  3. VEML6070 and VEML6075 UV sensors
52 Posts 6 Posters 20.8k Views 5 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    Normal transparent glass can apparently block up to 75% of UV-B..
    So one should look into what to use as a window over the chip area..
    alexsh1A 1 Reply Last reply
    • tbowmoT tbowmo
      alexsh1A
      alexsh1A
      alexsh1
      @tbowmo correct. This is why it has to be placed outside. And the sensor must be exposed as well. We need to build MySensors watertight IP67 enclosure now :-)
      • tbowmoT
        tbowmoT
        tbowmo
        @alexsh1
        But you can not expose the sensor to rain etc. So you still need to have some cover above the chip, and this should be UV transparent..
        • tbowmoT tbowmo
          @alexsh1
          alexsh1A
          alexsh1A
          alexsh1
          @tbowmo As I have just discovered there is a UV transparent plastic.
          Maybe the enclosure can be 3D printed with such plastic?
          There is also a UV transparent glass.
          • alexsh1A
            alexsh1A
            alexsh1
            The sensor has a peak
            sensitivity at 355 nm.
            UV Spectrum:
            UV-a -> 315-400nm
            UV-b -> 280-315nm
            UV-c -> 100-280nm
            UV-a goes through the glass and is a major one
            UV-b account for only 3% of UV radiation
            UV-c is absorbed by ozone layer
              @alexsh1 so if i were you i would have bought a veml6075 when you ordered at some ic supplier! I'm joking.. or not ;)
              • korttomaK
                korttomaK
                korttoma
                Anyone care to share a sketch that includes the VEML6075?
                • Tomas
                • korttomaK korttoma
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @korttoma I have not received VEML6075 yet so cannot help you
                    @korttoma what do you need exactly?? I can share some example, but there is nothing fancy for veml6075. On my side i'm using this lib for the moment https://github.com/schizobovine/VEML6075 , not digged much yet but it's working with MySensors of course. You simply need the same cooking in your sketch, as usual ;)
                    • korttomaK
                      korttomaK
                      korttoma
                      Well, I'm looking to replace my Oregon Scientific UV Sensor UVN800 (that finally stopped reporting any values) by using a VEML6075 and a Sensebender Micro.
                      I can probably work out the code for the sketch myself but I'm not a fan of reinventing the wheel so if someone already created a sketch it would simply save me the time.
                      I would expect the sensor to report a UV Index value between 0 and 10 like the Oregon sensor did according to this -> https://www.epa.gov/sunsafety/uv-index-scale-1
                      The example in the Lib you mentioned @scalz seems to have the UV Index posibility
                      • Tomas
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @korttoma this thread is about VEML6075 :-)
                        However, VEML6075 is more complex - it does report uv-a and uv-b. I do not think you'd get UVI from this sensor straight away, you'd need to do it in the sketch.
                        I can share the sketch after I get the sensor, write a code and convert it into MySensors
                          @korttoma oki, i agree with you about reinventing the wheel, but for big job. I think it's always better to know how to use the lib, so that's not a waste imho ;)
                          No time for the moment to check my bigger sketch and extract everything.
