  2. Announcements
  3. 💬 Battery Powered Sensors
battery
347 Posts 55 Posters 226.6k Views 53 Watching
  • F
    F
    FatBeard
    Hi, i've got a barebones arduino circuit set up with a dht22 sensor. It's powered off 2 aa batteries. All works well with the two batteries even when they are running at about 3.0 volts combined (it would probably run at lower voltages but batteries haven't gone down that far yet). If i power directly from usb with my ftdi interface all works. However, when i add the 3.3v step up, the radio doesn't get a response from the nrf gateway anymore. I have a 4.7u capacitor on the nrf. The gateway is receiving some data but not all as i can see "mygateway1-out/0/255/0/0/18 2.1.1" in my mqtt broker every couple of seconds but the mysensors client never seems to get fully initialised. I've tried two or three of the step ups and checked the voltage with a multimeter and i'm getting circa 3.3v. One thing i did notice is that when i swapped in one of my 3 dht22's it worked initially but then stopped, the other two wouldn't (all work without the step up). I think this is a bit of a red herring but putting in here for information. Any thoughts?
    • rozpruwaczR
      rozpruwaczR
      rozpruwacz
      share your schematic. from what you are describing it seems like the step up converter is not able to provide enough current.
        could be also noise generated from the booster, in fact you could run the NRF24 directly from battery since it can still work down to 1.9V
        • rozpruwaczR
          rozpruwaczR
          rozpruwacz
          but the dht22 would not work, it requires at least 3.3v (however i succesuffly used it with 3V). I think that NRF has some decoupling capacitors onboard, so unless the boost converter design is not totaly wrong it shouldn't be a problem. schematic would be helpful.
          F 1 Reply Last reply
          • rozpruwaczR rozpruwacz
            F
            F
            FatBeard
            @rozpruwacz 0_1498042165035_Mini Arduino Sensor W FTDI Double Sided Ordered_bb.jpg
            Here is my breadboard design, i'm afraid the schematic in fritzing isn't really in a state to post here. It's unreadable. The resistors shown in the diagram wouldn't have the correct values i used. The values i used are from the arduino site for creating an arduino. The ones shown are used for the sake of creating a pcb. The DHT22 goes on the 4 pin header, the NRF goes on the 8 pin header.
            • F FatBeard
              F
              F
              FatBeard
              @FatBeard I should point out that the step up was an afterthought and it was the ground and vout of the stepup were connected directly to the power rail along the bottom. It powers the whole circuit.
              • rozpruwaczR
                rozpruwaczR
                rozpruwacz
                @FatBeard said in 💬 Battery Powered Sensors:
                goes on
                ok, but what about boost converter ? as i understand the problem is when You use the boost converter ? is it some kind of module ? or your design ?
                  goes on
                  F
                  F
                  FatBeard
                  @rozpruwacz Ya, it's a module and it's the 3.3v step up module recommended on this page. Thanks for your help by the way
                  • rozpruwaczR
                    rozpruwaczR
                    rozpruwacz
                    recommended
                    which one ? could you paste a link ?
                      recommended
                      F
                      F
                      FatBeard
                      @rozpruwacz This one here on aliexpress.
                      https://www.aliexpress.com/item/1-PC-NEW-DC-0-8-3-3V-to-DC-3-3V-StepUP-Boost-Power-Mini/32724005061.html
                      • rozpruwaczR
                        rozpruwaczR
                        rozpruwacz
                        unless the dht22 pull up resistor is not to low, which would cause large current when the data pin is held low, i don;t see any mistakes ... are you able to measure the current drawn from the boost converter ?
                          F
                          F
                          FatBeard
                          @rozpruwacz Both resistors are 10k. I can measure the amps, i'll do this tonight and get back to you. thanks again
                          • rozpruwaczR
                            rozpruwaczR
                            rozpruwacz
                            one other thought, what type of nrf module You use in your gateway ? from my expirience i know that the PA+LNA modules are very sensitive to noise. Do you have other sensors in your network that are affected ? maybe it is the problem with the gateway nrf module and not the sensors nfr module ? You can try to shield the modules somehow.
                            • sundberg84S
                              sundberg84S
                              #109
                              Try adding a 0,1uF cheramic capacitor on the booster from Out to Gnd. Also external capacitor on the radio is crusial!
                              • F
                                F
                                FatBeard
                                The NRF is a NRF24L01+ without the antenna on the gateeway and all of the sensors. I'm going to try the capacitor idea now. I'll try measuring current shortly too.
                                • F
                                  F
                                  FatBeard
                                  I made progress. So the capacitor idea doesn't seem to work. However rozpruwacz suggested measuring the current which I did. I disconnected the negative wire and put my multimeter in between the negative from the battery and the ground pin on the step up module. I measured 72ma when the device powers up, then it runs at .16ma when in sleep mode. But here is the thing, in this configuration, mysensors worked as a thermometer. I got humidity and temperature readings from the sensor to my mqtt server through the gateway over the nrfs. When I removed the multimeter again from the equation it stopped working. Surely this would hint at what the problem is for someone more familiar with electronics than myself?
                                  • F
                                    F
                                    FatBeard
                                    Any thoughts on what I could do to fix the issue permanently without the multimeter?
                                      why don't you connect the radio directly to battery?
                                      • rozpruwaczR
                                        rozpruwaczR
                                        rozpruwacz
                                        this is very wierd ... maybe try another nrf module ? also try what gohan suggested. But it should work as it is. I have similar configuration, but the boost converter has pass trough mode, so i can switch it on and off from the atmega and have no problems with that setup, no matter if the boost converter is os or off, the communication is ok. Can you upload a picture of your setup ? maybe we see something you didn't realize is important to say.
                                        • F FatBeard
                                          sundberg84S
                                          sundberg84S
                                          @FatBeard - Could it be that the step up booster are making alot of noice. When you connect your multimeter it works in some way like a filter and reduces the noice?
                                          I have made alot of these sensors and i strongly suggest you connect i like @gohan suggest - radio directly to the bat.
                                          This is how i have created my EasyPCB and with alot of trial and error - radio + booster isnt a good idea.
                                          https://www.openhardware.io/view/4/EasyNewbie-PCB-for-MySensors
