  3. nRF5 action!
nRF5 action!
  • scalzS scalz
    all you have to do is set your defines for mysensors and this should work out of the box :)
    about the usb, weird, i've no problem here. what problem do you have? here it works smoothly (with custom board, but i have also an adafruit m0 proto, worked well too)
    #79
    @scalz
    Well, first, for the benefit of others who may be reading this but who aren't familiar with the two USB paradigm, this is how it looks on the Arduino Due:
    There are two physically distinct USB connections, but you can have both connected to your computer at the same time. The "Native USB Port" lets you read the console output, and the "Programming port" is for uploading new sketches. It works fine. I like it.
    So, with that as background, on both the Adafruit Feather M0 SamD21 and the Sparkfun M0 SamD21, there is the same concept, but only one physical USB port. So, let's say I just uploaded a sketch and then want to immediately switch to the "Native USB Port" so that I can read debugging information. Well, that doesn't happen automatically (as it should really). Instead, I get an error message which reads, "Couldn't find a Board on the selected port. Check that you have the correct port selected. If it is correct, try pressing the board's reset button after initiating the upload.
    processing.app.SerialException: Error opening serial port 'COM45'."
    Then, I have to go to the Tool menu and manually select Com44 and then open the serial console. Well, by then, the debug info would have already passed by, because it doesn't reboot upon opening the serial console. So, I've added a delay countdown to give me time to do this.
    And, by the way, every single time I upload a new sketch, it always reports, "An error occured while uploading the sketch," even though if I look at the details, it shows that it uploaded and even verified the upload, and even--sure enough--it really did upload. So, that part is really beginning to bother me, even though maybe it shouldn't. It's true for both the Adafruit and the Sparkfun Samd21 boards.
    Anyhow, it looks like the Hackaday guy did a board with two physical USBs, and maybe that's a good idea?alt text
    Or maybe it's still just one USB connection and three different connector types? Not really sure.
      #80
      Anyhow, I guess what I could do is simply write my serial debug output to a pair of Rx and Tx pins, and then I could side-step the whole mess without getting entangled in it. Not very elegant, but it would serve the purpose until I learn the ins-and-outs better.
      • tbowmoT
        tbowmoT
        tbowmo
        You will always have the issue of USB connection, when using a native USB device, because it will re-enumerate on the USB bus whenever you reset the device.
        That's also why you have to put the following code
        while(Serial) {}
        In the setup routine of sketches with native usb devices, if you expect to catch all debug messages from the start. This behavior does not change if you have both native and a programming port.
          #82
          By the way (and it's just an as yet an unverified first impression), but it seems like the RSSI received on the Feather RFM69 is much better than on an atmega328p RFM69 combo. If that bears out, then all by itself it might be reason to switch. Anyone else get this impression, or not?
          • tbowmoT tbowmo
            while(Serial) {}
            @tbowmo said in Minimalist SAMD21 TQFP32 Pro Mini:
            while(Serial) {}
            Cool. I just tried it. It turns out it's actually
            while(!Serial) {}
            but it works great. Thanks!
              about rfm69 and better rssi, it could also be related to ground plane size of the board.
              and for mcu, yep no need of the programming port. native is enough if there is the bootloader.
              • scalzS scalz
                #85
                @scalz said in Minimalist SAMD21 TQFP32 Pro Mini:
                I just now noticed that @Sweeman already did: https://forum.mysensors.org/topic/6908/adafruit-feather-m0-rfm69hcw-with-mysensors/6
                  #86
                  I hadn't noticed it before, but it looks like even Arduino will have an NRF52 board: http://www.arduino.org/products/boards/arduino-primo
                  Of course, that's a very good thing! Unfortunately, they don't seem to be in stock anywhere, even though they were first released in March, 2016. What's up with that?
                  So, I've ordered a couple of these to try out:
                  https://www.amazon.com/Adafruit-Feather-nRF52-Bluefruit-nRF52832/dp/B06XXSVYLC/ref=sr_1_1?ie=UTF8&qid=1498743679&sr=8-1&keywords=nrf52
                  The good news is that NRF52 modules don't seem to require many external parts, and for self-assembly that's a real advantage.