                          But in case you would like to try your new sensor, here a quick 5-10min conversion and mix of the lib example to mysensors uv. I wouldn't release it like this, not optimized, and untested version. But it's compiling, it should work :)
                          //#define MY_NODE_ID 10
                          #include <VEML6075.h>
                          VEML6075 veml6075 = VEML6075();
                          bool sensorFound = false;
                          #define CHILD_ID_UVI 0
                          #define CHILD_ID_UVA 0
                          #define CHILD_ID_UVB 0
                          uint32_t SLEEP_TIME = 30*1000; // Sleep time between reads (in milliseconds)
                          MyMessage uviMsg(CHILD_ID_UVI, V_UV);
                          MyMessage uvaMsg(CHILD_ID_UVA, V_UV);
                          MyMessage uvbMsg(CHILD_ID_UVB, V_UV);
                              sendSketchInfo("UV Sensor", "1.3");
                              present(CHILD_ID_UVI, S_UV);
                              present(CHILD_ID_UVA, S_UV);
                              present(CHILD_ID_UVB, S_UV);
                            if (!veml6075.begin()) {
                              Serial.println(F("VEML6075 not found!"));
                            } else
                              sensorFound = true;
                            if (sensorFound) {
                              unsigned long lastSend =0;
                              float uvi;
                              float uva;
                              float uvb;
                              static float uviOld = -1;
                              static float uvaOld = -1;
                              static float uvbOld = -1;
                              // Poll sensor
                              veml6075.poll();
                              uva = veml6075.getUVA();
                              Serial.print(F("UVA = "));
                              Serial.println(uva, 2);
                              uvb = veml6075.getUVB();
                              Serial.print(F("UVB = "));
                              Serial.println(uvb, 2);
                              uvi = veml6075.getUVIndex();
                              Serial.print(F("UV Index = "));
                              Serial.println(uvi, 1);
                              uint16_t devid = veml6075.getDevID();
                              Serial.print(F("Device ID = "));
                              Serial.println(devid, HEX);
                              Serial.println(F("----------------"));
                              if (uvi != uviOld) {
                                  send(uviMsg.set(uvi,2));
                                  uviOld = uvi;
                              if (uva != uvaOld) {
                                  send(uvaMsg.set(uva,2));
                                  uvaOld = uva;
                              if (uvb != uvbOld) {
                                  send(uvbMsg.set(uvb,2));
                                  uvbOld = uvb;
                            sleep(SLEEP_TIME);
                          It simply read sensor, send messages, and sleep.
                          As you can see, it's possible to get the three values from the lib.
                          korttomaK 1 Reply Last reply
                          • scalzS scalz
                              } else
                                sensorFound = true;
                              if (sensorFound) {
                                float uvi;
                                float uva;
                                float uvb;
                                // Poll sensor
                                veml6075.poll();
                                    uviOld = uvi;
                                    uvaOld = uva;
                                    uvbOld = uvb;
                              sleep(SLEEP_TIME);
                            korttomaK
                            korttomaK
                            korttoma
                            Thanks for the sketch @scalz , I made an attempt at it myself also. I was not avare that V_UV and S_UV could be used so I had V/S_LIGHT_LEVEL but I changed it now. Seems to compile just fine. Just need to get it tested.
                            SensebenderMicroWithUVIndex:
                             * Version 1.0 - Thomas Bowman Mørch
                             * Version 1.3 - Thomas Bowman Mørch
                             * Improved transmission logic, eliminating spurious transmissions (when temperatuere / humidity fluctuates 1 up and down between measurements)
                             * Added OTA boot mode, need to hold A1 low while applying power. (uses slightly more power as it's waiting for bootloader messages)
                             * Version 1.4 - Thomas Bowman Mørch
                             * Corrected division in the code deciding whether to transmit or not, that resulted in generating an integer. Now it's generating floats as expected.
                             * Simplified detection for OTA bootloader, now detecting if MY_OTA_FIRMWARE_FEATURE is defined. If this is defined sensebender automaticly waits 300mS after each transmission
                             * Moved Battery status messages, so they are transmitted together with normal sensor updates (but only every 60th minute)
                            // Define a static node address, remove if you want auto address assignment
                            #define MY_NODE_ID 27
                            // Enable to support OTA for this node (needs DualOptiBoot boot-loader to fully work)
                            #include <SI7021.h>
                            #ifndef MY_OTA_FIRMWARE_FEATURE
                            #include "drivers/SPIFlash/SPIFlash.cpp"
                            #include <EEPROM.h>
                            #include <sha204_lib_return_codes.h>
                            #include <sha204_library.h>
                            #include <RunningAverage.h>
                            //#include <avr/power.h>
                            // Uncomment the line below, to transmit battery voltage as a normal sensor value
                            //#define BATT_SENSOR    199
                            #define RELEASE "1.4"
                            #define AVERAGES 2
                            // Child sensor ID's
                            #define CHILD_ID_UVI    1
                            #define CHILD_ID_TEMP   2
                            #define CHILD_ID_HUM    3
                            // How many milli seconds should we wait for OTA?
