  3. VEML6070 and VEML6075 UV sensors
52 Posts 6 Posters 20.6k Views 5 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @alexsh1
    But you can not expose the sensor to rain etc. So you still need to have some cover above the chip, and this should be UV transparent..
    alexsh1A 1 Reply Last reply
    • tbowmoT tbowmo
      @alexsh1
      alexsh1A
      alexsh1A
      alexsh1
      @tbowmo As I have just discovered there is a UV transparent plastic.
      Maybe the enclosure can be 3D printed with such plastic?
      There is also a UV transparent glass.
      • alexsh1A
        alexsh1A
        alexsh1
        The sensor has a peak
        sensitivity at 355 nm.
        UV Spectrum:
        UV-a -> 315-400nm
        UV-b -> 280-315nm
        UV-c -> 100-280nm
        UV-a goes through the glass and is a major one
        UV-b account for only 3% of UV radiation
        UV-c is absorbed by ozone layer
          @alexsh1 so if i were you i would have bought a veml6075 when you ordered at some ic supplier! I'm joking.. or not ;)
          • korttomaK
            korttomaK
            korttoma
            Anyone care to share a sketch that includes the VEML6075?
            • Tomas
            • korttomaK korttoma
              alexsh1A
              alexsh1A
              alexsh1
              @korttoma I have not received VEML6075 yet so cannot help you
                @korttoma what do you need exactly?? I can share some example, but there is nothing fancy for veml6075. On my side i'm using this lib for the moment https://github.com/schizobovine/VEML6075 , not digged much yet but it's working with MySensors of course. You simply need the same cooking in your sketch, as usual ;)
                • korttomaK
                  korttomaK
                  korttoma
                  Well, I'm looking to replace my Oregon Scientific UV Sensor UVN800 (that finally stopped reporting any values) by using a VEML6075 and a Sensebender Micro.
                  I can probably work out the code for the sketch myself but I'm not a fan of reinventing the wheel so if someone already created a sketch it would simply save me the time.
                  I would expect the sensor to report a UV Index value between 0 and 10 like the Oregon sensor did according to this -> https://www.epa.gov/sunsafety/uv-index-scale-1
                  The example in the Lib you mentioned @scalz seems to have the UV Index posibility
                  • Tomas
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @korttoma this thread is about VEML6075 :-)
                    However, VEML6075 is more complex - it does report uv-a and uv-b. I do not think you'd get UVI from this sensor straight away, you'd need to do it in the sketch.
                    I can share the sketch after I get the sensor, write a code and convert it into MySensors
                      @korttoma oki, i agree with you about reinventing the wheel, but for big job. I think it's always better to know how to use the lib, so that's not a waste imho ;)
                      No time for the moment to check my bigger sketch and extract everything.
                      But in case you would like to try your new sensor, here a quick 5-10min conversion and mix of the lib example to mysensors uv. I wouldn't release it like this, not optimized, and untested version. But it's compiling, it should work :)
                      //#define MY_NODE_ID 10
                      #include <VEML6075.h>
                      VEML6075 veml6075 = VEML6075();
                      bool sensorFound = false;
                      #define CHILD_ID_UVI 0
                      #define CHILD_ID_UVA 0
                      #define CHILD_ID_UVB 0
                      uint32_t SLEEP_TIME = 30*1000; // Sleep time between reads (in milliseconds)
                      MyMessage uviMsg(CHILD_ID_UVI, V_UV);
                      MyMessage uvaMsg(CHILD_ID_UVA, V_UV);
                      MyMessage uvbMsg(CHILD_ID_UVB, V_UV);
                          sendSketchInfo("UV Sensor", "1.3");
                          present(CHILD_ID_UVI, S_UV);
                          present(CHILD_ID_UVA, S_UV);
                          present(CHILD_ID_UVB, S_UV);
                        if (!veml6075.begin()) {
                          Serial.println(F("VEML6075 not found!"));
                        } else
                          sensorFound = true;
                        if (sensorFound) {
                          unsigned long lastSend =0;
                          float uvi;
                          float uva;
                          float uvb;
                          static float uviOld = -1;
                          static float uvaOld = -1;
                          static float uvbOld = -1;
                          // Poll sensor
                          veml6075.poll();
                          uva = veml6075.getUVA();
                          Serial.print(F("UVA = "));
                          Serial.println(uva, 2);
                          uvb = veml6075.getUVB();
                          Serial.print(F("UVB = "));
                          Serial.println(uvb, 2);
                          uvi = veml6075.getUVIndex();
                          Serial.print(F("UV Index = "));
                          Serial.println(uvi, 1);
                          uint16_t devid = veml6075.getDevID();
                          Serial.print(F("Device ID = "));
                          Serial.println(devid, HEX);
                          Serial.println(F("----------------"));
                          if (uvi != uviOld) {
                              send(uviMsg.set(uvi,2));
                              uviOld = uvi;
                          if (uva != uvaOld) {
                              send(uvaMsg.set(uva,2));
                              uvaOld = uva;
                          if (uvb != uvbOld) {
                              send(uvbMsg.set(uvb,2));
                              uvbOld = uvb;
                        sleep(SLEEP_TIME);
                      It simply read sensor, send messages, and sleep.
