uvi;
                                  if (uva != uvaOld) {
                                      send(uvaMsg.set(uva,2));
                                      uvaOld = uva;
                                  if (uvb != uvbOld) {
                                      send(uvbMsg.set(uvb,2));
                                      uvbOld = uvb;
                                sleep(SLEEP_TIME);
                              It simply read sensor, send messages, and sleep.
                              As you can see, it's possible to get the three values from the lib.
                              korttomaK 1 Reply Last reply
                              • scalzS scalz
                                  } else
                                    sensorFound = true;
                                  if (sensorFound) {
                                    float uvi;
                                    float uva;
                                    float uvb;
                                    // Poll sensor
                                    veml6075.poll();
                                        uviOld = uvi;
                                        uvaOld = uva;
                                        uvbOld = uvb;
                                  sleep(SLEEP_TIME);
                                korttomaK
                                korttomaK
                                korttoma
                                Thanks for the sketch @scalz , I made an attempt at it myself also. I was not avare that V_UV and S_UV could be used so I had V/S_LIGHT_LEVEL but I changed it now. Seems to compile just fine. Just need to get it tested.
                                SensebenderMicroWithUVIndex:
                                 * Version 1.0 - Thomas Bowman Mørch
                                 * Version 1.3 - Thomas Bowman Mørch
                                 * Improved transmission logic, eliminating spurious transmissions (when temperatuere / humidity fluctuates 1 up and down between measurements)
                                 * Added OTA boot mode, need to hold A1 low while applying power. (uses slightly more power as it's waiting for bootloader messages)
                                 * Version 1.4 - Thomas Bowman Mørch
                                 * Corrected division in the code deciding whether to transmit or not, that resulted in generating an integer. Now it's generating floats as expected.
                                 * Simplified detection for OTA bootloader, now detecting if MY_OTA_FIRMWARE_FEATURE is defined. If this is defined sensebender automaticly waits 300mS after each transmission
                                 * Moved Battery status messages, so they are transmitted together with normal sensor updates (but only every 60th minute)
                                // Define a static node address, remove if you want auto address assignment
                                #define MY_NODE_ID 27
                                // Enable to support OTA for this node (needs DualOptiBoot boot-loader to fully work)
                                #include <SI7021.h>
                                #ifndef MY_OTA_FIRMWARE_FEATURE
                                #include "drivers/SPIFlash/SPIFlash.cpp"
                                #include <EEPROM.h>
                                #include <sha204_lib_return_codes.h>
                                #include <sha204_library.h>
                                #include <RunningAverage.h>
                                //#include <avr/power.h>
                                // Uncomment the line below, to transmit battery voltage as a normal sensor value
                                //#define BATT_SENSOR    199
                                #define RELEASE "1.4"
                                #define AVERAGES 2
                                // Child sensor ID's
                                #define CHILD_ID_UVI    1
                                #define CHILD_ID_TEMP   2
                                #define CHILD_ID_HUM    3
                                // How many milli seconds should we wait for OTA?
                                #define OTA_WAIT_PERIOD 300
                                #define FORCE_TRANSMIT_INTERVAL 30
                                #define UVI_TRANSMIT_THRESHOLD 0.1
                                // Pin definitions
                                #define TEST_PIN       A0
                                #define LED_PIN        A2
                                #define ATSHA204_PIN   17 // A3
                                const int sha204Pin = ATSHA204_PIN;
                                SI7021 humiditySensor;
                                SPIFlash flash(8, 0x1F65);
                                // Sensor messages
                                MyMessage msgUVI(CHILD_ID_UVI, V_UV);
                                #ifdef BATT_SENSOR
                                MyMessage msgBatt(BATT_SENSOR, V_VOLTAGE);
                                // Global settings
                                int measureCount = 0;
                                int sendBattery = 0;
                                boolean isMetric = true;
                                boolean highfreq = true;
                                boolean transmission_occured = false;
                                float lastTemperature = -100;
                                int lastHumidity = -100;
                                long lastBattery = -100;
                                int lastUVI = -100;
                                 * Setup code
                                  pinMode(LED_PIN, OUTPUT);
                                  digitalWrite(LED_PIN, LOW);
                                  //Serial.begin(115200);
                                  //Serial.print(F("Sensebender Micro FW "));
                                  //Serial.print(RELEASE);
                                  //Serial.flush();
                                  // First check if we should boot into test mode
                                  pinMode(TEST_PIN,INPUT);
                                  digitalWrite(TEST_PIN, HIGH); // Enable pullup
