  3. How to wire battery sensor with battery voltage reports...
25 Posts 7 Posters 20.4k Views 5 Watching
  • sundberg84S
    sundberg84S
    Hi!
    Thank you for great answers and links!
    What kind fo capasitor (in uF) is recommenden for paralell with R2?
    I have heard that the radio is sensitive to power ups/downs but it current not volts its sensitive to? - since you say it can opperate down to 1.9V ?
    Br
    Andreas
    • D
      dzairo
      Hi all...
      Right now I tested my node and serial gateway ..
      ATmega328P DIP 28 , Internal 8Mhz RC oscillator , TIMER2 with 32Khz crystal .
      powered 2xAA , 47uF tantalum capacitor .
      VBAT measure by resistor divider 1M and 390k with 220nF capacitor .
      I try if working down to 2V .. then I setting my regulated power source to 1.9V ..and use serial terminal for debugging message .. I use FT232R with 3.3V setting .. and working .. working good ... serial gateway and sensor node .. I send command to gateway from node also powered from 2V.
      I don't know how many it's safe .. but in my solution works..
      regards
      • sundberg84S
        sundberg84S
        Ahh i see the instructions for capacitor over tappoint now.
        Well I have a dht22 and it needs min 3v but doesnt arduino have a booster if i connect dht22 to VCC? (PRO mini 3.3 8mhz).
        tbowmoT 1 Reply Last reply
        • D
          dzairo
          ehm.. just small idea.. I checked capacitor .. I use 330uF ..not 47uF .. but in fact gateway use 47uF..
          • sundberg84S sundberg84
            tbowmoT
            tbowmoT
            tbowmo
            No, there is no booster on the arduinos, only step-down regulators.
            There are other sensors out there (Si7021, SHU21 etc) that are capable of operating down to 1.9V. And the price difference to the DHT22 is not that big.
            Anyway, if you stick with the DHT22, then yes.. a booster is necessary to operate from a battery, and also a voltage divider for battery measurement. Or power the arduino with 4xAA to RAW input, and then use the 3.3V output from the arduino to power the radio..
            • sundberg84S
              sundberg84S
              well, i have wired it all up and it seems to be almost working, i get humidity and temp from sensor but serial debugging sensor shows "st=fail" on all lines (almost). I think im loosing about 95% of all sent messages.
              I have capasitor over Radio., Measuring batteri is current 3.1 volts. Debug shows values from DHT is fine.
              Any ideas?
              • tbowmoT
                tbowmoT
                tbowmo
                @sundberg84
                What is the distance to the gateway? if it's to big, then it might be the problem. Also, I have seen some reports on the forum, that some have better luck, if they try another radio module (in GW / sensor nodes) So that could also be experimented with.
                / Thomas
                • sundberg84S
                  sundberg84S
                  It Seems to be a power issue-it works better with usb power supply. Ill check more when i get home.
                  What does st-fail means? Is it some missing/failed axcknowledge message from gw?
                    tbowmoT
                    tbowmoT
                    tbowmo
                    I think, that it means that the radio didn't receive an acknowledge from the receiving part. There are multiple ACK's in the system. both inter radio (from point to point, which is the one st=ok /st=fail is about). If there are repeaters between the sensor node, and the gw, then this ACK is only for the direct next uplink (repeater).
                    But also you can ask mysensor to send an ack for each message, this travels across repeaters from GW to sensor (or the other way arround).
                    So in this case, it means that the radio transmits, but there is no receiver ack'ing that it has heard the broadcast.
                    • sundberg84S
                      sundberg84S
                      Ok, tHanks! Will try to move closer to gw and see what happens.
                      • sundberg84S
                        sundberg84S
                        Yes - moving it closer to the gateway improves numbers of st=ok but still not 100% (not even close) even if i only have a fem meters between. Needs to check my soldering and wiring.
                        Thank you for answers - will upload new image when ready and it works.
                        • sundberg84S
                          sundberg84S
                          Hi!
                          Ok, i wanted to share my "sollution" or atleast current setup if someone else in the future has the same problem.Namnlös.jpg
                          The radio and battery voltage sensor (R1/R2) is not connected to Step up regulator.
                          Also DHT22 sensor needs atleast 3v to operate so i put the arduino and DHT22 after the voltage regulator.
                          Im sleeping the node for 15min, then sends temp and hum. The Battery status is sent each 8 loop. Now i will have a look how fast the battery is drained. I have not removed the led in the aurdino or step up reg so im guessing quite fast.
                          I have the radio about 15 meter (1 wall) from the gw - 100% seems to be st=ok.
                          Any improvement ideas - let me know,
                          Br
                          Andreas
                          hekH funky81F 2 Replies Last reply
                            Hi!
                            Br
                            Andreas
                            @sundberg84
                            Just love your pictures :)
                            • D
                              dzairo
                              picasso ..
                              • sundberg84S
                                sundberg84S
                                @hek just let me know if you need any additional designers for the homepage :+1: haha
                                /Andreas
                                • m26872M
                                  m26872M
                                  m26872
                                  wrote on last edited by m26872
                                  The 0,1uF capacitor is usually put in parallell with the 470k. Unless your battery wires are very long or interfered I think it's useless as it is.
                                    Hi!
                                    Br
                                    Andreas
                                    funky81F
                                    funky81F
                                    funky81
                                    @sundberg84
                                    @sundberg84 said:
                                    Hi!
                                    Br
                                    Andreas
                                    Hi all, I'm newbie with these libraries.
                                    And I'm a bit confused about the picture.
                                    I'm guessing is that the picture still similar with the battery page in build sites. What makes me confused is that resistor position. And also what is the source to measure in the voltage divider? Is it vcc?
                                    • funky81F
                                      funky81F
                                      funky81
                                      And also, is it correct to take power directly from the batteries instead from the arduino itself?
                                      • funky81F funky81
                                        @sundberg84
                                        @sundberg84 said:
                                        Hi!
                                        Br
                                        Andreas
                                        sundberg84S
                                        sundberg84S
                                        Im a newbie as well, also a bit on and off building...
                                        Yes, i have tried to work from the battery build site. I saw you did a own post about this and worked it out.
                                        1. I have also tried to take power to the radio from the booster - but this seems to drain the battery very fast, annyone else experienced this?
                                        2. Also i tried to take power to the radio from the arduino - and it works well, is there any downsides with this?
                                        3. Is the radio using any power not used? It seems like the battery last longer with the radio connected to the arduino instread of the battery. When the arduino sleeps - so does the radio i guess, but does the radio sleep any time connected directly to the battery?
                                        • ronnyandreR
                                          ronnyandreR
                                          ronnyandre
                                          Would be awesome if you made a fritz sketch of this :)
                                          Newbie with RPi and Domoticz, trying to automate my home.