                      As you can see, it's possible to get the three values from the lib.
                      korttomaK 1 Reply Last reply
                      • scalzS scalz
                          } else
                            sensorFound = true;
                          if (sensorFound) {
                            float uvi;
                            float uva;
                            float uvb;
                            // Poll sensor
                            veml6075.poll();
                                uviOld = uvi;
                                uvaOld = uva;
                                uvbOld = uvb;
                          sleep(SLEEP_TIME);
                        korttomaK
                        korttomaK
                        korttoma
                        Thanks for the sketch @scalz , I made an attempt at it myself also. I was not avare that V_UV and S_UV could be used so I had V/S_LIGHT_LEVEL but I changed it now. Seems to compile just fine. Just need to get it tested.
                        SensebenderMicroWithUVIndex:
                         * Version 1.0 - Thomas Bowman Mørch
                         * Version 1.3 - Thomas Bowman Mørch
                         * Improved transmission logic, eliminating spurious transmissions (when temperatuere / humidity fluctuates 1 up and down between measurements)
                         * Added OTA boot mode, need to hold A1 low while applying power. (uses slightly more power as it's waiting for bootloader messages)
                         * Version 1.4 - Thomas Bowman Mørch
                         * Corrected division in the code deciding whether to transmit or not, that resulted in generating an integer. Now it's generating floats as expected.
                         * Simplified detection for OTA bootloader, now detecting if MY_OTA_FIRMWARE_FEATURE is defined. If this is defined sensebender automaticly waits 300mS after each transmission
                         * Moved Battery status messages, so they are transmitted together with normal sensor updates (but only every 60th minute)
                        // Define a static node address, remove if you want auto address assignment
                        #define MY_NODE_ID 27
                        // Enable to support OTA for this node (needs DualOptiBoot boot-loader to fully work)
                        #include <SI7021.h>
                        #ifndef MY_OTA_FIRMWARE_FEATURE
                        #include "drivers/SPIFlash/SPIFlash.cpp"
                        #include <EEPROM.h>
                        #include <sha204_lib_return_codes.h>
                        #include <sha204_library.h>
                        #include <RunningAverage.h>
                        //#include <avr/power.h>
                        // Uncomment the line below, to transmit battery voltage as a normal sensor value
                        //#define BATT_SENSOR    199
                        #define RELEASE "1.4"
                        #define AVERAGES 2
                        // Child sensor ID's
                        #define CHILD_ID_UVI    1
                        #define CHILD_ID_TEMP   2
                        #define CHILD_ID_HUM    3
                        // How many milli seconds should we wait for OTA?
