  2. Announcements
  3. 💬 Battery Powered Sensors
battery
347 Posts 55 Posters 219.0k Views 53 Watching
  • rozpruwaczR rozpruwacz
    @FatBeard said in 💬 Battery Powered Sensors:
    goes on
    ok, but what about boost converter ? as i understand the problem is when You use the boost converter ? is it some kind of module ? or your design ?
    F
    F
    FatBeard
    @rozpruwacz Ya, it's a module and it's the 3.3v step up module recommended on this page. Thanks for your help by the way
    • rozpruwaczR
      rozpruwaczR
      rozpruwacz
      recommended
      which one ? could you paste a link ?
      F 1 Reply Last reply
        recommended
        F
        F
        FatBeard
        @rozpruwacz This one here on aliexpress.
        https://www.aliexpress.com/item/1-PC-NEW-DC-0-8-3-3V-to-DC-3-3V-StepUP-Boost-Power-Mini/32724005061.html
        • rozpruwaczR
          rozpruwaczR
          rozpruwacz
          unless the dht22 pull up resistor is not to low, which would cause large current when the data pin is held low, i don;t see any mistakes ... are you able to measure the current drawn from the boost converter ?
            F
            F
            FatBeard
            @rozpruwacz Both resistors are 10k. I can measure the amps, i'll do this tonight and get back to you. thanks again
            • rozpruwaczR
              rozpruwaczR
              rozpruwacz
              one other thought, what type of nrf module You use in your gateway ? from my expirience i know that the PA+LNA modules are very sensitive to noise. Do you have other sensors in your network that are affected ? maybe it is the problem with the gateway nrf module and not the sensors nfr module ? You can try to shield the modules somehow.
              • sundberg84S
                sundberg84S
                #109
                Try adding a 0,1uF cheramic capacitor on the booster from Out to Gnd. Also external capacitor on the radio is crusial!
                • F
                  F
                  FatBeard
                  The NRF is a NRF24L01+ without the antenna on the gateeway and all of the sensors. I'm going to try the capacitor idea now. I'll try measuring current shortly too.
                  • F
                    F
                    FatBeard
                    I made progress. So the capacitor idea doesn't seem to work. However rozpruwacz suggested measuring the current which I did. I disconnected the negative wire and put my multimeter in between the negative from the battery and the ground pin on the step up module. I measured 72ma when the device powers up, then it runs at .16ma when in sleep mode. But here is the thing, in this configuration, mysensors worked as a thermometer. I got humidity and temperature readings from the sensor to my mqtt server through the gateway over the nrfs. When I removed the multimeter again from the equation it stopped working. Surely this would hint at what the problem is for someone more familiar with electronics than myself?
                    • F
                      F
                      FatBeard
                      Any thoughts on what I could do to fix the issue permanently without the multimeter?
                        why don't you connect the radio directly to battery?
                        • rozpruwaczR
                          rozpruwaczR
                          rozpruwacz
                          this is very wierd ... maybe try another nrf module ? also try what gohan suggested. But it should work as it is. I have similar configuration, but the boost converter has pass trough mode, so i can switch it on and off from the atmega and have no problems with that setup, no matter if the boost converter is os or off, the communication is ok. Can you upload a picture of your setup ? maybe we see something you didn't realize is important to say.
                          • F FatBeard
                            sundberg84S
                            sundberg84S
                            @FatBeard - Could it be that the step up booster are making alot of noice. When you connect your multimeter it works in some way like a filter and reduces the noice?
                            I have made alot of these sensors and i strongly suggest you connect i like @gohan suggest - radio directly to the bat.
                            This is how i have created my EasyPCB and with alot of trial and error - radio + booster isnt a good idea.
                            https://www.openhardware.io/view/4/EasyNewbie-PCB-for-MySensors
                            • sundberg84S sundberg84
                              F
                              F
                              FatBeard
                              @sundberg84 Ok, thanks guys. I'll try your suggestions out tonight. I would have preferred to do it through the step up to get the most out of the batteries but maybe this is not practical.
                                maybe you could use the booster, but you would need to analyze the kind of noise and build a specific filter for that.
                                • F FatBeard
                                  rozpruwaczR
                                  rozpruwaczR
                                  rozpruwacz
                                  @FatBeard boost converter has limited efficiency, this means that it eat the battery power. Nrf can work down to 1.9 V so it is not so obvious that the booster actually will make your sensor live longer.
                                    wrote on last edited by gohan
                                    #119
                                    It can help drainig the battery to even lower voltages, but the tradeoff is lower efficiency and noise
                                    • sundberg84S
                                      sundberg84S
                                      Search the forum. Booster VS not booster - its always a tradeoff.
                                      Some people go further and skip booster and lower BOD on the arduino instead.
                                      I would say 1.9V is pretty good... I have had my longest temp sensor now since the beginning (Almost 3 years) and changed 2xAA once. If you are using sleep and measure once you will get away with a long lasting sensor.
                                      • mfalkviddM
                                        #121
                                        At 0.95V per cell, an alkaline battery has delivered about 99% of its total capacity. Look at a discharge curve like this:
                                        So if the booster has more than 1% overhead, using a booster to power nrf24 and atmega328 will give worse battery performance than running directly off 2 alkaline batteries.
                                        • F
                                          F
                                          FatBeard
                                          Thats for the response guys. So tried connecting directly to the battery. I cut the trace on the pcb, then soldered a wire directly from the vIn to the positive leg of the 4.7u cap that leads to the radio. No joy though. Still same problem.
                                          To the point about disabling bod, i have done that already, my issue with that setup though is that my dht22 seems to give inconsistent measurements when operating. It would give readings a degree apart every 5 minutes when the temperature would have remained a lot more stable. I assumed this to be due to the 2x batteries running at just a tad below 3v, while the dht22 is rated at 3.3v. Hence i thought the stepup would fix this problem.
