  3. communicate is good for first time for relays and sensors but after some days will be weak and some time stop working !
30 Posts 2 Posters 6.5k Views 3 Watching
    try update to latest libray first thing, then try also power other power levels pa_low and pa_high (some modules don't work well with pa_max)
    R 2 Replies Last reply
      R
      R
      Reza
      @gohan thank you i will try update and change to pa_high
        R
        R
        Reza
        @gohan sorry friend but how i can remove old version and install new update?
          I just clone the repository, stop the mysgw service, compile and run the install process if it doesn't start automatically on boot (maybe there is a better way to do it)
          R 1 Reply Last reply
            R
            R
            Reza
            @gohan i change this . do i need change pa_max in repeater node?i will test in next 3 days .thank you
              No, do one change at a time or you will not be able to pinpoint the problem
                R
                R
                Reza
                @gohan
                again i have this error after 3 hours.
                i test repeater, in this state (error in communicate) i reset repeater. but problem is related to controller or gateway . because after reset , repeater can not connect to gateway, or very hard and bad connect.
                  don't you have any other radio modules to try, right?
                    R
                    R
                    Reza
                    @gohan
                    i tested before. but test with similar radio from same Producer. other radios have support 5-6 meter distance for me. but this model support 15 meter.so i am using this for controller and repeater. do you think this is related to this model of radio ?
                    • R
                      R
                      Reza
                      this is strange for me, why sensors can send to gateway. but gateway can not send to relay node. is not related to power of radio ?
                      both "transfer" and "receive" need to same power ? i use regulator ams1117 and 100u cap but perhaps this modules is fake !?
                      • R
                        R
                        Reza
                        after reboot raspberry again work well for a time .but again...
                          maybe the voltage regulator? try to swap that too. It is all a matter of trial and error.
                            R
                            R
                            Reza
                            @gohan said in communicate is good for first time for relays and sensors but after some days will be weak and some time stop working !:
                            thank you . i will change the regulator with a better regulator.and i test again . thank you
                              also swapping things between gateway and repeater and see if problem follows the part or not.
                                R
                                R
                                Reza
                                @gohan
                                sorry i didn't get you. if swapping between repeater and gateway have problem so sensors can not send parameter to gateway. just problem is related to transfer from controller to relay node and repeater, that is right ?
                                  to test it out you would need at least 2 nodes connected to gateway and 2 to the repeater and test where the node to node communication between all nodes and see which is having problems. The best solution would be to use more than the 2 parts you currently have just to exclude both of them being faulty. I am really running out of options.
                                  R 3 Replies Last reply
                                    R
                                    R
                                    Reza
                                    ok thank you . i will test this .
                                      R
                                      R
                                      Reza
                                      @gohan
                                      for test first i change my regulator in controller and repeater,use LF33 instead of
                                      ams1117. but problem dont solve.now i put some relay near controller and connect directly to controller and i will test when there is problem and relay with repeater dont work, so relay that directly connect to controller have same problem or not !
                                        R
                                        R
                                        Reza
                                        @gohan hi
                                        again happen this problem . i test relay with repeater and test relay that connect to gateway directly. i see both have problem so i think this related to transmitter of controller and gateway. What do you think?
                                          are you using latest code from development branch ?
                                          12.5k