                        #define OTA_WAIT_PERIOD 300
                        #define FORCE_TRANSMIT_INTERVAL 30
                        #define UVI_TRANSMIT_THRESHOLD 0.1
                        // Pin definitions
                        #define TEST_PIN       A0
                        #define LED_PIN        A2
                        #define ATSHA204_PIN   17 // A3
                        const int sha204Pin = ATSHA204_PIN;
                        SI7021 humiditySensor;
                        SPIFlash flash(8, 0x1F65);
                        // Sensor messages
                        MyMessage msgUVI(CHILD_ID_UVI, V_UV);
                        #ifdef BATT_SENSOR
                        MyMessage msgBatt(BATT_SENSOR, V_VOLTAGE);
                        // Global settings
                        int measureCount = 0;
                        int sendBattery = 0;
                        boolean isMetric = true;
                        boolean highfreq = true;
                        boolean transmission_occured = false;
                        float lastTemperature = -100;
                        int lastHumidity = -100;
                        long lastBattery = -100;
                        int lastUVI = -100;
                         * Setup code
                          pinMode(LED_PIN, OUTPUT);
                          digitalWrite(LED_PIN, LOW);
                          //Serial.begin(115200);
                          //Serial.print(F("Sensebender Micro FW "));
                          //Serial.print(RELEASE);
                          //Serial.flush();
                          // First check if we should boot into test mode
                          pinMode(TEST_PIN,INPUT);
                          digitalWrite(TEST_PIN, HIGH); // Enable pullup
                          if (!digitalRead(TEST_PIN)) testMode();
                          // Make sure that ATSHA204 is not floating
                          pinMode(ATSHA204_PIN, INPUT);
                          digitalWrite(ATSHA204_PIN, HIGH);
                          digitalWrite(TEST_PIN,LOW);
                          digitalWrite(LED_PIN, HIGH);
                          humiditySensor.begin();
                          veml6075.begin();
                          //Serial.flush();
                          //Serial.println(F(" - Online!"));
                          isMetric = getControllerConfig().isMetric;
                          //Serial.print(F("isMetric: ")); Serial.println(isMetric);
                          raHum.clear();
                          sendTempHumidityMeasurements(false);
                          sendBattLevel(false);
                        #ifdef MY_OTA_FIRMWARE_FEATURE
                          //Serial.println("OTA FW update enabled");
                        void presentation()  {
                          sendSketchInfo("Sensebender Micro", RELEASE);
                          present(CHILD_ID_UVI,S_UV);
                          present(CHILD_ID_TEMP,S_TEMP);
                          present(CHILD_ID_HUM,S_HUM);
                        #ifdef BATT_SENSOR
                          present(BATT_SENSOR, S_POWER);
                         *  Main loop function
                          measureCount ++;
                          sendBattery ++;
                          bool forceTransmit = false;
                            highfreq = false;
                          if (measureCount > FORCE_TRANSMIT_INTERVAL) { // force a transmission
                            forceTransmit = true;
                            measureCount = 0;
                        /*  if (sendBattery > 60)
                             sendBattLevel(forceTransmit); // Not needed to send battery info that often
                             sendBattery = 0;
                          if (transmission_occured) {
                              wait(OTA_WAIT_PERIOD);
                          sleep(MEASURE_INTERVAL);
                         * Sends temperature and humidity from Si7021 sensor
                         * Parameters
                        void sendTempHumidityMeasurements(bool force)
                          bool tx = force;
                          veml6075.poll();
                            float UVA = veml6075.getUVA();
                            //Serial.print(F("UVA = "));
                            //Serial.println(UVA, 2);
                            float UVB = veml6075.getUVB();
                            //Serial.print(F("UVB = "));
                            //Serial.println(UVB, 2);
                            float UVI = veml6075.getUVIndex();
                            //Serial.print(F("UV Index = "));
                            //Serial.println(UVI, 1);
                          raHum.addValue(data.humidityPercent);
