  3. How best to find the "best" small solar panel of a particular size?
220 Posts 14 Posters 99.9k Views 17 Watching
    #177
    I'm playing around with a coulomb counter, actually a clone of:
    https://www.sparkfun.com/products/12052
    The only downside to it is that it requires a minimum of 2.7v on the input current that it's measuring, which isn't really ideal for a solar panel that might nonetheless be charging at a lower voltage. It also includes its own current consumption in the measurement, and it appears to be about 75ua. In addition to counting the coulombs, you can also measure the average current between interrupts by doing a little math (which is illustrated in the sample sketche).
    So, kinda cool. I changed out the sense resistor from 0.05ohm to 10ohm so that I get more frequent interrupts.
    • alexsh1A
      alexsh1A
      alexsh1
      I found this interesting fella
      https://www.tindie.com/products/closedcube/tps63030-high-efficient-buck-boost-up-to-96/
      Anyone tinkered with tps63030?
      C NeverDieN 2 Replies Last reply
        It's kind of pricey 😧
        alexsh1A 1 Reply Last reply
        • alexsh1A alexsh1
          C
          C
          ceech
          @alexsh1 I use it. On this board:
          http://www.ebay.com/itm/ATmega328p-board-w-NRF24l01-socket-LTC4079-battery-charger-in-Arduino-PRO-form-/331800929918?ssPageName=STRK:MESE:IT
          It works.
          • alexsh1A alexsh1
            @alexsh1
            Is it any better than:
            https://www.openhardware.io/view/276/33v-Buck-Boost-DC-DC-Converter
              @alexsh1
              alexsh1A
              alexsh1A
              alexsh1
              @NeverDie said in How best to find the "best" small solar panel of a particular size?:
              @alexsh1
              Interesting buck-boost converter, but Input voltage is from 1.8v to 5.5v.
              I'm looking at the one with a better range of 0.9-5.5V
              I need to use two 2.7V super caps in series with a maximum efficiency
                alexsh1A
                alexsh1A
                alexsh1
                @gohan said in How best to find the "best" small solar panel of a particular size?:
                Not cheap, I agree, but ideally I'm looking to use the whole range from 0 to 5.5V in two 2.7V super caps in series. If you have an idea of a good buck-boost converter outputing 3.3V, I'm all ears
                • C ceech
                  It works.
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @ceech no wonder I like your board. These buck-boost converter works really well with a solar panel
                    I already have one boost buck converter, I only need the supercap charge controller for 2 supercap or use the 5.5v 4F I have
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @gohan what's the input voltage for your buck-boost converter?
                        https://m.aliexpress.com/s/item/32757272432.html
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @gohan I think it looked at it. I liked the range, but I think it is a noisy one. Did you test it with oscilloscope?
                            Nope, no oscilloscope available 😇
                            • alexsh1A alexsh1
                              @alexsh1
                              @alexsh1 said in How best to find the "best" small solar panel of a particular size?:
                              According to its datasheet (http://www.ti.com/product/TPS63030), the TPS63030 has exactly the same Input Voltage Range: 1.8 V to 5.5 V
                              • C
                                C
                                ceech
                                There is a Maxim integrated buck-boost converter, that goes down to 0.7V
                                http://www.mouser.com/ds/2/256/MAX1584-MAX1585-43040.pdf
                                It's quite complex though
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @NeverDie you are correct - TPS63030 has got 1.8-5.5V input voltage.
                                  I wonder if there is a buck-boost converter with lower than 1V lower voltage?
                                  • C ceech
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @ceech you bet - personally I'd stick to something much more simple
                                    • alexsh1A alexsh1
                                      You'd probably get the biggest range by combining a separate boost converter with a separate buck converter, rather than using a single integrated buck-boost unit.
                                        Well, so far the green supercap isn't holding its charge any better. I'll leave it in-circuit for two or three days, though, and see if that improves. It's encouraging that the rate of voltage decrease is decreasing. Some supercaps apparently improve their ability to retain charge if they are forced to hold a charge long enough, though I have no idea why that is. For instance, some capacitor leakage test protocols call for holding a capacitor at its rated voltage for 72 hours before running the leakage test.
                                        #195
                                        Well, try as I might, I just can't recommend these Chinese supercaps. I've held them at rated voltage for days on end, and I've power cycled them too. For whatever reason, they just don't perform as well as the branded supercaps that I've ordered from Digikey. I'll use-up the few I have on some throw-away prototype experiments, and I won't be ordering any more of them. Presently I think the 10F supercap on Digikey for $2 from Illinois Capacitor continues to be the best of the "value" capacitors. For best performance, I've been pleased with the AVX brand of supercaps.
                                        However, if someone finds something better, either by value or by performance, please do post and let me know.
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          #196
                                          @NeverDie I have a few AVX caps and they are really good
