  3. How best to find the "best" small solar panel of a particular size?
220 Posts 14 Posters 99.9k Views 17 Watching
    Is there a way to do a full disconnect of the solar panel (so as to do an unloaded voltage measurement) without resorting to a relay? I've tried using a PFET, and although it can turn off the current flowing from the solar panel, it still somehow sucks the measured voltage down to about 0.3v above the supercap's voltage. On the other hand, if I physically disconnect the solar panel, then I'm able to then read it's unloaded voltaqe.
    #168
    Found a very good on-point thread which addresses the issue I'm having: https://forum.arduino.cc/index.php?topic=115233.0 So, it may be mosfet related, not just circuit related. If worse comes to worst, I'll order the Hexfet it references that supposedly does achieve a full disconnect the way you'd expect.
      @alexsh1 said in How best to find the "best" small solar panel of a particular size?:
      @ceech said iThe double cell 15F flat capacitor can only supply 70mA.
      It should be enough if not using nrf24l01+ pa lna or rfm69HW. In this case perhaps, it would be better to have 150mA at least to cover those transmitters?
      I like the size - It is really flat.
      If you start to get choosy, that's when it's time to start making your own boards. It's easier than you might think. Otherwise, you just have to accept that the off-the-shelf stuff will never be exactly what you want.
      It's really too bad there isn't more of a universal PCB format that's easily edited, so you can simply start with a board that's close to what you want and just customize it a bit (the way one might with, say, software). For instance, even just changing LDO's--unless the new LDO has exactly the same land pattern--can necessitate redoing the board. No problem if you're the original designer, but it's a PITA if you aren't.
      alexsh1A
      alexsh1A
      alexsh1
      @NeverDie said in How best to find the "best" small solar panel of a particular size?:
      I do not disagree with you. I have started looking at Eagle software. Obviously, the idea is that I'm going to start with improving somebody's design first and then designing something myself
        #170
        @ceech said in How best to find the "best" small solar panel of a particular size?:
        MIC5365
        I'm going to switch from the MAX8887EZK27 LDO over to: http://datasheet.sii-ic.com/en/voltage_regulator/S1313_E.pdf
        which also is the same size SOT-23-5 package.
        Why? Current consumption. The S1313 datasheet says it should consume a maximum of 1.35ua of current, whereas the MAX8887EZK27 may be consuming as much as 85ua (though I haven't actually tried measuring it). When the overall charging current from the solar panel is only around 50ua indoors far away from the windows, I'm betting it will make a difference. Likewise the MIC5365 also appears to have a rather high quiescent current of around 29ua, at least according to its datasheet that is.
        C 1 Reply Last reply
          MIC5365
          C
          C
          ceech
          @NeverDie Solid choice.
            #172
            I did the experiment of charging one of the green Chinese cheapo capacitors for 3 days at 2.7v, and then I removed it from the circuit and measured its voltage after 3 days with no charging and no load at all. It came out at 2.54v. So, I guess I would deem that use-able.
            alexsh1A 1 Reply Last reply
              alexsh1A
              alexsh1A
              alexsh1
              @NeverDie I suppose you broke it in. Try to do a few more cycles (charge / discharge) and see if self discharge improves
                It should get a little better after some cycles
                  I went ahead and made the switch on the node that I'm experimenting with: I'm now using a LTC3235D 3.3v passthrough boost converter. I switch it on when the node wakes up, do various measurements, then switch it off before transmitting the results if the supercap voltage is above threshold. Everything working smoothly.
                  I think I may next try putting a buck converter on the solar panel so I can get more juice out of it when its voltage is above 3.3v. I'll be trying this one:
                  https://www.openhardware.io/view/276/33v-Buck-Boost-DC-DC-Converter
                  because it's the only one I have on hand. If it seems to help, then I'll look for something more on-point (and less expensive!).
                  alexsh1A
                  alexsh1A
                  alexsh1
                  How does LTC3235D compare to BQ25570?
                  BQ25570 has got buck converter with Vout from 3.3V down to 2V (Vbat is from 5.1 down to 2V), which is just enough to run nrf24l01+ with AVR.
                  • alexsh1A alexsh1
                    #176
                    @alexsh1
                    Well, I'm sure it's easier to solder than the BQ25570. I'm no longer really considering anything that's difficult to solder unless there's just absolutely no alternative.
                    It looks as though @ceech sells them though already soldered to a breakout board, so maybe he can answer your question.
                      #177
                      I'm playing around with a coulomb counter, actually a clone of:
                      https://www.sparkfun.com/products/12052
                      The only downside to it is that it requires a minimum of 2.7v on the input current that it's measuring, which isn't really ideal for a solar panel that might nonetheless be charging at a lower voltage. It also includes its own current consumption in the measurement, and it appears to be about 75ua. In addition to counting the coulombs, you can also measure the average current between interrupts by doing a little math (which is illustrated in the sample sketche).
                      So, kinda cool. I changed out the sense resistor from 0.05ohm to 10ohm so that I get more frequent interrupts.
                      • alexsh1A
                        alexsh1A
                        alexsh1
                        I found this interesting fella
                        https://www.tindie.com/products/closedcube/tps63030-high-efficient-buck-boost-up-to-96/
                        Anyone tinkered with tps63030?
                        C NeverDieN 2 Replies Last reply
                          It's kind of pricey 😧
                          • alexsh1A alexsh1
                            C
                            C
                            ceech
                            @alexsh1 I use it. On this board:
                            http://www.ebay.com/itm/ATmega328p-board-w-NRF24l01-socket-LTC4079-battery-charger-in-Arduino-PRO-form-/331800929918?ssPageName=STRK:MESE:IT
                            It works.
                            • alexsh1A alexsh1
                              @alexsh1
                              Is it any better than:
                                @alexsh1
                                alexsh1A
                                alexsh1A
                                alexsh1
                                @alexsh1
                                Interesting buck-boost converter, but Input voltage is from 1.8v to 5.5v.
                                I'm looking at the one with a better range of 0.9-5.5V
                                I need to use two 2.7V super caps in series with a maximum efficiency
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @gohan said in How best to find the "best" small solar panel of a particular size?:
                                  Not cheap, I agree, but ideally I'm looking to use the whole range from 0 to 5.5V in two 2.7V super caps in series. If you have an idea of a good buck-boost converter outputing 3.3V, I'm all ears
                                  • C ceech
                                    It works.
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @ceech no wonder I like your board. These buck-boost converter works really well with a solar panel
                                      I already have one boost buck converter, I only need the supercap charge controller for 2 supercap or use the 5.5v 4F I have
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        @gohan what's the input voltage for your buck-boost converter?
                                          https://m.aliexpress.com/s/item/32757272432.html