                          float diffTemp = abs(lastTemperature - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths)/100.0);
                          float diffUVI = abs(lastUVI - UVI);
                          //Serial.print(F("TempDiff :"));Serial.println(diffTemp);
                          //Serial.print(F("HumDiff  :"));Serial.println(diffHum);
                          //Serial.print(F("UVIDiff  :"));Serial.println(diffUVI);
                          if (isnan(diffHum)) tx = true;
                          if (diffTemp > TEMP_TRANSMIT_THRESHOLD) tx = true;
                          if (diffHum > HUMI_TRANSMIT_THRESHOLD) tx = true;
                          if (diffUVI > UVI_TRANSMIT_THRESHOLD) tx = true;
                          if (tx) {
                            measureCount = 0;
                            float temperature = (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100.0;
                            //Serial.print("T: ");Serial.println(temperature);
                            //Serial.print("H: ");Serial.println(humidity);
                            send(msgTemp.set(temperature,1));
                            send(msgHum.set(humidity));
                            send(msgUVI.set(UVI,2));
                            lastHumidity = humidity;
                            lastUVI = UVI;
                            transmission_occured = true;
                            if (sendBattery > 60) {
                             sendBattLevel(true); // Not needed to send battery info that often
                             sendBattery = 0;
                         * Parameters
                          if (force) lastBattery = -1;
                          long vcc = readVcc();
                          if (vcc != lastBattery) {
                            lastBattery = vcc;
                        #ifdef BATT_SENSOR
                            float send_voltage = float(vcc)/1000.0f;
                            send(msgBatt.set(send_voltage,3));
                            // Calculate percentage
                            long percent = vcc / 14.0;
                            sendBatteryLevel(percent);
                        long readVcc() {
                         * Verify all peripherals, and signal via the LED if any problems.
                        void testMode()
                          uint8_t ret_code;
                          byte tests = 0;
                          digitalWrite(LED_PIN, HIGH); // Turn on LED.
                          //Serial.println(F(" - TestMode"));
                          //Serial.println(F("Testing peripherals!"));
                          //Serial.flush();
                          //Serial.print(F("-> SI7021 : "));
                          //Serial.flush();
                          if (humiditySensor.begin())
                            //Serial.println(F("ok!"));
                            tests ++;
                            //Serial.println(F("failed!"));
                          //Serial.flush();
                          //Serial.print(F("-> Flash : "));
                          //Serial.flush();
                          if (flash.initialize())
                            tests ++;
                          //Serial.flush();
                          //Serial.print(F("-> SHA204 : "));
                          //Serial.flush();
                          if (ret_code != SHA204_SUCCESS)
                            //Serial.print(F("Failed to wake device. Response: ")); Serial.println(ret_code, HEX);
                          //Serial.flush();
                          if (ret_code == SHA204_SUCCESS)
                            ret_code = sha204.getSerialNumber(rx_buffer);
                              //Serial.print(F("Failed to obtain device serial number. Response: ")); Serial.println(ret_code, HEX);
                              //Serial.print(F("Ok (serial : "));
                              for (int i=0; i<9; i++)
                                if (rx_buffer[i] < 0x10)
                                  //Serial.print('0'); // Because Serial.print does not 0-pad HEX
                                //Serial.print(rx_buffer[i], HEX);
                              //Serial.println(")");
                              tests ++;
                          //Serial.flush();
                          //Serial.println(F("Test finished"));
                          if (tests == 3)
                            //Serial.println(F("Selftest ok!"));
                            while (1) // Blink OK pattern!
                              delay(200);
                              delay(200);
                            //Serial.println(F("----> Selftest failed!"));
                            while (1) // Blink FAILED pattern! Rappidly blinking..