                            #define OTA_WAIT_PERIOD 300
                            #define FORCE_TRANSMIT_INTERVAL 30
                            #define UVI_TRANSMIT_THRESHOLD 0.1
                            // Pin definitions
                            #define TEST_PIN       A0
                            #define LED_PIN        A2
                            #define ATSHA204_PIN   17 // A3
                            const int sha204Pin = ATSHA204_PIN;
                            SI7021 humiditySensor;
                            SPIFlash flash(8, 0x1F65);
                            // Sensor messages
                            MyMessage msgUVI(CHILD_ID_UVI, V_UV);
                            #ifdef BATT_SENSOR
                            MyMessage msgBatt(BATT_SENSOR, V_VOLTAGE);
                            // Global settings
                            int measureCount = 0;
                            int sendBattery = 0;
                            boolean isMetric = true;
                            boolean highfreq = true;
                            boolean transmission_occured = false;
                            float lastTemperature = -100;
                            int lastHumidity = -100;
                            long lastBattery = -100;
                            int lastUVI = -100;
                             * Setup code
                              pinMode(LED_PIN, OUTPUT);
                              digitalWrite(LED_PIN, LOW);
                              //Serial.begin(115200);
                              //Serial.print(F("Sensebender Micro FW "));
                              //Serial.print(RELEASE);
                              //Serial.flush();
                              // First check if we should boot into test mode
                              pinMode(TEST_PIN,INPUT);
                              digitalWrite(TEST_PIN, HIGH); // Enable pullup
                              if (!digitalRead(TEST_PIN)) testMode();
                              // Make sure that ATSHA204 is not floating
                              pinMode(ATSHA204_PIN, INPUT);
                              digitalWrite(ATSHA204_PIN, HIGH);
                              digitalWrite(TEST_PIN,LOW);
                              digitalWrite(LED_PIN, HIGH);
                              humiditySensor.begin();
                              veml6075.begin();
                              //Serial.flush();
                              //Serial.println(F(" - Online!"));
                              isMetric = getControllerConfig().isMetric;
                              //Serial.print(F("isMetric: ")); Serial.println(isMetric);
                              raHum.clear();
                              sendTempHumidityMeasurements(false);
                              sendBattLevel(false);
                            #ifdef MY_OTA_FIRMWARE_FEATURE
                              //Serial.println("OTA FW update enabled");
                            void presentation()  {
                              sendSketchInfo("Sensebender Micro", RELEASE);
                              present(CHILD_ID_UVI,S_UV);
                              present(CHILD_ID_TEMP,S_TEMP);
                              present(CHILD_ID_HUM,S_HUM);
                            #ifdef BATT_SENSOR
                              present(BATT_SENSOR, S_POWER);
                             *  Main loop function
                              measureCount ++;
                              sendBattery ++;
                              bool forceTransmit = false;
                                highfreq = false;
                              if (measureCount > FORCE_TRANSMIT_INTERVAL) { // force a transmission
                                forceTransmit = true;
                                measureCount = 0;
                            /*  if (sendBattery > 60)
                                 sendBattLevel(forceTransmit); // Not needed to send battery info that often
                                 sendBattery = 0;
                              if (transmission_occured) {
                                  wait(OTA_WAIT_PERIOD);
                              sleep(MEASURE_INTERVAL);
                             * Sends temperature and humidity from Si7021 sensor
                             * Parameters
                            void sendTempHumidityMeasurements(bool force)
                              bool tx = force;
                              veml6075.poll();
                                float UVA = veml6075.getUVA();
                                //Serial.print(F("UVA = "));
                                //Serial.println(UVA, 2);
                                float UVB = veml6075.getUVB();
                                //Serial.print(F("UVB = "));
                                //Serial.println(UVB, 2);
                                float UVI = veml6075.getUVIndex();
                                //Serial.print(F("UV Index = "));
                                //Serial.println(UVI, 1);
                              raHum.addValue(data.humidityPercent);