                                  if (!digitalRead(TEST_PIN)) testMode();
                                  // Make sure that ATSHA204 is not floating
                                  pinMode(ATSHA204_PIN, INPUT);
                                  digitalWrite(ATSHA204_PIN, HIGH);
                                  digitalWrite(TEST_PIN,LOW);
                                  digitalWrite(LED_PIN, HIGH);
                                  humiditySensor.begin();
                                  veml6075.begin();
                                  //Serial.flush();
                                  //Serial.println(F(" - Online!"));
                                  isMetric = getControllerConfig().isMetric;
                                  //Serial.print(F("isMetric: ")); Serial.println(isMetric);
                                  raHum.clear();
                                  sendTempHumidityMeasurements(false);
                                  sendBattLevel(false);
                                #ifdef MY_OTA_FIRMWARE_FEATURE
                                  //Serial.println("OTA FW update enabled");
                                void presentation()  {
                                  sendSketchInfo("Sensebender Micro", RELEASE);
                                  present(CHILD_ID_UVI,S_UV);
                                  present(CHILD_ID_TEMP,S_TEMP);
                                  present(CHILD_ID_HUM,S_HUM);
                                #ifdef BATT_SENSOR
                                  present(BATT_SENSOR, S_POWER);
                                 *  Main loop function
                                  measureCount ++;
                                  sendBattery ++;
                                  bool forceTransmit = false;
                                    highfreq = false;
                                  if (measureCount > FORCE_TRANSMIT_INTERVAL) { // force a transmission
                                    forceTransmit = true;
                                    measureCount = 0;
                                /*  if (sendBattery > 60)
                                     sendBattLevel(forceTransmit); // Not needed to send battery info that often
                                     sendBattery = 0;
                                  if (transmission_occured) {
                                      wait(OTA_WAIT_PERIOD);
                                  sleep(MEASURE_INTERVAL);
                                 * Sends temperature and humidity from Si7021 sensor
                                 * Parameters
                                void sendTempHumidityMeasurements(bool force)
                                  bool tx = force;
                                  veml6075.poll();
                                    float UVA = veml6075.getUVA();
                                    //Serial.print(F("UVA = "));
                                    //Serial.println(UVA, 2);
                                    float UVB = veml6075.getUVB();
                                    //Serial.print(F("UVB = "));
                                    //Serial.println(UVB, 2);
                                    float UVI = veml6075.getUVIndex();
                                    //Serial.print(F("UV Index = "));
                                    //Serial.println(UVI, 1);
                                  raHum.addValue(data.humidityPercent);
                                  float diffTemp = abs(lastTemperature - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths)/100.0);
                                  float diffUVI = abs(lastUVI - UVI);
                                  //Serial.print(F("TempDiff :"));Serial.println(diffTemp);
                                  //Serial.print(F("HumDiff  :"));Serial.println(diffHum);
                                  //Serial.print(F("UVIDiff  :"));Serial.println(diffUVI);
                                  if (isnan(diffHum)) tx = true;
                                  if (diffTemp > TEMP_TRANSMIT_THRESHOLD) tx = true;
                                  if (diffHum > HUMI_TRANSMIT_THRESHOLD) tx = true;
                                  if (diffUVI > UVI_TRANSMIT_THRESHOLD) tx = true;
                                  if (tx) {
                                    measureCount = 0;
                                    float temperature = (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100.0;
                                    //Serial.print("T: ");Serial.println(temperature);
                                    //Serial.print("H: ");Serial.println(humidity);
                                    send(msgTemp.set(temperature,1));
                                    send(msgHum.set(humidity));
                                    send(msgUVI.set(UVI,2));
                                    lastHumidity = humidity;
                                    lastUVI = UVI;
                                    transmission_occured = true;
                                    if (sendBattery > 60) {
                                     sendBattLevel(true); // Not needed to send battery info that often
                                     sendBattery = 0;
                                 * Parameters
                                  if (force) lastBattery = -1;
                                  long vcc = readVcc();
                                  if (vcc != lastBattery) {
                                    lastBattery = vcc;
                                #ifdef BATT_SENSOR
                                    float send_voltage = float(vcc)/1000.0f;
                                    send(msgBatt.set(send_voltage,3));
                                    // Calculate percentage
                                    long percent = vcc / 14.0;
                                    sendBatteryLevel(percent);
                                long readVcc() {
                                 * Verify all peripherals, and signal via the LED if any problems.
                                void testMode()
                                  uint8_t ret_code;
                                  byte tests = 0;
                                  digitalWrite(LED_PIN, HIGH); // Turn on LED.
