  3. How best to find the "best" small solar panel of a particular size?
220 Posts 14 Posters 99.9k Views 17 Watching
    It should get a little better after some cycles
      I went ahead and made the switch on the node that I'm experimenting with: I'm now using a LTC3235D 3.3v passthrough boost converter. I switch it on when the node wakes up, do various measurements, then switch it off before transmitting the results if the supercap voltage is above threshold. Everything working smoothly.
      I think I may next try putting a buck converter on the solar panel so I can get more juice out of it when its voltage is above 3.3v. I'll be trying this one:
      https://www.openhardware.io/view/276/33v-Buck-Boost-DC-DC-Converter
      because it's the only one I have on hand. If it seems to help, then I'll look for something more on-point (and less expensive!).
      alexsh1A
      alexsh1A
      alexsh1
      @NeverDie said in How best to find the "best" small solar panel of a particular size?:
      How does LTC3235D compare to BQ25570?
      BQ25570 has got buck converter with Vout from 3.3V down to 2V (Vbat is from 5.1 down to 2V), which is just enough to run nrf24l01+ with AVR.
      • alexsh1A alexsh1
        #176
        @alexsh1
        Well, I'm sure it's easier to solder than the BQ25570. I'm no longer really considering anything that's difficult to solder unless there's just absolutely no alternative.
        It looks as though @ceech sells them though already soldered to a breakout board, so maybe he can answer your question.
          #177
          I'm playing around with a coulomb counter, actually a clone of:
          https://www.sparkfun.com/products/12052
          The only downside to it is that it requires a minimum of 2.7v on the input current that it's measuring, which isn't really ideal for a solar panel that might nonetheless be charging at a lower voltage. It also includes its own current consumption in the measurement, and it appears to be about 75ua. In addition to counting the coulombs, you can also measure the average current between interrupts by doing a little math (which is illustrated in the sample sketche).
          So, kinda cool. I changed out the sense resistor from 0.05ohm to 10ohm so that I get more frequent interrupts.
          • alexsh1A
            alexsh1A
            alexsh1
            I found this interesting fella
            https://www.tindie.com/products/closedcube/tps63030-high-efficient-buck-boost-up-to-96/
            Anyone tinkered with tps63030?
            C NeverDieN 2 Replies Last reply
              It's kind of pricey 😧
              alexsh1A 1 Reply Last reply
              • alexsh1A alexsh1
                C
                C
                ceech
                @alexsh1 I use it. On this board:
                http://www.ebay.com/itm/ATmega328p-board-w-NRF24l01-socket-LTC4079-battery-charger-in-Arduino-PRO-form-/331800929918?ssPageName=STRK:MESE:IT
                It works.
                • alexsh1A alexsh1
                  @alexsh1
                  Is it any better than:
                    @alexsh1
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @alexsh1
                    Interesting buck-boost converter, but Input voltage is from 1.8v to 5.5v.
                    I'm looking at the one with a better range of 0.9-5.5V
                    I need to use two 2.7V super caps in series with a maximum efficiency
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @gohan said in How best to find the "best" small solar panel of a particular size?:
                      Not cheap, I agree, but ideally I'm looking to use the whole range from 0 to 5.5V in two 2.7V super caps in series. If you have an idea of a good buck-boost converter outputing 3.3V, I'm all ears
                      • C ceech
                        It works.
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @ceech no wonder I like your board. These buck-boost converter works really well with a solar panel
                          I already have one boost buck converter, I only need the supercap charge controller for 2 supercap or use the 5.5v 4F I have
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @gohan what's the input voltage for your buck-boost converter?
                              https://m.aliexpress.com/s/item/32757272432.html
                                alexsh1A
                                alexsh1A
                                alexsh1
                                @gohan I think it looked at it. I liked the range, but I think it is a noisy one. Did you test it with oscilloscope?
                                  Nope, no oscilloscope available 😇
                                  • alexsh1A alexsh1
                                    @alexsh1
                                    @alexsh1 said in How best to find the "best" small solar panel of a particular size?:
                                    According to its datasheet (http://www.ti.com/product/TPS63030), the TPS63030 has exactly the same Input Voltage Range: 1.8 V to 5.5 V
                                    • C
                                      C
                                      ceech
                                      There is a Maxim integrated buck-boost converter, that goes down to 0.7V
                                      http://www.mouser.com/ds/2/256/MAX1584-MAX1585-43040.pdf
                                      It's quite complex though
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        @NeverDie you are correct - TPS63030 has got 1.8-5.5V input voltage.
                                        I wonder if there is a buck-boost converter with lower than 1V lower voltage?
                                        • C ceech
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @ceech you bet - personally I'd stick to something much more simple