                              float diffTemp = abs(lastTemperature - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths)/100.0);
                              float diffUVI = abs(lastUVI - UVI);
                              //Serial.print(F("TempDiff :"));Serial.println(diffTemp);
                              //Serial.print(F("HumDiff  :"));Serial.println(diffHum);
                              //Serial.print(F("UVIDiff  :"));Serial.println(diffUVI);
                              if (isnan(diffHum)) tx = true;
                              if (diffTemp > TEMP_TRANSMIT_THRESHOLD) tx = true;
                              if (diffHum > HUMI_TRANSMIT_THRESHOLD) tx = true;
                              if (diffUVI > UVI_TRANSMIT_THRESHOLD) tx = true;
                              if (tx) {
                                measureCount = 0;
                                float temperature = (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100.0;
                                //Serial.print("T: ");Serial.println(temperature);
                                //Serial.print("H: ");Serial.println(humidity);
                                send(msgTemp.set(temperature,1));
                                send(msgHum.set(humidity));
                                send(msgUVI.set(UVI,2));
                                lastHumidity = humidity;
                                lastUVI = UVI;
                                transmission_occured = true;
                                if (sendBattery > 60) {
                                 sendBattLevel(true); // Not needed to send battery info that often
                                 sendBattery = 0;
                             * Parameters
                              if (force) lastBattery = -1;
                              long vcc = readVcc();
                              if (vcc != lastBattery) {
                                lastBattery = vcc;
                            #ifdef BATT_SENSOR
                                float send_voltage = float(vcc)/1000.0f;
                                send(msgBatt.set(send_voltage,3));
                                // Calculate percentage
                                long percent = vcc / 14.0;
                                sendBatteryLevel(percent);
                            long readVcc() {
                             * Verify all peripherals, and signal via the LED if any problems.
                            void testMode()
                              uint8_t ret_code;
                              byte tests = 0;
                              digitalWrite(LED_PIN, HIGH); // Turn on LED.
                              //Serial.println(F(" - TestMode"));
                              //Serial.println(F("Testing peripherals!"));
                              //Serial.flush();
                              //Serial.print(F("-> SI7021 : "));
                              //Serial.flush();
                              if (humiditySensor.begin())
                                //Serial.println(F("ok!"));
                                tests ++;
                                //Serial.println(F("failed!"));
                              //Serial.flush();
                              //Serial.print(F("-> Flash : "));
                              //Serial.flush();
                              if (flash.initialize())
                                tests ++;
                              //Serial.flush();
                              //Serial.print(F("-> SHA204 : "));
                              //Serial.flush();
                              if (ret_code != SHA204_SUCCESS)
                                //Serial.print(F("Failed to wake device. Response: ")); Serial.println(ret_code, HEX);
                              //Serial.flush();
                              if (ret_code == SHA204_SUCCESS)
                                ret_code = sha204.getSerialNumber(rx_buffer);
                                  //Serial.print(F("Failed to obtain device serial number. Response: ")); Serial.println(ret_code, HEX);
                                  //Serial.print(F("Ok (serial : "));
                                  for (int i=0; i<9; i++)
                                    if (rx_buffer[i] < 0x10)
                                      //Serial.print('0'); // Because Serial.print does not 0-pad HEX
                                    //Serial.print(rx_buffer[i], HEX);
                                  //Serial.println(")");
                                  tests ++;
                              //Serial.flush();
                              //Serial.println(F("Test finished"));
                              if (tests == 3)
                                //Serial.println(F("Selftest ok!"));
                                while (1) // Blink OK pattern!
                                  delay(200);
                                  delay(200);
                                //Serial.println(F("----> Selftest failed!"));
                                while (1) // Blink FAILED pattern! Rappidly blinking..