                                  //Serial.println(F(" - TestMode"));
                                  //Serial.println(F("Testing peripherals!"));
                                  //Serial.flush();
                                  //Serial.print(F("-> SI7021 : "));
                                  //Serial.flush();
                                  if (humiditySensor.begin())
                                    //Serial.println(F("ok!"));
                                    tests ++;
                                    //Serial.println(F("failed!"));
                                  //Serial.flush();
                                  //Serial.print(F("-> Flash : "));
                                  //Serial.flush();
                                  if (flash.initialize())
                                    tests ++;
                                  //Serial.flush();
                                  //Serial.print(F("-> SHA204 : "));
                                  //Serial.flush();
                                  if (ret_code != SHA204_SUCCESS)
                                    //Serial.print(F("Failed to wake device. Response: ")); Serial.println(ret_code, HEX);
                                  //Serial.flush();
                                  if (ret_code == SHA204_SUCCESS)
                                    ret_code = sha204.getSerialNumber(rx_buffer);
                                      //Serial.print(F("Failed to obtain device serial number. Response: ")); Serial.println(ret_code, HEX);
                                      //Serial.print(F("Ok (serial : "));
                                      for (int i=0; i<9; i++)
                                        if (rx_buffer[i] < 0x10)
                                          //Serial.print('0'); // Because Serial.print does not 0-pad HEX
                                        //Serial.print(rx_buffer[i], HEX);
                                      //Serial.println(")");
                                      tests ++;
                                  //Serial.flush();
                                  //Serial.println(F("Test finished"));
                                  if (tests == 3)
                                    //Serial.println(F("Selftest ok!"));
                                    while (1) // Blink OK pattern!
                                      delay(200);
                                      delay(200);
                                    //Serial.println(F("----> Selftest failed!"));
                                    while (1) // Blink FAILED pattern! Rappidly blinking..
                                • Tomas
                                  #include <SI7021.h>
                                  #include <EEPROM.h>
                                  #define AVERAGES 2
                                  // Pin definitions
                                  #define TEST_PIN       A0
                                  #define LED_PIN        A2
                                  // Sensor messages
                                  #ifdef BATT_SENSOR
                                  // Global settings
                                  int lastUVI = -100;
                                   * Setup code
                                    //Serial.flush();
                                    veml6075.begin();
                                    //Serial.flush();
                                    raHum.clear();
                                  #ifdef BATT_SENSOR
                                    measureCount ++;
                                    sendBattery ++;
                                      highfreq = false;
                                      measureCount = 0;
                                       sendBattery = 0;
                                   * Parameters
                                    bool tx = force;
                                    veml6075.poll();
                                    if (tx) {
                                      measureCount = 0;
                                      lastUVI = UVI;
                                       sendBattery = 0;
                                   * Parameters
                                      lastBattery = vcc;
                                  #ifdef BATT_SENSOR
                                  long readVcc() {
                                  void testMode()
                                    uint8_t ret_code;
                                    byte tests = 0;
                                    //Serial.flush();
                                    //Serial.flush();
                                      tests ++;
                                    //Serial.flush();
                                    //Serial.flush();
                                      tests ++;
                                    //Serial.flush();
                                    //Serial.flush();
                                    //Serial.flush();
                                        tests ++;
                                    //Serial.flush();
                                    if (tests == 3)
                                        delay(200);
                                        delay(200);
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  This is the VEML6070 UV Index graph. The last day, I placed the sensor outside rather than behind my window. There is a huge difference :
                                  • alexsh1A
                                    alexsh1A
                                    alexsh1
                                    #21
                                    I finally received VEML6075 and comparing it with VEML6070 side y side
                                    _____UVI__UVA__UVB
                                    6070 0.9
                                    6075 1.2 1036.53 1005.31
                                    Not sure why there is a difference in UVI
                                    • korttomaK
                                      korttomaK
                                      korttoma
                                      Did anyone measure the current consumption of these VEML chips?
                                      I just compared a Sensebender Micro with the VEML6075 to a standalone Sensebender Micro and the standalone one measured 28uA and the one with the VEML6075 measured 740uA.
                                      I just checked the VEML6075 documentation and typical consumption is 480uA but it should also be possible to shut it down and then it should only draw 800nA.
                                      I need to check the Lib if there is some function to shut it down and wake it up. Or else I will try to change the setup so I can power the VEML6075 from an output pin so I can turn it completely off.
                                      • Tomas
                                      scalzS 1 Reply Last reply
                                        @korttoma
                                        if i remember, sleep is not implemented in the veml6075 lib above. I added a sleep function and set the corresponding CONF register. not a big thing ;)
                                        • scalzS scalz
                                          @korttoma
                                          korttomaK
                                          korttomaK
                                          korttoma
                                          #24
                                          @scalz please share your sleep function implementation :D it is quite a "big thing" for a non programmer.
                                          • Tomas