                  TerrenceT 1 Reply Last reply
                    Looks like a fully integrated board can be had for <$9, including e-packet delivery:
                    https://www.aliexpress.com/item/nRF52832-Bluetooth-4-1-BLE-Module-M4-Transparent-Transmission-SMA-512K-FLASH-64K-RAM-pass-through/32798522093.html?spm=2114.01010208.3.17.YON8eD&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10065_10151_10130_10068_5210015_10136_10137_10060_10155_10062_437_10154_10056_10055_10054_10059_303_100031_10099_10103_10102_5290015_10096_5320015_10052_10053_10107_10050_10142_10051_5280015_10084_10083_5250016_10119_10080_10082_10081_10178_10110_519_10111_10112_10113_5240015_10114_5230016_10182_10078_10079_5260014_10073_10123_10120_10189_5270015_142-10120,searchweb201603_49,ppcSwitch_4&btsid=02e4720e-a974-4d92-a890-0cd0f6510022&algo_expid=87b18aca-7c4a-43a5-8995-4d45694a7044-2&algo_pvid=87b18aca-7c4a-43a5-8995-4d45694a7044
                      TerrenceT
                      TerrenceT
                      Terrence
                      @NeverDie I was about to pull the trigger on some of those, but I can't seem to get my mind off of the potential long distance of the 840. I wonder when the world will be blessed with those modules?
                      Looking forward to your experience with the Adafruit BLE boards.
                      YveauxY NeverDieN 2 Replies Last reply
                      • TerrenceT Terrence
                        I wouldn't wait for them. Will probably take at least half a year or so (according to Nordic)
                        • YveauxY Yveaux
                          TerrenceT
                          TerrenceT
                          Terrence
                          @Yveaux You are correct, use what is available, not what will be in the future.
                            Same here, but hopefully (?) most of what I learn with the 832 will be applicable to the 840. The 840 is clearly more desirable, and I probably wouldn't have pulled the trigger on the 832 if I didn't know the 840 was coming.
                              TerrenceT
                              TerrenceT
                              Terrence
                              @NeverDie said in Minimalist SAMD21 TQFP32 Pro Mini:
                              Right. I have been trying to get my head around the BT communication pattern. It is a different beast indeed.
                                Looks as though the 52 Thingy might be a good starting point for some people:
                                http://www.mouser.com/new/nordicsemiconductor/nordic-thingy-52/
                                  #94
                                  What I'm not sure about is whether the NRF52832 will have truly adequate indoor range. Max tx power is 4db, which is better than the 0db of the NRF24L01. Will that be enough? I can only guess. That's why I ordered two of the Adafruit NRF52832 feathers: to see for myself. If they disappoint, then I may shelve them until the 840 becomes more available, and then try again using the 840. On the other hand, if the 832 turns out to be "good enough", then the 840 may not matter so much.
                                  I do like that it apparently is programmable from within the Arduino IDE. That will make trying it out a lot easier. If the OTA uploads are easy to do, then I'll be really happy. :)
                                    nrf52832 is definitely better than nrf24l01. if i'm not wrong, 4db can double range in theory.
                                    For range, an important point is the antenna, as you already know.
                                    Chip antenna can be ok, depending on the environment and usecase, but can't compete with a rfm69. These antennas are not for long range, so the adafruit board. How to miniaturize antennas without loosing performance..
                                    NeverDieN JokgiJ 2 Replies Last reply
                                    • scalzS scalz
                                      #96
                                      Good point. Looks as though the aliexpress module I referenced above, though, does have some kind of antenna connector on it:
                                      So, maybe plugging something (?) into that would give better range?
                                      Also, I just now read that these 832 modules can communicate with the older NRF24L01's. Is that true? That would be nice.
                                        #97
                                        yes these one looks better. looks like you can also tune ant (there are some footprints).
                                        note the "meandered" antenna. it reduces antenna size, needs some tuning, a bit less efficient vs others type. but maybe better than chip antenna i think. and you have the ipex in case, cool!
                                        Not so cheap (not fcc) but interesting i agree.
                                        Yes, indeed! it's compatible with nrf24 thx to @d00616
                                        You should try, i'm using my nrf52 board (aeos) with my esp32 gw (halo) :)
                                        And the cherry, with VS Micro, and multiple serial monitors in same ide ;)
                                        • scalzS scalz
                                          TerrenceT
                                          TerrenceT
                                          Terrence
                                          Guys I have been developing with VS Code (free) for Arduino type coding. been very happy with it. It does not have multi serial monitors (not that I know of).
                                          Anyone else using VS Code?