                            • Tomas
                              #include <SI7021.h>
                              #include <EEPROM.h>
                              #define AVERAGES 2
                              // Pin definitions
                              #define TEST_PIN       A0
                              #define LED_PIN        A2
                              // Sensor messages
                              #ifdef BATT_SENSOR
                              // Global settings
                              int lastUVI = -100;
                               * Setup code
                                //Serial.flush();
                                veml6075.begin();
                                //Serial.flush();
                                raHum.clear();
                              #ifdef BATT_SENSOR
                                measureCount ++;
                                sendBattery ++;
                                  highfreq = false;
                                  measureCount = 0;
                                   sendBattery = 0;
                               * Parameters
                                bool tx = force;
                                veml6075.poll();
                                if (tx) {
                                  measureCount = 0;
                                  lastUVI = UVI;
                                   sendBattery = 0;
                               * Parameters
                                  lastBattery = vcc;
                              #ifdef BATT_SENSOR
                              long readVcc() {
                              void testMode()
                                uint8_t ret_code;
                                byte tests = 0;
                                //Serial.flush();
                                //Serial.flush();
                                  tests ++;
                                //Serial.flush();
                                //Serial.flush();
                                  tests ++;
                                //Serial.flush();
                                //Serial.flush();
                                //Serial.flush();
                                    tests ++;
                                //Serial.flush();
                                if (tests == 3)
                                    delay(200);
                                    delay(200);
                              alexsh1A
                              alexsh1A
                              alexsh1
                              This is the VEML6070 UV Index graph. The last day, I placed the sensor outside rather than behind my window. There is a huge difference :
                              • alexsh1A
                                alexsh1A
                                alexsh1
                                #21
                                I finally received VEML6075 and comparing it with VEML6070 side y side
                                _____UVI__UVA__UVB
                                6070 0.9
                                6075 1.2 1036.53 1005.31
                                Not sure why there is a difference in UVI
                                • korttomaK
                                  korttomaK
                                  korttoma
                                  Did anyone measure the current consumption of these VEML chips?
                                  I just compared a Sensebender Micro with the VEML6075 to a standalone Sensebender Micro and the standalone one measured 28uA and the one with the VEML6075 measured 740uA.
                                  I just checked the VEML6075 documentation and typical consumption is 480uA but it should also be possible to shut it down and then it should only draw 800nA.
                                  I need to check the Lib if there is some function to shut it down and wake it up. Or else I will try to change the setup so I can power the VEML6075 from an output pin so I can turn it completely off.
                                  • Tomas
                                  scalzS 1 Reply Last reply
                                    @korttoma
                                    if i remember, sleep is not implemented in the veml6075 lib above. I added a sleep function and set the corresponding CONF register. not a big thing ;)
                                    • scalzS scalz
                                      @korttoma
                                      korttomaK
                                      korttomaK
                                      korttoma
                                      #24
                                      @scalz please share your sleep function implementation :D it is quite a "big thing" for a non programmer.
                                      • Tomas
                                        #25
                                        @korttoma you can try this, and you'll see it's not a big thing :smile:
                                        in your .h, in the public section, add this:
                                        void sleep(bool mode);
                                        then in the .cpp, add this:
                                        void VEML6075::sleep(bool mode) {
                                        	if (mode)
                                        		this->config |= 1; // Go to sleep
                                        		this->config &= 254; // Wake up
                                        	this->write16(VEML6075_REG_CONF, this->config);
                                        In your sketch, just do this:
                                        veml6075.sleep(true); // power down veml6075
                                        Note: i added this because i noticed it wasn't implemented, but i've not checked the power consumption yet. So if you can tell me if it's ok, please!
                                        Enjoy ;)
                                        korttomaK alexsh1A 2 Replies Last reply
                                        • scalzS scalz
                                          	if (mode)
                                          Enjoy ;)
                                          korttomaK
                                          korttomaK
                                          korttoma
                                          @scalz thanks for the sleep function! The current consumption is now down to 85uA but the problem is that onece it sleeps I cant get it to wake up.
                                          Tried with:
                                          veml6075.sleep(false);
                                          Tried allso adding a 500ms sleep after the wakeup to give it time to setle.
                                          But do I need to do something more?
                                          • Tomas