                        • Tomas
                          #include <SI7021.h>
                          #include <EEPROM.h>
                          #define AVERAGES 2
                          // Pin definitions
                          #define TEST_PIN       A0
                          #define LED_PIN        A2
                          // Sensor messages
                          #ifdef BATT_SENSOR
                          // Global settings
                          int lastUVI = -100;
                           * Setup code
                            //Serial.flush();
                            veml6075.begin();
                            //Serial.flush();
                            raHum.clear();
                          #ifdef BATT_SENSOR
                            measureCount ++;
                            sendBattery ++;
                              highfreq = false;
                              measureCount = 0;
                               sendBattery = 0;
                           * Parameters
                            bool tx = force;
                            veml6075.poll();
                            if (tx) {
                              measureCount = 0;
                              lastUVI = UVI;
                               sendBattery = 0;
                           * Parameters
                              lastBattery = vcc;
                          #ifdef BATT_SENSOR
                          long readVcc() {
                          void testMode()
                            uint8_t ret_code;
                            byte tests = 0;
                            //Serial.flush();
                            //Serial.flush();
                              tests ++;
                            //Serial.flush();
                            //Serial.flush();
                              tests ++;
                            //Serial.flush();
                            //Serial.flush();
                            //Serial.flush();
                                tests ++;
                            //Serial.flush();
                            if (tests == 3)
                                delay(200);
                                delay(200);
                          alexsh1A
                          alexsh1A
                          alexsh1
                          This is the VEML6070 UV Index graph. The last day, I placed the sensor outside rather than behind my window. There is a huge difference :
                          • alexsh1A
                            alexsh1A
                            alexsh1
                            #21
                            I finally received VEML6075 and comparing it with VEML6070 side y side
                            _____UVI__UVA__UVB
                            6070 0.9
                            6075 1.2 1036.53 1005.31
                            Not sure why there is a difference in UVI
                            • korttomaK
                              korttomaK
                              korttoma
                              Did anyone measure the current consumption of these VEML chips?
                              I just compared a Sensebender Micro with the VEML6075 to a standalone Sensebender Micro and the standalone one measured 28uA and the one with the VEML6075 measured 740uA.
                              I just checked the VEML6075 documentation and typical consumption is 480uA but it should also be possible to shut it down and then it should only draw 800nA.
                              I need to check the Lib if there is some function to shut it down and wake it up. Or else I will try to change the setup so I can power the VEML6075 from an output pin so I can turn it completely off.
                              • Tomas
                              scalzS 1 Reply Last reply
                                @korttoma
                                if i remember, sleep is not implemented in the veml6075 lib above. I added a sleep function and set the corresponding CONF register. not a big thing ;)
                                • scalzS scalz
                                  @korttoma
                                  korttomaK
                                  korttomaK
                                  korttoma
                                  #24
                                  @scalz please share your sleep function implementation :D it is quite a "big thing" for a non programmer.
                                  • Tomas
                                    #25
                                    @korttoma you can try this, and you'll see it's not a big thing :smile:
                                    in your .h, in the public section, add this:
                                    void sleep(bool mode);
                                    then in the .cpp, add this:
                                    void VEML6075::sleep(bool mode) {
                                    	if (mode)
                                    		this->config |= 1; // Go to sleep
                                    		this->config &= 254; // Wake up
                                    	this->write16(VEML6075_REG_CONF, this->config);
                                    In your sketch, just do this:
                                    veml6075.sleep(true); // power down veml6075
                                    Note: i added this because i noticed it wasn't implemented, but i've not checked the power consumption yet. So if you can tell me if it's ok, please!
                                    Enjoy ;)
                                    korttomaK alexsh1A 2 Replies Last reply
                                    • scalzS scalz
                                      	if (mode)
                                      Enjoy ;)
                                      korttomaK
                                      korttomaK
                                      korttoma
                                      @scalz thanks for the sleep function! The current consumption is now down to 85uA but the problem is that onece it sleeps I cant get it to wake up.
                                      Tried with:
                                      veml6075.sleep(false);
                                      Tried allso adding a 500ms sleep after the wakeup to give it time to setle.
                                      But do I need to do something more?
                                      • Tomas
                                        Tried with:
                                        #27
                                        @korttoma sorry for the copy/paste mistake :) you can try again, i've updated above. maybe someday i'll measure power consuption of a sensebender, weird that you get 28uA for the standalone..
                                        • scalzS scalz
                                          korttomaK
                                          korttomaK
                                          korttoma
                                          #28
                                          @scalz seems to be working now :D don´t take my current consumtion figures to sareously since Im using the Micro (nano) ampere meter and I realy have nothing good to calibrate it against.
                                          • Tomas
